15 Replies Latest reply: Sep 17, 2014 12:26 AM by dude man RSS
    problems with synch being ON
    zoharartist
      when I turn synch ON, and ask to synch the blue wheel spins and spins.  I tried putting the co
      rm ~/Library/Application\ Support/Adobe/CoreSync/options.tix
        • 1. Re: problems with synch being ON
          Kartikay_Sharma Employee Hosts
          Hi Zoharartist,
          Please try the steps mentioned in the below mentioned forum post and suggest if that worked for you or not .
          Creative Cloud Desktop App stuck on blue spinning wheel after update.
          Cheers,
          Kartikay Sharma
          • 2. Re: problems with synch being ON
            newwardorder
            I am having the same issues as Zoharatist. I have tried the steps in the link provided, to no avail. Please advise.
            • 3. Re: problems with synch being ON
              zoharartist Community Member
              I followed these instructions to the letter.  It did not work, synch reverts to OFF even though I turned it ON.
              Zoharartist
              • 4. Re: problems with synch being ON
                I have spent many hours following Forum suggestions to no avail.  Who is available at Adobe to TALK TO?  I tried the following steps in the thread:
                Open Finder, click on Go > Go to Folder. Type in ~/library and hit enter.
                Open Application Support/Adobe folder and rename OOBE folder to OOBEold.
                Click on Apple icon on the top left, select System Preferences
                Choose the network that is currently connected to internet that can be Ethernet or
                Airport(Wireless). Click on Advanced button and click Proxies Tab.
                Under 'Select a Proxy server to Configure' Uncheck all the proxy check boxes, then uncheck 'Use Passive FTP Mode (PASV)'.
                This did not work.  This is extremely frustrating.  I do not want to cancel my CC license or uninstall CC and then re-install and download all apps again ... this would be such a waste of time.
                Any suggestions.
                • 5. Re: problems with synch being ON
                  N.Goodall Employee Hosts
                  Hi Zoharartist,
                  I'm sorry you are having problems with sync and given you've tried all the usual workarounds I think the only way we will get to the bottom of your issue is if you could send me (goodall@adobe.com) the sync log files.
                  The location for each OS are:
                  • Mac OS X: ~/Library/Application Support/Adobe/CoreSync/CoreSync-yyyy-mm-dd.log
                  • Windows: %APPDATA%/Adobe/CoreSync/CoreSync-yyyy-mm-dd.log
                  Note that on Mac OS X to see the user library from the Finder click on the Go menu and hold down the Alt/ Option key. Note that on Windows %APPDATA% is a variable that will change to the correct path depending on if version of Windows being used.
                  • 6. Re: problems with synch being ON
                    tzongker Community Member
                    I was having the same problem and FINALLY got it to work.  Try quitting creative cloud, then rename the OOBE folder again (you probably will still have the first OOBEold folder, so I renamed it OOBEold1.)  Then in the same library directory, go to the core sync folder and delete the options.tix file.
                    I did this, which is a combination of two different "solutions" I saw here on the forum, and it worked for me.
                    Good luck!
                    • 7. Re: problems with synch being ON
                      Actually, the problem is that turning synch ON does not stay on but toggles back to OFF.  Therefore, to cloud an asset file, I need to click Turn Synch On again.  It turns out that the file DOES download and is accessible from the Creative Cloud File page.  So, the real question is:  S THERE A WAY TO KEEP SYNCH ON without clicking synch on each time.
                      Attached is the log.
                      • 8. Re: problems with synch being ON
                        As I said, that is the same problem I was having.  I would turn "on" sync but if I closed the preferences and reopened them, sync was back to "off."  I did what I described above, and now sync stays "on," I am able to sync files, I can close Creative Cloud and come back hours later and sync is still "on."  Which is exactly what I said in my earlier post.  Sorry it didn't work for you, but for me PROBLEM SOLVED.
                        • 9. Re: problems with synch being ON
                          CoreSync-2014-08-27.log
                          CoreSync-2014-08-28.log
                          CoreSync-2014-08-29.log
                          CoreSync-2014-08-30.log
                          CoreSync-2014-08-31.log
                          CoreSync-2014-09-01.log
                          CoreSync-2014-09-02.log
                          CoreSync-2014-09-03.log
                          CoreSync-2014-09-04.log
                          CoreSync-2014-09-06.log
                          CoreSync-2014-09-07.log
                          CoreSync-2014-09-08.log
                          CoreSync-2014-09-09.log
                          CoreSync-2014-09-10.log
                          CoreSync-2014-09-11.log
                          • 10. Re: problems with synch being ON
                            20140827-173135.360: MControllerDelegate::updateAccessToken
                            20140827-173135.361: ACCController::updateAccessToken accessToken 2d4a5bf6025e3691882d6facccbbfb54
                            20140827-173135.361: Informational: AppHookControllerImpl::onUpdateAccessToken in
                            20140827-173135.365: Informational: [livetype] onUpdateAccessToken
                            20140827-173135.365: Informational: AppHookControllerImpl::onUpdateAccessToken out
                            20140827-173135.366: ACCController::updateAccessToken completed
                            20140827-204125.821: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140827-204125.822: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140827-204125.822: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140827-204125.823: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140827-204125.823: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140827-204125.823: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140827-204125.824: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140827-204125.824: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140827-204125.824: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140827-204125.825: MControllerDelegate::enableCollaboration: YES
                            20140828-092347.764: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-092347.766: ACCController::doInjectFinderExt: appIdentifier: com.dashlane.Dashlane
                            20140828-092347.766: ACCController::doInjectFinderExt: app identifier: com.dashlane.Dashlane not equal to com.apple.finder
                            20140828-092805.529: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-092805.529: ACCController::doInjectFinderExt: appIdentifier: com.intuit.Quicken.2015
                            20140828-092805.529: ACCController::doInjectFinderExt: app identifier: com.intuit.Quicken.2015 not equal to com.apple.finder
                            20140828-092846.964: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-092846.965: ACCController::doInjectFinderExt: appIdentifier: com.intuit.QuickenEssentials
                            20140828-092846.965: ACCController::doInjectFinderExt: app identifier: com.intuit.QuickenEssentials not equal to com.apple.finder
                            20140828-092936.579: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-092936.579: ACCController::doInjectFinderExt: appIdentifier: com.intuit.Quicken.2015
                            20140828-092936.580: ACCController::doInjectFinderExt: app identifier: com.intuit.Quicken.2015 not equal to com.apple.finder
                            20140828-093111.320: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-093111.321: ACCController::doInjectFinderExt: appIdentifier: com.intuit.Quicken.2015
                            20140828-093111.321: ACCController::doInjectFinderExt: app identifier: com.intuit.Quicken.2015 not equal to com.apple.finder
                            20140828-093952.746: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-093952.747: ACCController::doInjectFinderExt: appIdentifier: com.intuit.Quicken.2015
                            20140828-093952.747: ACCController::doInjectFinderExt: app identifier: com.intuit.Quicken.2015 not equal to com.apple.finder
                            20140828-094418.877: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-094418.877: ACCController::doInjectFinderExt: appIdentifier: com.dashlane.Dashlane
                            20140828-094418.877: ACCController::doInjectFinderExt: app identifier: com.dashlane.Dashlane not equal to com.apple.finder
                            20140828-094640.401: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-094640.402: ACCController::doInjectFinderExt: appIdentifier: com.parallels.desktop.console
                            20140828-094640.402: ACCController::doInjectFinderExt: app identifier: com.parallels.desktop.console not equal to com.apple.finder
                            20140828-095004.689: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-095004.689: ACCController::doInjectFinderExt: appIdentifier: com.intuit.Quicken.2015
                            20140828-095004.690: ACCController::doInjectFinderExt: app identifier: com.intuit.Quicken.2015 not equal to com.apple.finder
                            20140828-095040.325: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-095040.326: ACCController::doInjectFinderExt: appIdentifier: com.dashlane.Dashlane
                            20140828-095040.326: ACCController::doInjectFinderExt: app identifier: com.dashlane.Dashlane not equal to com.apple.finder
                            20140828-100637.691: ACCController::osSleepWake: NSConcreteNotification 0x7ff84706da90 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7ff844318580>}
                            20140828-100637.692: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140828-100637.746: 2014-08-28 10:06:37: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140828-100703.144: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140828-101044.177: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140828-101103.307: ACCController::osSleepWake: NSConcreteNotification 0x7ff8441d2050 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7ff844318580>}
                            20140828-101839.539: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-101839.540: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140828-101839.540: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140828-120638.971: ACCController::shutdown
                            20140828-120638.972: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140828-120638.972: 2014-08-28 12:06:38: File Monitoring was asked to stop on: : shutdown
                            20140828-120638.973: 2014-08-28 12:06:38: File Monitoring was asked to stop on: : shutdown
                            20140828-120638.973: Informational: AppHookControllerImpl::onShutdown in
                            20140828-120639.236: MControllerDelegate::shutdownRequest
                            20140828-120639.460: Informational: [livetype] onShutdown
                            20140828-120639.488: Informational: [livetype]  disableFontSync
                            20140828-120639.489: Informational: [livetype] deactivated all fonts
                            20140828-120639.493: Informational: AppHookControllerImpl::onShutdown out
                            20140828-120639.496: ACCController::removeAllIcons
                            20140828-120639.500: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140828-131716.550: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140828-131716.563: ACCController::Init
                            20140828-131716.570: ACCController::Init: init fileState cache
                            20140828-131716.577: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140828-131716.578: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140828-131716.629: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140828-131716.680: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140828-131716.680: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140828-131716.680: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140828-131716.733: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140828-131716.734: Notice: setTargetDataRates: 0 upload, 0 download
                            20140828-131716.735: WorkerThreads: 8
                            20140828-131716.735: Notice: setTargetDataRates: 0 upload, 0 download
                            20140828-131716.738: ACCController::Init: add notification observers
                            20140828-131716.741: CJournalDB::Init: schema differs: incorrect number of tables
                            20140828-131716.742: CJournalDB::_create: successfully created 5 tables
                            20140828-131716.745: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140828-131716.745: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140828-131716.746: ACCController::updateWithState: 11
                            20140828-131716.746: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140828-131716.746: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140828-131716.753: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140828-131716.754: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140828-131716.759: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140828-131716.759: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140828-131716.764: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140828-131716.764: Informational: AppHookControllerImpl::onStartup in
                            20140828-131716.778: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140828-131716.779: Informational: [livetype] onStartup
                            20140828-131716.783: Informational: [livetype] onStartup => success
                            20140828-131716.783: Informational: AppHookControllerImpl::onStartup out
                            20140828-131716.809: ACCController::injectFinderExt
                            20140828-131716.811: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-131716.811: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140828-131716.825: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140828-131716.878: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140828-131716.893: ACCController::finderInitSuccessfull: injectExt:YES
                            20140828-131716.894: ACCController::finderInitSuccessfull: injectExt:YES
                            20140828-131716.895: ACCFinderExtensionController::init: intialization succsessfull
                            20140828-131717.859: MControllerDelegate::invalidateAccessToken
                            20140828-131717.859: ACCController::invalidateAccessToken
                            20140828-131717.860: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140828-131717.861: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140828-131717.861: Informational: [livetype] onInvalidateAccessToken
                            20140828-131717.862: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140828-131717.862: ACCController::invalidateAccessToken completed
                            20140828-131717.898: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140828-131717.899: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140828-131717.899: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140828-131717.900: Informational: [livetype] syncStatus: OFF
                            20140828-131826.317: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-131826.318: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140828-131826.318: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140828-131929.822: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-131929.822: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140828-131929.823: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140828-132051.954: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140828-132051.955: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140828-132051.955: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140828-132051.955: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140828-132051.956: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140828-132051.956: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140828-132051.956: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140828-132051.957: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140828-132051.957: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140828-132051.957: MControllerDelegate::enableCollaboration: YES
                            20140828-132053.860: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140828-132053.860: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140828-132053.861: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140828-132053.861: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140828-132053.861: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140828-132053.862: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140828-132053.862: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140828-132053.863: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140828-132053.863: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140828-132053.863: MControllerDelegate::enableCollaboration: YES
                            20140828-132053.864: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140828-132053.865: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 9e68818a6e79dabd1f7d0867e12f8778 userId 6E68593446662ED1992016B8@AdobeID
                            20140828-132053.866: MControllerDelegate::disableSync invoked
                            20140828-132053.867: ACCSync::stopJob: forced: 1, reason: Update job
                            20140828-132053.867: 2014-08-28 13:20:53: File Monitoring was asked to stop on: : Update job
                            20140828-132053.868: 2014-08-28 13:20:53: File Monitoring was asked to stop on: : Update job
                            20140828-132053.868: WorkerThreads: 8
                            20140828-132053.869: Notice: setTargetDataRates: 0 upload, 0 download
                            20140828-132053.869: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140828-132053.870: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140828-132053.870: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140828-132053.871: Informational: [livetype] syncStatus: OFF
                            20140828-132053.873: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140828-132053.874: ACCController::updateWithState: 11
                            20140828-132053.874: Informational: AppHookControllerImpl::onSignIn in
                            20140828-132053.876: Informational: [livetype] onSignIn
                            20140828-132053.876: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140828-132053.877: Informational: AppHookControllerImpl::onSignIn out
                            20140828-132053.878: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140828-132053.878: ACCController::disableSync sync is already disabled
                            20140828-132053.880: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140828-132053.881: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140828-133548.841: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-133548.842: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140828-133548.842: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140828-133655.730: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-133655.731: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140828-133655.731: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140828-135340.415: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-135340.416: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140828-135340.416: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140828-140025.164: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-140025.165: ACCController::doInjectFinderExt: appIdentifier: com.parallels.desktop.console
                            20140828-140025.165: ACCController::doInjectFinderExt: app identifier: com.parallels.desktop.console not equal to com.apple.finder
                            20140828-140255.962: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-140255.963: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140828-140255.963: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140828-140419.831: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-140419.832: ACCController::doInjectFinderExt: appIdentifier: com.adobe.illustrator
                            20140828-140419.832: ACCController::doInjectFinderExt: app identifier: com.adobe.illustrator not equal to com.apple.finder
                            20140828-151545.676: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-151545.677: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140828-151545.677: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140828-160621.454: ACCController::osSleepWake: NSConcreteNotification 0x7fbce0f06a50 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fbce31150b0>}
                            20140828-160621.454: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140828-160621.455: 2014-08-28 16:06:21: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140828-160829.966: ACCController::osSleepWake: NSConcreteNotification 0x7fbce0e5f790 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fbce31150b0>}
                            20140828-160830.000: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140828-161057.402: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-161057.403: ACCController::doInjectFinderExt: appIdentifier: com.parallels.desktop.console
                            20140828-161057.403: ACCController::doInjectFinderExt: app identifier: com.parallels.desktop.console not equal to com.apple.finder
                            20140828-163836.896: ACCController::osSleepWake: NSConcreteNotification 0x7fbce3201480 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fbce31150b0>}
                            20140828-163836.896: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140828-163836.897: 2014-08-28 16:38:36: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140828-164027.288: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140828-164027.293: ACCController::osSleepWake: NSConcreteNotification 0x7fbce0f066b0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fbce31150b0>}
                            20140828-164027.337: ACCController::osSleepWake: NSConcreteNotification 0x7fbce0f06b00 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fbce31150b0>}
                            20140828-164027.337: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140828-164027.338: 2014-08-28 16:40:27: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140828-164029.617: ACCController::osSleepWake: NSConcreteNotification 0x7fbce3201480 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fbce31150b0>}
                            20140828-164239.573: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-164239.573: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140828-164239.574: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140828-164654.833: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-164654.834: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140828-164654.834: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140828-165536.981: ACCController::shutdown
                            20140828-165536.981: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140828-165536.982: 2014-08-28 16:55:36: File Monitoring was asked to stop on: : shutdown
                            20140828-165536.982: Informational: AppHookControllerImpl::onShutdown in
                            20140828-165537.031: MControllerDelegate::shutdownRequest
                            20140828-165537.089: Informational: [livetype] onShutdown
                            20140828-165537.089: Informational: [livetype]  disableFontSync
                            20140828-165537.090: Informational: [livetype] deactivated all fonts
                            20140828-165537.090: Informational: AppHookControllerImpl::onShutdown out
                            20140828-165537.091: ACCController::removeAllIcons
                            20140828-165537.091: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140828-182249.141: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140828-182249.184: ACCController::Init
                            20140828-182249.219: ACCController::Init: init fileState cache
                            20140828-182249.226: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140828-182249.229: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140828-182249.280: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140828-182249.332: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140828-182249.332: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140828-182249.332: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140828-182249.387: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140828-182249.387: Notice: setTargetDataRates: 0 upload, 0 download
                            20140828-182249.388: WorkerThreads: 8
                            20140828-182249.389: Notice: setTargetDataRates: 0 upload, 0 download
                            20140828-182249.390: ACCController::Init: add notification observers
                            20140828-182249.396: CJournalDB::Init: schema differs: incorrect number of tables
                            20140828-182249.397: CJournalDB::_create: successfully created 5 tables
                            20140828-182249.400: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140828-182249.401: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140828-182249.401: ACCController::updateWithState: 11
                            20140828-182249.402: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140828-182249.402: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140828-182249.424: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140828-182249.424: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140828-182249.441: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140828-182249.441: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140828-182249.453: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140828-182249.453: Informational: AppHookControllerImpl::onStartup in
                            20140828-182249.458: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140828-182249.458: Informational: [livetype] onStartup
                            20140828-182249.460: Informational: [livetype] onStartup => success
                            20140828-182249.461: Informational: AppHookControllerImpl::onStartup out
                            20140828-182249.500: ACCController::injectFinderExt
                            20140828-182249.501: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-182249.502: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140828-182249.516: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140828-182249.583: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140828-182249.612: ACCController::finderInitSuccessfull: injectExt:YES
                            20140828-182249.614: ACCController::finderInitSuccessfull: injectExt:YES
                            20140828-182249.615: ACCFinderExtensionController::init: intialization succsessfull
                            20140828-182250.510: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140828-182250.511: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140828-182250.511: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140828-182250.512: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140828-182250.512: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140828-182250.512: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140828-182250.513: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140828-182250.513: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140828-182250.514: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140828-182250.514: MControllerDelegate::enableCollaboration: YES
                            20140828-182250.516: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140828-182250.516: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140828-182250.517: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140828-182250.517: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140828-182250.517: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140828-182250.518: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140828-182250.518: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140828-182250.518: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140828-182250.519: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140828-182250.519: MControllerDelegate::enableCollaboration: YES
                            20140828-182250.520: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140828-182250.520: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 07de92ce520223fae740b4fbce28974f userId 6E68593446662ED1992016B8@AdobeID
                            20140828-182250.521: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140828-182250.522: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140828-182250.523: ACCSync::stopJob: forced: 1, reason: Update job
                            20140828-182250.523: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140828-182250.527: Informational: [livetype] syncStatus: OFF
                            20140828-182250.527: 2014-08-28 18:22:50: File Monitoring was asked to stop on: : Update job
                            20140828-182250.531: 2014-08-28 18:22:50: File Monitoring was asked to stop on: : Update job
                            20140828-182250.531: WorkerThreads: 8
                            20140828-182250.532: Notice: setTargetDataRates: 0 upload, 0 download
                            20140828-182250.533: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140828-182250.534: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140828-182250.535: ACCController::updateWithState: 11
                            20140828-182250.535: Informational: AppHookControllerImpl::onSignIn in
                            20140828-182250.536: Informational: [livetype] onSignIn
                            20140828-182250.536: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140828-182250.537: Informational: AppHookControllerImpl::onSignIn out
                            20140828-182250.538: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140828-182250.539: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140828-182250.540: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140828-182251.521: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140828-182251.521: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140828-182251.521: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140828-182251.522: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140828-182251.522: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140828-182251.523: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140828-182251.523: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140828-182251.523: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140828-182251.524: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140828-182251.524: MControllerDelegate::enableCollaboration: YES
