10 Replies Latest reply on Apr 15, 2007 2:50 AM by Newsgroup_User
    remoteClasspath_geoLocator CFC issue
    Level 7
      On shared server with a less than helpful host...but that's a different grip
      entirely...;)
      Have been to source forge and have the latest remoteClasspath_geoLocator CFC
      with the latest InetAddressLocator.jar which includes some amendment for
      CFMX.
      Frankly, I know SFA about this stuff, except that I can't get it to work :(
      I have the jar file in the same directory as the cfc and it seems to point
      to it fine, but it throws the following error:
      java init failed: net.sf.javainetlocator.CFMXwrapper
      from the following try block:
      <cftry>
      <cfset jarFile=replace(jarFile,'\','/','all')> <!--- just in case --->
      <cfset URLObject.init("file:" & jarFile)>
      <cfset URLArray =
      createObject("java","java.lang.reflect.Array").newInstance(URLObject.getClass(),1)>
      <cfset arrayClass.set(URLArray,0,URLObject)>
      <cfset loader =
      createObject("java","java.net.URLClassLoader").init(URLArray)>
      <cfset variables.geoLocator =
      loader.loadClass("net.sf.javainetlocator.CFMXwrapper").newInstance()>
      <cfobject type="Java" action="Create" class="java.util.Locale"
      name="variables.javaLocale">
      <cfcatch type="Any">
      <cfthrow message="java init failed: net.sf.javainetlocator.CFMXwrapper"
      detail="#cfcatch.detail#" errorcode="1001">
      </cfcatch>
      </cftry>
      Can anyone please help this idiot figure out what he's doing wrong?
      Cheers,
      Lossed
      __when the only tool you have is a hammer, everything looks like a nail __
        • 1. Re: remoteClasspath_geoLocator CFC issue
          Level 7
          > entirely...;)
          these days i'm recommending that folks use mark mandel's javaLoader instead.
          i'll be putting up a new version (on sustainableGIS.com) sometime today.
          • 2. Re: remoteClasspath_geoLocator CFC issue
            Level 7
            get javaLoader from: http://javaloader.riaforge.org/
            get the new geoLocator CFC from:
            www.sustainableGIS.com/projects/geoLocator/geoLocator.zip
            • 3. Re: remoteClasspath_geoLocator CFC issue
              Level 7
              Tks Paul.
              Latest error now stems from the javaLoader CFC:
              com.compoundtheory.classloader.NetworkClassLoader
              at line 53.
              Is it meant to be loading that class from his site?
              Excuse the dim questions but I haven't got a clue :(
              "PaulH **AdobeCommunityExpert**" <paul@sustainableGIS.com> wrote in message
              news:evsfva$m22$1@forums.macromedia.com...
              • 4. Re: remoteClasspath_geoLocator CFC issue
                Level 7
                And in case it was ever in any doubt, to cement my dim-ness, there was
                mention in the read-me file of a possible memory leak using CF unless the
                javaLoader instances are stored in the server scope. Should I be worried
                about that?
                Lossed
                "Lossed" <blankemail@hotmail.com> wrote in message
                news:evsm35$bn$1@forums.macromedia.com...
                > Tks Paul.
                > at line 53.
                > message news:evsfva$m22$1@forums.macromedia.com...
                • 5. Re: remoteClasspath_geoLocator CFC issue
                  Level 7
                  no. did you d/l & "install" his CFC? there's a lib dir that needs to be under
                  the location of the javaloader CFC.
                  • 6. Re: remoteClasspath_geoLocator CFC issue
                    Level 7
                    > about that?
                    i would have put that into server scope except that you mentioned you were on a
                    shared host. whether that leaks affects your server depends on how you use
                    geoLocator but i'd suggest following mark's suggestion.
                    • 7. Re: remoteClasspath_geoLocator CFC issue
                      Level 7
                      OK, so, in addition to getting the javaLoader CFC, one also needs to place
                      the lib folder and it's class in the same directory as the CFC.
                      > Tks Paul.
                      > at line 53.
                      • 8. Re: remoteClasspath_geoLocator CFC issue
                        Level 7
                        SNAP:
                        was just advising that, after reading through the read-me file ;)
                        news:evsrcl$5e7$1@forums.macromedia.com...
                        > under the location of the javaloader CFC.
                        • 9. Re: remoteClasspath_geoLocator CFC issue
                          Level 7
                          cheers for putting up with the dimwit here :)
                          Not to mention the great CFC's
                          Very much appreciated.
                          We are all go now.
                          news:evsrgu$5e7$2@forums.macromedia.com...
                          >> about that?
                          > on a shared host. whether that leaks affects your server depends on how
                          > you use geoLocator but i'd suggest following mark's suggestion.
                          • 10. Re: remoteClasspath_geoLocator CFC issue
                            Level 7
                            you can put either of them anywhere you want as long as the javaLoader's lib is
                            under the javaLoader location and you amend the javaloader location in the
                            geoLocator CFC (and of course how you call the geoLocator CFC).
                            if you want to play it safe (and your host doesn't mind) in geoLocator's init()
                            method change:
                            <cfset var javaLoader=createObject("component","javaLoader").init(paths)>
                            <cftry>
                            javaLoader.create("net.sf.javainetlocator.InetAddressLocator")>
                            to (move the javaLoader createObject call inside the try block) :
                            <cftry>
                            <cfif NOT structKeyExists(server,"javaLoader")>
                            <cflock name="loadItext" timeout="60">
                            <cfset server.javaLoader=createObject("component","javaLoader").init(iTextPath)>
                            </cfif>
                            </cflock>
                            </cfif>
                            server.javaLoader.create("net.sf.javainetlocator.InetAddressLocator")>
