5 Replies Latest reply on May 12, 2006 11:52 AM by Newsgroup_User
    Moving app to beta3 producing strange error
    DWUser.com Level 1
      I'm porting an app from beta2 to beta3. I get the following error: Expecting semicolon before target. It provides a line number, but doesn't indicate any file. Any thoughts?
        • 1. Re: Moving app to beta3 producing strange error
          Level 7
          Hello,
          This has appeared before. One theory was that it was a static variable
          problem. You could cut out parts of your code to try to narrow it down, and
          post a smaller app. that just contains the suspected problem areas for us to
          look at.
          - Rob
          "N Rohler" <webforumsuser@macromedia.com> wrote in message
          news:e3u23m$am3$1@forums.macromedia.com...
          • 2. Moving app to beta3 producing strange error
            DWUser.com Level 1
            After a large amount of debugging, I finally determined the issue to be with a ? ... : .... style conditional inside an MXML attribute. I think that no filename was displayed because the error was within Flex-generated AS code.
            • 3. Re: Moving app to beta3 producing strange error
              Level 7
              Can you post the expression? That should work. For example, this works
              fine:
              <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" width="100%"
              height="100%">
              <mx:Script>
              public var bArriving:Boolean = true;
              </mx:Script>
              <mx:TextArea id="ta1" text="{bArriving ? 'hello' : 'goodbye'}" />
              </mx:Application>
              - Rob
              news:e40ev0$gbt$1@forums.macromedia.com...
              > After an large amount of debugging, I finally determined the issue to be
              > with a
              > code.
              • 4. Re: Moving app to beta3 producing strange error
                DWUser.com Level 1
                Sure, though I haven't tried to see if this has problems in an isolation test:
                <mx:Label text="Type: {editor_currentEditXML.children()[(editor_elementList.selectedIndex == -1 ? 0 : editor_elementList.selectedIndex)].name().toString()}" fontWeight="bold" width="100%"/>
                • 5. Re: Moving app to beta3 producing strange error
                  Level 7
                  Could you provide a complete testcase for this?
                  news:e40k62$mc2$1@forums.macromedia.com...
                  > test:
                  > {editor_currentEditXML.children().name().toString()}" fontWeight="bold"
                  > width="100%"/>