                            20140828-182251.526: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140828-182251.526: ACCController::updateAccessToken accessToken 07de92ce520223fae740b4fbce28974f
                            20140828-182251.527: Informational: AppHookControllerImpl::onUpdateAccessToken in
                            20140828-182251.527: Informational: [livetype] onUpdateAccessToken
                            20140828-182251.528: Informational: AppHookControllerImpl::onUpdateAccessToken out
                            20140828-182251.528: ACCController::updateAccessToken completed
                            20140828-182251.528: MControllerDelegate::disableSync invoked
                            20140828-182251.529: ACCController::disableSync sync is already disabled
                            20140828-182251.532: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140828-182251.533: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140828-182251.533: Informational: [livetype] syncStatus: OFF
                            20140828-182652.543: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-182652.544: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140828-182652.544: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140828-194602.284: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-194602.285: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140828-194602.285: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140828-222902.281: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-222902.281: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140828-222902.282: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140828-223239.290: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-223239.291: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140828-223239.291: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140828-223333.800: ACCController::doInjectFinderExt: injectExt = 1
                            20140828-223333.801: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140828-223333.801: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140829-090947.171: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-090947.178: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140829-090947.178: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140829-111422.512: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-111422.513: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140829-111422.513: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140829-111559.777: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-111559.777: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140829-111559.778: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140829-111620.780: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-111620.780: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140829-111620.781: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140829-112122.752: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-112122.753: ACCController::doInjectFinderExt: appIdentifier: com.apple.Preview
                            20140829-112122.754: ACCController::doInjectFinderExt: app identifier: com.apple.Preview not equal to com.apple.finder
                            20140829-112146.305: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-112146.305: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140829-112146.306: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140829-112208.495: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-112208.495: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140829-112208.496: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140829-112233.522: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-112233.522: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140829-112233.523: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140829-112257.882: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-112257.882: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140829-112257.883: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140829-112442.055: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-112442.055: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140829-112442.056: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140829-112521.542: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-112521.543: ACCController::doInjectFinderExt: appIdentifier: com.google.shp3os.app
                            20140829-112521.543: ACCController::doInjectFinderExt: app identifier: com.google.shp3os.app not equal to com.apple.finder
                            20140829-112557.555: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-112557.555: ACCController::doInjectFinderExt: appIdentifier: com.google.shp3os.app
                            20140829-112557.555: ACCController::doInjectFinderExt: app identifier: com.google.shp3os.app not equal to com.apple.finder
                            20140829-112728.141: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-112728.141: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140829-112728.142: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140829-112759.817: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-112759.818: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140829-112759.818: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140829-112844.689: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-112844.690: ACCController::doInjectFinderExt: appIdentifier: com.google.shp3os.app
                            20140829-112844.690: ACCController::doInjectFinderExt: app identifier: com.google.shp3os.app not equal to com.apple.finder
                            20140829-122852.123: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-122852.123: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140829-122852.124: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140829-171055.455: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-171055.456: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140829-171055.456: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140829-175421.986: MControllerDelegate::updateAccessToken
                            20140829-175421.986: ACCController::updateAccessToken accessToken fdce91ab8ebd297826564883c1406ba5
                            20140829-175421.987: Informational: AppHookControllerImpl::onUpdateAccessToken in
                            20140829-175421.987: Informational: [livetype] onUpdateAccessToken
                            20140829-175421.987: Informational: AppHookControllerImpl::onUpdateAccessToken out
                            20140829-175421.987: ACCController::updateAccessToken completed
                            20140829-181950.733: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140829-181950.734: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140829-181950.734: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140829-181950.734: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140829-181950.735: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140829-181950.735: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140829-181950.736: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140829-181950.736: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140829-181950.736: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140829-181950.737: MControllerDelegate::enableCollaboration: YES
                            20140829-214816.939: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-214816.940: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140829-214816.940: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140829-214828.247: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-214828.248: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140829-214828.248: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140829-215258.128: ACCController::doInjectFinderExt: injectExt = 1
                            20140829-215258.129: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140829-215258.129: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-081225.785: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-081225.792: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-081225.792: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-111233.844: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-111233.845: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140830-111233.845: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140830-115317.876: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-115317.876: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-115317.877: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-133745.684: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-133745.685: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-133745.685: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-140050.751: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-140050.752: ACCController::doInjectFinderExt: appIdentifier: com.parallels.desktop.console
                            20140830-140050.752: ACCController::doInjectFinderExt: app identifier: com.parallels.desktop.console not equal to com.apple.finder
                            20140830-150544.170: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-150544.171: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140830-150544.171: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140830-150622.501: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-150622.501: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140830-150622.502: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140830-151028.596: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-151028.596: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-151028.597: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-151129.627: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-151129.628: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-151129.628: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-151208.652: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-151208.652: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-151208.653: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-151428.349: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-151428.349: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140830-151428.350: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140830-151455.054: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-151455.055: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140830-151455.055: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140830-151656.148: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-151656.148: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140830-151656.149: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140830-151846.030: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-151846.031: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140830-151846.031: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140830-152011.364: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-152011.364: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140830-152011.365: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140830-152150.360: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-152150.360: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-152150.361: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-152352.434: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-152352.434: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140830-152352.434: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140830-152903.711: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-152903.712: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-152903.712: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-153601.622: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-153601.623: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140830-153601.623: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140830-154526.589: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-154526.590: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-154526.590: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-154700.024: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-154700.024: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-154700.025: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-155126.490: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-155126.490: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-155126.490: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-155330.407: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-155330.408: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140830-155330.408: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140830-155422.386: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-155422.387: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-155422.387: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-172530.690: MControllerDelegate::updateAccessToken
                            20140830-172530.690: ACCController::updateAccessToken accessToken 7af1544c16d0f9a1fef4bc3104fb1f92
                            20140830-172530.691: Informational: AppHookControllerImpl::onUpdateAccessToken in
                            20140830-172530.691: Informational: [livetype] onUpdateAccessToken
                            20140830-172530.692: Informational: AppHookControllerImpl::onUpdateAccessToken out
                            20140830-172530.692: ACCController::updateAccessToken completed
                            20140830-181651.789: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140830-181651.789: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140830-181651.790: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140830-181651.790: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140830-181651.791: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140830-181651.791: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140830-181651.791: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140830-181651.792: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140830-181651.792: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140830-181651.792: MControllerDelegate::enableCollaboration: YES
                            20140830-201646.959: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-201646.959: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-201646.960: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-202109.904: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-202109.905: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-202109.905: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-202236.803: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-202236.804: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140830-202236.804: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140830-202246.341: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-202246.341: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-202246.342: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140830-202331.324: ACCController::doInjectFinderExt: injectExt = 1
                            20140830-202331.324: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140830-202331.325: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140831-124051.494: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-124051.496: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140831-124051.497: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140831-124114.796: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-124114.796: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140831-124114.797: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140831-124326.894: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-124326.895: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140831-124326.895: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140831-124438.481: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-124438.481: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140831-124438.482: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140831-124704.375: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-124704.376: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140831-124704.376: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140831-152027.784: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-152027.784: ACCController::doInjectFinderExt: appIdentifier: com.dashlane.Dashlane
                            20140831-152027.785: ACCController::doInjectFinderExt: app identifier: com.dashlane.Dashlane not equal to com.apple.finder
                            20140831-152237.147: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-152237.147: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140831-152237.148: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140831-152329.639: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-152329.639: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140831-152329.640: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140831-153640.540: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-153640.540: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140831-153640.541: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140831-155146.211: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-155146.211: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140831-155146.212: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140831-165657.789: MControllerDelegate::updateAccessToken
                            20140831-165657.789: ACCController::updateAccessToken accessToken 747c58ac05fa5a5d4d88bb3b9aefd3c3
                            20140831-165657.790: Informational: AppHookControllerImpl::onUpdateAccessToken in
                            20140831-165657.790: Informational: [livetype] onUpdateAccessToken
                            20140831-165657.791: Informational: AppHookControllerImpl::onUpdateAccessToken out
                            20140831-165657.791: ACCController::updateAccessToken completed
                            20140831-181352.795: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140831-181352.796: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140831-181352.796: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140831-181352.797: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140831-181352.797: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140831-181352.797: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140831-181352.798: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140831-181352.798: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140831-181352.798: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140831-181352.799: MControllerDelegate::enableCollaboration: YES
                            20140831-195041.955: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-195041.955: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140831-195041.955: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140831-211524.873: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-211524.873: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140831-211524.874: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140831-214602.287: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-214602.288: ACCController::doInjectFinderExt: appIdentifier: com.apple.iMovieApp
                            20140831-214602.288: ACCController::doInjectFinderExt: app identifier: com.apple.iMovieApp not equal to com.apple.finder
                            20140831-214924.250: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-214924.251: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140831-214924.252: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140831-214939.749: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-214939.749: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140831-214939.750: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140831-220351.059: ACCController::doInjectFinderExt: injectExt = 1
                            20140831-220351.059: ACCController::doInjectFinderExt: appIdentifier: com.apple.iMovieApp
                            20140831-220351.060: ACCController::doInjectFinderExt: app identifier: com.apple.iMovieApp not equal to com.apple.finder
                            20140831-220524.116: ACCController::shutdown
                            20140831-220524.116: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140831-220524.117: 2014-08-31 22:05:24: File Monitoring was asked to stop on: : shutdown
                            20140831-220524.118: Informational: AppHookControllerImpl::onShutdown in
                            20140831-220524.173: Informational: [livetype] onShutdown
                            20140831-220524.174: Informational: [livetype]  disableFontSync
                            20140831-220524.210: Informational: [livetype] deactivated all fonts
                            20140831-220524.241: Informational: AppHookControllerImpl::onShutdown out
                            20140831-220524.242: ACCController::removeAllIcons
                            20140831-220524.268: MControllerDelegate::shutdownRequest
                            20140831-220524.284: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140901-083451.448: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140901-083451.468: ACCController::Init
                            20140901-083451.478: ACCController::Init: init fileState cache
                            20140901-083451.486: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140901-083451.491: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140901-083451.541: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140901-083451.542: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140901-083451.542: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140901-083451.594: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140901-083451.595: Notice: setTargetDataRates: 0 upload, 0 download
                            20140901-083451.595: WorkerThreads: 8
                            20140901-083451.596: Notice: setTargetDataRates: 0 upload, 0 download
                            20140901-083451.598: ACCController::Init: add notification observers
                            20140901-083451.604: CJournalDB::Init: schema differs: incorrect number of tables
                            20140901-083451.606: CJournalDB::_create: successfully created 5 tables
                            20140901-083451.608: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140901-083451.609: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140901-083451.610: ACCController::updateWithState: 11
                            20140901-083451.610: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140901-083451.611: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140901-083451.632: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140901-083451.633: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140901-083451.650: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140901-083451.650: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140901-083451.802: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140901-083451.802: Informational: AppHookControllerImpl::onStartup in
                            20140901-083451.840: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140901-083451.840: Informational: [livetype] onStartup
                            20140901-083451.847: Informational: [livetype] onStartup => success
                            20140901-083451.847: Informational: AppHookControllerImpl::onStartup out
                            20140901-083452.194: ACCController::injectFinderExt
                            20140901-083452.196: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-083452.196: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140901-083452.211: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140901-083452.270: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140901-083452.292: ACCController::finderInitSuccessfull: injectExt:YES
                            20140901-083452.294: ACCController::finderInitSuccessfull: injectExt:YES
                            20140901-083452.294: ACCFinderExtensionController::init: intialization succsessfull
                            20140901-083452.878: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140901-083452.879: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken eba4845d226fff181f26b63d9ab5eb46 userId 6E68593446662ED1992016B8@AdobeID
                            20140901-083452.908: ACCSync::stopJob: forced: 1, reason: Update job
                            20140901-083452.909: 2014-09-01 08:34:52: File Monitoring was asked to stop on: : Update job
                            20140901-083452.910: WorkerThreads: 8
                            20140901-083452.910: Notice: setTargetDataRates: 0 upload, 0 download
                            20140901-083452.911: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140901-083452.912: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140901-083452.912: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140901-083452.912: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140901-083452.913: ACCController::updateWithState: 11
                            20140901-083452.913: Informational: [livetype] syncStatus: OFF
                            20140901-083452.917: Informational: AppHookControllerImpl::onSignIn in
                            20140901-083452.917: Informational: [livetype] onSignIn
                            20140901-083452.918: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140901-083452.918: Informational: AppHookControllerImpl::onSignIn out
                            20140901-083452.919: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140901-083452.921: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140901-083452.923: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140901-083452.923: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140901-083452.923: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140901-083452.923: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140901-083452.924: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140901-083452.924: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140901-083452.924: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140901-083452.924: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140901-083452.925: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140901-083452.925: MControllerDelegate::enableCollaboration: YES
                            20140901-083453.934: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140901-083453.934: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140901-083453.935: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140901-083453.935: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140901-083453.935: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140901-083453.936: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140901-083453.936: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140901-083453.937: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140901-083453.937: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140901-083453.937: MControllerDelegate::enableCollaboration: YES
                            20140901-083453.938: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140901-083453.939: ACCController::updateAccessToken accessToken eba4845d226fff181f26b63d9ab5eb46
                            20140901-083453.939: Informational: AppHookControllerImpl::onUpdateAccessToken in
                            20140901-083453.939: Informational: [livetype] onUpdateAccessToken
                            20140901-083453.939: Informational: AppHookControllerImpl::onUpdateAccessToken out
                            20140901-083453.940: ACCController::updateAccessToken completed
                            20140901-083453.944: MControllerDelegate::disableSync invoked
                            20140901-083453.944: ACCController::disableSync sync is already disabled
                            20140901-083453.946: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140901-083453.947: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140901-083453.947: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140901-083453.948: Informational: [livetype] syncStatus: OFF
                            20140901-091126.015: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-091126.016: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140901-091126.016: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140901-091136.281: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-091136.282: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140901-091136.282: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140901-091317.244: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-091317.244: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140901-091317.245: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140901-124558.269: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-124558.269: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140901-124558.270: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140901-141222.569: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-141222.569: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140901-141222.570: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140901-141258.403: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-141258.403: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140901-141258.404: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140901-141928.550: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-141928.551: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140901-141928.551: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140901-143052.138: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-143052.139: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140901-143052.139: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140901-144221.895: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-144221.896: ACCController::doInjectFinderExt: appIdentifier: com.intuit.Quicken.2015
                            20140901-144221.896: ACCController::doInjectFinderExt: app identifier: com.intuit.Quicken.2015 not equal to com.apple.finder
                            20140901-144327.767: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-144327.768: ACCController::doInjectFinderExt: appIdentifier: com.intuit.Quicken.2015
                            20140901-144327.768: ACCController::doInjectFinderExt: app identifier: com.intuit.Quicken.2015 not equal to com.apple.finder
                            20140901-193555.092: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-193555.093: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140901-193555.093: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140901-193730.549: ACCController::doInjectFinderExt: injectExt = 1
                            20140901-193730.550: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140901-193730.550: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140902-060352.220: ACCController::shutdown
                            20140902-060352.232: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140902-060352.232: 2014-09-02 06:03:52: File Monitoring was asked to stop on: : shutdown
