20 Replies Latest reply on Aug 17, 2017 1:55 AM by Trevorׅ
    Create a build script for Extend Script
    mdegamo Level 1
      I have several scripts I want exported as binary via "File > Export as Binary" in ExtendScript Toolkit. I want to be able to call ESTK via shell script and tell it to compile that certain file.
        • 1. Re: Create a build script for Extend Script
          Trevorׅ Adobe Community Professional
          page 11 in the user manual
          Automatic jsxbin Conversion
          The jsxbin format (Binary JavaScript) enables distributing a script without exposing its source code. The
          ExtendScript ToolKit offers an Export to Binary feature that instantly converts a js(x) file into jsxbin. The
          jsxbin export process can be done automatically without user interaction.
          To do this:
          1. Write a compiler script file that compiles .jsx files into a .jsxbin file.
           The script file must start with this target directive:
          #target estoolkit#dbg
           Use the app.compile() method and pass the content of the script file as a String parameter.
           In the script, store the result in a new file with the extension .jsxbin.
          2. Launch the ExtendScript ToolKit with the command-line parameter -cmd [path to compiler script file]:
          Windows:
          "ExtendScript Toolkit.exe" -cmd compiler.jsx
          Mac:
          "ExtendScript Toolkit.app/Contents/MacOS/ExtendScript Toolkit" \
          -cmd compiler.jsx
          Here is a sample compiler script (compiler.jsx) with the source script's file path hardcoded.
          var fileIn = File("/c/jsxbin_test/source.jsx");
          fileIn.open("r");
          var s = fileIn.read();
          fileIn.close();
          var t = app.compile(s);
          var fileOut = File( fileIn.absoluteURI + "bin" ) ;
          fileOut.open("w");
          fileOut.write(t);
          • 2. Re: Create a build script for Extend Script
            mdegamo Level 1
            When my scripts contains new line, app.compile() doesn't return anything.
            • 3. Re: Create a build script for Extend Script
              mdegamo Level 1
              It's the #include directive the fails it from compiling.
              • 4. Re: Create a build script for Extend Script
                mdegamo Level 1
                Finally got it to work, using this:
                app.compile(s, undefined, fileIn.parent.absoluteURI);
                The third argument sets the includePath of the current script which resolves the relative import.
                2 people found this helpful
                • 5. Re: Create a build script for Extend Script
                  Glad you got it
                  If you need  to deal with #targetengine session or the like then you could do a regex on s (the read file) and remove the targetengine line and then enclose the jsx in a doScript preceded by the #targetengine
                  • Check if file has targetengine
                  • if yes remove it
                  • compile new string to export file b
                  • write new jsx file  #targetengine foo  + app.doScript( + read b + )
                  Trevor
                  BTW Bob Stucky has a script for batch binaries, search the forum or his site for it
                  • 6. Re: Create a build script for Extend Script
                    Hi Mark
                    I'm very interested where did you find out the arguments of compile?
                    Trevor
                    • 7. Re: Create a build script for Extend Script
                      mdegamo Level 1
                      Hi Trevor,
                      I found it implemented on line 2450 on this script "C:\Program Files\Adobe\Adobe Utilities - CS6\ExtendScript Toolkit CS6\Required\80document.jsx".
                      Mark
                      • 8. Re: Create a build script for Extend Script
                        Well spotted!
                        • 9. Re: Create a build script for Extend Script
                          Ah!
                          On Mac OSX its in the "Required" folder of the "SharedSupport" folder of the app package of the ESTK app one can reveal by "Open Package" with a right click on the app:
                          @Mark Anthony – thank you for sharing this!
                          Uwe
                          • 10. Re: Create a build script for Extend Script
                            TᴀW Adobe Community Professional & MVP
                            What are all those jsx files??
                            • 11. Re: Create a build script for Extend Script
                              @Ariel – They represent and control the inner workings of the ESTK and could reveal a lot of undocumented features. I think, Dirk Becker mentioned some of the possibilities to script the ESTK by looking into these files. Bob Stucky as well. There is a lot to detect here. :-)
                              See Dirk Becker's notes on the ESTK here:
                              Uwe
                              • 12. Re: Create a build script for Extend Script
                                Nice! I take it that the UI of ESTK is NOT ScriptUI, though, right? I
                                think it's Flash-based, IIRC.
                                • 13. Re: Create a build script for Extend Script
                                  I'm pretty sure it's flash based I tried in the past unsuccessfully to make some changes to the UI.
                                  Peter brings down 35omvUI.jsx in his SUI guide
                                  I have never seen any normal documentation on scripting the ESTK.  I now mainly use sublime text which is way way better and made a build to execute the scripts from there through the ESTK
                                  • 14. Re: Create a build script for Extend Script
                                    Hi Uwe,
                                    Thanks for the link to Dirk's site.  There's some very good stuff there (not just on this topic).
