21 Replies Latest reply on May 22, 2016 11:57 AM by BillClag
    Extension Manager CC not showing installed apps (mac)
    gschomburgbns
      I'm trying to install some extensions for Flash CC 2014, but I'm running into a problem with extension manager not knowing that Flash is installed.
      The issue seems pretty similar to this one: Re: Adobe Extension Manager CC Problems
      But I'm on a mac, running 10.9.4
      I did have other CS6 & CC apps installed but I uninstalled them all, ran the CC Cleaner, and now just have Flash CC 2014, Extension Manager, and Extendscript tool kit.
      I've run the bridge talk diagnostics the results are below.
      the flash cc path seems valid
      any suggestions?
      thanks
      Result: BridgeTalk Diagnostics
        Info:
        Name = estoolkit-4.0
        Status = PUMPING
        Group = cs
        Path = /Applications/Adobe ExtendScript Toolkit CC/ExtendScript Toolkit.app
        Version = 2.0
        Build = ES 4.5.5
        Next serial number = 40
        Logging: = OFF
        Now = 16:51:24
        Message Version = 2.05
        Authentication = ON
        Digest = ON
        Thread: estoolkit-4.0#thread
        Avg. pump interval = 32ms
        Last pump = 69ms ago
        Ping: 7
        ECHO_REQUEST: ECHO_RESPONSE
        Timeout = undefined
        Handler = undefined
        STATUS: PUMPING
        Timeout = undefined
        Handler = undefined
        MAIN: MAIN
        Timeout = undefined
        Handler = installed
        LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
        DIAGNOSTICS: DIAGNOSTICS
        Timeout = undefined
        Handler = installed
        INFO: INFO
        Timeout = undefined
        Handler = installed
        SETUPTIME: thread=0ms, left=12ms
        Timeout = undefined
        Handler = undefined
        Instances: 3
        estoolkit-4.0#dbg:
        msg[16:51:23]: 00000035
        @BT>Version = 2.05
        Target = estoolkit-4.0#dbg
        Sender = estoolkit-4.0#dbg
        Sender-ID = localhost:mac1301
        Timeout = 16:51:24
        Type = Ignore
        Response-Request = Timeout
        Headers = (no headers)
        Timestamp = 16:51:23
        Serial-Number = 35
        Received = undefined
        Result = undefined
        Error = undefined
        Body = (empty)
        Incoming: 1
        Outgoing: 0
        Handler: 9
        ExtendScript = for all messages
        Error = for only msg #25
        Error = for only msg #27
        Error = for only msg #31
        Result = for only msg #35
        Error = for only msg #35
        Timeout = for only msg #35
        Result = for only msg #37
        Error = for only msg #37
        estoolkit-4.0#estk:
        msg[16:51:23]: 00000037
        @BT>Version = 2.05
        Target = estoolkit-4.0#estk
        Timeout = 17:01:23
        Type = Debug
        Response-Request = Result Error
        Serial-Number = 37
        Result = undefined
        Error = undefined
        Body: 107 bytes
        Text = <get-properties engine="main" object="$.global" exclude="undefined,builtin,prototype" all="true" max="20"/>
        Incoming: 1
        Outgoing: 0
        Handler: 1
        estoolkit-4.0: (main)
        Incoming: 0
        Outgoing: 0
        Handler: 1
        Targets: 3
        Connector = PCD
        Installed: 0
        Running: 0
        estoolkit-4.0: PUMPING
        Group = cs
        Display Name = ExtendScript Toolkit CC
        MsgAuthentication = ON
        MsgDigest = ON
        ESTK = ON
        Status = PUMPING
        Info:
        Group = cs
        Version = 2.0
        Build = ES 4.5.5
        Next serial number = 43
        Logging: = OFF
        Now = 16:51:24
        Authentication = ON
        Digest = ON
        Last pump = 270ms ago
        Ping: 7
        Timeout = undefined
        Handler = undefined
        STATUS: PUMPING
        Timeout = undefined
        Handler = undefined
        MAIN: MAIN
        Timeout = undefined
        Handler = installed
        LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = installed
        INFO: INFO
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = undefined
        ExeName = ExtendScript Toolkit.app
        exman-7.0: IDLE
        Group = cs
        Path = /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app
        Display Name = Adobe Extension Manager CC
        MsgDigest = ON
        ESTK = OFF
        BundleID = com.adobe.exman
        Status = IDLE
        Info:
        Group = cs
        Version = 2.0