                            20140902-060352.233: 2014-09-02 06:03:52: File Monitoring was asked to stop on: : shutdown
                            20140902-060352.233: Informational: AppHookControllerImpl::onShutdown in
                            20140902-060352.246: MControllerDelegate::shutdownRequest
                            20140902-060352.288: Informational: [livetype] onShutdown
                            20140902-060352.289: Informational: [livetype]  disableFontSync
                            20140902-060352.289: Informational: [livetype] deactivated all fonts
                            20140902-060352.290: Informational: AppHookControllerImpl::onShutdown out
                            20140902-060352.290: ACCController::removeAllIcons
                            20140902-060352.291: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140902-081929.339: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140902-081929.362: ACCController::Init
                            20140902-081929.371: ACCController::Init: init fileState cache
                            20140902-081929.380: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140902-081929.383: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140902-081929.435: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140902-081929.435: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140902-081929.436: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140902-081929.488: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140902-081929.489: Notice: setTargetDataRates: 0 upload, 0 download
                            20140902-081929.490: WorkerThreads: 8
                            20140902-081929.490: Notice: setTargetDataRates: 0 upload, 0 download
                            20140902-081929.492: ACCController::Init: add notification observers
                            20140902-081929.499: CJournalDB::Init: schema differs: incorrect number of tables
                            20140902-081929.501: CJournalDB::_create: successfully created 5 tables
                            20140902-081929.504: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140902-081929.506: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140902-081929.507: ACCController::updateWithState: 11
                            20140902-081929.507: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140902-081929.508: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140902-081929.533: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140902-081929.533: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140902-081929.567: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140902-081929.567: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140902-081929.585: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140902-081929.585: Informational: AppHookControllerImpl::onStartup in
                            20140902-081929.591: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140902-081929.591: Informational: [livetype] onStartup
                            20140902-081929.597: Informational: [livetype] onStartup => success
                            20140902-081929.597: Informational: AppHookControllerImpl::onStartup out
                            20140902-081929.650: ACCController::injectFinderExt
                            20140902-081929.652: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-081929.652: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140902-081929.668: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140902-081929.728: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140902-081929.755: ACCController::finderInitSuccessfull: injectExt:YES
                            20140902-081929.757: ACCController::finderInitSuccessfull: injectExt:YES
                            20140902-081929.757: ACCFinderExtensionController::init: intialization succsessfull
                            20140902-081930.658: MControllerDelegate::invalidateAccessToken
                            20140902-081930.658: ACCController::invalidateAccessToken
                            20140902-081930.659: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-081930.659: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-081930.660: Informational: [livetype] onInvalidateAccessToken
                            20140902-081930.660: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-081930.661: ACCController::invalidateAccessToken completed
                            20140902-081930.666: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140902-081930.668: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140902-081930.669: Informational: [livetype] syncStatus: OFF
                            20140902-081939.410: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140902-081939.411: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140902-081939.411: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140902-081939.412: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140902-081939.412: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140902-081939.413: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140902-081939.413: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140902-081939.414: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140902-081939.414: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140902-081939.414: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140902-081939.415: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140902-081939.415: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140902-081939.415: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140902-081939.416: MControllerDelegate::enableCollaboration: YES
                            20140902-081940.688: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140902-081940.689: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140902-081940.689: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140902-081940.690: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140902-081940.690: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140902-081940.691: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140902-081940.692: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140902-081940.692: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140902-081940.692: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140902-081940.693: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140902-081940.693: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140902-081940.693: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140902-081940.694: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140902-081940.694: MControllerDelegate::enableCollaboration: YES
                            20140902-081940.696: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140902-081940.697: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken ef83fdc5d55f1a518b1c085165af6439 userId 6E68593446662ED1992016B8@AdobeID
                            20140902-081940.698: MControllerDelegate::disableSync invoked
                            20140902-081940.700: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140902-081940.700: ACCSync::stopJob: forced: 1, reason: Update job
                            20140902-081940.701: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140902-081940.705: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140902-081940.705: 2014-09-02 08:19:40: File Monitoring was asked to stop on: : Update job
                            20140902-081940.708: 2014-09-02 08:19:40: File Monitoring was asked to stop on: : Update job
                            20140902-081940.708: Informational: [livetype] syncStatus: OFF
                            20140902-081940.710: WorkerThreads: 8
                            20140902-081940.711: Notice: setTargetDataRates: 0 upload, 0 download
                            20140902-081940.713: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140902-081940.713: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140902-081940.714: ACCController::updateWithState: 11
                            20140902-081940.714: Informational: AppHookControllerImpl::onSignIn in
                            20140902-081940.715: Informational: [livetype] onSignIn
                            20140902-081940.716: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140902-081940.716: Informational: AppHookControllerImpl::onSignIn out
                            20140902-081940.717: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140902-081940.717: ACCController::disableSync sync is already disabled
                            20140902-081940.719: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140902-081940.720: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140902-081957.085: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-081957.086: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140902-081957.086: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140902-082310.720: ACCController::osSleepWake: NSConcreteNotification 0x7fb5ecc38300 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fb5ea710760>}
                            20140902-082310.721: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140902-082310.721: 2014-09-02 08:23:10: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140902-082310.722: 2014-09-02 08:23:10: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140902-082435.690: ACCController::osSleepWake: NSConcreteNotification 0x7fb5eca02420 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fb5ea710760>}
                            20140902-082435.724: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140902-083239.943: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-083239.943: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140902-083239.943: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140902-083254.995: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-083254.996: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140902-083254.996: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140902-083401.812: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-083401.812: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140902-083401.813: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140902-083751.243: ACCController::osSleepWake: NSConcreteNotification 0x7fb5ecc37d40 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fb5ea710760>}
                            20140902-083751.244: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140902-083751.244: 2014-09-02 08:37:51: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140902-083751.245: 2014-09-02 08:37:51: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140902-084249.697: ACCController::osSleepWake: NSConcreteNotification 0x7fb5ea71bfe0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fb5ea710760>}
                            20140902-084249.698: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140902-084448.576: ACCController::osSleepWake: NSConcreteNotification 0x7fb5ecc47bd0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fb5ea710760>}
                            20140902-084448.577: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140902-084448.577: 2014-09-02 08:44:48: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140902-084448.578: 2014-09-02 08:44:48: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140902-084503.423: ACCController::osSleepWake: NSConcreteNotification 0x7fb5ea613cc0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fb5ea710760>}
                            20140902-085336.717: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-085336.718: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140902-085336.718: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140902-085722.256: ACCController::shutdown
                            20140902-085722.257: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140902-085722.257: 2014-09-02 08:57:22: File Monitoring was asked to stop on: : shutdown
                            20140902-085722.258: 2014-09-02 08:57:22: File Monitoring was asked to stop on: : shutdown
                            20140902-085722.258: Informational: AppHookControllerImpl::onShutdown in
                            20140902-085722.321: MControllerDelegate::shutdownRequest
                            20140902-085722.335: Informational: [livetype] onShutdown
                            20140902-085722.336: Informational: [livetype]  disableFontSync
                            20140902-085722.336: Informational: [livetype] deactivated all fonts
                            20140902-085722.337: Informational: AppHookControllerImpl::onShutdown out
                            20140902-085722.338: ACCController::removeAllIcons
                            20140902-085722.338: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140902-095553.221: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140902-095553.513: ACCController::Init
                            20140902-095553.563: ACCController::Init: init fileState cache
                            20140902-095553.699: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140902-095553.735: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140902-095553.785: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140902-095553.786: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140902-095553.786: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140902-095553.838: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140902-095553.849: Notice: setTargetDataRates: 0 upload, 0 download
                            20140902-095553.849: WorkerThreads: 8
                            20140902-095553.850: Notice: setTargetDataRates: 0 upload, 0 download
                            20140902-095553.860: ACCController::Init: add notification observers
                            20140902-095553.957: CJournalDB::Init: schema differs: incorrect number of tables
                            20140902-095553.958: CJournalDB::_create: successfully created 5 tables
                            20140902-095554.034: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140902-095554.040: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140902-095554.041: ACCController::updateWithState: 11
                            20140902-095554.041: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140902-095554.063: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140902-095554.332: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140902-095554.333: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140902-095554.351: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140902-095554.351: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140902-095554.364: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140902-095554.364: Informational: AppHookControllerImpl::onStartup in
                            20140902-095554.369: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140902-095554.369: Informational: [livetype] onStartup
                            20140902-095554.371: Informational: [livetype] onStartup => success
                            20140902-095554.372: Informational: AppHookControllerImpl::onStartup out
                            20140902-095554.413: ACCController::injectFinderExt
                            20140902-095554.414: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-095554.414: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140902-095554.429: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140902-095554.511: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140902-095554.553: ACCController::finderInitSuccessfull: injectExt:YES
                            20140902-095554.554: ACCController::finderInitSuccessfull: injectExt:YES
                            20140902-095554.555: ACCFinderExtensionController::init: intialization succsessfull
                            20140902-095555.410: MControllerDelegate::invalidateAccessToken
                            20140902-095555.411: ACCController::invalidateAccessToken
                            20140902-095555.411: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-095555.411: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-095555.412: Informational: [livetype] onInvalidateAccessToken
                            20140902-095555.412: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-095555.413: ACCController::invalidateAccessToken completed
                            20140902-095557.640: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140902-095557.641: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140902-095557.663: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140902-095557.663: Informational: [livetype] syncStatus: OFF
                            20140902-095719.972: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-095719.972: ACCController::doInjectFinderExt: appIdentifier: com.intuit.Quicken.2015
                            20140902-095719.973: ACCController::doInjectFinderExt: app identifier: com.intuit.Quicken.2015 not equal to com.apple.finder
                            20140902-100128.708: MControllerDelegate::invalidateAccessToken
                            20140902-100128.709: ACCController::invalidateAccessToken
                            20140902-100128.709: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-100128.709: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-100128.710: Informational: [livetype] onInvalidateAccessToken
                            20140902-100128.710: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-100128.710: ACCController::invalidateAccessToken completed
                            20140902-100517.988: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-100517.989: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140902-100517.989: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140902-100700.184: MControllerDelegate::invalidateAccessToken
                            20140902-100700.184: ACCController::invalidateAccessToken
                            20140902-100700.184: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-100700.185: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-100700.185: Informational: [livetype] onInvalidateAccessToken
                            20140902-100700.185: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-100700.185: ACCController::invalidateAccessToken completed
                            20140902-101231.756: MControllerDelegate::invalidateAccessToken
                            20140902-101231.757: ACCController::invalidateAccessToken
                            20140902-101231.757: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-101231.757: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-101231.757: Informational: [livetype] onInvalidateAccessToken
                            20140902-101231.758: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-101231.758: ACCController::invalidateAccessToken completed
                            20140902-101803.248: MControllerDelegate::invalidateAccessToken
                            20140902-101803.248: ACCController::invalidateAccessToken
                            20140902-101803.248: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-101803.249: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-101803.249: Informational: [livetype] onInvalidateAccessToken
                            20140902-101803.249: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-101803.249: ACCController::invalidateAccessToken completed
                            20140902-102334.807: MControllerDelegate::invalidateAccessToken
                            20140902-102334.807: ACCController::invalidateAccessToken
                            20140902-102334.807: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-102334.807: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-102334.808: Informational: [livetype] onInvalidateAccessToken
                            20140902-102334.808: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-102334.808: ACCController::invalidateAccessToken completed
                            20140902-102906.348: MControllerDelegate::invalidateAccessToken
                            20140902-102906.348: ACCController::invalidateAccessToken
                            20140902-102906.348: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-102906.349: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-102906.349: Informational: [livetype] onInvalidateAccessToken
                            20140902-102906.349: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-102906.349: ACCController::invalidateAccessToken completed
                            20140902-103437.856: MControllerDelegate::invalidateAccessToken
                            20140902-103437.856: ACCController::invalidateAccessToken
                            20140902-103437.856: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-103437.857: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-103437.857: Informational: [livetype] onInvalidateAccessToken
                            20140902-103437.857: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-103437.857: ACCController::invalidateAccessToken completed
                            20140902-104009.262: MControllerDelegate::invalidateAccessToken
                            20140902-104009.262: ACCController::invalidateAccessToken
                            20140902-104009.263: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-104009.263: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-104009.263: Informational: [livetype] onInvalidateAccessToken
                            20140902-104009.263: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-104009.264: ACCController::invalidateAccessToken completed
                            20140902-104540.837: MControllerDelegate::invalidateAccessToken
                            20140902-104540.837: ACCController::invalidateAccessToken
                            20140902-104540.837: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-104540.838: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-104540.838: Informational: [livetype] onInvalidateAccessToken
                            20140902-104540.838: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-104540.838: ACCController::invalidateAccessToken completed
                            20140902-105112.311: MControllerDelegate::invalidateAccessToken
                            20140902-105112.312: ACCController::invalidateAccessToken
                            20140902-105112.312: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-105112.312: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-105112.312: Informational: [livetype] onInvalidateAccessToken
                            20140902-105112.313: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-105112.313: ACCController::invalidateAccessToken completed
                            20140902-105643.820: MControllerDelegate::invalidateAccessToken
                            20140902-105643.820: ACCController::invalidateAccessToken
                            20140902-105643.820: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-105643.821: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-105643.821: Informational: [livetype] onInvalidateAccessToken
                            20140902-105643.821: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-105643.821: ACCController::invalidateAccessToken completed
                            20140902-105733.666: ACCController::osSleepWake: NSConcreteNotification 0x7fb4c843b520 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fb4c8726ed0>}
                            20140902-105733.667: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140902-105733.670: 2014-09-02 10:57:33: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140902-110759.308: ACCController::osSleepWake: NSConcreteNotification 0x7fb4c85b86a0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fb4c8726ed0>}
                            20140902-111022.508: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-111022.509: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140902-111022.509: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140902-111159.190: MControllerDelegate::invalidateAccessToken
                            20140902-111159.191: ACCController::invalidateAccessToken
                            20140902-111159.191: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-111159.191: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-111159.192: Informational: [livetype] onInvalidateAccessToken
                            20140902-111159.192: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-111159.192: ACCController::invalidateAccessToken completed
                            20140902-111515.109: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-111515.109: ACCController::doInjectFinderExt: appIdentifier: com.apple.QuickTimePlayerX
                            20140902-111515.109: ACCController::doInjectFinderExt: app identifier: com.apple.QuickTimePlayerX not equal to com.apple.finder
                            20140902-111730.697: MControllerDelegate::invalidateAccessToken
                            20140902-111730.697: ACCController::invalidateAccessToken
                            20140902-111730.698: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-111730.698: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-111730.698: Informational: [livetype] onInvalidateAccessToken
                            20140902-111730.698: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-111730.699: ACCController::invalidateAccessToken completed
                            20140902-112112.648: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-112112.649: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140902-112112.649: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140902-112302.593: MControllerDelegate::invalidateAccessToken
                            20140902-112302.594: ACCController::invalidateAccessToken
                            20140902-112302.594: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-112302.594: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-112302.595: Informational: [livetype] onInvalidateAccessToken
                            20140902-112302.595: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-112302.595: ACCController::invalidateAccessToken completed
                            20140902-112835.054: MControllerDelegate::invalidateAccessToken
                            20140902-112835.055: ACCController::invalidateAccessToken
                            20140902-112835.055: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-112835.056: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-112835.056: Informational: [livetype] onInvalidateAccessToken
                            20140902-112835.057: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-112835.057: ACCController::invalidateAccessToken completed
                            20140902-112954.922: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-112954.922: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Lightroom5
                            20140902-112954.923: ACCController::doInjectFinderExt: app identifier: com.adobe.Lightroom5 not equal to com.apple.finder
                            20140902-113351.673: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-113351.674: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140902-113351.674: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140902-113407.585: MControllerDelegate::invalidateAccessToken
                            20140902-113407.585: ACCController::invalidateAccessToken
                            20140902-113407.586: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-113407.586: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-113407.586: Informational: [livetype] onInvalidateAccessToken
                            20140902-113407.586: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-113407.587: ACCController::invalidateAccessToken completed
                            20140902-113939.975: MControllerDelegate::invalidateAccessToken
                            20140902-113939.975: ACCController::invalidateAccessToken
                            20140902-113939.976: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-113939.976: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-113939.976: Informational: [livetype] onInvalidateAccessToken
                            20140902-113939.976: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-113939.977: ACCController::invalidateAccessToken completed
                            20140902-114503.808: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-114503.809: ACCController::doInjectFinderExt: appIdentifier: com.adobe.bridge6
                            20140902-114503.809: ACCController::doInjectFinderExt: app identifier: com.adobe.bridge6 not equal to com.apple.finder
                            20140902-114511.359: MControllerDelegate::invalidateAccessToken
                            20140902-114511.360: ACCController::invalidateAccessToken
                            20140902-114511.360: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-114511.360: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-114511.361: Informational: [livetype] onInvalidateAccessToken
                            20140902-114511.361: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-114511.361: ACCController::invalidateAccessToken completed
                            20140902-114535.852: ACCController::osSleepWake: NSConcreteNotification 0x7fb4caa00000 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fb4c8726ed0>}
                            20140902-114535.852: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140902-114535.853: 2014-09-02 11:45:35: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140902-114607.331: ACCController::osSleepWake: NSConcreteNotification 0x7fb4c85cb690 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fb4c8726ed0>}
                            20140902-114630.504: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-114630.505: ACCController::doInjectFinderExt: appIdentifier: com.adobe.bridge6
                            20140902-114630.505: ACCController::doInjectFinderExt: app identifier: com.adobe.bridge6 not equal to com.apple.finder
                            20140902-114833.945: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-114833.945: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140902-114833.946: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140902-115044.063: MControllerDelegate::invalidateAccessToken
                            20140902-115044.063: ACCController::invalidateAccessToken
                            20140902-115044.063: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-115044.064: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-115044.064: Informational: [livetype] onInvalidateAccessToken
                            20140902-115044.064: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-115044.064: ACCController::invalidateAccessToken completed
                            20140902-115325.653: ACCController::osSleepWake: NSConcreteNotification 0x7fb4caa035d0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fb4c8726ed0>}
                            20140902-115325.654: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140902-115325.655: 2014-09-02 11:53:25: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140902-115448.848: ACCController::osSleepWake: NSConcreteNotification 0x7fb4caa018b0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fb4c8726ed0>}
                            20140902-115718.311: MControllerDelegate::invalidateAccessToken
                            20140902-115718.311: ACCController::invalidateAccessToken
