• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
it wont install as it says i have safari open but i don't have safari open
Guest
Aug 29, 2014 Aug 29, 2014
flash player wont instal as it says that i need to close safari but i dont have safari open in the first place. help!!
Views
425
Translate
Translate
Report
Report
Community guidelines
community guidelines
Deleted User
Oct 27, 2014 Oct 27, 2014
click the apple icon in the top left of your mac. click 'force quit'. click on the programmes you need to quit in the box that appears and click 'force quit'. now install abode flash player.
Votes
Translate
Translate
Community Beginner ,
Aug 30, 2014 Aug 30, 2014
Apparently the installer mistakenly reports that Safari is running when certain other applications that use the same WebKit framework, like Dashboard, for example, are running. There are several ways to get around this:
  1. Restart your Mac and relaunch the Flash Player installer before you start any other apps.
  2. Launch Activity Monitor and check to see if Dashboard is running. (It may be running under more than one process.) Select the Dashboard process and click the "x" button in the upper left corner of the window. Click "Quit" in the dialog. If this doesn't work (it takes a few seconds) try again and choose "Force Quit." You have to repeat this for each Dashboard process.
  3. Download and install the ClickToFlash browser extension. This extension allows you to avoid using Flash under most circumstances. It prevents Flash from loading automatically and, if possible, allows content to be loaded and displayed as HTML5 video. If you don't use Flash, you won't need to update it. It's an awful resource hog and security risk anyway.
Adobe could make this process a lot easier if they would make the installer a little more intelligent about reporting process names and providing a more convenient way to quit them if necessary. Apparently they don't think it's worth the trouble, so I guess you have to ask yourself if Flash is worth the trouble.
Votes
Translate
Translate
Report
Report
Guest
LATEST
Votes
Translate
Translate
Report
Report
