1. Re: Disappearing elements in a pdf when flattening
Dov Isaacs Sep 2, 2014 11:03 PM (in response to jstaiman@staiman.com)The real question is why in the world you are flattening the PDF for your ads. Just place them in InDesign, for example, export PDF (preferably PDF/X-4), and let the RIP properly blend the transparency based on the exact print conditions and color management. You should never, repeat never, repeat yet again never open PDF submitted for placement in a publication in Illustrator or Photoshop and place the results of same into your publication. You are simply ruining your content and achieve no benefit whatsoever!!!
- Dov
2. Re: Disappearing elements in a pdf when flattening
jstaiman@staiman.com Sep 2, 2014 11:22 PM (in response to Dov Isaacs)Thanks, Dov, for your speedy reply. That is, of course, the easiest and simplest solution. However, years ago we found that in creating our final PDF it would get hung up on one ad or another for reasons we could not fathom. It would take hours of searching (at deadline, of course) to figure out why our file wouldn't work. So we took to converting all ads into JPGs as a solution, which usually worked fine. The publication itself is on newsprint, so any small degradation of quality would not have been an issue. Perhaps now, with faster, more powerful machines and software we'd be ok just using the PDFs.
3. Re: Disappearing elements in a pdf when flattening
Willi Adelberger Sep 3, 2014 12:35 AM (in response to jstaiman@staiman.com)If you rasterize or open a PDF in Photoshop you will see not only a small amount of loss of quality, it will be huge:
- Vectors and fonts are rasterized with the image resolution (e.g. 300ppi). That means that theit lines are not crispy any more. If they remain in vectors they will be later rasterized in the RIP or APPE which will create much smoother lines and output in higher quality.
- A PDF can contain a lot of different color spaces in RGB and CMYK. Photoshop will open a PDF and convert it to a single color space.
- A PDF might contain transparency, saving as JPG will eliminate and flatten any transparency.
It would be much better to set up a standard how your clients should deliver their adds like
- PDF/X-4 (which will include all used fonts embedded, not allow interactive objects, etc.)
- Bleed
- Output intent
- Minimum resolution of images
- Minimum width of lines and small letters
- Minimum width of lines and small letters, when printed on black and also when printed on 4c.
- If you need registration marks.
These things I am always asking for BEFORE I start a project. This will help to avoid errors and problems from the beginning.
- Opening a PDF (nor a delivered EPS) is not a solution.
- Sending the Add as EPS is neither a solution.
- Sending a rasterized anything is also not a good idea.
4. Re: Disappearing elements in a pdf when flattening
jstaiman@staiman.com Sep 3, 2014 1:01 AM (in response to Willi Adelberger)Thanks, Will. You are right. We were trying to be realistic -- it's hard enough to get some of these advertisers to send in the right size, let along the correct format, as many are do-it-yourself Mom & Pop businesses. But we should at least publish the specs and try to get what we need, rather than just give up on the quality. As the publication has just moved to a better printer, it becomes all the more important.
5. Re: Disappearing elements in a pdf when flattening
Dov Isaacs Sep 3, 2014 7:41 AM (in response to jstaiman@staiman.com)There is no question that when accepting ads from “the world” you will have some problematic submissions. I've encountered ads done in PowerPoint, Microsoft Paint, etc.
However, rather than using the elephant gun of opening in Photoshop or Illustrator or forcing flattening, why not try some preflight in Acrobat? Just make sure that you use a profile that checks for problems (transparency and RGB are not problems) and only do something for PDF files that have serious issues such as overprinting white or unembedded fonts.
- Dov
6. Re: Disappearing elements in a pdf when flattening
jstaiman@staiman.com Sep 3, 2014 7:59 AM (in response to Dov Isaacs)I'll confess that although I've been a designer for around 30 years and usually build documents which the printers have no issue with, I'm not usually on the pre-press end to that extent. Can you recommend a good-but-not-overly-technical primer on PDF preflighting, so we can better discern the meaningful issues from the minor ones?
7. Re: Disappearing elements in a pdf when flattening
Test Screen Name Sep 7, 2014 1:38 AM (in response to jstaiman@staiman.com)The important thing about preflighting is not to MAKE problems. Commonly people starting with preflighting pick a profile, and then spend ages chasing the "problems" it identifies. But with a few exceptions, what it identifies are not problems, just check boxes. So you need absolutely to start by understanding WHAT causes problems. For instance, would you want to reject (or at least know about) artwork under 150 dpi? Or nonembedded fonts? If so, preflight can help you. If not, it's no better than having someone stick pins in a list!
