10 Replies Latest reply on Aug 29, 2014 8:25 AM by Maronberg
    Calculation Help
    Maronberg
      Good Morning All,
      I have a form in which users type values into fields and at the bottom, the form automatically adds all of the amounts to show the "Total Monthly" value. Then, underneath, I have a field that multiplies the "Total Monthly" value by 12 to show the "Total Annually". My issue is that when nothing is typed in the form at all, these two fields have the value of "$0.00". I want to make it so that they are blank until someone types something into the form. I have attached two screenshots to show you what I am talking about. Thank you for your help in advance.Calculation.JPG
        • 1. Re: Calculation Help
          Use this code as their custom validation script:
          if (event.value==0) event.value = "";
          • 2. Re: Calculation Help
            Maronberg Level 1
            Sorry, I am a complete noob when it comes to coding. How do I do the multiplication as well?
            • 3. Re: Calculation Help
              It has nothing to do with each other. For the calculation enter this
              (EXACTLY) as the Simple Field Notation option under the Calculate tab:
              Total\ Monthly * 12
              • 4. Re: Calculation Help
                Maronberg Level 1
                Correct, I had that as my original script, except it leaves the $0.00" there when nothing is typed in.
                • 5. Re: Calculation Help
                  So what are you asking me, exactly?
                  • 6. Re: Calculation Help
                    Maronberg Level 1
                    I need a script that would take the value from the "Total Monthly" field with the dollar sign(that field automatically generates the sum from the above fields) and multiply it by "12" but also is blank when the there is nothing in the "Total Monthly" field.
                    • 7. Re: Calculation Help
                      Maronberg Level 1
                      So I have this script(see below) in another form. Instead of subtraction, I want it to multiply "Rent_20" by 12.
                      var res = +this.getField("Rent_20").value - +this.getField("TotalAnnualExpenses0").value;
                      if (res != 0) {
                          event.value = res;
                      else {
                          event.value = "";
                      • 8. Re: Calculation Help
                        If the result of a calculation has a currency symbol or a percentage symbol the custom formatting script will not work. You need a script to convert the formatting back to a numeric value with no currency symbol of percentage symbol.
                        var nDec = 2; // number of decimal places to display
                        var sepStyle = 0; // style for thousand and decimal separators;
                        var negStyle = 0; // style to display negative numbers;
                        var currencySymbol = "$"; // currency symbol to use;
                        var currencyPrepend = true; // pre-pend the currency symbol
                        if(event.value == 0) {
                        // value is zero;
                        event.value = ""; // set value to null string;
                        currencySymbol = ""; // set currency symbol to none;
                        AFNumber_Format(nDec, sepStyle, negStyle, "", currencySymbol, currencyPrepend); // format result;
                        } else {
                        // non-zero value, format as variables are set;
                        • 9. Re: Calculation Help
                          Maronberg Level 1
                          The currency symbol is only part of the template, not the actual form. See the attached pic. Sorry for being so confusing, I really appreciate your help.
                          • 10. Re: Calculation Help
                            Maronberg Level 1
                            I actually figured it out. A lot simpler than I thought. Thank you, I wouldn't have got it without you. Below is the code I used.
                            var res = +this.getField("Rent_20").value * 12;
                            if (res != 0) {
                                event.value = res;
                            else {
                                event.value = "";
