11 Replies Latest reply on Sep 5, 2014 9:42 PM by pwillener
    Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
    CflashP#84rocks
      When I discovered that I had Flash Player version 14.0.0.145, both as a plugin for "all other browsers", i. e., Mozilla Firefox, and the "Active X" files for Internet Explorer 11, I decided to do a "clean install". I went about the procedure, using the Adobe website instructions. I uninstalled the program, and checked my Windows Explorer, as per Adobe, to make sure all of the correct files had been deleted. The files were gone, and so I proceeded with the install, from the 3-step,"install now" Adobe page, (after closing IE), then checked to be certain ALL of the right files installed. They were all in my SysWow64 / Macromed / Flash folder, but only the Active X files necessary for FP to run in IE, but no "plugin" files at all were there for "all other browsers", and I also use Firefox, version 30, every now and then.
      SORRY, I have an Acer laptop, with a single core, ( I suppose you call it that, cuz it's not a dual core ) Intel Celeron CPU, Windows 7 Home Premium, SP1. As you already know, I have both IE11, and Firefox 30.
      Before the update, I had, in my Flash folder, both the "Active X", AND the "plugin" files, but now have only the Active X. From the "problems with installation" Adobe page, I clicked on the install for all other browsers link, next to the bottom of the page. The dialog box then appeared, asking if I wanted to go ahead with the "plugin" download...that files of this type could harm my computer. I had already seen, in the EXAMPLE, that the same dialog would pop up, and to go ahead and click on "run". I did that, and nothing happened. Nothing at all. I attempted the same steps three times, and got the same result. So, now, I have the latest version of FP for Internet Explorer, but no Flash at all for Firefox.
      What to do?
        • 1. Re: Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
          pwillener Level 8
          Can you post the contents of the FlashInstall.log file from syswow64\Macromed\Flash?
          After that try the offline installer http://download.macromedia.com/pub/flashplayer/current/support/install_flash_player.exe
          • 2. Re: Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
            CflashP#84rocks Level 1
            Pat, first, let me just say a quick thanks for your reply. Here is a screenshot of the Flash folder contents. I tried to make it big enough to be legible. Hope this helps out. Thanks again.
            Tommy
            • 3. Re: Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
              pwillener Level 8
              Thank you; however, I'd like to see the contents of the FlashInstall[.log] file.
              • 4. Re: Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
                Pat, this .log file is perhaps 100 lines of text or more when I open it in Notepad, and I can't figure out how to get it in our reply boxes here at Adobe forums. Do you possibly know how to do this, and if so, just reply and tell me, or email me. I'm not sure if you have my email address. It's probably on my profile, but to save you the trouble, it is [removed]
                • 5. Re: Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
                  pwillener Level 8
                  Open the log file in Notepad, then
                  1. Alt+E (Edit)
                  2. Ctrl+A (Select all)
                  3. Ctrl+C (Copy)
                  then go to the forum (or your forum notification email), and paste the content using Ctrl+V.
                  • 6. Re: Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
                    pwillener Level 8
                    P.S. this is a public forum; please do not post your email address or other private data.
                    • 7. Re: Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
                      =O====== M/11.2.202.235 2013-03-20+13-31-27.659 ========
                      0000 [W] 00001113 C:\Windows\SysWOW64\Macromed\Flash\\* 3
                      0001 [I] 00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\{F814ED46-365D-45C2-AC95-9AFAF94095BA}\InstallFlash Player.exe" -install -skipARPEntry -iv 1 -au 4294967295
                      0002 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
                      0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0004 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                      0006 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_235.ocx
                      0007 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.exe
                      0008 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.dll
                      0009 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0010 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      =X====== M/11.2.202.235 2013-03-20+13-31-28.876 ========
                      =O====== M/11.9.900.117 2013-10-20+21-41-14.271 ========
                      0000 [I] 00000010 "C:\Users\justin\AppData\Local\Adobe\AIH.5c09b0e9e91d973d320d5e2d3d743412d4266a2e\install _flash_player.exe" -install -iv 8 -au 0
                      0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
                      0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0003 [I] 00000011 1
                      0005 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                      0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                      0007 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                      0008 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                      0009 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
                      0010 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0011 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0012 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0013 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0014 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_117.dll
                      0015 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_Plugin.exe
                      0016 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                      0017 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                      0018 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_117.exe
                      0019 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0020 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0021 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0022 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0023 [W] 00001106
                      0024 [W] 00001106
                      0025 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0026 [I] 00000012
                      =X====== M/11.9.900.117 2013-10-20+21-41-24.853 ========
                      2013-10-21+2-42-5.845 [error] 1226 1062
                      =O====== M/11.9.900.117 2013-10-21+02-41-53.877 ========
                      0000 [I] 00000010 FlashPlayerInstaller.exe -install -iv 9
                      0001 [I] 00000011 1
                      0002 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0003 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                      0004 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashUtil32_11_2_202_235_ActiveX.exe/ 2
                      0005 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx
                      0006 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe
                      0007 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll
                      0008 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                      0010 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0011 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0012 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0013 [W] 00001106