8. Re: Disappearing elements in a pdf when flattening
Dov Isaacs Sep 7, 2014 12:02 PM (in response to jstaiman@staiman.com)To answer your specific question, I have not ever seen such a technical primer, although such a reputable guide is really necessary in an industry where many of the prepress “professionals” are in fact relying on word-of-mouth urban legends as their guides to what is correct and printable PDF. Many also act Luddites in terms of embracing newer, more reliable PDF print publishing workflows (such as use of PDF file with live transparency and ICC color management as well as not converting calibrated RGB imagery to process CMYK other that at the RIP itself).
If I can find (or write) such a primer, I'll report back to this forum with same!
- Dov
9. Re: Disappearing elements in a pdf when flattening
jstaiman@staiman.com Sep 8, 2014 1:59 AM (in response to Test Screen Name)Thanks. I guess I should contact the printer of the publication, and find out from them which items are most likely to cause problems, and which ones I can ignore.
10. Re: Disappearing elements in a pdf when flattening
jstaiman@staiman.com Sep 8, 2014 2:05 AM (in response to Dov Isaacs)As someone who is probably around your age, I must confess to perhaps being one of your "Luddites". After all, Photoshop 3.1 was just fine when I got it...why do they have to keep changing it? . In any case, while I'm not an early adopter, I do want to work correctly, and have my files print in the best possible way. I'll look forward to your update if you find something, and as I mentioned to the previous poster, I will contact our printer for their recommendations on how we can do better pre-flighting. כתיבה וחתימה טובה!
11. Re: Disappearing elements in a pdf when flattening
SteveC01 Oct 7, 2014 5:12 AM (in response to Dov Isaacs)We have had instances where our Rampage RIP has mangled transparent objects, and even instances where the only way Preps 5.2.3 would accept a PDF file would be to export as PS and redistill at PDF v1.3. Now in a perfect environment, with the latest RIPS and software versions, transparencies may be the bomb, but in a lot of real world shops, the bomb explodes.
12. Re: Disappearing elements in a pdf when flattening
Dov Isaacs Oct 7, 2014 8:11 AM (in response to SteveC01)If you are having problems by which your Rampage RIP mangles transparent objects, it would behoove you to report the problem to Rampage and get them to fix their bugs. (Note Rampage products are not based on any Adobe technology and as such, Adobe cannot assist with that!) Similarly, if Preps is buggy, bug the software provider to provide the fixes. Otherwise, choose other software vendors.
- Dov
13. Re: Disappearing elements in a pdf when flattening
SteveC01 Oct 7, 2014 8:18 AM (in response to Dov Isaacs)I agree with that, unfortunately we peasants cannot dictate as to what what
tools we are provided. So we must beat the PDF into submission to force it
to run the gauntlet.
Fortunately, we are finally moving to Prinergy in December, so hopefully
that will alleviate these issues.
Thank you,
Steve Cook
Prepress Technical Specialist
P.A. Hutchison Company
400 Penn Ave
Mayfield, PA 18433
Telephone: 570-876-4560
Fax: 570-876-4561
Email: scook@pahutch.com
www.linkedin.com/pub/steve-cook/8/334/b8/
14. Re: Disappearing elements in a pdf when flattening
Dov Isaacs Oct 7, 2014 8:27 AM (in response to SteveC01)Although as a “peasant” you cannot dictate what tools you are provided with, it would certainly behoove you to make your management aware of issues that cost your company time and ultimately money. Too many print service providers are penny-wise and pound-foolish when it comes to workflow software. All too often, new “iron” is the only investment that is understood when in fact, that is increasingly becoming a much less important factor in efficient, profitable operations.
- Dov
15. Re: Disappearing elements in a pdf when flattening
SteveC01 Oct 7, 2014 8:54 AM (in response to Dov Isaacs)Rampage is end of life, so we had to move forward and I am confident that
our management has made an excellent choice in Prinergy having worked with
it in the past. We did go back to Rampage many times for issues and a lot of
them were addressed. New iron may not always be the best answer but in this
case a very necessary one. I wasn¹t belittling Adobe for the issues we were
having, I was merely stating a fact of our workflow. In fact, I think Adobe
products are awesome and the technology is incredible.
