4 Replies Latest reply on Aug 29, 2014 7:14 AM by EncoreBroadcastSolutions
    Crash on Launch PP ME AE
    david.marquardt
      I just started over with a new setup and installed Adobe CC, brand new windows installation
      windows 7 sp1
      CPU: Intel Core i7 4790k
      Mobo: ASUS Sabertooth Z97 mark1
      RAM: G.skill 16GB DDR3 1866
      Matrox MXO2MINI
      Premiere Pro CC(2014)
      Problem signature:
        Problem Event Name: APPCRASH
        Application Name: Adobe Premiere Pro.exe
        Application Version: 8.0.1.21
        Application Timestamp: 53c7b17f
        Fault Module Name: ImageRenderer.dll
        Fault Module Version: 8.0.1.21
        Fault Module Timestamp: 53c7659e
        Exception Code: c000001d
        Exception Offset: 00000000001f5382
        OS Version: 6.1.7600.2.0.0.256.4
        Locale ID: 1033
        Additional Information 1: 0b2d
        Additional Information 2: 0b2df4702c3fc6489bf922fb8e966350
        Additional Information 3: c22a
        Additional Information 4: c22aa4c23205653c649b0a738906b525
      Problem signature:
        Application Name: Adobe QT32 Server.exe
        Application Timestamp: 53c7afcc
        Fault Module Timestamp: 53c76485
        Exception Offset: 001e5353
        Locale ID: 1033
        Additional Information 1: 0a9e
        Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
        Additional Information 3: 0a9e
        Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
      Media Encoder CC(2014)
      Problem signature:
        Application Name: Adobe Media Encoder.exe
        Application Version: 8.0.1.48
        Application Timestamp: 53c99d97
        Fault Module Version: 8.0.1.48
        Fault Module Timestamp: 53c973f4
        Locale ID: 1033
        Additional Information 1: 8636
        Additional Information 2: 863685f0bf3e340ab304447b8b4fbcf8
        Additional Information 3: 77f4
        Additional Information 4: 77f4e769e0e751f38c9e967abedfb2d5
      After Effects CC(2014)
      After Effects error: Crash in progress. Last logged message was: <1416>
      <GPUManager> <2> Sniffer Result Code:3
      Problem signature:
        Application Name: AfterFX.exe
        Application Version: 13.0.2.3
        Application Timestamp: 53e06bec
        Fault Module Version: 13.0.2.3
        Fault Module Timestamp: 53e0584e
        Locale ID: 1033
        Additional Information 1: 0f2e
        Additional Information 2: 0f2e4625c9946dee74ad73d4872f948e
        Additional Information 3: 05c1
        Additional Information 4: 05c1865944a037b49b5906cfe46ff9eb
        • 1. Re: Crash on Launch PP ME AE
          david.marquardt Level 1
          i tried reinstalling a few times to no avail, i also tried selective reboot
          • 2. Re: Crash on Launch PP ME AE
            David, here's a reply I found:
            Re: Premiere Pro crashes at splash screen
            Personally, I suspect a display driver.  Follow this procedure to completely uninstall nVidia.  (As always, back up your registry file prior to making any changes.)
            Once you've uninstalled everything, install the driver for your Quadro 2000D from this page.  NVIDIA DRIVERS Quadro Desktop/Quadro Notebook Driver Release 340 WHQL
            This is the WHQL version for Win7 64-bit, which seems to be the best fit.  Oddly, the only Quadro driver that appears in the 'Adobe CC certified' list is v331, which is a Win7 32-bit driver...
            Remove Drivers:
            1. Access Add/Remove Programs via the Windows Control Panel
            2. Remove Any Nvidia Associated Software
            3. Reboot after the uninstall process has completed
            Remove left over files/folders:
            1. Access Folder Options from Windows Control Panel
            2. Click the view tab and select “Show hidden files/ folders and drives (Apply Settings)
            3. Access Drive “C” (Or wherever your OS is installed)
            4. Delete the folder named “NVIDIA”
            5. Go to “Program Files” and delete all NVIDIA associated folders
            6. Go to “Program Files (x86)” and delete all NVIDIA associated folders
            7. Go to “ProgramData” and delete all NVIDIA associated folders
            8. Go to “Users\YourUserName\AppData\Local” and delete all NVIDIA associated folders
            9. Go to “Users\YourUserName\AppData\Roaming” and delete all NVIDIA associated folders
            Remove left over registry entries:
            1. Access ‘Regedit’ (This can be found in Administrative Tools or by Windows Search)
            Please Note: We will be using the left side panel within ‘regedit’ during this tutorial
            2. Click “HKEY_CURRENT_USER” and extend the folder
            3. Click “Software” and extend the folder
            4. Delete NVIDIA associated folders
            5. Click “HKEY_LOCAL_MACHINE” and extend the folder
            6. Click “SOFTWARE” and extend the folder
            7. Delete NVIDIA associated folders
            8. Click “Wow6432Node” and extend the folder
            9. Delete NVIDIA associated folders
            10. Click “HKEY_USERS” and extend the folder
            11. Click “.DEFAULT” and extend the folder
            12. Click “Software” and extend the folder
            13. Delete NVIDIA associated folders
            14. Click “S-1-5-18” and extend the folder
            15. Click “Software” and extend the folder
            16. Delete NVIDIA associated folders
            17. Feel free to check the remaining “S-1-5” / “Software” folders for NVIDIA folders (and remove them)
            18. Close ‘regedit’ and empty your recycle bin, followed by a reboot
            • 3. Re: Crash on Launch PP ME AE
              Just got it running!!!  I disabled the realtek audio card (mobo) and the realtek lan (mobo) in the BIOS, reinstalled windows again, Very minimal mobo drivers (Basically just the NIC to install updates), and the Performance video driver, installed all windows updates, (there’s actually two packages called sp1), then QuickTime 7.6.2 then the CC installer package, then matrox drivers and FX wipes. Also disabled UAC & firewall, and, increased pagefile size.
              • 4. Re: Crash on Launch PP ME AE
                EncoreBroadcastSolutions Level 1
                That's excellent!
                I wonder if an Adobe expert can supply us with a list of exclusions and permissions that CC requires to work properly with Windows Firewall.  I have seen a number of cloud-based programs that choke when Windows Firewall is enabled.  I'm not saying that having Firewall enabled was necessarilythe problem in this case - most probably was a driver issue.  Still, a comprehensinv Firewall setup plan for CC would be nice to have.
