4 Replies Latest reply on Sep 2, 2014 4:07 AM by Peter Spier
    Selection tool in InDesign doesn't proportionally resize an object, object is distorted.
    Level 1
      When I click the selection tool in InDesign, the object's frame is highlighted but the diagonal arrows that normally appear at the corners are no longer there.  When I click shift/command and then try and drag the corner, the object distorts.  Also, the object's "grabber" no longer appears in the middle of the frame.  This just started to happen.  What is the solution?  Sounds like discarding preferences doesn't do the trick.