                      0014 [W] 00001106
                      0015 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0016 [I] 00000012
                      =X====== M/11.9.900.117 2013-10-21+02-42-07.546 ========
                      =O====== M/11.9.900.117 2013-11-03+09-47-21.433 ========
                      0000 [I] 00000010 "C:\ProgramData\Adobe\AIH.1dba56d17d2a0523c381f0d39b1181659dc06df9\install_flash_player.e xe" -install -iv 8
                      0001 [I] 00000011 1
                      0003 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                      0004 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                      0005 [W] 00001036 Software\Mozilla\Mozilla Thunderbird\extensions/Plugins 2
                      0006 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
                      0007 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0008 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0009 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0010 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0011 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_117.dll
                      0012 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_Plugin.exe
                      0013 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                      0014 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                      0015 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_117.exe
                      0016 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0017 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0018 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0019 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0020 [W] 00001106
                      0021 [W] 00001106
                      0022 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0023 [I] 00000012
                      =X====== M/11.9.900.117 2013-11-03+09-47-43.868 ========
                      =O====== M/11.9.900.117 2013-11-15+17-17-54.732 ========
                      0000 [I] 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_Plugin.exe" -update plugin
                      =X====== M/11.9.900.117 2013-11-15+17-18-32.184 ========
                      =O====== M/11.9.900.117 2013-11-21+16-01-39.034 ========
                      =X====== M/11.9.900.117 2013-11-21+16-01-59.220 ========
                      =O====== M/11.9.900.152 2013-11-21+16-04-32.047 ========
                      0000 [I] 00000010 "C:\Users\justin\AppData\Local\Adobe\AIH.56cefe21463c39c77d9c21070fa1a1e1b276c8e8\install _flash_player.exe" -install -iv 10
                      0001 [I] 00000011 1
                      0005 [W] 00001036 Software\Mozilla\Mozilla Firefox 25.0.1\extensions/Plugins 2
                      0006 [W] 00001036 Software\Mozilla\Mozilla Thunderbird\extensions/Plugins 2
                      0007 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
                      0009 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0011 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0012 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_117.dll 5
                      0013 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_117.dll 5
                      0014 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_117.exe 5
                      0015 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_117.exe 5
                      0016 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_152.dll
                      0017 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_152_Plugin.exe
                      0018 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                      0019 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                      0020 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_152.exe
                      0021 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0022 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0023 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0024 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0025 [W] 00001106
                      0026 [W] 00001106
                      0027 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0028 [I] 00000012
                      =X====== M/11.9.900.152 2013-11-21+16-04-41.534 ========
                      2013-12-11+19-58-4.20 [error] 1226 1062
                      =O====== M/11.9.900.170 2013-12-11+19-57-47.263 ========
                      0000 [I] 00000010 FlashPlayerInstaller.exe -install -iv 11
                      0001 [I] 00000011 1
                      0003 [I] 00000013 C:\Windows\TEMP\{6B68004C-2A12-41F7-B983-3340BB81CFC1}\Flash32_11_9_900_170.ocx
                      0004 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe
                      0005 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe
                      0006 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.dll
                      0007 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                      0008 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0009 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0010 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0011 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0012 [W] 00001106
                      0013 [W] 00001106
                      0014 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0015 [I] 00000012
                      =X====== M/11.9.900.170 2013-12-11+19-58-07.748 ========
                      2013-12-11+20-41-48.988 [error] 1226 1062
                      =O====== M/11.9.900.170 2013-12-11+20-41-38.049 ========
                      0001 [I] 00000011 1
                      0012 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_152.dll 5
                      0013 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_152.dll 5
                      0014 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_152.exe 5
                      0015 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_152.exe 5
                      0016 [I] 00000014 C:\Windows\TEMP\{F2E5B4B6-96C1-497B-A521-FE17CFCD1080}\NPSWF32_11_9_900_170.dll
                      0017 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_Plugin.exe
                      0018 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_Plugin.exe
                      0019 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                      0020 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                      0021 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_170.exe
                      0022 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0023 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0024 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0025 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0026 [W] 00001106
                      0027 [W] 00001106
                      0028 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0029 [I] 00000012
                      =X====== M/11.9.900.170 2013-12-11+20-41-51.521 ========
                      2014-1-22+0-41-11.214 [error] 1221 1115
                      2014-2-5+13-59-43.649 [error] 1226 1062
                      =O====== M/12.0.0.44 2014-02-05+13-59-30.747 ========
                      0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/12.0 2
                      0002 [I] 00000011 1
                      0003 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0004 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_170.ocx 5
                      0005 [I] 00000018
                      0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_170.ocx 5
