11 Replies Latest reply on Jul 1, 2015 3:29 AM by Anit_Kumar
    Coldfusion 11 Developer wont work after local machine restart
    AB4260
      I'm brand new to CF.  I've installed CF 11 Developer & attached to IIS.  I'm on a windows 7 machine.  Every time I have to restart my machine for whatever reason, the CF Administrator wont work, nor will any CFM page work.  I have to completely uninstall CF11 & then reinstall it in order for it to work again.  Any ideas or suggestions as to what might be causing this behavior?  Below is the error message I receive when I try to hit CF Administrator:
      HTTP Status 500 - ROOT CAUSE:
      type Exception report
      message ROOT CAUSE:
      description The server encountered an internal error that prevented it from fulfilling this request.
      exception
      javax.servlet.ServletException: ROOT CAUSE: coldfusion.server.ServiceFactory$ServiceNotAvailableException: The Monitoring service is not available. at coldfusion.server.ServiceFactory.getMonitoringService(ServiceFactory.java:223) at coldfusion.CfmServlet.service(CfmServlet.java:199) at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42) at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at coldfusion.inspect.weinre.MobileDeviceDomInspectionFilter.doFilter(MobileDeviceDomInspectionFilter.java:121) at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:422) at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:198) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:313) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source)  coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:70) coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46) coldfusion.inspect.weinre.MobileDeviceDomInspectionFilter.doFilter(MobileDeviceDomInspectionFilter.java:121) coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
      note The full stack trace of the root cause is available in the Apache Tomcat/7.0.52 logs.
