3 Replies Latest reply on Aug 31, 2014 8:43 AM by mosheyri
    How to set automatic backups to specific folder in InDesign
    mosheyri Level 1
      The following script saves a copy of an InDesign file to a set folder in the same location of its file being backed up.
      Question: How can I edit the script to save the backup file to a specific path? For example, to a network drive (Z:/backup). Which line in the script should be changed?
      Much is appreciated.
      //saveVersions.jsx
      //DESCRIPTION: Saves the active document versions in a numbered loop
      #targetengine "session"
      var myEventListenerVersions = app.addEventListener("beforeSave", SaveVersion);
      function SaveVersion()
          var myFolderName = 'Backup';
          var myDoc = app.documents.firstItem();
          // Create Backup only if the document has already secured after production
          // (That exists as a file on a disk)
          if (myDoc.saved == true)
              var myCounter = getVersion (myDoc); // Refers version number; this is re-set if required
              var myPathName = myDoc.filePath.fullName + '/' + myFolderName;
              var mySFolder = Folder(myPathName);
              try {
                  //  Create backup folder
                  mySFolder.create();
              catch(e)
                  alert("Problem when creating the folder")
              // Create version copies
              var myName = setVersionName(myDoc.name, myCounter);
              File(myDoc.fullName).copy(myPathName + "/" + myName);
      function getVersion(aDoc)
          if (myMax = aDoc.extractLabel( 'theMax' ))
              // version number
              myVersion = aDoc.extractLabel( 'theVersion' )
          else
              // version number
              do
                  // Prompt max. version number
                  myMax = prompt ('Maximum Versions:', 5);
                  if (myMax == null)
                      exit();
              } while (myMax < 1)
              myVersion = '0';
              aDoc.insertLabel( 'theVersion', myVersion);
              aDoc.insertLabel( 'theMax', myMax);
          // Sichern der Versionsdaten
          myNewVersion = setVersion( aDoc, [myMax, myVersion]);
          return myNewVersion;
      function setVersion( aDoc, aData )
          myNum = Number( aData[1] );
          (myNum >= Number( aData[0] )) ? myNum = 1 : myNum++;
          aDoc.insertLabel( 'theVersion', String( myNum ) );
          return String( myNum );
      function setVersionName(aName, aCounter)
              var myIndex = aName.indexOf( '.indd');
              if (myIndex == -1)
                  var theNewName = aName + '_' + aCounter;
              else
                  var theNewName = aName.substring(0, myIndex) + '_' +  aCounter + aName.substring(myIndex, aName.length);
          return theNewName;