                      0007 [I] 00000013 C:\Windows\TEMP\{31D6582F-73B9-4C31-87B3-6F26465EE0ED}\Flash32_12_0_0_44.ocx
                      0008 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.exe
                      0009 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.exe
                      0010 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.dll
                      0011 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                      0012 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0013 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0014 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0015 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0016 [W] 00001106
                      0017 [W] 00001106
                      0018 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0019 [I] 00000012
                      =X====== M/12.0.0.44 2014-02-05+13-59-46.536 ========
                      2014-2-5+14-41-38.790 [error] 1226 1062
                      =O====== M/12.0.0.44 2014-02-05+14-41-35.467 ========
                      0001 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0002 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                      0003 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                      0004 [W] 00001036 Software\Mozilla\Mozilla Firefox 26.0\extensions/Plugins 2
                      0006 [W] 00001036 Software\Mozilla\Mozilla Thunderbird 24.2.0\extensions/Plugins 2
                      0012 [I] 00000014 C:\Windows\TEMP\{AC9F4D8A-F8EA-4AE4-B745-498164B66E67}\NPSWF32_12_0_0_44.dll
                      0013 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_Plugin.exe
                      0014 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_Plugin.exe
                      0015 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                      0016 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                      0017 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_44.exe
                      0018 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0019 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0020 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0021 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0022 [W] 00001106
                      0023 [W] 00001106
                      0024 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0025 [I] 00000012
                      =X====== M/12.0.0.44 2014-02-05+14-41-40.365 ========
                      =O====== M/12.0.0.44 2014-02-08+19-45-24.340 ========
                      0000 [I] 00000010 "C:\Users\Tom\AppData\Local\Adobe\AIH.2a77cd9fa5bc686aa75244c04985a9e93d07996c\install_fl ash_player.exe" -install -iv 10
                      0001 [F] 00001041
                      =X====== M/12.0.0.44 2014-02-08+19-45-25.640 ========
                      =O====== M/12.0.0.44 2014-02-08+19-46-30.340 ========
                      0001 [F] 00001041
                      =X====== M/12.0.0.44 2014-02-08+19-46-30.719 ========
                      =O====== M/12.0.0.44 2014-02-08+19-46-56.612 ========
                      0001 [I] 00000011 1
                      0005 [W] 00001036 Software\Mozilla\Mozilla Firefox 27.0\extensions/Plugins 2
                      0007 [W] 00001036 Software\Mozilla\Mozilla Thunderbird 24.3.0\extensions/Plugins 2
                      0008 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
                      0013 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_44.dll
                      0022 [W] 00001106
                      0023 [W] 00001106
                      0025 [I] 00000012
                      =X====== M/12.0.0.44 2014-02-08+19-47-06.774 ========
                      2014-2-21+16-17-11.703 [error] 1226 1062
                      =O====== M/12.0.0.70 2014-02-21+16-16-51.140 ========
                      0000 [I] 00000010 "C:\Users\Tom\AppData\Local\Temp\{7993A6F4-5DBE-4034-85CC-E59112033743}\InstallFlashPlaye r.exe" -iv 4
                      0001 [I] 00000011 1
                      0005 [W] 00001036 Software\Mozilla\Mozilla Firefox 27.0.1\extensions/Plugins 2
                      0013 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_Plugin.exe 5
                      0014 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_Plugin.exe 5
                      0015 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_70.dll
                      0016 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_Plugin.exe
                      0017 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                      0018 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                      0019 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_70.exe
                      0020 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0021 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0022 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0023 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0024 [W] 00001106
                      0025 [W] 00001106
                      0026 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0027 [I] 00000012
                      =X====== M/12.0.0.70 2014-02-21+16-17-18.567 ========
                      2014-2-21+16-42-16.825 [error] 1226 1062
                      =O====== M/12.0.0.70 2014-02-21+16-42-03.223 ========
                      0002 [I] 00000011 1
                      0004 [I] 00000013 C:\Windows\TEMP\{B128A8A3-31DE-470D-9AEC-931FF053D924}\Flash32_12_0_0_70.ocx
                      0005 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
                      0006 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
                      0007 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.dll
                      0013 [W] 00001106
                      0014 [W] 00001106
                      0016 [I] 00000012
                      =X====== M/12.0.0.70 2014-02-21+16-42-18.687 ========
                      2014-2-21+17-41-5.200 [error] 1221 1115
                      2014-3-11+18-57-59.89 [error] 1226 1062
                      =O====== M/12.0.0.77 2014-03-11+18-57-43.473 ========
                      0001 [I] 00000011 1
                      0003 [I] 00000013 C:\Windows\TEMP\{B68E51FE-629C-42DE-9766-AB731C575C2A}\Flash32_12_0_0_77.ocx
                      0004 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.exe
                      0005 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.exe
                      0006 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.dll
                      0012 [W] 00001106
                      0013 [W] 00001106
                      0015 [I] 00000012
                      =X====== M/12.0.0.77 2014-03-11+18-58-02.584 ========
                      2014-3-11+19-41-32.944 [error] 1226 1062
                      =O====== M/12.0.0.77 2014-03-11+19-41-24.842 ========
                      0001 [I] 00000011 1
                      0013 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_70.dll 5
                      0014 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_70.dll 5
                      0015 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_70.exe 5
                      0016 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_70.exe 5
                      0017 [I] 00000014 C:\Windows\TEMP\{57ECB675-63A2-40CC-B386-C1292A7261DB}\NPSWF32_12_0_0_77.dll
                      0018 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_77_Plugin.exe
                      0019 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_77_Plugin.exe
                      0020 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                      0021 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                      0022 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_77.exe
