16 Replies Latest reply on Sep 4, 2014 11:50 PM by BKBK
    requested scope session has not been enabled
    teedoffnewbie Helper
      Trying to get a site login set up and I keep getting the above error. I have enabled session vars in the CF admin, and have used sessionmanagement in my cfapplication. Not sure what I've done wrong.
       <cfapplication name="myApp" sessionmanagement="yes" setclientcookies="yes" sessiontimeout="#CreateTimeSpan(0,1,0,0)#">
       <!--- Now define that this user is logged out by default --->
       <CFPARAM NAME="session.allowin" DEFAULT="false" />
       <CFPARAM NAME="session.userName" DEFAULT="" />
       <!--- Now if the variable "session.allowin" does not equal true, send user to the login page --->
       <!--- the other thing you must check for is if the page calling this application.cfm is the "login.cfm" page and the "Login_process.cfm" page since the Application.cfm is always called, if this is not checked the application will simply Loop over and over. To check that, you do the following call --->
       <cfif session.allowin neq "true">
           <cfif  ListLast(CGI.SCRIPT_NAME, "/") EQ "login.cfm">
           <cfelseif ListLast(CGI.SCRIPT_NAME, "/") EQ "login_process.cfm">
           <cfelse>
               <!--- this user is not logged in, alert user and redirect to the login.cfm page --->
               <script>
                   alert("You must login to access this area!");
                   self.location="login.cfm";
               </script>
           </cfif>
       </cfif>
      Any help would be greatly appreciated.
