4 Replies Latest reply on Apr 15, 2007 1:11 PM by Newsgroup_User
    long process on shared server?
    AndyMilk
      I built an application that has 2 scheduled tasks. One of them sends
      e-mails to a list on a daily basis and the other completes an HTTP
      request.
      The number of records is getting larger and these tasks are failing
      because they exceed the timeout set on the ColdFusion or web server.
      I'm using a shared hosting environment at Network Solutions and it's
      unlikely I'd be able to increase the timeout.
      This application is built using ColdFusion Components.
      I had heard of a asynchronous gateway I might be able to use, but
      again, I don't know if I'd be able to set that up on a shared hosting
      environment.
      Does anyone have any ideas, aside from getting a dedicated server?
      I thought about maybe instead of performing all these requests in a
      single page call, but instead, scheduling each request a few seconds
      from each other, but I don't know if CFSCHEDULE will allow hundreds of
      entries at a time.
      Andy
        • 1. Re: long process on shared server?
          Level 7
          > environment.
          the asynch gateway should be cheaper than a dedicated server. i'd start w/that
          first. it works very well.
          • 2. Re: long process on shared server?
            Level 7
            I do not know how this plays in shared hosting environment so use with
            extreme caution. But you can use the <cfsetting requesttimeout=""> tag
            at the beginning of a page to specify how long that page has to run,
            somewhat overriding the setting given in the administrator. But I could
            see hosting companies controlling this tag for what it could do to the
            performance of their servers if misused.
            Async gateways are a good option if they are available to you. They do
            require the 'enterprise' level of CF. Gateways are not included in the
            'standard' edition. They also require some CF-Administrator
            configuration, but nothing more then a scheduled task or DSN
            configuration does.
            • 3. Re: long process on shared server?
              AndyMilk Level 1
              How can I use the asynch gateway on a shared hosting environment?
              Can I set it up without having access to the ColdFusion Administrator?
              • 4. Re: long process on shared server?
                Level 7
                ask your host to set one up (provided, as ian says, they have enterprise).
                nope.
