1. Re: 17 small videos to make a dvd in Encore need settings help please
Soshman Sep 2, 2014 2:45 PM (in response to Soshman) -
2. Re: 17 small videos to make a dvd in Encore need settings help please
Ann Bens Sep 2, 2014 2:50 PM (in response to Soshman)Your source is lower, so keep it lower fields. Just pick a preset and you will be ok.
After exporting (hit queue) you will have two files, one for audio and one for video. Import those two in Encore.
Make menu and burn.
3. Re: 17 small videos to make a dvd in Encore need settings help please
Soshman Sep 2, 2014 2:56 PM (in response to Ann Bens)Thanks Ann!
So you mean my field order i should change to lower instead of progressive. I should always keep the output the same as the source?
Also my Audio was PCM and i changed it to dolby. ZFor some reason i seem to remember having issues with PCM in the past. Is this ok as well
Thanks again :-)
Mark
4. Re: 17 small videos to make a dvd in Encore need settings help please
Soshman Sep 2, 2014 2:58 PM (in response to Soshman)PS i was going to make a cd out of the audio part of the videos.
I forgot that mpeg-dvd makes an audio and a video
Would i be able to use those audios on a track and export them into a .wav or .mp3 file for a CD?
5. Re: 17 small videos to make a dvd in Encore need settings help please
Ann Bens Sep 2, 2014 2:58 PM (in response to Soshman)Yes lower.
Keep it pcm and let Encore transcode it to Dolby.
6. Re: 17 small videos to make a dvd in Encore need settings help please
Soshman Sep 2, 2014 3:18 PM (in response to Ann Bens)Thanks so much for the quick response Ann!
I am on # 5 already :-)
Cheers!
7. Re: 17 small videos to make a dvd in Encore need settings help please
Soshman Sep 2, 2014 3:24 PM (in response to Ann Bens)so i just found a few of the videos that are progressive...should i change them from lower to progressive?
