10 Replies Latest reply on Apr 18, 2007 8:20 AM by Newsgroup_User
    Fade in/out to stage
    Level 7
      Hello:
      Is possible to make a nice fade out/in to the stage when change the movie?
      Some samples or demo?
      thank you very much
        • 1. Re: Fade in/out to stage
          Level 7
          I've had luck taking a screen shot of your opening screen in the second
          movie, creating a bitmap with it in the first movie and fade into that just
          before navigating into the next movie. Then when you do navigate, assuming
          the stage size and location are the same, it should be seamless.
          Craig
          Craig Wollman
          Lingo Specialist
          Word of Mouth Productions
          212-928-9581
          www.wordofmouthpros.com
          "Anne" <anmalo42@lycos.es> wrote in message
          news:f00c8v$dr7$1@forums.macromedia.com...
          > Hello:
          > thank you very much
          • 2. Re: Fade in/out to stage
            Level 7
            Thank you:
            but how to get a screen shot and put in a sprite (or catmember)?
            "forum.macromedia.com" <lingoboy@wordofmo.com> escribió en el mensaje
            news:f00f9l$hin$1@forums.macromedia.com...
            > just before navigating into the next movie. Then when you do navigate,
            > assuming the stage size and location are the same, it should be seamless.
            > Craig
            > Craig Wollman
            > Lingo Specialist
            > 212-928-9581
            >> Hello:
            >> movie?
            >> thank you very much
            • 3. Re: Fade in/out to stage
              Level 7
              go to your message window and type
              scr = (the stage).image
              newMember = new (#bitmap, member (x, y)
              -- where x = an empty cast member and y is that members cast lib number or
              name
              newMember.image = scr
              This should create a new cast member with a shot of the stage.
              Craig Wollman
              Lingo Specialist
              212-928-9581
              news:f00i1n$l17$1@forums.macromedia.com...
              > Thank you:
              >> Craig
              >> Craig Wollman
              >> Lingo Specialist
              >> 212-928-9581
              >>> Hello:
              >>> movie?
              >>> thank you very much
              • 4. Re: Fade in/out to stage
                James Newton, ACP Level 3
                Here's a very simple behavior. Attach it to a bitmap sprite. It will fade from the previous screen to the current screen over 30 frames.
                • 5. Re: Fade in/out to stage
                  Level 7
                  I think you forgot the part about changing to another movie.
                  Craig Wollman
                  Lingo Specialist
                  212-928-9581
                  "openspark" <webforumsuser@macromedia.com> wrote in message
                  news:f019i1$j0a$1@forums.macromedia.com...
                  > fade
                  > -- SIMPLEST DISSOLVE TRANSITION --
                  > property mySprite
                  > property myFrame
                  > on beginSprite(me)
                  > mySprite = sprite(me.spriteNum)
                  > -- Grab the image of the previous frame
                  > stageImage = (the stage).image
                  > -- Crop the image to the size of this sprite
                  > stageImage = stageImage.crop(mySprite.rect)
                  > -- Show image of previous frame in this sprite
                  > mySprite.member.image = stageImage
                  > -- Start countdown
                  > myFrame = 30
                  > end beginSprite
                  > on exitFrame(me)
                  > if myFrame then
                  > -- Reduce the opacity of this sprite
                  > myFrame = myFrame - 1
                  > mySprite.blendLevel = (255 / 30) * myFrame
                  > end if
                  > end exitFrame
                  • 6. Re: Fade in/out to stage
                    Level 7
                    Thank you very much:
                    Is possible to make any more nice effect with, for example imaging lingo, to
                    change the stage when change the movie?
                    Thank you again.
                    • 7. Re: Fade in/out to stage
                      Level 7
                      sure, you can duplicate pretty much any of director's transitions and others
                      if you're creative. Some require trigonometry to code. I have created a
                      handful of transitions that work on exitFrame or stepFrame. The advantage
                      is that you don't lose all interactivity during the transition as you do
                      when you use Director's built in transitions.
                      If you search Goolge, you'll find code.
                      Craig Wollman
                      Lingo Specialist
                      212-928-9581
                      news:f01p8t$676$1@forums.macromedia.com...
                      > to change the stage when change the movie?
                      > Thank you again.
                      • 8. Re: Fade in/out to stage
                        Level 7
                        Thank you again:
                        But what exactly do I have to search in google?
                        Many many thanks
                        • 9. Re: Fade in/out to stage
                          Level 7
                          now give me your hand...;)
                          Something like,
                          lingo imaging transitions
                          Or add a more specific transition name to the search like "wipe"
                          Craig Wollman
                          Lingo Specialist
                          212-928-9581
                          news:f02km2$a81$1@forums.macromedia.com...
                          > Thank you again:
                          > Many many thanks
                          • 10. Re: Fade in/out to stage
                            Level 7
                            I need two things with SIMPLEST DISSOLVE TRANSITION .-
                            1.- Wait in the frame until the transition was happend.
                            2.- I need to go slow with the transition (speed).
                            Can you help me please?
                            Many many thanks