                            20140902-115718.311: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-115718.312: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-115718.312: Informational: [livetype] onInvalidateAccessToken
                            20140902-115718.312: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-115718.313: ACCController::invalidateAccessToken completed
                            20140902-120250.793: MControllerDelegate::invalidateAccessToken
                            20140902-120250.794: ACCController::invalidateAccessToken
                            20140902-120250.794: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-120250.794: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-120250.794: Informational: [livetype] onInvalidateAccessToken
                            20140902-120250.795: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-120250.795: ACCController::invalidateAccessToken completed
                            20140902-120411.506: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-120411.507: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140902-120411.507: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140902-120822.891: MControllerDelegate::invalidateAccessToken
                            20140902-120822.892: ACCController::invalidateAccessToken
                            20140902-120822.892: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-120822.892: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-120822.893: Informational: [livetype] onInvalidateAccessToken
                            20140902-120822.893: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-120822.893: ACCController::invalidateAccessToken completed
                            20140902-121355.279: MControllerDelegate::invalidateAccessToken
                            20140902-121355.280: ACCController::invalidateAccessToken
                            20140902-121355.280: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-121355.280: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-121355.281: Informational: [livetype] onInvalidateAccessToken
                            20140902-121355.281: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-121355.281: ACCController::invalidateAccessToken completed
                            20140902-121927.802: MControllerDelegate::invalidateAccessToken
                            20140902-121927.803: ACCController::invalidateAccessToken
                            20140902-121927.803: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-121927.803: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-121927.803: Informational: [livetype] onInvalidateAccessToken
                            20140902-121927.804: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-121927.804: ACCController::invalidateAccessToken completed
                            20140902-122500.117: MControllerDelegate::invalidateAccessToken
                            20140902-122500.118: ACCController::invalidateAccessToken
                            20140902-122500.118: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-122500.118: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-122500.118: Informational: [livetype] onInvalidateAccessToken
                            20140902-122500.119: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-122500.119: ACCController::invalidateAccessToken completed
                            20140902-123032.578: MControllerDelegate::invalidateAccessToken
                            20140902-123032.578: ACCController::invalidateAccessToken
                            20140902-123032.579: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-123032.579: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-123032.579: Informational: [livetype] onInvalidateAccessToken
                            20140902-123032.579: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-123032.580: ACCController::invalidateAccessToken completed
                            20140902-123604.813: MControllerDelegate::invalidateAccessToken
                            20140902-123604.813: ACCController::invalidateAccessToken
                            20140902-123604.814: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-123604.814: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-123604.814: Informational: [livetype] onInvalidateAccessToken
                            20140902-123604.814: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-123604.815: ACCController::invalidateAccessToken completed
                            20140902-124137.336: MControllerDelegate::invalidateAccessToken
                            20140902-124137.336: ACCController::invalidateAccessToken
                            20140902-124137.337: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-124137.337: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-124137.337: Informational: [livetype] onInvalidateAccessToken
                            20140902-124137.338: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-124137.338: ACCController::invalidateAccessToken completed
                            20140902-124521.675: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-124521.676: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140902-124521.676: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140902-124709.673: MControllerDelegate::invalidateAccessToken
                            20140902-124709.674: ACCController::invalidateAccessToken
                            20140902-124709.674: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-124709.674: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-124709.674: Informational: [livetype] onInvalidateAccessToken
                            20140902-124709.675: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-124709.675: ACCController::invalidateAccessToken completed
                            20140902-125242.046: MControllerDelegate::invalidateAccessToken
                            20140902-125242.047: ACCController::invalidateAccessToken
                            20140902-125242.047: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-125242.047: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-125242.048: Informational: [livetype] onInvalidateAccessToken
                            20140902-125242.048: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-125242.048: ACCController::invalidateAccessToken completed
                            20140902-125814.461: MControllerDelegate::invalidateAccessToken
                            20140902-125814.461: ACCController::invalidateAccessToken
                            20140902-125814.461: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-125814.462: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-125814.462: Informational: [livetype] onInvalidateAccessToken
                            20140902-125814.462: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-125814.463: ACCController::invalidateAccessToken completed
                            20140902-130346.751: MControllerDelegate::invalidateAccessToken
                            20140902-130346.751: ACCController::invalidateAccessToken
                            20140902-130346.752: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-130346.752: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-130346.752: Informational: [livetype] onInvalidateAccessToken
                            20140902-130346.753: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-130346.753: ACCController::invalidateAccessToken completed
                            20140902-130918.912: MControllerDelegate::invalidateAccessToken
                            20140902-130918.912: ACCController::invalidateAccessToken
                            20140902-130918.912: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-130918.913: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-130918.913: Informational: [livetype] onInvalidateAccessToken
                            20140902-130918.913: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-130918.913: ACCController::invalidateAccessToken completed
                            20140902-131451.296: MControllerDelegate::invalidateAccessToken
                            20140902-131451.296: ACCController::invalidateAccessToken
                            20140902-131451.297: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-131451.297: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-131451.297: Informational: [livetype] onInvalidateAccessToken
                            20140902-131451.297: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-131451.298: ACCController::invalidateAccessToken completed
                            20140902-132023.522: MControllerDelegate::invalidateAccessToken
                            20140902-132023.522: ACCController::invalidateAccessToken
                            20140902-132023.523: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-132023.523: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-132023.523: Informational: [livetype] onInvalidateAccessToken
                            20140902-132023.523: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-132023.524: ACCController::invalidateAccessToken completed
                            20140902-132556.046: MControllerDelegate::invalidateAccessToken
                            20140902-132556.046: ACCController::invalidateAccessToken
                            20140902-132556.047: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-132556.047: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-132556.047: Informational: [livetype] onInvalidateAccessToken
                            20140902-132556.047: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-132556.048: ACCController::invalidateAccessToken completed
                            20140902-132850.051: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-132850.052: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Lightroom5
                            20140902-132850.052: ACCController::doInjectFinderExt: app identifier: com.adobe.Lightroom5 not equal to com.apple.finder
                            20140902-132904.873: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-132904.873: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140902-132904.874: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140902-133128.326: MControllerDelegate::invalidateAccessToken
                            20140902-133128.327: ACCController::invalidateAccessToken
                            20140902-133128.327: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-133128.327: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-133128.327: Informational: [livetype] onInvalidateAccessToken
                            20140902-133128.328: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-133128.328: ACCController::invalidateAccessToken completed
                            20140902-133300.261: ACCController::shutdown
                            20140902-133300.262: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140902-133300.262: 2014-09-02 13:33:00: File Monitoring was asked to stop on: : shutdown
                            20140902-133300.263: 2014-09-02 13:33:00: File Monitoring was asked to stop on: : shutdown
                            20140902-133300.263: Informational: AppHookControllerImpl::onShutdown in
                            20140902-133300.282: MControllerDelegate::shutdownRequest
                            20140902-133300.321: Informational: [livetype] onShutdown
                            20140902-133300.322: Informational: [livetype]  disableFontSync
                            20140902-133300.322: Informational: [livetype] deactivated all fonts
                            20140902-133300.322: Informational: AppHookControllerImpl::onShutdown out
                            20140902-133300.323: ACCController::removeAllIcons
                            20140902-133300.324: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140902-174346.353: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140902-174346.390: ACCController::Init
                            20140902-174346.401: ACCController::Init: init fileState cache
                            20140902-174346.406: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140902-174346.409: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140902-174346.460: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140902-174346.461: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140902-174346.461: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140902-174346.513: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140902-174346.514: Notice: setTargetDataRates: 0 upload, 0 download
                            20140902-174346.515: WorkerThreads: 8
                            20140902-174346.515: Notice: setTargetDataRates: 0 upload, 0 download
                            20140902-174346.517: ACCController::Init: add notification observers
                            20140902-174346.522: CJournalDB::Init: schema differs: incorrect number of tables
                            20140902-174346.524: CJournalDB::_create: successfully created 5 tables
                            20140902-174346.693: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140902-174346.695: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140902-174346.695: ACCController::updateWithState: 11
                            20140902-174346.696: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140902-174346.697: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140902-174346.707: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140902-174346.708: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140902-174346.716: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140902-174346.717: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140902-174346.726: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140902-174346.726: Informational: AppHookControllerImpl::onStartup in
                            20140902-174346.744: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140902-174346.744: Informational: [livetype] onStartup
                            20140902-174346.747: Informational: [livetype] onStartup => success
                            20140902-174346.747: Informational: AppHookControllerImpl::onStartup out
                            20140902-174346.791: ACCController::injectFinderExt
                            20140902-174346.794: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-174346.794: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140902-174346.849: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140902-174346.941: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140902-174346.969: ACCController::finderInitSuccessfull: injectExt:YES
                            20140902-174346.972: ACCController::finderInitSuccessfull: injectExt:YES
                            20140902-174346.973: ACCFinderExtensionController::init: intialization succsessfull
                            20140902-174347.815: MControllerDelegate::invalidateAccessToken
                            20140902-174347.816: ACCController::invalidateAccessToken
                            20140902-174347.817: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140902-174347.818: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140902-174347.818: Informational: [livetype] onInvalidateAccessToken
                            20140902-174347.818: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140902-174347.819: ACCController::invalidateAccessToken completed
                            20140902-174348.548: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140902-174348.577: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140902-174348.577: Informational: [livetype] syncStatus: OFF
                            20140902-174536.015: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140902-174536.015: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140902-174536.016: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140902-174536.016: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140902-174536.017: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140902-174536.017: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140902-174536.017: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140902-174536.018: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140902-174536.018: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140902-174536.018: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140902-174536.018: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140902-174536.019: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140902-174536.019: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140902-174536.019: MControllerDelegate::enableCollaboration: YES
                            20140902-174537.008: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140902-174537.008: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140902-174537.008: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140902-174537.008: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140902-174537.009: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140902-174537.009: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140902-174537.010: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140902-174537.010: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140902-174537.010: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140902-174537.010: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140902-174537.011: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140902-174537.011: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140902-174537.011: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140902-174537.011: MControllerDelegate::enableCollaboration: YES
                            20140902-174537.012: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140902-174537.013: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 57a17f3db4e0b2ad27b861b6e726a6d7 userId 6E68593446662ED1992016B8@AdobeID
                            20140902-174537.014: MControllerDelegate::disableSync invoked
                            20140902-174537.016: ACCSync::stopJob: forced: 1, reason: Update job
                            20140902-174537.016: 2014-09-02 17:45:37: File Monitoring was asked to stop on: : Update job
                            20140902-174537.017: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140902-174537.018: WorkerThreads: 8
                            20140902-174537.019: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140902-174537.020: Notice: setTargetDataRates: 0 upload, 0 download
                            20140902-174537.022: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140902-174537.023: Informational: [livetype] syncStatus: OFF
                            20140902-174537.023: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140902-174537.024: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140902-174537.024: ACCController::updateWithState: 11
                            20140902-174537.025: Informational: AppHookControllerImpl::onSignIn in
                            20140902-174537.026: Informational: [livetype] onSignIn
                            20140902-174537.026: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140902-174537.027: Informational: AppHookControllerImpl::onSignIn out
                            20140902-174537.027: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140902-174537.027: ACCController::disableSync sync is already disabled
                            20140902-174537.029: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140902-174537.030: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140902-204544.411: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-204544.411: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140902-204544.412: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140902-204553.855: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-204553.856: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140902-204553.856: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140902-204644.173: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-204644.174: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140902-204644.174: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140902-204833.403: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-204833.404: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140902-204833.404: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140902-204959.377: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-204959.378: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140902-204959.378: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140902-205035.627: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-205035.627: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140902-205035.628: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140902-205037.865: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-205037.865: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.autoupdate2
                            20140902-205037.866: ACCController::doInjectFinderExt: app identifier: com.microsoft.autoupdate2 not equal to com.apple.finder
                            20140902-205837.732: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-205837.732: ACCController::doInjectFinderExt: appIdentifier: com.apple.installer
                            20140902-205837.733: ACCController::doInjectFinderExt: app identifier: com.apple.installer not equal to com.apple.finder
                            20140902-210130.788: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-210130.789: ACCController::doInjectFinderExt: appIdentifier: com.apple.Safari
                            20140902-210130.789: ACCController::doInjectFinderExt: app identifier: com.apple.Safari not equal to com.apple.finder
                            20140902-210158.773: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-210158.773: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140902-210158.774: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140902-210307.017: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-210307.017: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140902-210307.018: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140902-210443.793: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-210443.793: ACCController::doInjectFinderExt: appIdentifier: com.dashlane.Dashlane
                            20140902-210443.794: ACCController::doInjectFinderExt: app identifier: com.dashlane.Dashlane not equal to com.apple.finder
                            20140902-211115.606: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-211115.606: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140902-211115.607: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140902-212606.269: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-212606.269: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140902-212606.270: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140902-220927.783: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-220927.783: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140902-220927.783: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140902-221049.379: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-221049.380: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140902-221049.380: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140902-222144.077: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-222144.078: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140902-222144.078: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140902-222750.188: ACCController::doInjectFinderExt: injectExt = 1
                            20140902-222750.189: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140902-222750.190: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140902-223605.410: ACCController::osSleepWake: NSConcreteNotification 0x7fd2b406fc40 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fd2b2561970>}
                            20140902-223605.411: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140902-223605.412: 2014-09-02 22:36:05: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140903-045145.687: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-053007.151: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-054200.189: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-064200.150: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-074200.159: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-074922.176: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-074923.001: ACCController::osSleepWake: NSConcreteNotification 0x7fd2b253d520 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fd2b2561970>}
                            20140903-082400.515: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-082400.515: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140903-082400.516: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140903-083057.968: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-083057.969: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140903-083057.969: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140903-083436.930: ACCController::osSleepWake: NSConcreteNotification 0x7fd2b253d520 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fd2b2561970>}
                            20140903-083436.930: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140903-083436.931: 2014-09-03 08:34:36: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140903-090451.195: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-091810.188: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-092932.848: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-092932.863: ACCController::osSleepWake: NSConcreteNotification 0x7fd2b42fb3d0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fd2b2561970>}
                            20140903-094855.542: ACCController::osSleepWake: NSConcreteNotification 0x7fd2b2707200 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fd2b2561970>}
                            20140903-094855.543: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140903-094855.544: 2014-09-03 09:48:55: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140903-105921.306: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-142926.709: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-142928.987: ACCController::osSleepWake: NSConcreteNotification 0x7fd2b4059220 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fd2b2561970>}
                            20140903-144128.173: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-144128.173: ACCController::doInjectFinderExt: appIdentifier: com.apple.archiveutility
                            20140903-144128.174: ACCController::doInjectFinderExt: app identifier: com.apple.archiveutility not equal to com.apple.finder
                            20140903-144140.790: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-144140.790: ACCController::doInjectFinderExt: appIdentifier: com.adobe.illustrator
                            20140903-144140.791: ACCController::doInjectFinderExt: app identifier: com.adobe.illustrator not equal to com.apple.finder
                            20140903-144218.366: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-144218.367: ACCController::doInjectFinderExt: appIdentifier: com.adobe.illustrator
                            20140903-144218.367: ACCController::doInjectFinderExt: app identifier: com.adobe.illustrator not equal to com.apple.finder
                            20140903-144239.004: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-144239.005: ACCController::doInjectFinderExt: appIdentifier: com.adobe.illustrator
                            20140903-144239.005: ACCController::doInjectFinderExt: app identifier: com.adobe.illustrator not equal to com.apple.finder
                            20140903-144959.608: MControllerDelegate::enableSync invoked
                            20140903-144959.610: ACCController::enableSync switch sync ON
                            20140903-144959.613: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-144959.625: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-144959.630: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-144959.630: ACCController::updateWithState: 1
                            20140903-144959.630: ACCController::updateLocalFolder:
                            20140903-144959.630: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-144959.632: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-144959.632: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-144959.632: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-144959.633: MControllerDelegate::syncStatus state 1 (CoreSyncStateSignedIn)
                            20140903-144959.634: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-144959.635: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-144959.635: There is no cloud folder at [], so now initalize it.
                            20140903-144959.636: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-144959.636: ACCController::enableSync switch sync OFF
                            20140903-144959.637: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-144959.638: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-144959.638: ACCController::updateWithState: 11
                            20140903-144959.640: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-144959.640: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-144959.641: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-144959.642: 2014-09-03 14:49:59: File Monitoring was asked to stop on: : Sync turned off
                            20140903-144959.644: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-144959.644: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-144959.645: ACCController::updateWithState: 11
                            20140903-144959.645: ACCController::removeAllIcons
                            20140903-144959.646: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-144959.646: ACCController::enableSync completed switch sync OFF
                            20140903-144959.648: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-144959.648: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-144959.649: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-144959.649: 2014-09-03 14:49:59: File Monitoring was asked to stop on: : Update job
                            20140903-144959.650: WorkerThreads: 8
                            20140903-144959.650: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-144959.651: ACCController::enableSync completed switch sync ON
                            20140903-145101.300: MControllerDelegate::enableSync invoked
                            20140903-145101.301: ACCController::enableSync switch sync ON
                            20140903-145101.303: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145101.304: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-145101.304: ACCController::updateWithState: 1
                            20140903-145101.305: ACCController::updateLocalFolder:
                            20140903-145101.305: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145101.307: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-145101.308: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-145101.309: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-145101.309: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145101.311: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-145101.312: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-145101.312: There is no cloud folder at [], so now initalize it.