                                    I just posted Dirk a mail asking if he knows of where to get documentation of the properties and methods of scripting the ESTK
                                    Trevor
                                    • 15. Re: Create a build script for Extend Script
                                      jazzyman02 Level 1
                                      Hi Trevor!
                                      I don't understand...
                                      • if yes remove it
                                      Please Someting to detail....
                                      • 16. Re: Create a build script for Extend Script
                                        Not sure what your not clear about.
                                        But here goes again.
                                        Let's say we have our jsx script
                                        #target indesign-12
                                        #targetengine test
                                        alert('$.fileName: ' + $.fileName + '\n$.engineName: ' + $.engineName + '\napp.name:' + app.name);
                                        We save it in ~/Documents/Adobe%20Scripts/Scripts%20Panel/Forum%20Scripts/targetEngineTest.jsx
                                        We then write and save the below file and then execute it.
                                        var jsxFile, jsxBinFile, jsxScript, jsxbinString;
                                        jsxFile = new File('~/Documents/Adobe%20Scripts/Scripts%20Panel/Forum%20Scripts/targetEngineTest.jsx');
                                        jsxBinFile = new File( jsxFile.absoluteURI + 'bin' ) ;
                                        jsxFile.open('r');
                                        jsxBinFile.open('w');
                                        jsxScript = jsxFile.read();
                                        jsxbinString = app.compile(jsxScript);
                                        jsxBinFile.write(jsxbinString);
                                        jsxFile.close();
                                        jsxBinFile.close();
                                        We then run the jsxbin file (You can just copy and paste the below the line breaks aren't important)
                                        @JSXBIN@ES@2.0@MyBbyBn0ABJCnAEjzFjBjMjFjSjUBfRBCzBhLCCCCCCCCCnXzIjGjJjMjFiOjBjNj
                                        FDfjzBhEEfeMhEhOjGjJjMjFiOjBjNjFhahAnnnePKhEhOjFjOjHjJjOjFiOjBjNjFhahAXzKjFjOjH
                                        jJjOjFiOjBjNjFFfjEfnnnneKKjBjQjQhOjOjBjNjFhaXzEjOjBjNjFGfjzDjBjQjQHfnnff0DzAIBy
                                        B
                                        If we run the jsxbin from for example the ExtendedScript CC Toolkit engine we would still expect the script to be executed by InDesign, that's what the #target is supposed to do, also we would expect the "test" target engine to be created.
                                        But it's not
                                        If we run the regular jsx script from the ExtendedScript CC Toolkit engine we get what we expect
                                        The reason is simple.
                                        Let's rewrite the jsx script missing out the #target and #targetengine lines
                                        The result is almost identical
                                        @JSXBIN@ES@2.0@MyBbyBn0ABJAnAEjzFjBjMjFjSjUBfRBCzBhLCCCCCCCCCnXzIjGjJjMjFiOjBjNj
                                        B
                                        There's just one character change. That's shows you the the app.compile just ignores the # lines.
                                        So this is the fix I was suggesting.
                                        var targetReg, targetEngineReg, wrapper, target, targetEngine;
                                        targetReg = /#target [^\r\n]+/;
                                        targetEngineReg = /#targetengine [^\r\n]+/;
                                        jsxBinFile = new File(jsxFile.absoluteURI + 'bin');
                                        jsxFile.open('r');
                                        jsxFile.encoding = 'UTF8';
                                        jsxBinFile.encoding = 'UTF8';
                                        target = jsxScript.match(targetReg);
                                        targetEngine = jsxScript.match(targetEngineReg);
                                        if (target || targetEngine) {
                                            if (target) {
                                                wrapper = target + '\n';
                                            if (targetEngine) {
                                                wrapper += targetEngine + '\n';
                                            jsxbinString = wrapper + 'app.doScript("myScript");'.replace(/myScript/, jsxbinString.replace(/[\n\r]/g,''));
                                        jsxFile.close();
                                        jsxBinFile.close();
                                        This will save the file as
                                        #target indesign-12
                                        #targetengine test
                                        app.doScript("@JSXBIN@ES@2.0@MyBbyBn0ABJCnAEjzFjBjMjFjSjUBfRBCzBhLCCCCCCCCCnXzIjGjJjMjFiOjBjNjFDfjzBhEEfeMhEhOjGjJjMjFiOjBjNjFhahAnnnePKhEhOjFjOjHjJjOjFiOjBjNjFhahAXzKjFjOjHjJjOjFiOjBjNjFFfjEfnnnneKKjBjQjQhOjOjBjNjFhaXzEjOjBjNjFGfjzDjBjQjQHfnnff0DzAIByB");
                                        It will then run correctly.
