10 Replies Latest reply on Aug 31, 2014 7:01 AM by David André Erichsen
    Document font
    David André Erichsen Level 1
      Hello.
      [AS]
      Can anyone make a script that make a folder called "Document Fonts" at the same location as the .indd-file, ant copy all used fonts into that folder?
      That would be very nice to have!
        • 1. Re: Document font
          Larry G. Schneider Adobe Community Professional & MVP
          Have you tried the Package command in ID which will do as you ask?
          • 2. Re: Document font
            Yes, I have. But I want to have a shortcut to do just that, without any other clicking. A script will do this mutch faster, and i want to have a routine that saves the fonts in every document. Also in the future I then find the correct font easy - see?
            • 3. Re: Document font
              The purpose of this forum is to help people compose scripts for their own purpose, not to have someone else write a free script for them. Have you tried anything? Are you willing to pay for someone to write the script?
              • 4. Re: Document font
                Im sorry for asking for a complete script. I will try to figure it out.
                • 5. Re: Document font
                  OK, I now got this and it works:
                  tell application "InDesign"
                    tell front document
                    set ThePath to get file path as string
                    tell application "Finder"
                    try
                    make new folder at alias (ThePath) with properties {name:"Document fonts"}
                    end try
                    end tell
                    package to ThePath with copying fonts, ignore preflight errors, copying profiles, updating graphics, including hidden layers and copying linked graphics
                    end tell
                  end tell
                  How can I set the properties for the Pakage to only copy fonts, and not include report and linked graphics?
                  • 6. Re: Document font
                    When I tried it seemed that the options are mandatory but they can be set to false. I just can't figure out how to do it. The inner tell making the Document fonts folder is unnecessary. The package command does that (at least for me when I tried without it).
                    • 7. Re: Document font
                      Dirk Becker Level 4
                      Use the "without" AppleScript keyword to set a boolean parameter to false.
                      Something like:
                      package to ThePath with copying fonts without ignore preflight errors, copying profiles, updating graphics, including hidden layers and copying linked graphics
                      • 8. Re: Document font
                        I thought I tried that but I guess I didn't have the syntax quite right.
                        • 9. Re: Document font
                          This work in InDesign CC:
                          But is there a way to delete the a folder right away, insted of moving it to the trash?
                          tell application "Adobe InDesign CC"
                            tell front document
                            set myDocPath to get file path as string
                            set myTempPath to myDocPath & "temp:"
                            set myFontPath to myTempPath & "Document fonts:"
                            try
                            package to myFontPath copying fonts yes copying linked graphics no including hidden layers yes copying profiles no updating graphics no ignore preflight errors yes creating report no force save yes
                            end try
                            end tell
                          end tell
                            set TheDest to myDocPath & "Document fonts:"
                            try
                            make new folder at alias (myDocPath) with properties {name:"Document fonts"}
                            end try
                            try
                            make new folder at alias (myDocPath) with properties {name:"temp"}
                            end try
                            try
                            move entire contents of folder myFontPath to folder TheDest
                            end try
                            move folder myTempPath to trash
                            --end try
                          end tell
                          • 10. Re: Document font
                            Some bugs fixet with this, but still wonder if i can delete the temp folder without moving tor trash:
                            tell application "Adobe InDesign CC 2014"
                              tell front document
                              set ThePath2 to ThePath & "temp-folder:"
                              set ThePath3 to ThePath2 & "Document fonts:"
                              try
                              package to ThePath2 copying fonts yes copying linked graphics no including hidden layers yes copying profiles no updating graphics no ignore preflight errors yes creating report no include pdf no force save yes
                              end try
                              end tell
                            end tell
                              set TheDest to ThePath & "Document fonts:"
                              try
                              end try
                              try
                              move entire contents of folder ThePath3 to folder TheDest
                              end try
                              move folder ThePath2 to trash
                              --end try
                            end tell
