3 Replies Latest reply on May 12, 2007 3:43 AM by tomharding
    How can I build up an array based on 'checked' checkboxes?
    tomharding
      POO! Just realised this is in the wrong forum. Sorry
      Hey all.. I just have a question about forms in FLEX 2:
      I've got a repeater populated by a list of musicians taken from an XML file. Each artist is represented by a checkbox and when a submit button is clicked, I want that array to be sent over to a php script.
      This is the vbox containing the artist info and checkbox:
      <mx:VBox>
      <mx:Text text="{artistRepeat.currentItem.name}" />
      <mx:Image source =
      "{artistRepeat.currentItem.image}" scaleContent="true" />
      <mx:CheckBox data="{artistRepeat.currentItem.name}" id="cBox" click="modifyArray(Object)" />
      <mx:Text text="{cBox.data}" />
      </mx:VBox>
      And the function for handling this is:
      public function modifyArray(item:Object):String{
      if(cBox.data != null){
      return artistlist.text;
      return artistlist.text = "(artist = "+cBox.data+")";;
      This registers the artist as 'undefined'. Am I going the right direction here?
      Tom
        • 1. Re: How can I build up an array based on 'checked' checkboxes?
          KomputerMan.com Level 1
          This is what I did to process the checkboxes. I put my checked checkboxes into a comma seperated string so I could process it as a list in Cold Fusiojn. I am sure you can modify this code a bit to populate an array instead of a list though. myCFNames is the name of my repeater too.
          var tmpCFCnt:String="";
          var firsttime:int = 0;
          for(var y:int = 0; y < myCFNames.length; y++)
          if (myCFNames[y].selected == true)
          if (firsttime == 0)
          tmpCFCnt = myCFNames[y].validationSubField;
          else
          tmpCFCnt = tmpCFCnt + "," + myCFNames[y].validationSubField;
          firsttime = firsttime + 1;
          Have an Ordianry Day...
          KomputerMan ~|:-)
          • 2. Re: How can I build up an array based on 'checked' checkboxes?
            tomharding Level 1
            Ok.. I've got this down here:
            [Bindable]
            public var artistArray:String;
            /*public var artistArray:ArrayCollection = null;
            public function artistsReceived(item:Object):void
            artistArray = new String(item.label);
            var artistArray:String="";
            for(var y:int = 0; y < artistRepeat.length; y++)
            if (artistRepeat[y].selected == true)
            if (firsttime == 0)
            artistArray = artistRepeat[y].validationSubField;
            else
            artistArray = artistArray + "," + artistRepeat[y].validationSubField;
            And the checkbox code still stays the same..
            However i'm getting a 1119 error in response to my repeater..
            Thanks for the reply anyway :)
            • 3. How can I build up an array based on 'checked' checkboxes?
              tomharding Level 1
              EDIT: Forget it. I've had it with this program. We're done.
              It's about a user friendly as a donkeys back hoof. Honestly, I'm never going to use this once I graduate, unless Adobe stop employing Russians to write their error messages and a decent support website somewhere be setup.
              I'm sorry, I feel bad enough that a program has nearly induced several heart attacks. It's not good for my health building in this :-)
              Thankyou anyway,
              Tom
