2 Replies Latest reply on Aug 30, 2014 5:25 AM by canyouunderstandmyq
    When working with muliple tracks, how do you rearrange video/audio clips without splitting everything else?
    canyouunderstandmyq
      Premiere Elements 12
      I am working on multiple video tracks with one soundtrack. When I rearrange video clips, the program cuts the soundtrack and any other videos at that point - sometimes spacing them far away. I have learned to rearrange video/pics in quick mode without effecting the soundtrack, but this still spits other video clips. So, I end up with audio and video cut into many pieces, having to painstakingly put them all back together individually, and so far (other than the "group" option - which doesn't keep the video from being spliced again) I can't find a way to rejoin two pieces of video/audio.
        • 1. Re: When working with muliple tracks, how do you rearrange video/audio clips without splitting everything else?
          A.T. Romano Level 7
          can
          Have you asked this question here before?
          On what computer operating system is your Premiere Elements 12 running on? Have you updated from 12 to 12.1 yet using an opened project's Help Menu/Update? If not, please do so.
          But, as to your immediate problem and assuming that you are using Windows 7, 8, or 8.1 64 bit computer....
          As you hold down the Alt key of the computer main keyboard, make your additions carefully to the existing Timeline content. Premiere Elements does not have any locked track feature. In some instanced, you may want to select (all at one time) a group of clips to move them as a group. Or, you could select (all at one time) a group and apply the Clip Menu/Group command for a permanent grouping of that particular group of clips.
          You can select clips (all at one time)...
          a. Hold down the Shift key and click on all the clips you want selected all at one time
          or
          b. Using the mouse cursor, draw a rectangle around the clips to be selected in order to select them all at one time.
          Any questions or need clarification, please do not hesitate to ask.
          Thank you.
          ATR
          • 2. Re: When working with muliple tracks, how do you rearrange video/audio clips without splitting everything else?
            canyouunderstandmyq Level 1
            Thanks! The Alt key did the trick! I've divided up my song in the soundtrack so many times and wasted so much time putting it back together or reinserting it. I really appreciate your help and how quickly you responded.
            Is there a way that I can set it as the default so that I don't have to push alt every time I move a video?
