1. Re: Autenticação Media Server
hparmarSep 4, 2014 6:14 AM (in response to Roberto Paraiso)
you can download access plugin from the same location the you downloaded the FMLE(Adobe Media Live Encoder)...
You need to drop that access plugin into AMS for authentication on FMLE end to work...Note that along with that access plugin, you will also find an exe which if you run will allow you to add users to the list which will be consmed by access plugin for authenticating it.
2. Re: Autenticação Media Server
Roberto Paraiso Sep 4, 2014 7:06 AM (in response to hparmar)hi hparmar,
the location where the downloaded FMLE has nothing that tells me where to download the plugin and not exe, you could let me know the link.
thanks for attention.
3. Re: Autenticação Media Server
hparmarSep 4, 2014 7:51 AM (in response to Roberto Paraiso)
check the following thread for a similar discussion...
prevent non autherized users from using my FMS
And the plugin can be downloaded from
The exe called users.exe is installed along with the plugin and can be found @ C:\Program Files\Adobe\Adobe Media Server 5\conf\users.exe
4. Re: Autenticação Media Server
Roberto Paraiso Sep 4, 2014 8:40 AM (in response to hparmar)hi hparmar,
friend, I have already installed FMLE, version 3.2 and the extended adobe media server 5, already have the plugin installed on dll module and still not working, I use windows 7 x64 on the exe you told me in my briefcase C: \ Program Files \ Adobe \ Adobe Media Server 5 \ conf \ users.exe there but not users.exe users.xml.
sorry my english, I'm translating in translating google.
thanks for attention. -
6. Re: Autenticação Media Server
Roberto Paraiso Sep 4, 2014 9:32 AM (in response to hparmar)hi hparmar,
you're the guy, worked perfectly, so one more doubt, using this users.exe, which syntax? how do I add the users?
Thank you very much. -
7. Re: Autenticação Media Server
Roberto Paraiso Sep 4, 2014 10:19 AM (in response to Roberto Paraiso)hi hparmar,
friend, decided all questions, thank you.
Roberto Paraiso
