1. Re: 'completing pending document save operations' - HELP
station_two Aug 24, 2014 7:34 AM (in response to michelleturnbull84)BOILERPLATE TEXT:
If you give complete and detailed information about your setup and the issue at hand, such as your platform (Mac or Win), exact versions of your OS, of Photoshop and of Bridge, machine specs, such as total installed RAM, scratch file HDs, video card specs, what troubleshooting steps you have taken so far, what error message(s) you receive, if having issues opening raw files also the exact camera make and model that generated them, etc., someone may be able to help you.
Please read this FAQ for advice on how to ask your questions correctly for quicker and better answers:
http://forums.adobe.com/thread/419981?tstart=0
Thanks!
2. Re: 'completing pending document save operations' - HELP
DonJohnston Feb 5, 2015 8:19 AM (in response to michelleturnbull84)Hi Michelle
Same thing for me too. Sporadic occurrence. I tend to load up 20 layered tifs at a time to spot and correct histograms. I found a workaround which is to cancel out of the operation and then manually Command S Save (Mac) and Command W close. At some point the save operation kicks in normally. It is part of an action for me, where I flatten, convert to 8 bit and save as tif and close.
Mac OS snow leopard. Photoshop CC. 24 GB RAM, maxed out on the % allotted to PS.
3. Re: 'completing pending document save operations' - HELP
DonJohnston Aug 14, 2017 9:39 AM (in response to michelleturnbull84)I finally found a solution to this issue courtesy of a blogger Christopher Grant. Go to preferences in Photoshop>>file handling and uncheck 'Save in Background' I'm now on Mac OS El Capitan and Photoshop 2015.5. So far so good.
