3 Replies Latest reply on Aug 31, 2014 9:44 AM by A.T. Romano
    Der organizer in premiere elements 11 funktioniert nicht
    Reinhard und Steffi
      Trotz kompletter Neuinstallation
      zeigt der Organizer viele Datein mit ? an
      bevor fehlende Datein gesucht werden können
      stürzt das Programm ab
        • 1. Re: Der organizer in premiere elements 11 funktioniert nicht
          A.T. Romano Mythic
          Reinhard und Steffi
          What computer operating system is your Premiere Elements 11 running on?
          What is the problem that is causing you to reinstall Premiere Elements 11? Is the problem that
          each of the Elements Organizer 12 thumbnails has a question mark in it?
          Did you move, delete, or rename files/folders in the Elements Organizer 12 after you had imported
          the files into the Elements Organizer 12?
          Where are the originals stored on your computer - internal hard drive or external hard drive?
          How many entries are in the Elements Organizer 12 - how many video, how many stills?
          Let us start off by deleting settings files - first the one for the Elements Organizer 12 - assuming Windows 7, 8, or 8.1 64 bit.
          Local Disk C
          Users
          Owner
          AppData
          Roaming
          Adobe
          Elements Organizer
          12.0
          Organizer
          and in the Organizer Folder is the psa.prf file that you disable by renaming it from psa.prf to psa.prfOLD or by deleting it.
          Let us start here and then decide what next.
          Thank you.
          ATR
          • 2. Re: Der organizer in premiere elements 11 funktioniert nicht
            Reinhard und Steffi Newcomer
            mit freundlichen Grüßen
            Reinhard Uhl
            Druckagentur Printpool
            Im Brühl 22
            71404 Korb
            Tel. 07151 1679125
            Fax 07151 1679480
            mobil 0163 5536333
            reinhard.uhl@gmail.com
            Von: A.T. Romano
            Gesendet: Samstag, 30. August 2014 00:27
            An: Reinhard Uhl
            Betreff:  Der organizer in premiere elements 11 funktioniert nicht
            created by A.T. Romano <https://forums.adobe.com/people/A.T.+Romano>  in Premiere Elements - View the full discussion <https://forums.adobe.com/message/6685676#6685676>
            • 3. Re: Der organizer in premiere elements 11 funktioniert nicht
              A.T. Romano Mythic
              Reinhard und Steffi
              Thanks for the reply. I did not see the details of the problem that I requested. But, that might be my fault.
              Only now I saw a typing problem on my side. I started out writing "11" which is the version that you have and for some reason then typed "12".
              Everything in my post numbered 1 applies and is OK except wherever I typed "12" in that post, please see "11". The system is not allowing me to make the correction in the post itself at this time.
              Please let me know if you understand the correction to which I am referring. Looking forward to the answers to the questions in post numbered 1.
              Best wishes
              ATR
