2 Replies Latest reply on Sep 3, 2014 2:49 PM by AnneMarie Concepcion
    Remove font scaling - need help with FindChangeList.txt
    AnneMarie Concepcion Adobe Community Professional
      First an overall question: Is there a utility or method that will let me convert a saved F/C query to the sort of written out expression required by the FindChangeByList.jsx script?
      Like:
      text{findWhat:" - "}{changeTo:"^="}{includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}Find all space-dash-space and replace with an en dash.
      (This is just to jog your memory ... actually it's not the text string ones I need help with, but formatting find/changes.)
      I need a fast way to go through a document and remove any instance of glyph scaling whether local or from a style. That is, to turn it back to 100% horizontal and vertical. This is necessary for good output in EPUB (Fixed Layout) format.
      A script would be great, but lacking that, a way to write out that kind of formatting instruction to add to FindChangeByList.jsx would serve me well in the long run, as I have other similar kinds of doc-wide formatting I often need to do.
      AM