                            20140903-145101.313: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-145101.313: ACCController::enableSync switch sync OFF
                            20140903-145101.313: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145101.314: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-145101.314: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145101.315: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-145101.317: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145101.317: ACCController::updateWithState: 11
                            20140903-145101.318: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145101.319: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145101.319: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-145101.319: 2014-09-03 14:51:01: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145101.320: 2014-09-03 14:51:01: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145101.321: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145101.322: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145101.322: ACCController::updateWithState: 11
                            20140903-145101.323: ACCController::removeAllIcons
                            20140903-145101.323: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145101.324: ACCController::enableSync completed switch sync OFF
                            20140903-145101.325: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145101.326: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145101.326: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145101.326: 2014-09-03 14:51:01: File Monitoring was asked to stop on: : Update job
                            20140903-145101.327: 2014-09-03 14:51:01: File Monitoring was asked to stop on: : Update job
                            20140903-145101.327: WorkerThreads: 8
                            20140903-145101.327: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145101.327: ACCController::enableSync completed switch sync ON
                            20140903-145158.077: MControllerDelegate::enableSync invoked
                            20140903-145158.078: ACCController::enableSync switch sync ON
                            20140903-145158.080: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145158.081: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-145158.081: ACCController::updateWithState: 1
                            20140903-145158.082: ACCController::updateLocalFolder:
                            20140903-145158.082: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145158.083: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-145158.085: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-145158.086: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-145158.086: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145158.088: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-145158.088: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-145158.088: There is no cloud folder at [], so now initalize it.
                            20140903-145158.088: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-145158.089: ACCController::enableSync switch sync OFF
                            20140903-145158.093: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145158.097: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-145158.098: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145158.098: ACCController::updateWithState: 11
                            20140903-145158.099: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145158.100: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145158.100: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-145158.101: 2014-09-03 14:51:58: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145158.102: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145158.103: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145158.103: ACCController::updateWithState: 11
                            20140903-145158.104: ACCController::removeAllIcons
                            20140903-145158.104: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145158.105: ACCController::enableSync completed switch sync OFF
                            20140903-145158.106: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145158.107: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145158.107: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145158.108: 2014-09-03 14:51:58: File Monitoring was asked to stop on: : Update job
                            20140903-145158.109: WorkerThreads: 8
                            20140903-145158.109: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145158.110: ACCController::enableSync completed switch sync ON
                            20140903-145221.396: MControllerDelegate::enableSync invoked
                            20140903-145221.396: ACCController::enableSync switch sync ON
                            20140903-145221.398: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145221.399: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-145221.399: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145221.399: ACCController::updateWithState: 1
                            20140903-145221.402: ACCController::updateLocalFolder:
                            20140903-145221.403: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-145221.406: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-145221.406: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145221.406: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-145221.410: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-145221.411: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-145221.411: There is no cloud folder at [], so now initalize it.
                            20140903-145221.412: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-145221.412: ACCController::enableSync switch sync OFF
                            20140903-145221.412: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145221.413: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-145221.413: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-145221.413: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145221.414: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145221.414: ACCController::updateWithState: 11
                            20140903-145221.416: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145221.416: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145221.417: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-145221.417: 2014-09-03 14:52:21: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145221.418: 2014-09-03 14:52:21: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145221.419: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145221.419: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145221.420: ACCController::updateWithState: 11
                            20140903-145221.420: ACCController::removeAllIcons
                            20140903-145221.421: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145221.421: ACCController::enableSync completed switch sync OFF
                            20140903-145221.422: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145221.423: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145221.423: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145221.424: 2014-09-03 14:52:21: File Monitoring was asked to stop on: : Update job
                            20140903-145221.424: WorkerThreads: 8
                            20140903-145221.424: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145221.425: ACCController::enableSync completed switch sync ON
                            20140903-145249.132: MControllerDelegate::enableSync invoked
                            20140903-145249.132: ACCController::enableSync switch sync ON
                            20140903-145249.134: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145249.135: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-145249.135: ACCController::updateWithState: 1
                            20140903-145249.136: ACCController::updateLocalFolder:
                            20140903-145249.136: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-145249.136: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145249.140: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-145249.141: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-145249.141: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145249.143: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-145249.144: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-145249.144: There is no cloud folder at [], so now initalize it.
                            20140903-145249.145: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-145249.145: ACCController::enableSync switch sync OFF
                            20140903-145249.147: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145249.148: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145249.149: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-145249.150: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-145249.150: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145249.151: ACCController::updateWithState: 11
                            20140903-145249.152: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145249.153: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145249.153: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-145249.154: 2014-09-03 14:52:49: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145249.155: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145249.156: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145249.156: ACCController::updateWithState: 11
                            20140903-145249.156: ACCController::removeAllIcons
                            20140903-145249.157: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145249.158: ACCController::enableSync completed switch sync OFF
                            20140903-145249.159: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145249.159: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145249.160: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145249.160: 2014-09-03 14:52:49: File Monitoring was asked to stop on: : Update job
                            20140903-145249.160: WorkerThreads: 8
                            20140903-145249.161: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145249.161: ACCController::enableSync completed switch sync ON
                            20140903-145301.534: MControllerDelegate::enableSync invoked
                            20140903-145301.534: ACCController::enableSync switch sync ON
                            20140903-145301.536: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145301.537: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-145301.538: ACCController::updateWithState: 1
                            20140903-145301.538: ACCController::updateLocalFolder:
                            20140903-145301.539: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-145301.539: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145301.540: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-145301.540: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-145301.541: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145301.543: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-145301.544: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-145301.544: There is no cloud folder at [], so now initalize it.
                            20140903-145301.545: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-145301.545: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145301.545: ACCController::enableSync switch sync OFF
                            20140903-145301.548: MControllerDelegate::syncStatus state 1 (CoreSyncStateSignedIn)
                            20140903-145301.550: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145301.551: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145301.551: ACCController::updateWithState: 11
                            20140903-145301.552: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145301.553: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145301.553: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-145301.553: 2014-09-03 14:53:01: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145301.554: 2014-09-03 14:53:01: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145301.555: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145301.556: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145301.556: ACCController::updateWithState: 11
                            20140903-145301.557: ACCController::removeAllIcons
                            20140903-145301.557: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145301.558: ACCController::enableSync completed switch sync OFF
                            20140903-145301.559: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145301.560: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145301.560: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145301.560: 2014-09-03 14:53:01: File Monitoring was asked to stop on: : Update job
                            20140903-145301.561: 2014-09-03 14:53:01: File Monitoring was asked to stop on: : Update job
                            20140903-145301.561: WorkerThreads: 8
                            20140903-145301.561: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145301.562: ACCController::enableSync completed switch sync ON
                            20140903-145318.434: MControllerDelegate::enableSync invoked
                            20140903-145318.435: ACCController::enableSync switch sync ON
                            20140903-145318.437: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145318.438: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-145318.438: ACCController::updateWithState: 1
                            20140903-145318.438: ACCController::updateLocalFolder:
                            20140903-145318.439: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-145318.439: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145318.442: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-145318.442: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-145318.443: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145318.445: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-145318.446: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-145318.446: There is no cloud folder at [], so now initalize it.
                            20140903-145318.446: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-145318.446: ACCController::enableSync switch sync OFF
                            20140903-145318.447: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145318.447: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-145318.447: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-145318.449: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145318.449: ACCController::updateWithState: 11
                            20140903-145318.450: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145318.451: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145318.451: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-145318.451: 2014-09-03 14:53:18: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145318.452: 2014-09-03 14:53:18: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145318.453: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145318.454: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145318.454: ACCController::updateWithState: 11
                            20140903-145318.454: ACCController::removeAllIcons
                            20140903-145318.455: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145318.456: ACCController::enableSync completed switch sync OFF
                            20140903-145318.457: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145318.458: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145318.458: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145318.459: 2014-09-03 14:53:18: File Monitoring was asked to stop on: : Update job
                            20140903-145318.459: WorkerThreads: 8
                            20140903-145318.459: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145318.460: ACCController::enableSync completed switch sync ON
                            20140903-145345.159: MControllerDelegate::shutdownRequest
                            20140903-145345.159: ACCController::shutdown
                            20140903-145345.159: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140903-145345.160: 2014-09-03 14:53:45: File Monitoring was asked to stop on: : shutdown
                            20140903-145345.161: Informational: AppHookControllerImpl::onShutdown in
                            20140903-145345.278: Informational: [livetype] onShutdown
                            20140903-145345.279: Informational: [livetype]  disableFontSync
                            20140903-145345.279: Informational: [livetype] deactivated all fonts
                            20140903-145345.281: Informational: AppHookControllerImpl::onShutdown out
                            20140903-145345.283: ACCController::removeAllIcons
                            20140903-145345.286: ACCController::shutdown completed
                            20140903-145412.171: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140903-145412.186: ACCController::Init
                            20140903-145412.196: ACCController::Init: init fileState cache
                            20140903-145412.199: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140903-145412.200: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-145412.251: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-145412.303: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140903-145412.304: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140903-145412.304: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140903-145412.356: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140903-145412.357: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145412.357: WorkerThreads: 8
                            20140903-145412.358: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145412.358: ACCController::Init: add notification observers
                            20140903-145412.362: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145412.363: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145412.363: ACCController::updateWithState: 11
                            20140903-145412.364: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140903-145412.364: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140903-145412.379: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140903-145412.379: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140903-145412.389: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140903-145412.389: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140903-145412.397: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140903-145412.397: Informational: AppHookControllerImpl::onStartup in
                            20140903-145412.401: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140903-145412.401: Informational: [livetype] onStartup
                            20140903-145412.407: Informational: [livetype] onStartup => success
                            20140903-145412.407: Informational: AppHookControllerImpl::onStartup out
                            20140903-145412.469: ACCController::injectFinderExt
                            20140903-145412.471: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-145412.472: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140903-145412.476: ACCController::finderInitSuccessfull: injectExt:YES
                            20140903-145413.465: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-145413.465: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-145413.465: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-145413.466: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-145413.466: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-145413.467: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-145413.467: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-145413.467: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-145413.468: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-145413.468: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-145413.469: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-145413.469: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-145413.470: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-145413.470: MControllerDelegate::enableCollaboration: YES
                            20140903-145413.472: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-145413.472: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-145413.472: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-145413.473: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-145413.473: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-145413.473: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-145413.473: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-145413.474: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-145413.474: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-145413.474: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-145413.474: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-145413.475: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-145413.475: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-145413.475: MControllerDelegate::enableCollaboration: YES
                            20140903-145413.476: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140903-145413.476: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 4f84510f387723546777d981171fcbf2 userId 6E68593446662ED1992016B8@AdobeID
                            20140903-145413.477: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-145413.478: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-145413.478: PrefernceManager::updatePrefernces
                            20140903-145413.478: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145413.479: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-145413.479: 2014-09-03 14:54:13: File Monitoring was asked to stop on: : Update job
                            20140903-145413.481: 2014-09-03 14:54:13: File Monitoring was asked to stop on: : Update job
                            20140903-145413.481: Informational: [livetype] syncStatus: OFF
                            20140903-145413.482: WorkerThreads: 8
                            20140903-145413.484: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145413.485: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145413.486: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145413.486: ACCController::updateWithState: 11
                            20140903-145413.488: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145413.488: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-145413.488: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145413.489: Informational: AppHookControllerImpl::onSignIn in
                            20140903-145413.490: Informational: [livetype] onSignIn
                            20140903-145413.490: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140903-145413.491: Informational: AppHookControllerImpl::onSignIn out
                            20140903-145413.491: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140903-145413.493: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-145414.271: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-145414.271: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-145414.271: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-145414.272: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-145414.272: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-145414.272: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-145414.272: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-145414.273: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-145414.273: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-145414.273: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-145414.273: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-145414.274: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-145414.274: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-145414.274: MControllerDelegate::enableCollaboration: YES
                            20140903-145414.275: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140903-145414.275: ACCController::updateAccessToken accessToken 4f84510f387723546777d981171fcbf2
                            20140903-145414.276: Informational: AppHookControllerImpl::onUpdateAccessToken in
                            20140903-145414.276: Informational: [livetype] onUpdateAccessToken
                            20140903-145414.276: Informational: AppHookControllerImpl::onUpdateAccessToken out
                            20140903-145414.276: MControllerDelegate::disableSync invoked
                            20140903-145414.276: ACCController::updateAccessToken completed
                            20140903-145414.280: ACCController::disableSync sync is already disabled
                            20140903-145414.280: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-145414.281: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-145414.281: Informational: [livetype] syncStatus: OFF
                            20140903-145439.845: MControllerDelegate::enableSync invoked
                            20140903-145439.845: ACCController::enableSync switch sync ON
                            20140903-145439.847: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145439.848: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-145439.849: ACCController::updateWithState: 1
                            20140903-145439.849: ACCController::updateLocalFolder:
                            20140903-145439.850: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-145439.850: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145439.853: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-145439.853: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-145439.854: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145439.856: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-145439.857: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-145439.857: There is no cloud folder at [], so now initalize it.
                            20140903-145439.858: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-145439.858: ACCController::enableSync switch sync OFF
                            20140903-145439.858: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145439.862: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-145439.862: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-145439.863: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145439.863: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145439.864: ACCController::updateWithState: 11
                            20140903-145439.865: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145439.865: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145439.866: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-145439.866: 2014-09-03 14:54:39: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145439.867: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145439.868: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145439.868: ACCController::updateWithState: 11
                            20140903-145439.868: ACCController::removeAllIcons
                            20140903-145439.869: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145439.870: ACCController::enableSync completed switch sync OFF
                            20140903-145439.871: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145439.871: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145439.872: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145439.872: 2014-09-03 14:54:39: File Monitoring was asked to stop on: : Update job
                            20140903-145439.873: WorkerThreads: 8
                            20140903-145439.873: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145439.873: ACCController::enableSync completed switch sync ON
                            20140903-145502.797: MControllerDelegate::enableSync invoked
                            20140903-145502.798: ACCController::enableSync switch sync ON
                            20140903-145502.800: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145502.801: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145502.801: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-145502.805: ACCController::updateWithState: 1
                            20140903-145502.805: ACCController::updateLocalFolder:
                            20140903-145502.806: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-145502.808: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-145502.809: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145502.811: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-145502.813: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-145502.813: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-145502.814: There is no cloud folder at [], so now initalize it.
                            20140903-145502.814: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-145502.814: ACCController::enableSync switch sync OFF
                            20140903-145502.815: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145502.816: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-145502.816: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-145502.817: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145502.818: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145502.818: ACCController::updateWithState: 11
                            20140903-145502.819: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145502.820: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145502.820: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-145502.820: 2014-09-03 14:55:02: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145502.821: 2014-09-03 14:55:02: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145502.822: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145502.822: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145502.823: ACCController::updateWithState: 11
                            20140903-145502.823: ACCController::removeAllIcons
                            20140903-145502.824: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145502.825: ACCController::enableSync completed switch sync OFF
                            20140903-145502.826: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145502.827: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145502.827: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145502.827: 2014-09-03 14:55:02: File Monitoring was asked to stop on: : Update job
                            20140903-145502.828: WorkerThreads: 8
                            20140903-145502.828: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145502.829: ACCController::enableSync completed switch sync ON
                            20140903-145612.793: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140903-145612.801: ACCController::Init
                            20140903-145612.809: ACCController::Init: init fileState cache
                            20140903-145612.812: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140903-145612.813: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-145612.865: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-145612.916: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140903-145612.917: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140903-145612.917: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140903-145612.969: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140903-145612.970: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145612.971: WorkerThreads: 8
                            20140903-145612.971: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145612.972: ACCController::Init: add notification observers
                            20140903-145612.975: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145612.976: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145612.977: ACCController::updateWithState: 11
                            20140903-145612.977: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140903-145612.978: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140903-145612.985: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140903-145612.985: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140903-145612.989: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140903-145612.990: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140903-145612.994: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140903-145612.995: Informational: AppHookControllerImpl::onStartup in
                            20140903-145612.997: Informational: [livetype] onStartup
                            20140903-145612.997: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140903-145613.002: Informational: [livetype] onStartup => success
                            20140903-145613.002: Informational: AppHookControllerImpl::onStartup out
                            20140903-145613.025: ACCController::injectFinderExt
                            20140903-145613.027: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-145613.027: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140903-145613.030: ACCController::finderInitSuccessfull: injectExt:YES
                            20140903-145614.065: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-145614.065: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-145614.066: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-145614.066: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-145614.067: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-145614.067: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-145614.068: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-145614.068: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-145614.069: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-145614.070: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-145614.070: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-145614.070: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-145614.071: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-145614.071: MControllerDelegate::enableCollaboration: YES
                            20140903-145614.073: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140903-145614.073: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 4f84510f387723546777d981171fcbf2 userId 6E68593446662ED1992016B8@AdobeID
                            20140903-145614.074: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145614.075: 2014-09-03 14:56:14: File Monitoring was asked to stop on: : Update job
                            20140903-145614.076: WorkerThreads: 8
                            20140903-145614.076: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145614.077: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145614.078: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145614.078: ACCController::updateWithState: 11
                            20140903-145614.079: Informational: AppHookControllerImpl::onSignIn in
                            20140903-145614.079: Informational: [livetype] onSignIn
                            20140903-145614.080: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140903-145614.081: Informational: AppHookControllerImpl::onSignIn out
                            20140903-145614.081: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140903-145614.082: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-145614.083: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-145614.083: Informational: [livetype] syncStatus: OFF
                            20140903-145614.084: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-145614.085: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-145614.086: MControllerDelegate::enableSync invoked
                            20140903-145614.086: ACCController::enableSync switch sync ON
                            20140903-145614.088: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145614.088: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-145614.089: ACCController::updateWithState: 1
                            20140903-145614.089: ACCController::updateLocalFolder:
                            20140903-145614.089: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-145614.090: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-145614.090: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-145614.092: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-145614.092: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-145614.092: There is no cloud folder at [], so now initalize it.
