6 Replies Latest reply on Sep 2, 2014 10:36 PM by VeluVK
    Distribute column
    VeluVK Level 1
      Anyone having script for the below requirement:
      For all tables, from second column onwards distribute the column width into "6p" (first column width variable). and also tables need to be fit (100%) with in the text margin.
      Regards,
      Velu
        • 1. Re: Distribute column
          Chinnadk Level 4
          Hi Velu,
          Try this,
          var doc = app.activeDocument;
          doc.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.picas;
          doc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.picas;
          for(var i =app.selection[0].columns.length-1;i>0;i--)
                  app.selection[0].columns[i].width = "6P";
          var w = doc.documentPreferences.pageWidth,
              _left = doc.marginPreferences.left,
              _right = doc.marginPreferences.right;
          try
                  app.selection[0].columns[0].width  =  (w - _left - _right) - (app.selection[0].columns.length-1)*6;
          catch(e)
                  alert("Table width exeeds the length of the text area!")
          Regards,
          Chinna
          • 2. Re: Distribute column
            VeluVK Level 1
            Hi Chinna,
            Please find below error.
            Regards,
            Velu
            • 3. Re: Distribute column
              Chinnadk Level 4
              Hi Velu,
              The table must be selected instead of putting a cursor into it.
              Regards,
              Chinna
              • 4. Re: Distribute column
                VeluVK Level 1
                Hi Chinna,
                When i select table the script working, but the table width exceed out of the margin.
                I need the script for all the tables. The documents contains 200+ tables.
                Regards,
                Velu
                • 5. Re: Re: Distribute column
                  Chinnadk Level 4
                  Try now, it will run on all the tables.
                  var doc = app.activeDocument,
                      _tables = doc.stories.everyItem().tables.everyItem().getElements(),
                      w = doc.documentPreferences.pageWidth;
                  for(var i =0;i<_tables.length;i++)
                          for(var j =_tables[i].columns.length-1;j>0;j--)
                                  _tables[i].columns[j].width = "6P";
                          var _left = _tables[i].parent.parentPage.marginPreferences.left,
                              _right = _tables[i].parent.parentPage.marginPreferences.right;
                          try
                                  _tables[i].columns[0].width  =  (w - (_left + _right)) - (_tables[i].columns.length-1)*6 ;
                          catch(e)
                  Regards,
                  Chinna
                  • 6. Re: Distribute column
                    VeluVK Level 1
                    Hi Chinna,
                    Thank you so much, Script working perfect.
                    Regards,
                    Velumani
