1 Reply Latest reply on Aug 25, 2014 6:21 AM by joel_pau
    Simple code doesn't work in edge?
    RavenDesign Level 1
      Ok so if I was hand coding this it would work fine but for some reason it doesn't wok in edge ? here it is
      sym.$("#Stage_Info_Facebook img").click(function() {
      sym.$("#Stage_Info").hide();
      For some reason it doesn't work?
      there is method to the madness I need the img inside the div to be clickable not the actual div itself
      Any idea's?
        • 1. Re: Simple code doesn't work in edge?
          joel_pau Level 5
          Well, i don't see your code panel. But, it doesn't run because you are mixing Edge API and jQuery.
          • jQuery: $(selector). Selector can be the id:"#Stage_...".
          • Edge API: sym.$(elementName).
          Here is a good mix: $( sym.lookupSelector("elementName") ).hide();
          Because sym.lookupSelector("elementName") returns the id: "#Stage_..."
          Note: with a click event, you can use e.target: sym.$("elementName").click( function(){ sym.$(e.target).hide() }).
          Using this line $("#Stage_Info_Facebook img") what do you want ? Targeting #Stage_Info_Facebook and then $(img) ?
