8 Replies Latest reply on Aug 26, 2014 12:54 AM by VeluVK
    Financial table alignment
    VeluVK Level 1
      I am working in financial tables. i need script for the below requirement. Any one please suggest.
      For all tables from second column onwards ""Tbody_rightalign" paragraph style. and all parenthesis values should be "Tbody_bracket" style, but these changes to be omitted in first rows because column head having separate style.
      Grey should be Tbody_rightalign, paragraph style.
      Pink color should be Tbody_bracket, paragraph style.
      Any one help me pls. i am having 150+ tables.
      Velu
        • 1. Re: Financial table alignment
          Sajeev Sridharan Level 4
          Try this,
          var myTable = app.activeDocument.stories.everyItem().tables.everyItem().getElements();
          for(t=0; t<myTable.length; t++)
              myTable[t].select();
              app.selection[0].rows[1].columns[1].cells[1].select();
              app.selection[0].parent.cells[-1].select(SelectionOptions.ADD_TO);
              app.findGrepPreferences = app.changeGrepPreferences = null;
              app.findGrepPreferences.findWhat = ".+";
              found = app.selection[0].findGrep (true);
              for (i = 0; i < found.length; i++)
                  if(found[i].contents.toString().match(')'))
                      found[i].texts[0].appliedParagraphStyle = "Tbody_bracket";
                  else
                      found[i].texts[0].appliedParagraphStyle = "Tbody_rightalign";
          Vandy
          • 2. Re: Financial table alignment
            VeluVK Level 1
            Hi Vandy,
            Thanks for the script. It works perfectly.
            I need one more requirement.
            Tables For all parenthesis underline values should be "Tbody_rule1" paragraph style. And without bracket underline words are "Tbody_rule1" Paragraph Style"
            Regards,
            Velu
            • 3. Re: Financial table alignment
              VeluVK Level 1
              Hi Vandy,
              Thanks a lot for the script. Much appreciated. It works perfectly. It is very very useful.
              In Tables, For all parenthesis underline values should be "Tbody_rule1(bracket)" paragraph style, without bracket underline words should be "Tbody_rule1(nobracket)" Paragraph Style"
              All these and the previous "Financial table alignment" script can merge into a single script is better for me.
              For example:
              All grey shaded underlined words should be a "Tbody_rule1(nobracket)"
              All pink shaded parenthesis underlined words should be a "Tbody_rule1(bracket)"
              Regards,
              Velu
              • 4. Re: Re: Financial table alignment
                Try this,
                        if(found[i].contents.toString().match(')') && found[i].underline == true)
                            found[i].texts[0].appliedParagraphStyle = "Tbody_rule1(bracket)"
                        if(!found[i].contents.toString().match(')') && found[i].underline == true)
                            found[i].texts[0].appliedParagraphStyle = "Tbody_rule1(nobracket)"
                        else
                Vandy
                • 5. Re: Financial table alignment
                  VeluVK Level 1
                  Hi Vandy,
                  The script working fine (except the below condition), In Merged script missed the below condition. can you please include this condition?
                  if(found[i].contents.toString().match(')') && !found[i].underline == true)
                  Values within parenthesis & no underline words should be  "Tbody_bracket" Paragraph style (as per first script)
                  Regards,
                  Velu
                  • 6. Re: Re: Financial table alignment
                                found[i].texts[0].appliedParagraphStyle = "Tbody_rule1(bracket)";
                            else if(found[i].contents.toString().match(')') && found[i].underline == false)
                            else if(!found[i].contents.toString().match(')') && found[i].underline == true)
                                found[i].texts[0].appliedParagraphStyle = "Tbody_rule1(nobracket)";
                            else
                    Vandy
                    • 7. Re: Financial table alignment
                      VeluVK Level 1
                      Hi Vandy,
                      Thank you so much, It working Perfect.
                      Regards,
                      Velu
                      • 8. Re: Financial table alignment
                        VeluVK Level 1
                        Hi Vandy,
                        For all tables second column onwards, need to distribute column width into "6p" width. Suggest pls.
                        Regards,
                        Velu