                      0023 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0024 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0025 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0026 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0027 [W] 00001106
                      0028 [W] 00001106
                      0029 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0030 [I] 00000012
                      =X====== M/12.0.0.77 2014-03-11+19-41-34.536 ========
                      =O====== M/13.0.0.182 2014-04-21+18-45-37.077 ========
                      0000 [I] 00000010 "C:\Users\Tom\AppData\Local\Adobe\AIH.84acd1325e70176f661641a370e54fb66c513944\install_fl ash_player.exe" -install -iv 8
                      0001 [I] 00000011 1
                      0005 [W] 00001036 Software\Mozilla\Mozilla Firefox 28.0\extensions/Plugins 2
                      0007 [W] 00001036 Software\Mozilla\Mozilla Thunderbird 24.4.0\extensions/Plugins 2
                      0013 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_77.dll 5
                      0014 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_77.dll 5
                      0015 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_77.exe 5
                      0016 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_77.exe 5
                      0017 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_13_0_0_182.dll
                      0018 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_182_Plugin.exe
                      0021 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_13_0_0_182.exe
                      0026 [W] 00001106
                      0027 [W] 00001106
                      0029 [I] 00000012
                      =X====== M/13.0.0.182 2014-04-21+18-45-49.316 ========
                      2014-4-29+16-44-32.606 [error] 1226 1062
                      =O====== M/13.0.0.206 2014-04-29+16-43-45.740 ========
                      0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/13.0 2
                      0002 [I] 00000011 1
                      0004 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_13_0_0_206.ocx
                      0005 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_206_ActiveX.exe
                      0006 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_206_ActiveX.dll
                      0012 [W] 00001106
                      0013 [W] 00001106
                      0015 [I] 00000012
                      =X====== M/13.0.0.206 2014-04-29+16-44-35.587 ========
                      2014-4-29+17-42-10.792 [error] 1226 1062
                      =O====== M/13.0.0.206 2014-04-29+17-42-00.857 ========
                      0001 [I] 00000011 1
                      0013 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_13_0_0_182.dll 5
                      0014 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_13_0_0_182.dll 5
                      0015 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_13_0_0_182.exe 5
                      0016 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_13_0_0_182.exe 5
                      0017 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_13_0_0_206.dll
                      0018 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_206_Plugin.exe
                      0021 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_13_0_0_206.exe
                      0026 [W] 00001106
                      0027 [W] 00001106
                      0029 [I] 00000012
                      =X====== M/13.0.0.206 2014-04-29+17-42-12.382 ========
                      2014-5-12+18-5-50.969 [error] 1223 1056
                      2014-5-13+18-42-25.196 [error] 1226 1062
                      =O====== M/13.0.0.214 2014-05-13+18-41-53.588 ========
                      0001 [I] 00000011 1
                      0003 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_13_0_0_214.ocx
                      0004 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_ActiveX.exe
                      0005 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_ActiveX.dll
                      0006 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                      0007 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0008 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0009 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0011 [W] 00001106
                      0012 [W] 00001106
                      0013 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0014 [I] 00000012
                      =X====== M/13.0.0.214 2014-05-13+18-42-27.675 ========
                      2014-5-13+19-42-9.823 [error] 1226 1062
                      =O====== M/13.0.0.214 2014-05-13+19-41-59.891 ========
                      0001 [I] 00000011 1
                      0005 [W] 00001036 Software\Mozilla\Mozilla Firefox 29.0.1\extensions/Plugins 2
                      0007 [W] 00001036 Software\Mozilla\Mozilla Thunderbird 24.5.0\extensions/Plugins 2
                      0013 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_13_0_0_214.dll
                      0014 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_Plugin.exe
                      0017 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_13_0_0_214.exe
                      0022 [W] 00001106
                      0023 [W] 00001106
                      0025 [I] 00000012
                      =X====== M/13.0.0.214 2014-05-13+19-42-10.993 ========
                      2014-5-27+1-59-7.535 [error] 1226 1062
                      =O====== M/13.0.0.214 2014-05-29+15-43-53.282 ========
                      0000 [I] 00000010 "C:\Users\Tom\Desktop\uninstall_flash_player.exe" -force
                      =X====== M/13.0.0.214 2014-05-29+15-44-43.096 ========
                      =O====== M/13.0.0.214 2014-05-29+15-44-51.162 ========
                      0001 [E] 00001039
                      =X====== M/13.0.0.214 2014-05-29+15-45-08.509 ========
                      =O====== M/13.0.0.214 2014-05-29+15-46-06.002 ========
                      0001 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                      0002 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                      0003 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                      0004 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                      0005 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                      0006 [W] 00001021
                      0007 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0008 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0009 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0010 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                      0011 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                      0012 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                      0013 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                      0014 [W] 00001021
                      0015 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0016 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0017 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0018 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0019 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
                      0020 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0021 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0022 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                      0023 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                      0024 [W] 00001036 Software\Mozilla\Mozilla Firefox 29.0.1\extensions/Plugins 2
                      0025 [W] 00001036 Software\Mozilla\Mozilla Thunderbird\extensions/Plugins 2
