4 Replies Latest reply on Oct 23, 2014 6:01 AM by 134gs
    Logging in with multiple CC accounts, personal and enterprise
      I need to be logged in to two CC accounts with two different email addresses at once, one is my preexisting personal and the other is a new enterprise.
      One is used for Typekit only (personal) and one is used for programs (enterprise). Despite me using Typekit this is not a Typekit issue regardless of what Adobe support says, it is a login issue with the CC manager software although anybody with whom I chat (I cannot get someone on the phone) cannot see how that is the case and tries to pass off the issue to Typekit support.
      I need access to both at all times. I was initially told by an Adobe chat rep that since the apps do not need a constant connection to the Internet to work (offline grace period) I could login to my enterprise, establish the license, log out, work as normal, and only need to log in to establish a license before the grace period ends. That I learned is not the case. Although it seems like a logical solution since if the program does not need to be connected to the Adobe servers it should not need to be logged in at all.
      I thought for a brief period of time that I resolved the issue. Yesterday I was on on with both accounts for a while by logging in to my CC manager with my personal and into the application with my enterprise. but when I turned on my computer today I was logged into my CC manager with my enterprise account and all my fonts were missing when I logged back in correctly to my CC manager I was no longer logged into my programs.
      This would be less of a hassle on a regular basis if it kicked me out of the Enterprise in the applications and I only had to log back into one account on a regular basis, not two.
      I either need to connect my enterprise so that I can be logged in with my personal, install the CC manager twice, or make it so my applications do not need to be constantly connected online.
      I also tried and failed changing my enterprise email to match my personal one, which needs to be the controlling account.
      Please if anybody has found a solution to this problem let me know. Thanks in advance.
        • 1. Re: Logging in with multiple CC accounts, personal and enterprise
          Scott V Adobe Employee (Admin)
          Since you do have the Educational Creative Cloud subscription which included the Typekit fonts. Do you need to have the additional Typekit subscription?
          You can try step 2 of this doc to help reset the Creative Cloud app manager. Sign out first before removing the OPM.DB
          http://helpx.adobe.com/creative-cloud/kb/creative-cloud-application-recognizing-available. html
          Then sign back in and you should see the fonts listed.
          • 2. Re: Logging in with multiple CC accounts, personal and enterprise
            digitalproducer Level 1
            Scott -
            You would know from Twitter that I need to keep Typekit under the @gmail
            account not recreate it under the @email. account.
            This is what I was saying about needing a single high-level tech to whom I
            can speak and nobody so far understating the problem. These points have
            again been demonstrated.
            I have kits created and that code in websites that would need to be changed
            if I change Typekit accounts, not to mention the time that would have to go
            into doing all of that. I should just be able to login to cloud manager
            with one (gmail/personal) and apps with the edu (@email.). If that is not
            the case I must be able to manage everything under my EXISTING @gmail
            Please see my initial forum post https://t.co/XVPqvyictQ for details
            • 3. Re: Logging in with multiple CC accounts, personal and enterprise
              I do see your point of wanting to have a separate account for your kits that you created.
              You are not able to have two version of the Creative Cloud application manager installed on the computer.
              When you sign out of your Educational subscription and sign in with your Typekit Adobe ID, it is a different profile as you know.
              Switching back and forth could of caused corrupt data for the Creative Cloud app with signing out as it would remove fonts synced with Typekit.
              Removing the OPM.DB file will help reset the CC app manager and you should see your fonts when you log in with your Educational CC subscription.
              You can still log in to the Adobe Typekit Webpage with your Gmail Adobe ID,  while being logged in to the CC app manager with your Educational subscription. That is thru a web session
              When you sign out of the CC app manager for the Educational paid subscription, you deactivate the software session. You would be prompted to sign in to use the software when launched. That is why you are not able to use the software while being signed with your Gmail Adobe ID. It is not associated with the subscription. Can you try adding the fonts that you need from the Gmail ID to the EDU subscription? You should be able to add the kits and have the same fonts for both accounts. I know you mention that you want to keep the accounts separate, as I was thinking that would be less frustrating for you.
              • 4. Re: Logging in with multiple CC accounts, personal and enterprise
                I would also like to know how to handle this.  We have a similar situation in that we have an educational enterprise license deployed to multiple departments.  Then we have a single department (8 users) that need to use TypeKit for font syncing.
                I have talked to my regional rep, an enterprise level Typekit manager, and enterprise support.  I've gotten three different answers from three different individuals.
                The situation is simply this:
                Applications should be licensed under our enterprise account
                TypeKit should be licensed under 8 "sub accounts" or personal accounts.
                We should then be able to use our applications under our enterprise license, but use the personal subscription of Typekit to sync fonts.
                I would also like to talk to a high level tech that understands how Typekit works with enterprise education licenses.  I've been trying to resolve this for weeks now.  Yesterday, I was on hold waiting for enterprise level support for three and a half hours.
