3 Replies Latest reply on Sep 1, 2014 4:25 PM by theRightStoph
    Change character color according to a condition
    theRightStoph
      Hi there,
      I'm working on a list that contains color coded page numbers and letters (ie. A1...T17...Z8) and each of these need to be color coded according to the letter. The order is random so I want to be able to set either "Find/Change" or "Paragraph/Character Styles" to go through the list and apply a color. For instance, go through the list and all of the "z#" are red (z1, z2 ,z8 -->red, B1, B8, B5 -->Blue). Because they're not in order I would like to search the list, find the letter and change both the number and letter to a color I specify.  Is this possible? Would I have to create a GREP style or something?  Any help would be hugely appreciated, I'm not even sure where to begin. This seem like a macro that would be highly useful to people.  If I could think of an if statement it would be something like ...Search the list --> if "A(and any number)" are present --> Change the color to "Whatever I specify"
      Thank you so much in advance.
        • 1. Re: Change character color according to a condition
          Obi-wan Kenobi Level 5
          26 lettres… 26 Grep styles as:
          A\d+
          Red
          B\d+
          Blue
          C\d+
          Green
          D\d+
          Orange
          • 2. Re: Change character color according to a condition
            If you want the list to be automatically updated as you edit, Obi-wan's 27 grep styles along with 27 swatches is the way to go.
            You could also do it with a script which would require less setup—the grep approach would need a paragraph style with 27 grep rules linked to 27 character styles using 27 swatches.
            This AppleScript (OSX only) picks up the first character of the paragraph and colors the paragraph text with a swatch named the same. So this short example uses uppercase A, B, C named swatches to color corresponding paragraphs starting with the same letter:
            tell application "Adobe InDesign CS6"
                --make sure there's a selection and get the text and its frame
                try
                    set c to {insertion point, character, word, line, paragraph}
                    if class of selection is in c then
                        set t to parent of selection
                    else if class of selection is text frame then
                        set t to parent story of selection
                    end if
                on error
                    display dialog "Please select some text"
                    return
                end try
                --get all of the story paragraphs
                set p to object reference of every paragraph of t
                --color each paragraph with the swatch that's named with the paragraph's first letter
                repeat with x in p
                    set c to character 1 of x as string
                    set s to (every swatch of active document whose name is c)
                    try
                        set fill color of every character of x to item 1 of s
                    end try
                end repeat
            end tell
            • 3. Re: Change character color according to a condition
              theRightStoph Level 1
              Thank you guys sooooo much, this is exactly what I was after! Perfect.