                      0026 [W] 00001036 Software\Mozilla\Mozilla Thunderbird 24.5.0\extensions/Plugins 2
                      0027 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
                      0028 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0029 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0030 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0031 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0032 [I] 00000011 1
                      =X====== M/13.0.0.214 2014-05-29+15-46-19.745 ========
                      =O====== M/13.0.0.214 2014-05-29+15-51-08.129 ========
                      0000 [I] 00000010 "C:\Users\Tom\Desktop\install_flash_player.exe FF.exe"
                      0003 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
                      0004 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0005 [I] 00000011 1
                      0006 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0007 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                      0008 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                      0009 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                      0010 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                      0011 [W] 00001036 Software\Mozilla\Mozilla Firefox 29.0.1\extensions/Plugins 2
                      0012 [W] 00001036 Software\Mozilla\Mozilla Thunderbird\extensions/Plugins 2
                      0013 [W] 00001036 Software\Mozilla\Mozilla Thunderbird 24.5.0\extensions/Plugins 2
                      0014 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
                      0015 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0016 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0017 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0018 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0019 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_13_0_0_214.dll
                      0020 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_Plugin.exe
                      0021 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                      0022 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                      0023 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_13_0_0_214.exe
                      0024 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      =X====== M/13.0.0.214 2014-05-29+15-54-25.647 ========
                      =O====== M/13.0.0.214 2014-05-29+15-56-38.529 ========
                      0000 [I] 00000010 "C:\Users\Tom\Desktop\install_flash_player_ax.exe IE.exe"
                      0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0003 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/13.0 2
                      0004 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0005 [I] 00000011 1
                      0007 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                      0008 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_13_0_0_214.ocx
                      0009 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_ActiveX.exe
                      0010 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_ActiveX.dll
                      0016 [W] 00001106
                      0017 [W] 00001106
                      =X====== M/13.0.0.214 2014-05-29+15-57-00.728 ========
                      =O====== M/13.0.0.214 2014-05-31+21-42-41.454 ========
                      0006 [W] 00001021
                      0014 [W] 00001021
                      0032 [I] 00000011 1
                      =X====== M/13.0.0.214 2014-05-31+21-43-05.493 ========
                      =O====== M/13.0.0.214 2014-05-31+21-43-27.599 ========
                      0005 [I] 00000011 1
                      0013 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      =X====== M/13.0.0.214 2014-05-31+21-43-50.142 ========
                      =O====== M/13.0.0.214 2014-05-31+21-45-19.553 ========
                      0003 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0005 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0006 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0007 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0008 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0009 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0010 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0011 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0012 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0013 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0014 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0015 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0017 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0019 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0020 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0022 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0023 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0024 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0025 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0026 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0027 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0028 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0029 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0030 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0031 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0032 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0033 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0034 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0035 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0036 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0037 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0038 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0039 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0040 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0041 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0042 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0043 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0044 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0045 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0046 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0047 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0048 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0049 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0050 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0051 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0052 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0053 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0054 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0055 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0056 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0057 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0058 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0059 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0060 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0061 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0062 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0063 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0064 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0065 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0066 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0067 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0068 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0069 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0070 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0071 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0072 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0073 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0074 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0075 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0076 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0077 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0078 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0079 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0080 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0081 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0082 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0083 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0084 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0085 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0086 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0087 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0088 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0089 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0090 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0091 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      =X====== M/13.0.0.214 2014-05-31+21-46-43.694 ========