                                        There's a few downsides, most significantly that not all the apps can run the JSXBIN using app.doScript but in an InDesign forum that will pass.
                                        HTH
                                        Trevor
                                        • 17. Re: Create a build script for Extend Script
                                          jazzyman02 Level 1
                                          Ohh~~! Thank you very much. Trevor!
                                          • 18. Re: Create a build script for Extend Script
                                            jazzyman02 Level 1
                                            Hi Trevor!
                                            jsxFile.open('r');
                                            jsxFile.close();
                                            jsxBinFile.close();
                                            your code very well run!
                                            Extend Script Toolkit CC application inside.
                                            But!
                                            I want to excute your code. automatically.
                                            with other indesign script.
                                            without excute Extend Script Toolkit application and run action.
                                            How to this work?
                                            • 19. Re: Create a build script for Extend Script
                                              You mean, that you want to do a jsxbin file without using the ESTK?
                                              I don't think that's possible…
                                              Regards,
                                              Uwe
                                              • 20. Re: Create a build script for Extend Script
                                                Read the annotations!!
                                                The normal way of doing this would be stait from terminal or cmd, below is a wrapper
                                                // For compiling jsxbin from an InDesign Script             //
                                                // You MUST have the ESTK CLOSED!!! (always good advise ;-) //
                                                // You must run the script from InDesign                    //
                                                // By Trevor http://creative-scripts.com                    //
                                                // For Mac and Windows                                      //
                                                // change to address of your favorite scripts
                                                compileJSX('~/Documents/Adobe%20Scripts/Scripts%20Panel/Forum%20Scripts/targetEngineTest.jsx');
                                                function compileJSX(jsxFile) {
                                                    var compileScript, tempFile, isMac, script;
                                                    isMac = +($.os[0] === 'M');
                                                    compileScript = [
                                                        "#target estoolkit#dbg",
                                                        "var jsxFile, jsxBinFile, jsxScript, jsxbinString;",
                                                        "var targetReg, targetEngineReg, wrapper, target, targetEngine;",
                                                        "targetReg = /#target [^\\r\\n]+/;",
                                                        "targetEngineReg = /#targetengine [^\\r\\n]+/;",
                                                        "jsxFile = new File('__FILE__');",
                                                        "jsxBinFile = new File(jsxFile.absoluteURI + 'bin');",
                                                        "jsxFile.open('r');",
                                                        "jsxBinFile.open('w');",
                                                        "jsxFile.encoding = 'UTF8';",
                                                        "jsxBinFile.encoding = 'UTF8';",
                                                        "jsxScript = jsxFile.read();",
                                                        "jsxbinString = app.compile(jsxScript);",
                                                        "target = jsxScript.match(targetReg);",
                                                        "targetEngine = jsxScript.match(targetEngineReg);",
                                                        "if (target || targetEngine) {",
                                                        "if (target) {",
                                                        "wrapper = target + '\\n';",
                                                        "if (targetEngine) {",
                                                        "wrapper += targetEngine + '\\n';",
                                                        "jsxbinString = wrapper + 'app.doScript(\"myScript\");'.replace(/myScript/, jsxbinString.replace(/[\\n\\r]/g, ''));",
                                                        "jsxBinFile.write(jsxbinString);",
                                                        "jsxFile.close();",
                                                        "jsxBinFile.close();",
                                                        "jsxBinFile.parent.execute();",
                                                    ].join('\n').replace(/__FILE__/, jsxFile);
                                                    tempFile = new File(Folder.temp + '/compileJSX_' + (+new Date()) + '.jsx');
                                                    tempFile.open('w');
                                                    tempFile.write(compileScript);
                                                    tempFile.close();
                                                    script = localize(
                                                        isMac ?
                                                        'do shell script "\\"/Applications/Adobe ExtendScript Toolkit CC/ExtendScript Toolkit.app/Contents/MacOS/ExtendScript Toolkit\\" -cmd \\"%1\\""' :
                                                        'CreateObject("WScript.Shell").Run(\"\"\"C:\\Program Files (x86)\\Adobe\\Adobe ExtendScript Toolkit CC\\ExtendScript Toolkit.exe"" -cmd ""%1\"\"\")',
                                                        tempFile.fsName
                                                    try {
                                                        app.doScript(script, ScriptLanguage[["VISUAL_BASIC", "APPLESCRIPT_LANGUAGE"][isMac]]);
                                                        return script;
                                                    } catch (e){
                                                        return e + '\n' + script;
