2 Replies Latest reply on Sep 1, 2014 10:38 AM by Peter Grainge
    Robohelp 10 command line crashes
    Duck Master
      I am trying to build a robohelp project at the command line and it crashes. Building manually in the IDE works.
      The event log show:
      Faulting application name: RHCL.exe, version:, time stamp: 0x4ff35c65
      Faulting module name: HtmSingleSourceMultiScreenHelp.dll, version:, time stamp: 0x4ff358bc
      Exception code: 0xc0000005
      Fault offset: 0x0000f38a
      Faulting process id: 0x7f8
      Faulting application start time: 0x01cfc3baef76dd63
      Faulting application path: C:\Program Files (x86)\Adobe\Adobe RoboHelp 10\RoboHTML\RHCL.exe
      Faulting module path: C:\Program Files (x86)\Adobe\Adobe RoboHelp 10\RoboHTML\HtmSingleSourceMultiScreenHelp.dll
      Report Id: 30ffeec3-2fae-11e4-9ddc-f4ce46ba20d2
      The generated log shows that it crashes right after it logs 'Processing index data...'.
      It appears to be the same issue found here: Generating either Multiscreen or Responsive HTML5 from command line (RHCL)
      What can I do to get this building on the command line successfully? I have 4 other projects I am doing this the same way with and they are generating the output fine.
