1 Reply Latest reply: Aug 29, 2014 10:41 AM by scottli RSS
    Transform not working? CP v5.5
    scottli Community Member
      Hello.
      I am inserting a Text Caption, using the HaloBlue style. I want to be able to resize the caption box but using the anchors doesn't work. I can't adjust it. So, I tried using the Transform option. I took off the "Contraint Proportion" and tried adjusting the size that way. I can adjust it UP (make it larger) but cannot adjust it smaller beyond W:156 H:81.
      So confused. Wondering if somebody can help.
        • 1. Re: Transform not working? CP v5.5
          Never mind. Found it myself.
          Edit a text caption
          If you are resizing a text caption, you cannot make the text caption smaller than the bitmap used to create the text caption. For example, the text caption style “Pill” uses bitmaps sized approximately 18 pixels (wide) x 16 pixels (high), so these bitmaps could not be resized to 15 x 12 pixels. However, any of the text caption bitmaps can be made larger. If you need very small text captions, consider creating custom captions