                      =O====== M/13.0.0.214 2014-05-31+21-50-57.836 ========
                      0005 [I] 00000011 1
                      0025 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0026 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0027 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0028 [W] 00001106
                      0029 [W] 00001106
                      0030 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      =X====== M/13.0.0.214 2014-05-31+21-54-37.049 ========
                      =O====== M/13.0.0.214 2014-06-01+22-52-23.324 ========
                      0000 [I] 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_Plugin.exe"
                      =X====== M/13.0.0.214 2014-06-01+22-52-30.328 ========
                      =O====== M/13.0.0.214 2014-06-01+23-21-29.956 ========
                      =X====== M/13.0.0.214 2014-06-01+23-21-36.539 ========
                      =O====== M/13.0.0.214 2014-06-01+23-22-01.780 ========
                      0006 [W] 00001021
                      0014 [W] 00001021
                      0032 [I] 00000011 1
                      =X====== M/13.0.0.214 2014-06-01+23-22-16.007 ========
                      =O====== M/13.0.0.214 2014-06-01+23-47-53.357 ========
                      0000 [I] 00000010 "C:\Users\Tom\Downloads\install_flash_player.exe"
                      0005 [I] 00000011 1
                      =X====== M/13.0.0.214 2014-06-01+23-48-37.451 ========
                      =O====== M/13.0.0.214 2014-06-02+03-58-20.441 ========
                      0001 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0003 [W] 00001018
                      0004 [W] 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
                      0006 [W] 00001019
                      0007 [W] 00001020
                      0008 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                      0009 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                      0010 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                      0011 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                      0012 [W] 00001037 Software\Macromedia\FlashPlayerActiveXReleaseType/ 2
                      0013 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                      0014 [W] 00001021
                      0016 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0018 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                      0019 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                      0020 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                      0021 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                      0022 [W] 00001021
                      0023 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0025 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0027 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
                      0028 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0030 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                      0031 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                      0032 [W] 00001036 Software\Mozilla\Mozilla Firefox 29.0.1\extensions/Plugins 2
                      0033 [W] 00001036 Software\Mozilla\Mozilla Thunderbird\extensions/Plugins 2
                      0034 [W] 00001036 Software\Mozilla\Mozilla Thunderbird 24.5.0\extensions/Plugins 2
                      0035 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
                      0036 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0037 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0038 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0039 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0040 [I] 00000011 1
                      =X====== M/13.0.0.214 2014-06-02+04-00-07.599 ========
                      =O====== M/13.0.0.214 2014-06-02+04-15-24.141 ========
                      0005 [I] 00000011 1
                      =X====== M/13.0.0.214 2014-06-02+04-15-49.085 ========
                      =O====== M/13.0.0.214 2014-06-02+04-16-06.310 ========
                      0005 [I] 00000011 1
                      0016 [W] 00001106
                      0017 [W] 00001106
                      =X====== M/13.0.0.214 2014-06-02+04-16-27.588 ========
                      =O====== M/14.0.0.125 2014-06-17+15-18-49.267 ========
                      0000 [I] 00000010 "C:\Users\Tom\AppData\Local\Adobe\install_flash_player_ax.exe" -install -iv 10
                      0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/14.0 2
                      0002 [I] 00000011 1
                      0004 [I] 00000013
                      0005 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_125_ActiveX.exe
                      0006 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_125_ActiveX.dll
                      0012 [W] 00001106
                      0013 [W] 00001106
                      0015 [I] 00000012
                      =X====== M/14.0.0.125 2014-06-17+15-19-03.713 ========
                      =O====== M/13.0.0.214 2014-06-24+20-35-29.626 ========
                      0001 [I] 00000011 1
                      0011 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_13_0_0_214.dll
                      0012 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_Plugin.exe
                      0015 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_13_0_0_214.exe
                      0020 [W] 00001106
                      0021 [W] 00001106
                      =X====== M/13.0.0.214 2014-06-24+20-36-14.304 ========
                      =O====== M/13.0.0.214 2014-06-27+15-35-10.845 ========
                      0000 [I] 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_Plugin.exe" -maintain plugin
                      0001 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_Plugin.exe 5
                      0002 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_Plugin.exe 5
                      0003 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                      0004 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                      0005 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                      0006 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                      0007 [W] 00001021
                      0011 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                      0012 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                      0013 [W] 00001036 Software\Mozilla\Mozilla Thunderbird\extensions/Plugins 2
                      0019 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_Plugin.exe 5
