• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CF10 Data Source: is value in Driver Class required?
Guest
Sep 01, 2014 Sep 01, 2014
I'm trying to upgrade my SQL Anywhere database server from 10 to 16
I want to use the newer JDBC connection
( My database runs on a different machine/server than the CF server )
On my test system
Server Product    ColdFusion
Version    ColdFusion 10,282462
Edition    Developer
Operating System    Windows 2003   Standard Service Pack 2
OS Version    5.2
Update Level    /C:/ColdFusion10/cfusion/lib/updates/chf10000002.jar
Adobe Driver Version    4.1 (Build 0001)
Data sources using the old jdbc-odbc bridge driver work
CF data source name: -> demo
JDBC URL ->jdbc:ianywhere:driver=SQL Anywhere 10;dbn=demo;links=tcpip
(HOST=xx.0.0.xx;PORT=2620);eng=demo16
Driver Class -> ianywhere.ml.jdbcodbc.jdbc3.IDriver
Driver Name -> SQL Anywhere 10
User Name ->  dba
Password -> sql
(with, as you might expect, numeric values in place of xx)
In order for these to work I needed
dbjodbc10.dll and jodbc.jar in C:\ColdFusion10\cfusion\lib  ( Actually to be honest, I apparently installed a copy of Sybase Anywhere 10 on my web server out of desperation the last time I tried an upgrade so these are in that folder as well and I set CF classpath on the JVM  page -> "C:\Program Files\SQL Anywhere 10\java")
the new driver components are sajdbc4.jar and dbjdbc16.dll  so I put them in the same place
and SAP/Sybase/SQL Anywhere says that it does NOT use a driver name value
JDBC URL ->jdbc:ianywhere:dbn=demo;links=tcpip
Driver Class ->
Driver Name -> SQL Anywhere 16
User Name ->  dba
Password -> sql
Connection verification failed for data source: demo
java.sql.SQLException: No suitable driver available for demo, please
check the driver setting in resources file,
I'm wondering if CF10 (and for that matter CF8 which my production machine is running) require Driver Class to be filled in.
Any clues?  and  What resources file ?
Views
485
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Sep 02, 2014 Sep 02, 2014
I think your JDBC URL should be jdbc:sqlanywhere and not jdbc:ianywhere.
--J
Votes
Translate
Translate
Report
Report
Guest
LATEST
You are certainly correct.. careless of me.
I also just applied hotfix 12  so I'm now at CF10, 286680
but alas, no better result
Votes
Translate
Translate
Report
Report
Resources
Documentation
