0 Replies Latest reply on Aug 7, 2006 12:55 AM by FrodeHansen
    Cairngorm - resulthandling problem
    FrodeHansen
      We are using the Cairngorm framework in our Flex 2.0 app. and have now met a problem related to the resulthandling. If I trace the result in the onResult handler in the Command class, the traces once the first time i call the service, two times the second, three times the third and so on. It might be related to the code which adds the event handler, but I'm not sure.
      Have any of you met the same problem, or maby see some errors in the code below?
      Event class:
      public class GetCategoriesEvent extends CairngormEvent
      public function GetCategoriesEvent() {
      super( GetCategoriesEvent.EVENT_GET_CATEGORIES );
      public static var EVENT_GET_CATEGORIES:String = "getCategories";
      Command class:
      public class GetCategoriesCommand implements Command, Responder {
      private var model : ModelLocator = ModelLocator.getInstance();
      public function execute( event : CairngormEvent ) : void {
      var delegate : GetCategoriesDelegate = new GetCategoriesDelegate ( this );
      var getCategoriesEvent : GetCategoriesEvent = GetCategoriesEvent( event );
      delegate.getCategories();
      public function onResult( event : * = null ) : void {
      Application.application.trace("onResult: " + event.result);
      public function onFault( event : * = null ) : void {
      Application.application.trace("onFault: " + event.result);
      Delegate class:
      public class GetCategoriesDelegate
      private var responder : Responder;
      private var service : Object;
      public function GetCategoriesDelegate ( responder : Responder )
      this.service = ServiceLocator.getInstance().getHTTPService( "getCategories" ) as HTTPService;
      this.responder = responder;
      public function getCategories(): void {
      service.addEventListener(ResultEvent.RESULT, getCategories_onResult);
      service.addEventListener(FaultEvent.FAULT, getCategories_onFault);
      service.send();
      private function getCategories_onResult( event:ResultEvent ): void {
      responder.onResult(event);
      private function getCategories_onFault( event:FaultEvent ): void {
      responder.onFault();
      Service:
      <mx:HTTPService id="getCategories" url=" http://localhost:9081/sparing/fondtilbud/action?action=list_verdipapir_kategorier"
      showBusyCursor="true"
      useProxy="false" />
