3 Replies Latest reply on Sep 12, 2014 2:31 AM by SimonESATS
    Problem using sendDocument
    Simon D Kemp
      Can anyone tell me why the xml below fails ("Not enough message parts were received for the operation."). I believe all required parameters are present.
      Totally stuck on this and would appreciate any pointers.
      Simon
      <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
      <soap:Body>
        <sendDocument>
         <apiKey>*MYAPIKEY*</apiKey>
         <documentCreationInfo>
          <recipients>
           <RecipientInfo>
            <email>xyz@gmail.com</email>
            <role>SIGNER</role>
           </RecipientInfo>
          </recipients>
          <name>test document</name>
          <message>some text to go in the email...</message>
          <fileInfos>
           <FileInfo>
            <fileName>Test Document.pdf</fileName>
            <file>*BASE64ENCODEDFILEHERE*</file>
           </FileInfo>
          </fileInfos>
          <signatureType>ESIGN</signatureType>
          <signatureFlow>SENDER_SIGNATURE_NOT_REQUIRED</signatureFlow>
         </documentCreationInfo>
        </sendDocument>
      </soap:Body>
      </soap:Envelope>
        • 1. Re: Problem using sendDocument
          SimonESATS Adobe Employee
          Hi Simon,
          By the face of it it looks like you are not declaring any name spaces, though i do believe you have the minimum elelemtns required,
          use a tool such as soapui to quickly test your requests and to also see an example of a valid request.
          For example if using v19 if the api::
          <soapenv:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:api="http://api.echosign" xmlns:dto="http://dto.api.echosign" xmlns:dto9="http://dto9.api.echosign" xmlns:dto1="http://dto14.api.echosign">
            <soapenv:Header/>
            <soapenv:Body>
                <api:sendDocument>
                  <api:apiKey>[apikey]</api:apiKey>
                  <api:senderInfo xsi:nil="true"/>
                  <api:documentCreationInfo>
                      <!--Optional:-->
                      <dto:callbackInfo xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:ccs xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:daysUntilSigningDeadline xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:externalId xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:fileInfos>
                        <!--Zero or more repetitions:-->
                        <dto:FileInfo>
                            <!--Optional:-->
                            <dto:file>[base64 goes here]</dto:file>
                            <dto:fileName>test.docx</dto:fileName>
                            <!--Optional:-->
                                 </dto:FileInfo>
                      </dto:fileInfos>
                      <!--Optional:-->
                      <dto:formFieldLayerTemplates xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:locale xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:mergeFieldInfo xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:mergeFile xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:message>test message</dto:message>
                      <!--Optional:-->
                      <dto:name>agreement name</dto:name>
                      <!--Optional:-->
                      <dto:recipients>
                        <dto1:RecipientInfo>
                            <!--Optional:-->
                            <dto1:email>someemail@domain.com</dto1:email>
                            <!--Optional:-->
                            <dto1:fax xsi:nil="true"/>
                            <!--Optional:-->
                            <dto1:role>SIGNER</dto1:role>
                        </dto1:RecipientInfo>
                      </dto:recipients>
                      <!--Optional:-->
                      <dto:reminderFrequency xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:securityOptions xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:signatureFlow xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:signatureType xsi:nil="true"/>
                      <!--Optional:-->
                      <dto:tos xsi:nil="true"/>
                      <dto:vaultingInfo xsi:nil="true"/>
                  </api:documentCreationInfo>
                </api:sendDocument>
            </soapenv:Body>
          </soapenv:Envelope>
          • 2. Re: Problem using sendDocument
            Simon D Kemp Level 1
            Should have come back earlier to report things were working OK...
            You're absolutely right - adding namespaces got things going.
            • 3. Re: Problem using sendDocument
              Cheers for the update Simon. I did see this thread earlier, but life got in the way. Glad you got it working ok.