        Build = ES 3.92.104
        Next serial number = 3
        Logging: = OFF
        Now = 16:51:26
        Authentication = ON
        Digest = ON
        exman-7.0: IDLE
        Thread: exman-7.0#thread
        Avg. pump interval = 5147ms
        Last pump = 101ms ago
        Ping: 7
        Timeout = undefined
        Handler = undefined
        STATUS: IDLE
        Timeout = undefined
        Handler = undefined
        MAIN: MAIN
        Timeout = undefined
        Handler = installed
        LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = installed
        INFO: INFO
        Timeout = undefined
        Handler = installed
        SETUPTIME: thread=0ms, left=990ms
        Timeout = undefined
        Handler = undefined
        ExeName = Adobe Extension Manager CC.app
        flash-14.0:
        Path = /Applications/Adobe Flash CC 2014/Adobe Flash CC 2014.app
        Display Name = Adobe Flash Professional CC 2014
        MsgDigest = ON
        ESTK = OFF
        BundleID = com.adobe.flash
        Status = (not running)
        ExeName = Adobe Flash CC 2014.app
        Installed: 1
        Running: 2
        Groups: 142
        cs3:
        acrobat-8.0
        aftereffects-8.0
        soundbooth-1.0
        bridge-2.0
        contribute-4.5
        devicecentral-1.0
        dreamweaver-9.0
        encore-3.0
        estoolkit-2.0
        fireworks-9.0
        flash-9.0
        illustrator-13.0
        indesign-5.0
        indesignserver-5.0
        incopy-5.0
        photoshop-10.0
        premiere-3.0
        premierepro-3.0
        stockphotos-1.5
        audition-3.0
        cs4:
        acrobat-9.0
        aftereffects-9.0
        soundbooth-2.0
        bridge-3.0
        contribute-5.0
        devicecentral-2.0
        dreamweaver-10.0
        encore-4.0
        estoolkit-3.0
        fireworks-10.0
        flash-10.0
        illustrator-14.0
        indesign-6.0
        indesignserver-6.0
        incopy-6.0
        photoshop-11.*
        premierepro-4.0
        audition-4.0
        ame-1.0
        exman-2.0
        cs5:
        acrobat-9.0
        aftereffects-10.0
        soundbooth-3.0
        bridge-4.0
        contribute-6.0
        devicecentral-3.0
        dreamweaver-11.0
        encore-5.0
        estoolkit-3.5
        fireworks-11.0
        flash-11.0
        illustrator-15.0
        indesign-7.0
        indesignserver-7.0
        incopy-7.0
        photoshop-12.*
        premierepro-5.0
        audition-5.0
        ame-2.0
        exman-3.0
        flashbuilder-4.0
        flashcatalyst-1.0
        ts1:
        captivate3-en_us
        captivate3-fr_fr
        captivate3-it_it
        captivate3-ja_jp
        captivate3-es_es
        captivate3-de_de
        ts2:
        captivate-4.0
        el2:
        captivate-5.0
        as1:
        acrobat-10.0
        ts3:
        robohelp-9.0
        framemaker-10.0
        cs55:
        aftereffects-10.5
        audition-4.0
        bridge-4.1
        contribute-6.1
        devicecentral-3.5
        dreamweaver-11.5
        encore-5.1
        estoolkit-3.6
        fireworks-11.1
        flash-11.5
        illustrator-15.1
        indesign-7.5
        indesignserver-7.5
        incopy-7.5
        photoshop-55.*
        premierepro-5.5
        ame-2.5
        exman-5.5
        flashbuilder-4.5
        flashcatalyst-1.5
        switchboard-2.0
        el25:
        captivate-5.5
        cs60:
        aftereffects-11.0
        audition-5.0
        bridge-5.*
        contribute-6.88
        devicecentral-4.0
        dreamweaver-12.0
        encore-6.0
        estoolkit-3.8
        fireworks-12.0
        flash-12.0
        illustrator-16.*
        indesign-8.0
        indesignserver-8.0
        incopy-8.0
        photoshop-60.*
        premierepro-6.0
        ame-6.0
        exman-6.0
        flashbuilder-4.52
        switchboard-2.0
        prelude-1.0
        speedgrade-6.0
        el60:
        captivate-60.*
        ts4:
        robohelp-10.0
        framemaker-11.0
        cs70:
        audition-6.0
        bridge-6.*
        dreamweaver-13.0
        encore-7.0
        fireworks-13.0
        flash-13.0
        illustrator-17.*
        indesign-9.*
        indesignserver-9.0
        incopy-9.*
        photoshop-70.*
        premierepro-7.0
        ame-7.0
        exman-7.0
        flashbuilder-5.0
        prelude-2.0
        estoolkit-4.0
        aftereffects-12.0
        el70:
        captivate-70.*
        cs80:
        bridge-6.*
        photoshop-80.*
        estoolkit-4.0
