1 Reply Latest reply on Sep 2, 2014 3:17 PM by Shadowsych
    Flash AS2 won't load data from mySQL database! (Using PhP, AS2, and MySQL)
    Shadowsych
      Hello! I have a problem! Flash CS6 (AS2) won't load up data from mySQL database. It does successfuly send data from flash to phpmyadmin but flash doesn't load it up D:. I need help please!
      So the problem is that whenever I test the movie it traces undefined for the variable I want to load from mySQL. Everything is on one frame including the code and textboxes, buttons, etc. Here is my code:
      PHP
      <?php
      require_once('/home/a6934122/public_html/AccountSystem/dbconnect.php');
      $testdata1= $_GET['testdata1'];
      $testdata2 = $_GET['testdata2'];
      $user = $_GET['user'];
      $result = mysql_query("SELECT * FROM accounts WHERE user = '$user'");
      $result2 = mysql_query("SELECT * FROM accounts WHERE testdata1 = '$testdata1'");
      if(mysql_num_rows($result) == 0){
      $status = "&Thestatus = PhP Failed.";
      echo($status);
      } else {
      $row2 = mysql_fetch_array($result2);
      $row = mysql_fetch_array($result);
      $user=$row['user'];
      $testdata1=$row2['testdata1'];
      $status = "&Thestatus = PhP Successful.";
      mysql_query("UPDATE accounts SET testdata1='$testdata1', testdata2='$testdata2' WHERE user='$user'");
      echo($status);
      FLASH AS2
      stop();
      //Result SendData Code
      var result_lv:LoadVars = new LoadVars();
      result_lv.onLoad = function(success:Boolean) {
          if (success) {
              result_ta.text = "We are in business.";
          } else {
              result_ta.text = "Error connecting to server.";
      //Sending Account Data
      SendData = new LoadVars();
      //Register Account
      register = new LoadVars();
      registered = new LoadVars();
      //Login Account
      login = new LoadVars();
      logged = new LoadVars();
      //Send Datas
      SendData.user = user
      submitURL = "http://lumosityentertainment.hostei.com/AccountSystem/PhpLoadTest.php";
        SendData.testdata1 = testdata1;
        SendData.testdata2 = "Testing";
      trace(SendData.testdata1);
      //now the magic
        SendData.sendAndLoad(submitURL, result_lv, "GET");
      Please help!