                            20140903-145614.093: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-145614.093: ACCController::enableSync switch sync OFF
                            20140903-145614.094: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145614.095: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145614.095: ACCController::updateWithState: 11
                            20140903-145614.096: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145614.097: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145614.097: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-145614.097: 2014-09-03 14:56:14: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145614.098: 2014-09-03 14:56:14: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145614.098: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145614.099: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145614.099: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145614.102: ACCController::updateWithState: 11
                            20140903-145614.103: ACCController::removeAllIcons
                            20140903-145614.103: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145614.104: ACCController::enableSync completed switch sync OFF
                            20140903-145614.104: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145614.108: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-145614.109: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145614.110: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-145614.111: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145614.111: Informational: [livetype] syncStatus: OFF
                            20140903-145614.111: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145614.112: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145614.119: 2014-09-03 14:56:14: File Monitoring was asked to stop on: : Update job
                            20140903-145614.119: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-145614.122: 2014-09-03 14:56:14: File Monitoring was asked to stop on: : Update job
                            20140903-145614.122: WorkerThreads: 8
                            20140903-145614.123: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145614.123: ACCController::enableSync completed switch sync ON
                            20140903-145624.558: MControllerDelegate::enableSync invoked
                            20140903-145624.559: ACCController::enableSync switch sync ON
                            20140903-145624.560: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145624.561: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-145624.561: ACCController::updateWithState: 1
                            20140903-145624.561: ACCController::updateLocalFolder:
                            20140903-145624.562: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-145624.562: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-145624.562: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-145624.564: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-145624.564: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-145624.564: There is no cloud folder at [], so now initalize it.
                            20140903-145624.565: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-145624.565: ACCController::enableSync switch sync OFF
                            20140903-145624.566: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145624.567: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145624.568: ACCController::updateWithState: 11
                            20140903-145624.569: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145624.570: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145624.570: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-145624.570: 2014-09-03 14:56:24: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145624.571: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145624.572: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145624.572: ACCController::updateWithState: 11
                            20140903-145624.572: ACCController::removeAllIcons
                            20140903-145624.573: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145624.573: ACCController::enableSync completed switch sync OFF
                            20140903-145624.575: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145624.576: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145624.577: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145624.577: 2014-09-03 14:56:24: File Monitoring was asked to stop on: : Update job
                            20140903-145624.578: 2014-09-03 14:56:24: File Monitoring was asked to stop on: : Update job
                            20140903-145624.578: WorkerThreads: 8
                            20140903-145624.579: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145624.580: ACCController::enableSync completed switch sync ON
                            20140903-145644.474: MControllerDelegate::enableSync invoked
                            20140903-145644.474: ACCController::enableSync switch sync ON
                            20140903-145644.476: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145644.476: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-145644.476: ACCController::updateWithState: 1
                            20140903-145644.477: ACCController::updateLocalFolder:
                            20140903-145644.477: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-145644.477: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145644.478: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-145644.478: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-145644.479: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145644.481: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-145644.481: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-145644.481: There is no cloud folder at [], so now initalize it.
                            20140903-145644.481: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-145644.482: ACCController::enableSync switch sync OFF
                            20140903-145644.485: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145644.489: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-145644.489: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145644.489: ACCController::updateWithState: 11
                            20140903-145644.490: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145644.491: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145644.491: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-145644.491: 2014-09-03 14:56:44: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145644.492: 2014-09-03 14:56:44: File Monitoring was asked to stop on: : Sync turned off
                            20140903-145644.493: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145644.494: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145644.494: ACCController::updateWithState: 11
                            20140903-145644.494: ACCController::removeAllIcons
                            20140903-145644.495: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-145644.496: ACCController::enableSync completed switch sync OFF
                            20140903-145644.497: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-145644.498: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-145644.498: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-145644.498: 2014-09-03 14:56:44: File Monitoring was asked to stop on: : Update job
                            20140903-145644.499: 2014-09-03 14:56:44: File Monitoring was asked to stop on: : Update job
                            20140903-145644.499: WorkerThreads: 8
                            20140903-145644.499: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-145644.500: ACCController::enableSync completed switch sync ON
                            20140903-150333.068: MControllerDelegate::enableSync invoked
                            20140903-150333.068: ACCController::enableSync switch sync ON
                            20140903-150333.070: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150333.071: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-150333.071: ACCController::updateWithState: 1
                            20140903-150333.071: ACCController::updateLocalFolder:
                            20140903-150333.072: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-150333.072: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-150333.073: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-150333.074: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-150333.074: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-150333.075: There is no cloud folder at [], so now initalize it.
                            20140903-150333.075: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-150333.075: ACCController::enableSync switch sync OFF
                            20140903-150333.076: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150333.077: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150333.078: ACCController::updateWithState: 11
                            20140903-150333.079: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150333.079: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150333.080: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-150333.080: 2014-09-03 15:03:33: File Monitoring was asked to stop on: : Sync turned off
                            20140903-150333.081: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150333.082: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150333.082: ACCController::updateWithState: 11
                            20140903-150333.082: ACCController::removeAllIcons
                            20140903-150333.083: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-150333.084: ACCController::enableSync completed switch sync OFF
                            20140903-150333.085: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150333.086: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150333.087: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-150333.087: 2014-09-03 15:03:33: File Monitoring was asked to stop on: : Update job
                            20140903-150333.088: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-150333.089: 2014-09-03 15:03:33: File Monitoring was asked to stop on: : Update job
                            20140903-150333.090: WorkerThreads: 8
                            20140903-150333.091: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-150333.091: ACCController::enableSync completed switch sync ON
                            20140903-150333.092: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150333.095: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150333.095: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-150417.858: MControllerDelegate::enableSync invoked
                            20140903-150417.858: ACCController::enableSync switch sync ON
                            20140903-150417.861: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150417.862: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-150417.862: ACCController::updateWithState: 1
                            20140903-150417.863: ACCController::updateLocalFolder:
                            20140903-150417.863: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-150417.863: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-150417.867: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-150417.867: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-150417.868: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150417.870: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-150417.870: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-150417.870: There is no cloud folder at [], so now initalize it.
                            20140903-150417.871: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150417.871: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-150417.874: MControllerDelegate::syncStatus state 1 (CoreSyncStateSignedIn)
                            20140903-150417.874: ACCController::enableSync switch sync OFF
                            20140903-150417.879: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150417.880: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150417.880: ACCController::updateWithState: 11
                            20140903-150417.881: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150417.881: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150417.882: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-150417.882: 2014-09-03 15:04:17: File Monitoring was asked to stop on: : Sync turned off
                            20140903-150417.883: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150417.884: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150417.884: ACCController::updateWithState: 11
                            20140903-150417.885: ACCController::removeAllIcons
                            20140903-150417.885: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-150417.886: ACCController::enableSync completed switch sync OFF
                            20140903-150417.888: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150417.888: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150417.888: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-150417.889: 2014-09-03 15:04:17: File Monitoring was asked to stop on: : Update job
                            20140903-150417.890: WorkerThreads: 8
                            20140903-150417.890: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-150417.891: ACCController::enableSync completed switch sync ON
                            20140903-150509.176: MControllerDelegate::enableSync invoked
                            20140903-150509.177: ACCController::enableSync switch sync ON
                            20140903-150509.179: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150509.179: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-150509.180: ACCController::updateWithState: 1
                            20140903-150509.180: ACCController::updateLocalFolder:
                            20140903-150509.180: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-150509.181: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-150509.181: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-150509.183: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-150509.183: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-150509.183: There is no cloud folder at [], so now initalize it.
                            20140903-150509.184: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-150509.184: ACCController::enableSync switch sync OFF
                            20140903-150509.185: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150509.186: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150509.186: ACCController::updateWithState: 11
                            20140903-150509.187: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150509.188: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150509.188: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-150509.188: 2014-09-03 15:05:09: File Monitoring was asked to stop on: : Sync turned off
                            20140903-150509.189: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150509.190: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150509.190: ACCController::updateWithState: 11
                            20140903-150509.191: ACCController::removeAllIcons
                            20140903-150509.191: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-150509.192: ACCController::enableSync completed switch sync OFF
                            20140903-150509.193: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150509.194: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150509.194: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-150509.195: 2014-09-03 15:05:09: File Monitoring was asked to stop on: : Update job
                            20140903-150509.196: WorkerThreads: 8
                            20140903-150509.196: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-150509.197: ACCController::enableSync completed switch sync ON
                            20140903-150517.905: MControllerDelegate::enableSync invoked
                            20140903-150517.905: ACCController::enableSync switch sync ON
                            20140903-150517.907: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150517.908: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-150517.908: ACCController::updateWithState: 1
                            20140903-150517.908: ACCController::updateLocalFolder:
                            20140903-150517.909: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-150517.909: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-150517.909: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-150517.911: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-150517.912: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-150517.912: There is no cloud folder at [], so now initalize it.
                            20140903-150517.912: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-150517.912: ACCController::enableSync switch sync OFF
                            20140903-150517.914: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150517.914: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150517.914: ACCController::updateWithState: 11
                            20140903-150517.915: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150517.916: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150517.916: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-150517.916: 2014-09-03 15:05:17: File Monitoring was asked to stop on: : Sync turned off
                            20140903-150517.917: 2014-09-03 15:05:17: File Monitoring was asked to stop on: : Sync turned off
                            20140903-150517.918: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150517.918: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150517.918: ACCController::updateWithState: 11
                            20140903-150517.919: ACCController::removeAllIcons
                            20140903-150517.919: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-150517.920: ACCController::enableSync completed switch sync OFF
                            20140903-150517.921: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150517.923: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150517.923: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-150517.924: 2014-09-03 15:05:17: File Monitoring was asked to stop on: : Update job
                            20140903-150517.924: WorkerThreads: 8
                            20140903-150517.925: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-150517.926: ACCController::enableSync completed switch sync ON
                            20140903-150539.773: MControllerDelegate::enableSync invoked
                            20140903-150539.773: ACCController::enableSync switch sync ON
                            20140903-150539.775: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150539.776: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-150539.776: ACCController::updateWithState: 1
                            20140903-150539.777: ACCController::updateLocalFolder:
                            20140903-150539.777: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-150539.778: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-150539.779: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-150539.780: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-150539.781: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150539.782: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-150539.782: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-150539.783: There is no cloud folder at [], so now initalize it.
                            20140903-150539.783: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-150539.784: ACCController::enableSync switch sync OFF
                            20140903-150539.788: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150539.792: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-150539.792: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-150539.792: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150539.795: ACCController::updateWithState: 11
                            20140903-150539.796: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150539.796: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150539.797: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-150539.797: 2014-09-03 15:05:39: File Monitoring was asked to stop on: : Sync turned off
                            20140903-150539.798: 2014-09-03 15:05:39: File Monitoring was asked to stop on: : Sync turned off
                            20140903-150539.799: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150539.799: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150539.800: ACCController::updateWithState: 11
                            20140903-150539.800: ACCController::removeAllIcons
                            20140903-150539.801: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-150539.801: ACCController::enableSync completed switch sync OFF
                            20140903-150539.803: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-150539.803: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-150539.804: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-150539.804: 2014-09-03 15:05:39: File Monitoring was asked to stop on: : Update job
                            20140903-150539.805: 2014-09-03 15:05:39: File Monitoring was asked to stop on: : Update job
                            20140903-150539.805: WorkerThreads: 8
                            20140903-150539.806: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-150539.806: ACCController::enableSync completed switch sync ON
                            20140903-151129.145: MControllerDelegate::enableSync invoked
                            20140903-151129.146: ACCController::enableSync switch sync ON
                            20140903-151129.148: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151129.148: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-151129.149: ACCController::updateWithState: 1
                            20140903-151129.149: ACCController::updateLocalFolder:
                            20140903-151129.149: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-151129.150: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-151129.150: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-151129.152: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-151129.152: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-151129.152: There is no cloud folder at [], so now initalize it.
                            20140903-151129.153: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-151129.153: ACCController::enableSync switch sync OFF
                            20140903-151129.154: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151129.155: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151129.155: ACCController::updateWithState: 11
                            20140903-151129.156: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151129.157: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151129.157: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-151129.158: 2014-09-03 15:11:29: File Monitoring was asked to stop on: : Sync turned off
                            20140903-151129.159: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151129.160: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151129.160: ACCController::updateWithState: 11
                            20140903-151129.160: ACCController::removeAllIcons
                            20140903-151129.161: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151129.162: ACCController::enableSync completed switch sync OFF
                            20140903-151129.163: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151129.164: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151129.164: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-151129.165: 2014-09-03 15:11:29: File Monitoring was asked to stop on: : Update job
                            20140903-151129.165: WorkerThreads: 8
                            20140903-151129.165: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-151129.166: ACCController::enableSync completed switch sync ON
                            20140903-151228.545: MControllerDelegate::enableSync invoked
                            20140903-151228.546: ACCController::enableSync switch sync ON
                            20140903-151228.548: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151228.549: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-151228.549: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151228.549: ACCController::updateWithState: 1
                            20140903-151228.552: ACCController::updateLocalFolder:
                            20140903-151228.552: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-151228.553: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-151228.553: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151228.555: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-151228.557: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-151228.558: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-151228.558: There is no cloud folder at [], so now initalize it.
                            20140903-151228.559: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-151228.559: ACCController::enableSync switch sync OFF
                            20140903-151228.559: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151228.560: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-151228.560: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-151228.560: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151228.561: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151228.561: ACCController::updateWithState: 11
                            20140903-151228.562: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151228.563: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151228.563: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-151228.563: 2014-09-03 15:12:28: File Monitoring was asked to stop on: : Sync turned off
                            20140903-151228.564: 2014-09-03 15:12:28: File Monitoring was asked to stop on: : Sync turned off
                            20140903-151228.565: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151228.565: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151228.566: ACCController::updateWithState: 11
                            20140903-151228.566: ACCController::removeAllIcons
                            20140903-151228.567: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151228.567: ACCController::enableSync completed switch sync OFF
                            20140903-151228.569: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151228.569: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151228.570: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-151228.570: 2014-09-03 15:12:28: File Monitoring was asked to stop on: : Update job
                            20140903-151228.571: WorkerThreads: 8
                            20140903-151228.571: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-151228.572: ACCController::enableSync completed switch sync ON
                            20140903-151400.673: MControllerDelegate::enableSync invoked
                            20140903-151400.674: ACCController::enableSync switch sync ON
                            20140903-151400.676: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151400.676: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-151400.677: ACCController::updateWithState: 1
                            20140903-151400.677: ACCController::updateLocalFolder:
                            20140903-151400.678: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-151400.678: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151400.679: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-151400.679: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-151400.680: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151400.681: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-151400.682: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-151400.682: There is no cloud folder at [], so now initalize it.
                            20140903-151400.683: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-151400.683: ACCController::enableSync switch sync OFF
                            20140903-151400.686: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151400.687: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151400.690: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-151400.691: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151400.691: ACCController::updateWithState: 11
                            20140903-151400.692: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151400.693: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151400.693: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-151400.694: 2014-09-03 15:14:00: File Monitoring was asked to stop on: : Sync turned off
                            20140903-151400.695: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151400.696: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151400.697: ACCController::updateWithState: 11
                            20140903-151400.697: ACCController::removeAllIcons
                            20140903-151400.698: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151400.698: ACCController::enableSync completed switch sync OFF
                            20140903-151400.700: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151400.700: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151400.701: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-151400.701: 2014-09-03 15:14:00: File Monitoring was asked to stop on: : Update job
                            20140903-151400.702: 2014-09-03 15:14:00: File Monitoring was asked to stop on: : Update job
                            20140903-151400.702: WorkerThreads: 8
                            20140903-151400.703: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-151400.703: ACCController::enableSync completed switch sync ON
                            20140903-151401.264: MControllerDelegate::enableSync invoked
                            20140903-151401.265: ACCController::enableSync switch sync ON
                            20140903-151401.266: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.267: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-151401.268: ACCController::updateWithState: 1
                            20140903-151401.268: ACCController::updateLocalFolder:
                            20140903-151401.268: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-151401.269: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-151401.269: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151401.273: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-151401.274: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.274: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-151401.276: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-151401.276: There is no cloud folder at [], so now initalize it.
