1 Reply Latest reply on Apr 17, 2007 8:49 AM by Newsgroup_User
    Help Please
    rojere3
      yes i need help in the if then else coding in flash
      i have 3 buttons.
      when i click on each button i want to designate a variable for that button.
      each button will load a certain movie clip
      btn1_txt_mc for i made a text element inside a movie clip that i want displayed.
      btn2_txt_mc
      btn3_txt_mc
      button 1 = gave instance name btn1_mc
      need to set variable to btn1
      button 2 = gave instance name btn2_mc
      need to set variable to btn2
      button 3 = gave instance name btn3_mc
      need to set variable to btn3
      then in actionscript i want to toggle those conditions.
      if variable = btn1
      then
      display btn1_txt_mc - movie clip
      else
      if variable = btn2
      then
      display btn2_txt_mc - movie clip
      else
      if variable = btn3
      then
      display btn3_txt_mc - movie clip
      else
      display nothing
      end if
      but in actionscript im not sure how to implement any of that.
      can anyone help?
        • 1. Re: Help Please
          Level 7
          Do something like this.
          //Put all the movieclips on the stage. Then set the visibility to false.
          myMC1._visible = false
          myMC2._visible = false
          myMC3._visible = false
          //then just make them visible when the buttons are clicked.
          btn1_mc.onRelease = function(){
          myMC1._visible = true;
          myMC2._visible = false ; //set the others to false if you want
          myMC3._visible = false;
          btn2_mc.onRelease = function(){
          myMC1._visible = false;
          myMC2._visible = true;
          Dan Mode
          --> Adobe Community Expert
          *Flash Helps* http://www.smithmediafusion.com/blog/?cat=11
          *THE online Radio* http://www.tornadostream.com <--check this
          *Must Read* http://www.smithmediafusion.com/blog
          "rojere3" <webforumsuser@macromedia.com> wrote in message
          news:evviug$cr6$1@forums.macromedia.com...
          > i have 3 buttons.
          > button.
          > displayed.
          > btn2_txt_mc
          > btn3_txt_mc
          > if variable = btn1
          > then
          > else
          > if variable = btn2
          > then
          > else
          > if variable = btn3
          > then
          > else
          > display nothing
          > end if
          > can anyone help?
