2 Replies Latest reply on Aug 29, 2014 10:27 PM by alain-fr
    problem with hyperlink in inDesign cc 2014
    alain-fr
      Hello,
      i hope someone can help me...
      when i convert my inDesign document to ePub 3 format, the hyperlink inserted in the document
      appear correctly in underlined blue, mais i can t click on them, they don t work at all... i use
      iBook as ePub reader or a iPad, it s the same problem...
      thanks a lot if you know how to fix this problem
      bye
      Alain
        • 1. Re: problem with hyperlink in inDesign cc 2014
          Steve Werner Adobe Community Professional & MVP
          I've moved your question to the InDesign EPUB forum.
          Is your EPUB 3 file set for Reflowable EPUB or Fixed Layout EPUB? I suspect the latter.
          If so, you've run into a current limitation of EPUB 3 Fixed Layout. It doesn't yet support text hyperlinks. Only object hyperlinks. This will probably be fixed in the next InDesign CC 2014 update.
          Anne-Marie Conception suggested a workaround (probably a bit of a pain). You can create a graphic frame and place a picture in it (required). Then set the opacity of the picture to 0%. Place the graphic frame on a separate layer above the text you want to link. Create a hyperlink to that frame. She mentioned this in the most recent podcast on www.indesignsecrets.com.
          • 2. Re: problem with hyperlink in inDesign cc 2014
            alain-fr Level 1
            yes it s Fixed Layout EPUB...
            thanks a lot for the answer, i understand now .
