12 Replies Latest reply on Aug 23, 2014 9:21 AM by vishok75
    Remove not active layer
    vishok75
      i have a psd with a lot of layers. I'd like to remove all layer but not the first or the active one. Someone cuold help me to do this?
        • 1. Re: Remove not active layer
          c.pfaffenbichler Level 9
          This hardly seems worth the effort of creating a Script, ctrl-shift clicking the visibility icon and selecting "Hide all other layers" then "Delete Hidden Layers" from the Layers Panel’s fly-out menu would seem easy enough.
          • 2. Re: Remove not active layer
            vishok75 Level 1
            ues but beacuse i have a lot of images i would like to do this with a script .jsx
            • 3. Re: Remove not active layer
              You should be able to use ScriptingListener.plugin to record the aforementioned steps, actually even an Action should work.
              Sorry, did a test, this is apparently not the case.
              • 4. Re: Remove not active layer
                Sorry, my mistake, "Hide all other layers" does not seem to record properly.
                • 5. Re: Remove not active layer
                  Would it be acceptable to leave Groups alone?
                  Because while one can fairly easily identify the "selected Layers" the Groups they are contained in are harder to identify.
                  • 6. Re: Remove not active layer
                    vishok75 Level 1
                    • 7. Re: Remove not active layer
                      Could you give this a try?
                      // based on code by paul mr; removes unselected layers but leaves layersets untouched;
                      // 2014, use at your own risk;
                      #target "photoshop-70.032"
                      if (app.documents.length > 0) {
                      try {activeDocument.selection.deselect()} catch (e) {};
                      // get selected layers’ indices;
                      var theSelected = getSelectedLayersIdx();
                      // select the previously unselected layers;
                      selectUnselected (theSelected);
                      // delete;
                      var idDlt = charIDToTypeID( "Dlt " );
                          var desc3 = new ActionDescriptor();
                          var idnull = charIDToTypeID( "null" );
                              var ref2 = new ActionReference();
                              var idLyr = charIDToTypeID( "Lyr " );
                              var idOrdn = charIDToTypeID( "Ordn" );
                              var idTrgt = charIDToTypeID( "Trgt" );
                              ref2.putEnumerated( idLyr, idOrdn, idTrgt );
                          desc3.putReference( idnull, ref2 );
                      executeAction( idDlt, desc3, DialogModes.NO );
                      function GetSelectedLayers() {
                      var A=[];
                          var desc11 = new ActionDescriptor();
                              var ref9 = new ActionReference();
                              ref9.putClass( stringIDToTypeID('layerSection') );
                          desc11.putReference( charIDToTypeID('null'), ref9 );
                              var ref10 = new ActionReference();
                              ref10.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                          desc11.putReference( charIDToTypeID('From'), ref10 );
                          executeAction( charIDToTypeID('Mk  '), desc11, DialogModes.NO );
                      var gL = activeDocument.activeLayer.layers;
                      for(var i=0;i<gL.length;i++){
                      A.push(gL[i]);
                      executeAction( charIDToTypeID('undo'), undefined, DialogModes.NO );
                      return A;
                      function selectUnselected (theSelected) {
                      // check for background layer;
                      var ref = new ActionReference();
                      ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                      var docDesc = executeActionGet(ref);
                      var hasBackground = docDesc.getBoolean(stringIDToTypeID("hasBackgroundLayer"));
                      // get number of layers;
                      var applicationDesc = executeActionGet(ref);
                      var theNumber = applicationDesc.getInteger(stringIDToTypeID("numberOfLayers"));
                      if (hasBackground == false) {var theStart = 1} else {var theStart = 0};
                      for (var m = 0; m <= theNumber; m++) {
                      try {
                      //ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                      ref.putIndex( charIDToTypeID( "Lyr " ), m);
                      var layerDesc = executeActionGet(ref);
                      var layerSet = typeIDToStringID(layerDesc.getEnumerationValue(stringIDToTypeID("layerSection")));
                      var isBackground = layerDesc.getBoolean(stringIDToTypeID("background"));
                      // if not layer group collect values;
                      if (layerSet != "layerSectionEnd" && layerSet != "layerSectionStart") {
                      var theCheck = false;
                      for (var n = 0; n < theSelected.length; n++) {
                      if (theSelected[n] == m) {theCheck = true}
                      if (theCheck == false) {
                      if (m == theStart) {selectLayerByIndex(m,false)}
                      else {selectLayerByIndex(m,true)};
                      catch (e) {};
                      ////// by paul mr;
                      function getSelectedLayersIdx(){
                            var selectedLayers = new Array;
                            var desc = executeActionGet(ref);
                            if( desc.hasKey( stringIDToTypeID( 'targetLayers' ) ) ){
                               desc = desc.getList( stringIDToTypeID( 'targetLayers' ));
                                var c = desc.count
                                var selectedLayers = new Array();
                                for(var i=0;i<c;i++){
                                  try{
                                     activeDocument.backgroundLayer;
                                     selectedLayers.push(  desc.getReference( i ).getIndex() );
                                  }catch(e){
                                     selectedLayers.push(  desc.getReference( i ).getIndex()+1 );
                             }else{
                               ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "ItmI" ));
                               try{
                                  selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-1);
                               }catch(e){
                                  selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" )));
                            return selectedLayers;
                      // by mike hale, via paul riggott;
                      // http://forums.adobe.com/message/1944754#1944754
                      function selectLayerByIndex(index,add){
                      add = undefined ? add = false:add
                          ref.putIndex(charIDToTypeID("Lyr "), index);
                          var desc = new ActionDescriptor();
                          desc.putReference(charIDToTypeID("null"), ref );
                             if(add) desc.putEnumerated( stringIDToTypeID( "selectionModifier" ), stringIDToTypeID( "selectionModifierType" ), stringIDToTypeID( "addToSelection" ) );
                            desc.putBoolean( charIDToTypeID( "MkVs" ), false );
                         try{
                          executeAction(charIDToTypeID("slct"), desc, DialogModes.NO );
                      }catch(e){
                      alert(e.message);
                      • 8. Re: Remove not active layer
                        vishok75 Level 1
                        I get an error :
                        Linea: 95
                        ->  var hasBackground = docDesc.getBoolean(stringIDToTypeID("hasBackgroundLayer"));
                        • 9. Re: Remove not active layer
                          Which version of Photoshop are you using?
                          • 10. Re: Remove not active layer
                            vishok75 Level 1
                            photoshop cc
                            Version 14.0 x64
                            • 11. Re: Remove not active layer
                              That’s strange, it works fine for me in CC; but you may want to update Photoshop CC, though – it’s at 14.2.1 is the current version.
                              You can try to replace that line with
                              var hasBackground = activeDocument.layers[activeDocument.layers.length - 1].isBackgroundLayer;
                              • 12. Re: Remove not active layer
                                vishok75 Level 1
                                you are great. works. Thank you