                      0020 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_214_Plugin.exe 5
                      0021 [I] 00000011 1
                      0022 [I] 00000012
                      =X====== M/13.0.0.214 2014-06-27+15-35-22.061 ========
                      =O====== M/14.0.0.125 2014-06-28+03-48-08.802 ========
                      0000 [I] 00000010 "C:\Users\Tom\AppData\Local\Temp\fp_pl_pfs_installer.exe"
                      0005 [I] 00000011 1
                      0011 [W] 00001036 Software\Mozilla\Mozilla Thunderbird\extensions/Plugins 2
                      0012 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
                      0013 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0014 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0015 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0016 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0017 [I] 00000014
                      0018 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_125_Plugin.exe
                      0021 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_14_0_0_125.exe
                      0026 [W] 00001106
                      0027 [W] 00001106
                      0029 [I] 00000012
                      =X====== M/14.0.0.125 2014-06-28+03-48-30.533 ========
                      2014-7-8+22-6-31.567 [error] 1226 1062
                      =O====== M/14.0.0.145 2014-07-08+22-06-21.849 ========
                      0001 [I] 00000011 1
                      0003 [I] 00000013
                      0004 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.exe
                      0005 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.exe
                      0006 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.dll
                      0012 [W] 00001106
                      0013 [W] 00001106
                      0015 [I] 00000012
                      =X====== M/14.0.0.145 2014-07-08+22-06-34.578 ========
                      2014-7-8+23-6-27.531 [error] 1226 1062
                      =O====== M/14.0.0.145 2014-07-08+23-06-22.258 ========
                      0001 [I] 00000011 1
                      0011 [I] 00000014
                      0012 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_Plugin.exe
                      0013 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_Plugin.exe
                      0014 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                      0015 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                      0016 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_14_0_0_145.exe
                      0017 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0018 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                      0019 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                      0020 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                      0021 [W] 00001106
                      0022 [W] 00001106
                      0023 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0024 [I] 00000012
                      =X====== M/14.0.0.145 2014-07-08+23-06-28.888 ========
                      =O====== M/14.0.0.179 2014-08-17+20-56-08.535 ========
                      0000 [I] 00000010 "C:\Users\Tom\AppData\Local\Adobe\install_flash_player.exe" -install -iv 10
                      0001 [I] 00000011 1
                      0006 [W] 00001036 Software\Mozilla\Mozilla Thunderbird 24.6.0\extensions/Plugins 2
                      0012 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_14_0_0_145.dll 5
                      0013 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_14_0_0_145.dll 5
                      0014 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_14_0_0_145.exe 5
                      0015 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_14_0_0_145.exe 5
                      0016 [I] 00000014
                      0017 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_179_Plugin.exe
                      0020 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_14_0_0_179.exe
                      0025 [W] 00001106
                      0026 [W] 00001106
                      0028 [I] 00000012
                      =X====== M/14.0.0.179 2014-08-17+20-56-21.460 ========
                      2014-8-30+19-46-18.652 [error] 1226 1062
                      =O====== M/14.0.0.145 2014-08-30+19-41-12.531 ========
                      0000 [I] 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.exe"
                      0001 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0002 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0003 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0004 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0005 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0006 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0007 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0008 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0009 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0010 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0011 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0012 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0013 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0014 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0015 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0016 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0017 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0018 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0019 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0020 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0021 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0022 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0023 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0024 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0025 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0026 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0027 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0028 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0029 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0030 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0031 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0032 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0033 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0034 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0035 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0036 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0037 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0038 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0039 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0040 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0041 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0042 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.exe 5
                      0043 [I] 00000018
                      0044 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.exe 5
                      0045 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.dll 5
                      0046 [I] 00000018
                      0047 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.dll 5
                      0048 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                      0049 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                      0050 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                      0051 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                      0052 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                      0053 [W] 00001021
