3 Replies Latest reply on Sep 10, 2014 12:19 AM by BKBK
    Coldfusion 10: execute as command line
    charedrive
      Using CF10 on a unix system.  Attempting to use cfexecute on perl and batch files do not work but they run fine when executed directly from command line.  The perl and bat file permissions are set so anyone can execute them.  Does anyone know if I make coldfusion execute the perl or bat file as if it was running as a command line?  May need to designate specific user the execute them as.
      <cfexecute name="#EDRSDIR#/uploadconvertwrapper.pl" arguments="#filedirectory# #finalfilename# #dcnflag# #splflag# outputFile="/dev/null" timeOut="0" />
      <cfexecute name="#EDRSDIR#/uploadconvert.bat" argumensts="#filedirectory# #finalfilename# #dcnflag# #splflag# outputFile="/dev/null" timeout="0" />
        • 1. Re: Coldfusion 10: execute as command line
          BKBK Adobe Community Professional & MVP
          What about:
          correcting the spelling of 'arguments';
          dropping the .pl and .bat extensions;
          giving the timeout a value greater than 0;
          adding an error variable which you can output for debugging.
          <cfexecute name="#EDRSDIR#/uploadconvertwrapper" arguments="#filedirectory# #finalfilename# #dcnflag# #splflag# errorVariable="errorOutput" timeout="10" />
          <cfexecute name="#EDRSDIR#/uploadconvert" argumensts="#filedirectory# #finalfilename# #dcnflag# #splflag# errorVariable="errorOutput" timeout="10" />
          • 2. Re: Coldfusion 10: execute as command line
            charedrive Level 1
            The "argumensts" was a typo just in my forum post.
            I did finally find the answer.  The coldfusion was running under a different account than what I was using for command line testing.  Once I tried the commmand line with the coldfusion account, I found some hidden directories that required permission updates.  Thanks for the input, BKBK.
            • 3. Re: Coldfusion 10: execute as command line
              Thanks for sharing that. Could you please mark it as the correct answer? It will help someone else.