                            20140903-151401.277: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-151401.277: ACCController::enableSync switch sync OFF
                            20140903-151401.278: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.278: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.279: ACCController::updateWithState: 11
                            20140903-151401.279: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.282: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-151401.283: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.284: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.284: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-151401.284: 2014-09-03 15:14:01: File Monitoring was asked to stop on: : Sync turned off
                            20140903-151401.285: 2014-09-03 15:14:01: File Monitoring was asked to stop on: : Sync turned off
                            20140903-151401.286: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.286: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.287: ACCController::updateWithState: 11
                            20140903-151401.287: ACCController::removeAllIcons
                            20140903-151401.287: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151401.288: ACCController::enableSync completed switch sync OFF
                            20140903-151401.289: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.290: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.290: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-151401.290: 2014-09-03 15:14:01: File Monitoring was asked to stop on: : Update job
                            20140903-151401.291: 2014-09-03 15:14:01: File Monitoring was asked to stop on: : Update job
                            20140903-151401.291: WorkerThreads: 8
                            20140903-151401.291: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-151401.292: ACCController::enableSync completed switch sync ON
                            20140903-151401.532: MControllerDelegate::enableSync invoked
                            20140903-151401.533: ACCController::enableSync switch sync ON
                            20140903-151401.535: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.536: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-151401.536: ACCController::updateWithState: 1
                            20140903-151401.536: ACCController::updateLocalFolder:
                            20140903-151401.537: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-151401.538: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-151401.538: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151401.538: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-151401.543: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-151401.543: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.547: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-151401.547: There is no cloud folder at [], so now initalize it.
                            20140903-151401.547: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-151401.548: ACCController::enableSync switch sync OFF
                            20140903-151401.549: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.549: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.550: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.551: ACCController::updateWithState: 11
                            20140903-151401.552: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-151401.554: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.554: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.555: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-151401.555: 2014-09-03 15:14:01: File Monitoring was asked to stop on: : Sync turned off
                            20140903-151401.556: 2014-09-03 15:14:01: File Monitoring was asked to stop on: : Sync turned off
                            20140903-151401.556: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.557: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.557: ACCController::updateWithState: 11
                            20140903-151401.558: ACCController::removeAllIcons
                            20140903-151401.558: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151401.559: ACCController::enableSync completed switch sync OFF
                            20140903-151401.561: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.561: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.561: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-151401.562: 2014-09-03 15:14:01: File Monitoring was asked to stop on: : Update job
                            20140903-151401.562: WorkerThreads: 8
                            20140903-151401.562: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-151401.563: ACCController::enableSync completed switch sync ON
                            20140903-151401.790: MControllerDelegate::enableSync invoked
                            20140903-151401.790: ACCController::enableSync switch sync ON
                            20140903-151401.792: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.793: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-151401.794: ACCController::updateWithState: 1
                            20140903-151401.794: ACCController::updateLocalFolder:
                            20140903-151401.794: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-151401.795: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-151401.795: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151401.796: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-151401.799: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-151401.799: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.803: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-151401.804: There is no cloud folder at [], so now initalize it.
                            20140903-151401.804: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-151401.804: ACCController::enableSync switch sync OFF
                            20140903-151401.806: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.806: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.808: ACCController::updateWithState: 11
                            20140903-151401.809: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-151401.812: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.812: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.813: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-151401.813: 2014-09-03 15:14:01: File Monitoring was asked to stop on: : Sync turned off
                            20140903-151401.814: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.815: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.815: ACCController::updateWithState: 11
                            20140903-151401.815: ACCController::removeAllIcons
                            20140903-151401.816: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151401.817: ACCController::enableSync completed switch sync OFF
                            20140903-151401.818: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151401.818: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151401.819: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-151401.819: 2014-09-03 15:14:01: File Monitoring was asked to stop on: : Update job
                            20140903-151401.820: 2014-09-03 15:14:01: File Monitoring was asked to stop on: : Update job
                            20140903-151401.820: WorkerThreads: 8
                            20140903-151401.821: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-151401.821: ACCController::enableSync completed switch sync ON
                            20140903-151402.048: MControllerDelegate::enableSync invoked
                            20140903-151402.048: ACCController::enableSync switch sync ON
                            20140903-151402.050: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151402.051: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-151402.051: ACCController::updateWithState: 1
                            20140903-151402.052: ACCController::updateLocalFolder:
                            20140903-151402.052: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-151402.052: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151402.053: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-151402.054: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-151402.055: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151402.056: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-151402.057: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-151402.057: There is no cloud folder at [], so now initalize it.
                            20140903-151402.057: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-151402.057: ACCController::enableSync switch sync OFF
                            20140903-151402.061: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151402.064: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-151402.064: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151402.065: ACCController::updateWithState: 11
                            20140903-151402.066: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151402.066: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151402.067: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-151402.067: 2014-09-03 15:14:02: File Monitoring was asked to stop on: : Sync turned off
                            20140903-151402.069: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151402.069: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151402.070: ACCController::updateWithState: 11
                            20140903-151402.070: ACCController::removeAllIcons
                            20140903-151402.071: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-151402.071: ACCController::enableSync completed switch sync OFF
                            20140903-151402.073: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-151402.074: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-151402.074: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-151402.074: 2014-09-03 15:14:02: File Monitoring was asked to stop on: : Update job
                            20140903-151402.075: 2014-09-03 15:14:02: File Monitoring was asked to stop on: : Update job
                            20140903-151402.075: WorkerThreads: 8
                            20140903-151402.076: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-151402.076: ACCController::enableSync completed switch sync ON
                            20140903-152106.175: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-152106.176: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140903-152106.176: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140903-152351.359: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-152351.360: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140903-152351.360: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140903-154012.891: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-154012.891: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140903-154012.891: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140903-154415.288: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-154415.289: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140903-154415.289: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140903-155413.047: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140903-155413.048: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140903-155441.745: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-155441.746: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140903-155441.746: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140903-155654.628: ACCController::osSleepWake: NSConcreteNotification 0x7ffc5cc25900 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7ffc5a7657e0>}
                            20140903-155654.628: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140903-155654.629: 2014-09-03 15:56:54: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140903-163005.158: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-163028.604: ACCController::osSleepWake: NSConcreteNotification 0x7ffc5c820da0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7ffc5a7657e0>}
                            20140903-163655.696: MControllerDelegate::enableSync invoked
                            20140903-163655.697: ACCController::enableSync switch sync ON
                            20140903-163655.698: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-163655.699: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-163655.699: ACCController::updateWithState: 1
                            20140903-163655.699: ACCController::updateLocalFolder:
                            20140903-163655.700: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-163655.700: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-163655.700: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-163655.702: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-163655.702: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-163655.702: There is no cloud folder at [], so now initalize it.
                            20140903-163655.703: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-163655.703: ACCController::enableSync switch sync OFF
                            20140903-163655.704: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-163655.705: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-163655.705: ACCController::updateWithState: 11
                            20140903-163655.707: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-163655.707: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-163655.708: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-163655.708: 2014-09-03 16:36:55: File Monitoring was asked to stop on: : Sync turned off
                            20140903-163655.709: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-163655.710: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-163655.710: ACCController::updateWithState: 11
                            20140903-163655.710: ACCController::removeAllIcons
                            20140903-163655.711: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-163655.711: ACCController::enableSync completed switch sync OFF
                            20140903-163655.713: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-163655.713: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-163655.714: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-163655.714: 2014-09-03 16:36:55: File Monitoring was asked to stop on: : Update job
                            20140903-163655.715: 2014-09-03 16:36:55: File Monitoring was asked to stop on: : Update job
                            20140903-163655.715: WorkerThreads: 8
                            20140903-163655.715: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-163655.716: ACCController::enableSync completed switch sync ON
                            20140903-163831.326: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-163831.327: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140903-163831.327: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140903-164703.363: MControllerDelegate::enableSync invoked
                            20140903-164703.363: ACCController::enableSync switch sync ON
                            20140903-164703.365: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-164703.366: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-164703.366: ACCController::updateWithState: 1
                            20140903-164703.367: ACCController::updateLocalFolder:
                            20140903-164703.367: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-164703.367: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-164703.370: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-164703.370: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-164703.371: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-164703.372: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-164703.373: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-164703.373: There is no cloud folder at [], so now initalize it.
                            20140903-164703.373: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-164703.373: ACCController::enableSync switch sync OFF
                            20140903-164703.378: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-164703.382: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-164703.382: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-164703.382: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-164703.383: ACCController::updateWithState: 11
                            20140903-164703.384: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-164703.385: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-164703.385: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-164703.385: 2014-09-03 16:47:03: File Monitoring was asked to stop on: : Sync turned off
                            20140903-164703.386: 2014-09-03 16:47:03: File Monitoring was asked to stop on: : Sync turned off
                            20140903-164703.387: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-164703.387: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-164703.387: ACCController::updateWithState: 11
                            20140903-164703.388: ACCController::removeAllIcons
                            20140903-164703.388: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-164703.389: ACCController::enableSync completed switch sync OFF
                            20140903-164703.391: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-164703.391: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-164703.392: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-164703.392: 2014-09-03 16:47:03: File Monitoring was asked to stop on: : Update job
                            20140903-164703.392: WorkerThreads: 8
                            20140903-164703.393: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-164703.393: ACCController::enableSync completed switch sync ON
                            20140903-164725.184: MControllerDelegate::enableSync invoked
                            20140903-164725.185: ACCController::enableSync switch sync ON
                            20140903-164725.187: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-164725.187: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-164725.187: ACCController::updateWithState: 1
                            20140903-164725.188: ACCController::updateLocalFolder:
                            20140903-164725.188: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-164725.188: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-164725.189: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-164725.190: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-164725.191: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-164725.191: There is no cloud folder at [], so now initalize it.
                            20140903-164725.191: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-164725.192: ACCController::enableSync switch sync OFF
                            20140903-164725.193: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-164725.193: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-164725.194: ACCController::updateWithState: 11
                            20140903-164725.195: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-164725.195: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-164725.196: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-164725.196: 2014-09-03 16:47:25: File Monitoring was asked to stop on: : Sync turned off
                            20140903-164725.197: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-164725.197: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-164725.198: ACCController::updateWithState: 11
                            20140903-164725.198: ACCController::removeAllIcons
                            20140903-164725.199: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-164725.199: ACCController::enableSync completed switch sync OFF
                            20140903-164725.200: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-164725.201: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-164725.201: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-164725.201: 2014-09-03 16:47:25: File Monitoring was asked to stop on: : Update job
                            20140903-164725.202: 2014-09-03 16:47:25: File Monitoring was asked to stop on: : Update job
                            20140903-164725.202: WorkerThreads: 8
                            20140903-164725.202: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-164725.203: ACCController::enableSync completed switch sync ON
                            20140903-164756.617: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-164756.618: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Excel
                            20140903-164756.619: ACCController::doInjectFinderExt: app identifier: com.microsoft.Excel not equal to com.apple.finder
                            20140903-165414.040: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140903-165414.041: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140903-165414.041: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140903-165417.119: MControllerDelegate::shutdownRequest
                            20140903-165417.119: ACCController::shutdown
                            20140903-165417.120: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140903-165417.120: 2014-09-03 16:54:17: File Monitoring was asked to stop on: : shutdown
                            20140903-165417.120: Informational: AppHookControllerImpl::onShutdown in
                            20140903-165417.200: Informational: [livetype] onShutdown
                            20140903-165417.201: Informational: [livetype]  disableFontSync
                            20140903-165417.201: Informational: [livetype] deactivated all fonts
                            20140903-165417.202: Informational: AppHookControllerImpl::onShutdown out
                            20140903-165417.203: ACCController::removeAllIcons
                            20140903-165417.225: ACCController::shutdown completed
                            20140903-165445.812: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140903-165445.820: ACCController::Init
                            20140903-165445.826: ACCController::Init: init fileState cache
                            20140903-165445.829: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140903-165445.830: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-165445.880: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-165445.931: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140903-165445.932: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140903-165445.932: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140903-165445.983: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140903-165445.984: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165445.985: WorkerThreads: 8
                            20140903-165445.985: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165445.985: ACCController::Init: add notification observers
                            20140903-165445.988: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165445.989: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165445.989: ACCController::updateWithState: 11
                            20140903-165445.990: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140903-165445.990: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140903-165445.995: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140903-165445.995: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140903-165446.000: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140903-165446.000: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140903-165446.005: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140903-165446.006: Informational: AppHookControllerImpl::onStartup in
                            20140903-165446.010: Informational: [livetype] onStartup
                            20140903-165446.010: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140903-165446.015: Informational: [livetype] onStartup => success
                            20140903-165446.015: Informational: AppHookControllerImpl::onStartup out
                            20140903-165446.075: ACCController::injectFinderExt
                            20140903-165446.076: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-165446.077: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140903-165446.080: ACCController::finderInitSuccessfull: injectExt:YES
                            20140903-165447.095: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-165447.095: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-165447.096: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-165447.096: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-165447.097: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-165447.098: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-165447.098: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-165447.099: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-165447.099: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-165447.100: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-165447.100: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-165447.101: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-165447.101: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-165447.102: MControllerDelegate::enableCollaboration: YES
                            20140903-165447.103: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-165447.103: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-165447.104: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-165447.104: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-165447.104: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-165447.105: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-165447.105: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-165447.105: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-165447.105: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-165447.106: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-165447.106: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-165447.106: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-165447.106: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-165447.107: MControllerDelegate::enableCollaboration: YES
                            20140903-165447.107: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140903-165447.108: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 84eddec45d6ee98b899bf75f3b74dca6 userId 6E68593446662ED1992016B8@AdobeID
                            20140903-165447.109: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-165447.110: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-165447.110: Informational: [livetype] syncStatus: OFF
                            20140903-165447.111: PrefernceManager::updatePrefernces
                            20140903-165447.111: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-165447.111: 2014-09-03 16:54:47: File Monitoring was asked to stop on: : Update job
                            20140903-165447.112: 2014-09-03 16:54:47: File Monitoring was asked to stop on: : Update job
                            20140903-165447.112: WorkerThreads: 8
                            20140903-165447.112: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165447.113: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165447.114: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165447.114: ACCController::updateWithState: 11
                            20140903-165447.116: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165447.116: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-165447.116: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165447.117: Informational: AppHookControllerImpl::onSignIn in
                            20140903-165447.118: Informational: [livetype] onSignIn
                            20140903-165447.118: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140903-165447.119: Informational: AppHookControllerImpl::onSignIn out
                            20140903-165447.119: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140903-165447.121: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-165447.907: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-165447.907: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-165447.907: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-165447.907: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-165447.908: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-165447.908: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-165447.908: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-165447.908: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-165447.909: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-165447.909: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-165447.909: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-165447.909: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-165447.910: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-165447.910: MControllerDelegate::enableCollaboration: YES
                            20140903-165447.911: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140903-165447.911: ACCController::updateAccessToken accessToken 84eddec45d6ee98b899bf75f3b74dca6
                            20140903-165447.911: Informational: AppHookControllerImpl::onUpdateAccessToken in
                            20140903-165447.912: MControllerDelegate::disableSync invoked
                            20140903-165447.912: Informational: [livetype] onUpdateAccessToken
                            20140903-165447.912: Informational: AppHookControllerImpl::onUpdateAccessToken out
                            20140903-165447.913: ACCController::updateAccessToken completed
                            20140903-165447.913: ACCController::disableSync sync is already disabled
                            20140903-165447.914: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-165447.915: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-165447.915: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-165447.915: Informational: [livetype] syncStatus: OFF
                            20140903-165518.811: MControllerDelegate::enableSync invoked
                            20140903-165518.811: ACCController::enableSync switch sync ON
                            20140903-165518.813: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165518.814: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-165518.814: ACCController::updateWithState: 1
                            20140903-165518.815: ACCController::updateLocalFolder:
                            20140903-165518.815: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165518.817: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-165518.819: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-165518.819: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-165518.819: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165518.821: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-165518.821: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-165518.821: There is no cloud folder at [], so now initalize it.
                            20140903-165518.822: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-165518.822: ACCController::enableSync switch sync OFF
                            20140903-165518.822: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165518.823: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-165518.823: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-165518.824: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165518.824: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165518.825: ACCController::updateWithState: 11
                            20140903-165518.826: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165518.826: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165518.827: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-165518.827: 2014-09-03 16:55:18: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165518.828: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165518.829: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165518.829: ACCController::updateWithState: 11
                            20140903-165518.829: ACCController::removeAllIcons
                            20140903-165518.830: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165518.831: ACCController::enableSync completed switch sync OFF
                            20140903-165518.832: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165518.833: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165518.834: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-165518.834: 2014-09-03 16:55:18: File Monitoring was asked to stop on: : Update job
                            20140903-165518.834: WorkerThreads: 8
                            20140903-165518.835: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165518.835: ACCController::enableSync completed switch sync ON
                            20140903-165541.610: MControllerDelegate::enableSync invoked
                            20140903-165541.611: ACCController::enableSync switch sync ON
                            20140903-165541.613: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165541.613: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-165541.614: ACCController::updateWithState: 1
                            20140903-165541.615: ACCController::updateLocalFolder:
                            20140903-165541.615: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165541.616: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-165541.618: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-165541.618: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-165541.619: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165541.621: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-165541.621: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-165541.621: There is no cloud folder at [], so now initalize it.
                            20140903-165541.622: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-165541.622: ACCController::enableSync switch sync OFF
                            20140903-165541.622: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165541.622: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-165541.623: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-165541.623: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165541.624: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165541.624: ACCController::updateWithState: 11
                            20140903-165541.625: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165541.626: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165541.626: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-165541.626: 2014-09-03 16:55:41: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165541.627: 2014-09-03 16:55:41: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165541.628: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165541.628: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165541.629: ACCController::updateWithState: 11
                            20140903-165541.629: ACCController::removeAllIcons
                            20140903-165541.630: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165541.630: ACCController::enableSync completed switch sync OFF
                            20140903-165541.632: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165541.633: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165541.633: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-165541.634: 2014-09-03 16:55:41: File Monitoring was asked to stop on: : Update job
                            20140903-165541.634: WorkerThreads: 8
                            20140903-165541.634: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165541.635: ACCController::enableSync completed switch sync ON
                            20140903-165609.975: MControllerDelegate::enableSync invoked
                            20140903-165609.976: ACCController::enableSync switch sync ON
                            20140903-165609.978: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165609.978: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-165609.979: ACCController::updateWithState: 1
                            20140903-165609.979: ACCController::updateLocalFolder:
                            20140903-165609.980: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165609.980: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-165609.983: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-165609.983: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-165609.984: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165609.986: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-165609.986: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-165609.986: There is no cloud folder at [], so now initalize it.
