3 Replies Latest reply on Aug 26, 2014 3:30 AM by Moshu'
    Indesign complex indexing automation
    mrpinkpix
      Hi, I'm working on a catalog with products references in each page.
      I would like to automate the index according to the model below:
      Reference | Name | Page number.
      But the difficulty is that the name won't be exactly the same that the one written in the catalog and the good names will be stored in a excel database like this: Reference | Name
      Is there a solution for this ?
      Thanks!
        • 1. Re: Indesign complex indexing automation
          Migintosh Level 4
          I don't think I can help you with this, but it seems a little unclear what you have, so maybe if you give some detail, someone will be able to give you an answer.
          mrpinkpix wrote:
          the name won't be exactly the same that the one written in the catalog…
          So, does that mean that you will have a name (let's  just call it Smith) on page 43, you will generate an index that reads:
          Smith...........................43
          …but you want to automate a process that will read something like Jones from a database and change the Smith's to:
          Jones...........................43
          …without changing it on the document pages?
          • 2. Re: Indesign complex indexing automation
            mrpinkpix Level 1
            That's right,
            For example, on page 5 of the catalog we could read: Ref 123456 - GRAPHIC
            CARD 2GB POWERCOLOR HD7850 PCS AND POWERDRIVER - 207,40 €
            And on the index, because the products' names are too long, we will have:
            Ref 1234 - GC 2GB HD7850  - 207,40 €
            May be the best way is to use an xml file.
            Thanks.
            2014-08-26 11:39 GMT+02:00 Migintosh <forums_noreply@adobe.com>:
                Indesign complex indexing automation  created by Migintosh
            <https://forums.adobe.com/people/Migintosh> in InDesign - View the full
            discussion <https://forums.adobe.com/message/6674153#6674153>
            • 3. Re: Indesign complex indexing automation
              Moshu'
              You must find a way to find a unique match between text from layout and text from the data entry from the excel file. For example the reference numbers? Do they correspond? If not, perhaps a combined search of parts from entry from excel file could solve the right match in the layout file. The idea is that, as soon as you can find such a rule of matching, the index can be done by scripting.
