18 Replies Latest reply on Sep 3, 2014 9:20 AM by ImageLink
    Double-Sided Name Badges ...
    ImageLink
      How do I import a multi-page PDF document in InDesign and then Duplicate each page in order to output double-sided SAME image ?
        • 1. Re: Double-Sided Name Badges ...
          BobLevine MVP & Adobe Community Professional
          That won’t work. Simply printing the same thing on two sides of the paper will not give you the same imprint on both sides.
          Try it. You’ll see.
          • 2. Re: Double-Sided Name Badges ...
            ImageLink Level 1
            Hey Bob, let me know if you get this email?
            JIM
            • 3. Re: Double-Sided Name Badges ...
              Your response went through on the forums.
              • 4. Re: Double-Sided Name Badges ...
                ImageLink Level 1
                So the client gives us a 400 page PDF file and each page is variable with a unique Name and a unique Barcode on it for a set of 400 name badges.
                What we need do now is to turn it into a 800 page document where every 2 pages is the same name and barcode.
                Then send it to the rip and have it print 15up on a 13x19 sheet size and end up with 400 double sided badges.
                Any thoughts on how to autotmatically duplicate each of the 400 pages in order?
                Let me know.
                JIM
                • 5. Re: Double-Sided Name Badges ...
                  It would be a lot simple to set up to print two adjacent copies on one side of the sheet, then cut and fold.
                  • 6. Re: Double-Sided Name Badges ...
                    ImageLink Level 1
                    Yeah but the final product is Laminated, 10mil, flush cut and a slot hole to hang from a neckband
                    Good brainstorming though.
                    • 7. Re: Double-Sided Name Badges ...
                      We don't know what you don't tell us...;)
                      I think you need a pro-level imposition tool for this one, not ID.
                      • 8. Re: Double-Sided Name Badges ...
                        There's a sample script that comes with ID, that places multi-page PDFs. It would be fairly easy to adjust the example to place the pages twice. So the ApplScript version would be (run the script and choose the PDF with pages to place):
                        set myPDF to choose file "Select a PDF file to place"
                        tell application "Adobe InDesign CS6"
                            set myDocument to make document
                            my myPlacePDF(myDocument, page 1 of myDocument, myPDF)
                        end tell
                        --places each page of the pdf on a new page and duplicates
                        on myPlacePDF(myDocument, myPage, myPDF)
                                set myDone to false
                                set PDF crop of PDF place preferences to crop media
                                --a counter for pdf page count
                                set myCounter to 1
                                repeat until myDone is true
                                    tell myDocument
                                        if myCounter > 1 then
                                            set myPage to make page at after myPage
                                        end if
                                    end tell
                                    set page number of PDF place preferences to myCounter
                                    --place the pdf page
                                    tell myPage
                                        set myPDFPage to place myPDF
                                        set myPDFPage to item 1 of myPDFPage
                                    end tell
                                    --if it's page 1 adjust the document to the PDF page dimensions
                                    if myCounter = 1 then
                                        set myFirstPage to page number of PDF attributes of myPDFPage
                                        set {a, b, c, d} to geometric bounds of parent of myPDFPage
                                        set properties of document preferences of myDocument to {facing pages:false, page width:d, page height:c}
                                        --reset the first PDF position
                                        set geometric bounds of parent of myPDFPage to {a, b, c, d}
                                        set geometric bounds of myPDFPage to {a, b, c, d}
                                    else
                                        --if the PDF page number is back to 1 clean up
                                        if page number of PDF attributes of myPDFPage = myFirstPage then
                                            tell myPage to delete
                                            set myDone to true
                                        end if
                                    end if
                                    --duplicates the placed page, gives 1,1,2,2,3,3 etc
                                    try
                                        tell myPage to duplicate to before myPage
                                    end try
                                    set myCounter to myCounter + 1
                                end repeat
                            end tell
                        end myPlacePDF
                        • 9. Re: Double-Sided Name Badges ...
                          That would be fine for 1-up, but the OP wants to print 15-up back to back the same content....
                          • 10. Re: Double-Sided Name Badges ...
                            Do any of you know if Quite Imposing is able to handle this direct from the PDF?
                            • 11. Re: Double-Sided Name Badges ...
                              ImageLink Level 1
                              Hey Rob, we are def going to try this in the morning.
                              Thanks for Brainstorming with us, it is greatly appreciated.
                              JIM
                              • 12. Re: Double-Sided Name Badges ...
                                ImageLink Level 1
                                The rip software will handle the imposition so we will send it to the rip as an 800page file, 1up on the 13x19.
                                • 13. Re: Double-Sided Name Badges ...
                                  If the RIP can impose it, just impose the PDF. You don't need ID for this...
                                  • 14. Re: Double-Sided Name Badges ...
                                    Bo LeBeau Level 4
                                    I did something similar in Quite Imposing years ago with flash cards that had front & back info and also needed to be set multiple up per sheet.
                                    Couldn't tell the exact procedure, but I remember splitting the master file into an even pages only file and an odd pages only file..
                                    Also the reading direction reversed from front to back so the correct back of the card printed on the correct front.
                                    Doing multiple ups of these are possible but its been years ago . . . .
                                    • 15. Re: Double-Sided Name Badges ...
                                      ImageLink Level 1
                                      I guess we were using indesign to make the double pages.
                                      I wonder if we could just do that in acrobat?
                                      • 16. Re: Double-Sided Name Badges ...
                                        You do it with your imposition module, just as you would impose any other PDF into a booklet or whathaveyou.
                                        Quite Imposing is a relatively inexpensive add-on imposition module for Acrobat, but you don't need it if you already have imposition software, and it sounds like you do. Who handles prepress in your company?
                                        • 17. Re: Double-Sided Name Badges ...
                                          ImageLink Level 1
                                          I will have John check that out.
                                          It has been years since we had impo software.
                                          You have been very helpful, thanks
                                          JIM
                                          • 18. Re: Double-Sided Name Badges ...
                                            ImageLink Level 1
                                            A final update and huge thanks to all that pitched in advice and comments.
                                            Rob Day was the winner, we did this suggestion this morning and it worked perfect and lightning fast.
                                            Thanks Again!
                                            JIM Thompson
                                            ImageLink