                      0054 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0055 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0056 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0057 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0058 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0059 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                      0060 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                      0061 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                      0062 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                      0063 [W] 00001021
                      0064 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0066 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0067 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0069 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0070 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
                      0071 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0073 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0074 [W] 00001018
                      0075 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Pepper/ 2
                      0076 [W] 00001019
                      0077 [W] 00001020
                      0078 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                      0079 [W] 00001037 Software\Macromedia\FlashPlayerPepper/ 2
                      0080 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                      0081 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                      0082 [W] 00001037 Software\Macromedia\FlashPlayerPepperReleaseType/ 2
                      0083 [W] 00001021
                      0084 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0086 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0087 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
                      0088 [W] 00001048
                      0089 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0090 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0092 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0093 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashPlayerApp.exe/ 2
                      0094 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
                      0095 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0096 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0097 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                      0098 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                      0099 [W] 00001036 Software\Mozilla\Mozilla Thunderbird\extensions/Plugins 2
                      0100 [W] 00001036 Software\Mozilla\Mozilla Thunderbird 24.6.0\extensions/Plugins 2
                      0101 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
                      0102 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0103 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0104 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0105 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0106 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.dll 5
                      0107 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.dll 5
                      0108 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.exe 5
                      0109 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.exe 5
                      0110 [I] 00000011 1
                      =X====== M/14.0.0.145 2014-08-30+19-46-28.293 ========
                      =O====== M/14.0.0.176 2014-08-30+20-14-55.145 ========
                      0000 [I] 00000010 "C:\Users\Tom\AppData\Local\Adobe\install_flash_player_ax.exe" -install -iv 8 -au 0
                      0003 [I] 00000011 1
                      0006 [I] 00000013
                      0007 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_176_ActiveX.exe
                      0008 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_14_0_0_176_ActiveX.dll
                      0009 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                      0010 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                      0012 [I] 00000012
                      =X====== M/14.0.0.176 2014-08-30+20-15-03.108 ========
                      • 8. Re: Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
                        pwillener Level 8
                        There are indeed some errors showing in the log file.  Can you try a clean install as described in https://forums.adobe.com/thread/928315
                        You will have to reinstall both ActiveX and plugin.
                        • 9. Re: Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
                          I attempted a clean install, by uninstalling all Flash Player files first. The mms.cfg file is supposed to be opened, revealing the " %appdata%" files,  the system32/Macromed/Flash file(s), and the sysWow64/Adobe/Flash files that also should be deleted, as per Adobe instructions. The computer will not open this file, per se, instead, shows me a dialog box with a list of applications that I must choose from, to open the file. I chose to use Acrobat Reader, but the PC tells me that Reader cannot do the job for some reason, and from that point, the necessary steps get so detailed and complicated that I don't understand them. I am not very astute with such procedures, and do try to play it by ear as best I can, but this is beyond me, unless an expert is willing to help.
                          Also, there was an .ocx file left behind after I deleted everything else, and I am being told that I must have Administrator's permission to delete it, and successfully navigating through these steps have proven to be too elusive as well.
                          Call me plain old stupid, but I am, so far, unable to go forward with a clean install, until these issues have been resolved. I am going to have another look to see if there is anything further that I might be "savvy" enough to do to get me started, but I am not etching that in stone.
                          If it is at all possible, ANY assistance would be welcomed, to say the least.
                          • 10. Re: Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
                            maria__ Adobe Employee
                            Hello,
                            Regarding "The mms.cfg file is supposed to be opened, revealing the " %appdata%" files,  the system32/Macromed/Flash file(s), and the sysWow64/Adobe/Flash files that also should be deleted, as per Adobe instructions"  What instructions indicate this?  Please provide the URL to where you got this information.  The mms.cfg file contains some configuration information for the Flash Player that the player writes to during install/uninstall.  It is not opened to be viewed by the user during install/uninstall, and it doesn't list files that should be deleted.
                            If you have run the uninstaller and some files remain, they may have been in use during a previous upgrade/install.  If so, these files will be marked (in the registry) for deletion upon system reboot.  If the files remain after a reboot, or you're not able to remove them manually as a user with Administrative permissions, then the permissions on the file may have become corrupt.
                            Please ensure no programs are open, run the uninstaller and reboot your machine.  This should remove all Flash Player files.
                            Maria
                            • 11. Re: Why did FP14.0.0.179, Active X, install for IE11, but not the FP plugin for "all other browsers"?
                              pwillener Level 8
                              You should not need to open these files, just delete them.  (Yes, using an Administrator account.)
