0 Replies Latest reply on Aug 10, 2006 7:26 AM by GuyGuyTheFlex
    Why do I get an Error Message when trying to "External link" an SWC?
    GuyGuyTheFlex
      hi.
      when I use the "external link" option in the SCW linckage dialog box, the running SWF produces an alert box saying :
      "VerifyError: Error #1014: Class mx.core::Application could not be found.
      at flash.display::MovieClip/gotoAndStop()
      at mx.managers::SystemManager/::preloader_initProgressHandler()
      at flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at mx.preloaders::Preloader/::timerHandler()
      at flash.utils::Timer/flash.utils:Timer::_timerDispatch()
      at flash.utils::Timer/flash.utils:Timer::tick()
      I did what the documentation said, still I get that error... :(
      ..quoting the "Using flex builder 2" doc:
      "To set the SWC file as an external library file:
      With a project selected in the Navigator view, select Project > Properties > Flex Build Path.
      Select the Library tab, and then select and expand the SWC file entry to display the SWC options.
      Double-click the Link Type option. The Library Path Items Options dialog box appears.
      Select the External option, and click OK. "
      Anty suggestions?
      thanks,
      Guy.
