1 Reply Latest reply on Sep 1, 2014 8:38 AM by Apollo102
    Doc Import Param to suppress XML import validation message
    tracey.orso Level 1
      I'm running a script where the first part is to import an xml document, then to make some changes to the imported xml.
      Problem is, the xml may not always be valid. If it isn't I would like to still make the changes regardless.
      Unfortunately, my code is not running as I end up with "Validation of XML file failed. Continue? " prompt.
      Can I somehow suppress this ?  or is there a way to send the OK key hit - so my code can just continue without requiring any user interaction ?
      var importParams = GetImportDefaultParams();
                               i=GetPropIndex(importParams,Constants.FS_ImportAsType);
                              importParams[i].propVal.ival=Constants.FV_TYPE_XML;
                               i=GetPropIndex(importParams,Constants.FS_FileIsXmlDoc);
                              importParams[i].propVal.ival=Constants.FV_DoOK;
                              i=GetPropIndex(importParams,Constants.FS_AlertUserAboutFailure);
                              importParams[i].propVal.ival=0;
                               i=GetPropIndex(importParams,Constants.FS_DontNotifyAPIClients);
                              importParams[i].propVal.ival=1;
                             // var importParams = GetImportDefaultParams();
                              i=GetPropIndex(importParams,Constants.FS_HowToImport);
                              importParams[i].propVal.ival=Constants.FV_DoByCopy;
                              var returnParams = new PropVals() ;
                      alert("importing");
                              doc.Import (doc.TextSelection.end , filename, importParams, returnParams);
                   app.ActiveDoc = doc;
      do_something_else();
      thanks!
      Tracey
