4 Replies Latest reply on Sep 9, 2015 9:36 AM by -david
    Trigger Action at the end of Video
    RW8
      I see that this question has been asked and answered a few times here, but, for the life of me, I just can’t get this to work in my composition.
      I want to trigger an action when a video is done playing. My talents lean more towards the design side than the programming side, so a lot of this is new to me.
      I have a video group named “eot_sast_vd” in a symbol named “MovieAndBG_Sym,” which is the only symbol on my stage.
      I’ve added alerts in the code to help me troubleshoot the issues.
      I have tried:
      var myVideo = document.getElementById('eot_sast_vd');
      alert(myVideo); // always comes up “Null”
      myVideo.addEventListener("ended", function(){
      alert("in the function"); //never comes up
      Then the whole composition comes to a grinding halt and nothing further happens.
      Also, I’ve Tried
      var vid = sym.$(‘eot_sast_vd’);
      alert(vid) // displays “ [object Object] “
      var vidEnd = $(vid).children().first();
      alert(vidEnd) // displays “ [object Object] “
      $(vidEnd).bind('ended', function ()
      alert(“I am now in the function”) //never comes up
      Then the composition, again, comes to a grinding halt and nothing further happens.
      In addition, I’ve tried adding both these lines of codes to the stage’s “Composition Ready,” and “Creation Complete.”
      Also the symbol “MovieAndBG_Sym’s” “Creation Complete” and even a timeline trigger on it’s timeline.
      Any help would be greatly appreciated.
        • 1. Re: Trigger Action at the end of Video
          Robyn_cpl Level 2
          I can see what you are trying to do in your code the only thing I can maybe see could be a issue is that your video group is inside a symbol. (Just from my own experience I've never added it to a symbol)
          The way I've managed to get a video ended is:
          var vidCtr = sym.$('INSERT_VIDEO GROUP NAME HERE');
          vidCtr.html('<video style="width:900px;height:500px;" controls autoplay" ><source src=WWW.ENTERURLOF VIDEO HERE.mp4></video>');
          var vid = $(vidCtr).children().first();
          $(vid).bind('ended', function ()
          THIS IS THE ENDED FUNCTION
          Hope this helps with your code
          • 2. Re: Trigger Action at the end of Video
            jbowden Adobe Employee
            Hi RWB,
            Any reason why you wouldn't want to import the video in Animate and then directly address it as a video element? It's very likely a scoping issue (e.g., the video is not part of the Stage timeline) as Robyn mentioned.
            To address a video element, you must include the array notation, e.g., sym.$(‘eot_sast_vd’)[0] would address a video element on the same timeline named "eot_sast_vd".
            Otherwise, your addEventListener code looks correct - but you need to address the video element array, as I mentioned previously.
            hth,
            Joe
            • 3. Re: Trigger Action at the end of Video
              RW8 Level 1
              This did the trick!
              I was missing the [0], and that's all it took.
              Thanks for all the help!
              • 4. Re: Trigger Action at the end of Video
                -david
                Hi jbowden,
                The video is playing but the function wont execute when it finished..  (No alert and no video hiding)
                I have a symbol called videoPlayer on the stage.
                Heres my code :
                sym.stop();
                var vid = sym.$("videoPlayer");
                vid.html('<video width ="300" height ="168" src = "Video/MyVideo.mp4" type = "video/mp4" controls autoplay></video>');
                alert("Video Ended");
                vid.hide();
                I dont really understant where to put the [0] on my code...
                Can you please help me figure it ?
                -david