                            20140903-165609.987: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-165609.987: ACCController::enableSync switch sync OFF
                            20140903-165609.987: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165609.990: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-165609.990: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-165609.990: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165609.991: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165609.991: ACCController::updateWithState: 11
                            20140903-165609.992: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165609.993: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165609.993: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-165609.993: 2014-09-03 16:56:09: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165609.994: 2014-09-03 16:56:09: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165609.995: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165609.995: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165609.996: ACCController::updateWithState: 11
                            20140903-165609.996: ACCController::removeAllIcons
                            20140903-165609.997: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165609.998: ACCController::enableSync completed switch sync OFF
                            20140903-165609.999: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165610.000: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165610.000: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-165610.000: 2014-09-03 16:56:10: File Monitoring was asked to stop on: : Update job
                            20140903-165610.001: WorkerThreads: 8
                            20140903-165610.001: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165610.001: ACCController::enableSync completed switch sync ON
                            20140903-165631.375: VulcanMessageAdapter::errorReceived : Error received : DestinationUnreachable
                            20140903-165631.375: VulcanMessageAdapter::errorReceived : EndPoint unreachable : payload <fault><endPoint><endPointId>4781.1409770451</endPointId><appId>ACCC</appId><appVersion>1 .3.0.x</appVersion></endPoint></fault>
                            20140903-165631.376: Error: [livetype] onErrorReceived 'DestinationUnreachable' '<fault><endPoint><endPointId>4781.1409770451</endPointId><appId>ACCC</appId><appVersion> 1.3.0.x</appVersion></endPoint></fault>'
                            20140903-165636.835: MControllerDelegate::enableSync invoked
                            20140903-165636.836: ACCController::enableSync switch sync ON
                            20140903-165636.838: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165636.838: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-165636.838: ACCController::updateWithState: 1
                            20140903-165636.839: ACCController::updateLocalFolder:
                            20140903-165636.839: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-165636.839: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165636.842: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-165636.842: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-165636.843: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165636.844: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-165636.845: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-165636.845: There is no cloud folder at [], so now initalize it.
                            20140903-165636.846: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-165636.846: ACCController::enableSync switch sync OFF
                            20140903-165636.849: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165636.852: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-165636.852: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-165636.852: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165636.854: ACCController::updateWithState: 11
                            20140903-165636.855: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165636.856: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165636.856: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-165636.856: 2014-09-03 16:56:36: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165636.857: 2014-09-03 16:56:36: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165636.858: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165636.859: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165636.859: ACCController::updateWithState: 11
                            20140903-165636.859: ACCController::removeAllIcons
                            20140903-165636.860: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165636.861: ACCController::enableSync completed switch sync OFF
                            20140903-165636.862: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165636.863: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165636.863: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-165636.864: 2014-09-03 16:56:36: File Monitoring was asked to stop on: : Update job
                            20140903-165636.864: WorkerThreads: 8
                            20140903-165636.864: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165636.865: ACCController::enableSync completed switch sync ON
                            20140903-165746.717: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140903-165746.725: ACCController::Init
                            20140903-165746.734: ACCController::Init: init fileState cache
                            20140903-165746.736: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140903-165746.737: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-165746.788: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140903-165746.788: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140903-165746.789: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140903-165746.841: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140903-165746.841: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165746.843: WorkerThreads: 8
                            20140903-165746.843: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165746.844: ACCController::Init: add notification observers
                            20140903-165746.847: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165746.848: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165746.848: ACCController::updateWithState: 11
                            20140903-165746.849: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140903-165746.849: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140903-165746.855: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140903-165746.855: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140903-165746.860: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140903-165746.860: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140903-165746.865: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140903-165746.865: Informational: AppHookControllerImpl::onStartup in
                            20140903-165746.868: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140903-165746.868: Informational: [livetype] onStartup
                            20140903-165746.872: Informational: [livetype] onStartup => success
                            20140903-165746.872: Informational: AppHookControllerImpl::onStartup out
                            20140903-165746.894: ACCController::injectFinderExt
                            20140903-165746.896: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-165746.896: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140903-165746.900: ACCController::finderInitSuccessfull: injectExt:YES
                            20140903-165747.944: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-165747.944: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-165747.945: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-165747.945: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-165747.945: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-165747.946: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-165747.946: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-165747.947: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-165747.947: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-165747.948: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-165747.948: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-165747.949: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-165747.949: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-165747.949: MControllerDelegate::enableCollaboration: YES
                            20140903-165747.951: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140903-165747.951: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 84eddec45d6ee98b899bf75f3b74dca6 userId 6E68593446662ED1992016B8@AdobeID
                            20140903-165747.953: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-165747.954: 2014-09-03 16:57:47: File Monitoring was asked to stop on: : Update job
                            20140903-165747.954: WorkerThreads: 8
                            20140903-165747.954: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165747.956: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165747.956: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165747.956: ACCController::updateWithState: 11
                            20140903-165747.957: Informational: AppHookControllerImpl::onSignIn in
                            20140903-165747.958: Informational: [livetype] onSignIn
                            20140903-165747.958: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140903-165747.959: Informational: AppHookControllerImpl::onSignIn out
                            20140903-165747.959: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140903-165747.961: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-165747.962: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-165747.962: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-165747.963: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-165747.963: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-165747.963: Informational: [livetype] syncStatus: OFF
                            20140903-165747.964: MControllerDelegate::enableSync invoked
                            20140903-165747.965: ACCController::enableSync switch sync ON
                            20140903-165747.966: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165747.967: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-165747.967: ACCController::updateWithState: 1
                            20140903-165747.967: ACCController::updateLocalFolder:
                            20140903-165747.967: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-165747.968: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-165747.968: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-165747.970: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-165747.970: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-165747.970: There is no cloud folder at [], so now initalize it.
                            20140903-165747.971: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-165747.971: ACCController::enableSync switch sync OFF
                            20140903-165747.972: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165747.973: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165747.974: ACCController::updateWithState: 11
                            20140903-165747.975: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165747.975: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165747.976: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-165747.976: 2014-09-03 16:57:47: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165747.977: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165747.977: 2014-09-03 16:57:47: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165747.983: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165747.986: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165747.986: ACCController::updateWithState: 11
                            20140903-165747.986: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-165747.988: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-165747.988: ACCController::removeAllIcons
                            20140903-165747.992: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-165747.992: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165747.992: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165747.998: Informational: [livetype] syncStatus: OFF
                            20140903-165747.999: ACCController::enableSync completed switch sync OFF
                            20140903-165748.000: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-165748.009: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165748.009: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165748.010: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-165748.010: 2014-09-03 16:57:48: File Monitoring was asked to stop on: : Update job
                            20140903-165748.011: WorkerThreads: 8
                            20140903-165748.011: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165748.012: ACCController::enableSync completed switch sync ON
                            20140903-165756.818: MControllerDelegate::enableSync invoked
                            20140903-165756.818: ACCController::enableSync switch sync ON
                            20140903-165756.820: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165756.821: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-165756.821: ACCController::updateWithState: 1
                            20140903-165756.822: ACCController::updateLocalFolder:
                            20140903-165756.822: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-165756.822: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165756.824: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-165756.824: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-165756.825: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165756.827: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-165756.827: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-165756.828: There is no cloud folder at [], so now initalize it.
                            20140903-165756.828: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-165756.828: ACCController::enableSync switch sync OFF
                            20140903-165756.834: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165756.838: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-165756.838: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165756.839: ACCController::updateWithState: 11
                            20140903-165756.841: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165756.842: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165756.842: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-165756.842: 2014-09-03 16:57:56: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165756.843: 2014-09-03 16:57:56: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165756.844: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165756.845: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165756.845: ACCController::updateWithState: 11
                            20140903-165756.845: ACCController::removeAllIcons
                            20140903-165756.846: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165756.847: ACCController::enableSync completed switch sync OFF
                            20140903-165756.849: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165756.850: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165756.850: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-165756.851: 2014-09-03 16:57:56: File Monitoring was asked to stop on: : Update job
                            20140903-165756.851: WorkerThreads: 8
                            20140903-165756.852: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165756.852: ACCController::enableSync completed switch sync ON
                            20140903-165902.041: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140903-165902.050: ACCController::Init
                            20140903-165902.059: ACCController::Init: init fileState cache
                            20140903-165902.062: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140903-165902.063: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-165902.114: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-165902.165: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140903-165902.166: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140903-165902.166: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140903-165902.219: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140903-165902.220: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165902.221: WorkerThreads: 8
                            20140903-165902.222: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165902.223: ACCController::Init: add notification observers
                            20140903-165902.226: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165902.227: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165902.227: ACCController::updateWithState: 11
                            20140903-165902.228: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140903-165902.228: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140903-165902.234: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140903-165902.234: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140903-165902.239: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140903-165902.239: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140903-165902.244: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140903-165902.244: Informational: AppHookControllerImpl::onStartup in
                            20140903-165902.247: Informational: [livetype] onStartup
                            20140903-165902.247: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140903-165902.251: Informational: [livetype] onStartup => success
                            20140903-165902.252: Informational: AppHookControllerImpl::onStartup out
                            20140903-165902.274: ACCController::injectFinderExt
                            20140903-165902.276: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-165902.276: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140903-165902.279: ACCController::finderInitSuccessfull: injectExt:YES
                            20140903-165903.326: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-165903.327: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-165903.327: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-165903.328: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-165903.328: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-165903.329: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-165903.329: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-165903.329: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-165903.330: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-165903.330: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-165903.331: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-165903.331: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-165903.331: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-165903.332: MControllerDelegate::enableCollaboration: YES
                            20140903-165903.333: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140903-165903.333: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 84eddec45d6ee98b899bf75f3b74dca6 userId 6E68593446662ED1992016B8@AdobeID
                            20140903-165903.335: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-165903.336: 2014-09-03 16:59:03: File Monitoring was asked to stop on: : Update job
                            20140903-165903.336: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-165903.337: WorkerThreads: 8
                            20140903-165903.338: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-165903.339: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165903.341: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-165903.341: MControllerDelegate::enableSync invoked
                            20140903-165903.342: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165903.344: Informational: [livetype] syncStatus: OFF
                            20140903-165903.348: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165903.348: ACCController::updateWithState: 11
                            20140903-165903.349: Informational: AppHookControllerImpl::onSignIn in
                            20140903-165903.350: Informational: [livetype] onSignIn
                            20140903-165903.350: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140903-165903.351: Informational: AppHookControllerImpl::onSignIn out
                            20140903-165903.351: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140903-165903.352: ACCController::enableSync switch sync ON
                            20140903-165903.352: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165903.353: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165903.354: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-165903.355: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165903.357: ACCController::updateWithState: 1
                            20140903-165903.357: ACCController::updateLocalFolder:
                            20140903-165903.358: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-165903.358: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-165903.358: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-165903.362: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-165903.362: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-165903.365: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-165903.365: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-165903.366: Informational: [livetype] syncStatus: OFF
                            20140903-165903.366: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-165903.366: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165903.371: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-165903.371: MControllerDelegate::syncStatus state 1 (CoreSyncStateSignedIn)
                            20140903-165903.375: There is no cloud folder at [], so now initalize it.
                            20140903-165903.375: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-165903.375: ACCController::enableSync switch sync OFF
                            20140903-165903.377: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165903.377: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165903.378: ACCController::updateWithState: 11
                            20140903-165903.379: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165903.379: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165903.380: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-165903.380: 2014-09-03 16:59:03: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165903.381: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165903.382: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165903.382: ACCController::updateWithState: 11
                            20140903-165903.382: ACCController::removeAllIcons
                            20140903-165903.383: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165903.384: ACCController::enableSync completed switch sync OFF
                            20140903-165903.385: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165903.386: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165903.386: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-165903.387: 2014-09-03 16:59:03: File Monitoring was asked to stop on: : Update job
                            20140903-165903.387: WorkerThreads: 8
                            20140903-165903.387: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165903.388: ACCController::enableSync completed switch sync ON
                            20140903-165922.350: MControllerDelegate::enableSync invoked
                            20140903-165922.350: ACCController::enableSync switch sync ON
                            20140903-165922.352: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165922.353: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-165922.354: ACCController::updateWithState: 1
                            20140903-165922.354: ACCController::updateLocalFolder:
                            20140903-165922.355: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-165922.355: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165922.358: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-165922.358: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-165922.359: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165922.361: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-165922.361: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-165922.361: There is no cloud folder at [], so now initalize it.
                            20140903-165922.361: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-165922.362: ACCController::enableSync switch sync OFF
                            20140903-165922.367: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165922.370: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-165922.371: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165922.371: ACCController::updateWithState: 11
                            20140903-165922.372: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165922.373: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165922.373: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-165922.374: 2014-09-03 16:59:22: File Monitoring was asked to stop on: : Sync turned off
                            20140903-165922.375: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165922.376: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165922.376: ACCController::updateWithState: 11
                            20140903-165922.377: ACCController::removeAllIcons
                            20140903-165922.377: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-165922.378: ACCController::enableSync completed switch sync OFF
                            20140903-165922.380: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-165922.381: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-165922.381: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-165922.382: 2014-09-03 16:59:22: File Monitoring was asked to stop on: : Update job
                            20140903-165922.382: WorkerThreads: 8
                            20140903-165922.383: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-165922.383: ACCController::enableSync completed switch sync ON
                            20140903-170000.870: MControllerDelegate::enableSync invoked
                            20140903-170000.871: ACCController::enableSync switch sync ON
                            20140903-170000.872: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170000.873: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-170000.873: ACCController::updateWithState: 1
                            20140903-170000.873: ACCController::updateLocalFolder:
                            20140903-170000.874: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-170000.874: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-170000.874: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-170000.877: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-170000.880: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170000.881: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-170000.881: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-170000.881: There is no cloud folder at [], so now initalize it.
                            20140903-170000.882: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-170000.882: ACCController::enableSync switch sync OFF
                            20140903-170000.883: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170000.884: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170000.884: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170000.885: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-170000.887: ACCController::updateWithState: 11
                            20140903-170000.888: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170000.889: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170000.889: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-170000.890: 2014-09-03 17:00:00: File Monitoring was asked to stop on: : Sync turned off
                            20140903-170000.891: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170000.892: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170000.892: ACCController::updateWithState: 11
                            20140903-170000.893: ACCController::removeAllIcons
                            20140903-170000.893: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-170000.894: ACCController::enableSync completed switch sync OFF
                            20140903-170000.895: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170000.896: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170000.897: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-170000.897: 2014-09-03 17:00:00: File Monitoring was asked to stop on: : Update job
                            20140903-170000.897: WorkerThreads: 8
                            20140903-170000.898: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-170000.898: ACCController::enableSync completed switch sync ON
                            20140903-170102.549: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140903-170102.558: ACCController::Init
                            20140903-170102.565: ACCController::Init: init fileState cache
                            20140903-170102.568: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140903-170102.569: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-170102.619: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-170102.671: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140903-170102.672: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140903-170102.672: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140903-170102.725: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140903-170102.726: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-170102.727: WorkerThreads: 8
                            20140903-170102.727: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-170102.728: ACCController::Init: add notification observers
                            20140903-170102.731: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170102.732: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170102.732: ACCController::updateWithState: 11
                            20140903-170102.733: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140903-170102.733: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140903-170102.738: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140903-170102.738: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140903-170102.743: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140903-170102.743: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140903-170102.748: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140903-170102.748: Informational: AppHookControllerImpl::onStartup in
                            20140903-170102.751: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140903-170102.751: Informational: [livetype] onStartup
                            20140903-170102.756: Informational: [livetype] onStartup => success
                            20140903-170102.756: Informational: AppHookControllerImpl::onStartup out
                            20140903-170102.778: ACCController::injectFinderExt
                            20140903-170102.780: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-170102.780: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140903-170102.783: ACCController::finderInitSuccessfull: injectExt:YES
                            20140903-170103.813: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-170103.814: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-170103.814: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-170103.815: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-170103.815: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-170103.815: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-170103.816: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-170103.816: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-170103.817: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-170103.817: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-170103.817: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-170103.818: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-170103.818: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-170103.818: MControllerDelegate::enableCollaboration: YES
                            20140903-170103.819: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140903-170103.820: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 84eddec45d6ee98b899bf75f3b74dca6 userId 6E68593446662ED1992016B8@AdobeID
                            20140903-170103.821: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-170103.822: 2014-09-03 17:01:03: File Monitoring was asked to stop on: : Update job
                            20140903-170103.822: WorkerThreads: 8
                            20140903-170103.823: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-170103.824: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170103.824: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-170103.824: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170103.828: ACCController::updateWithState: 11
                            20140903-170103.828: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-170103.832: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-170103.832: Informational: AppHookControllerImpl::onSignIn in
                            20140903-170103.832: MControllerDelegate::enableSync invoked
                            20140903-170103.836: Informational: [livetype] syncStatus: OFF
                            20140903-170103.839: Informational: [livetype] onSignIn
                            20140903-170103.840: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140903-170103.840: Informational: AppHookControllerImpl::onSignIn out
                            20140903-170103.840: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140903-170103.841: ACCController::enableSync switch sync ON
                            20140903-170103.842: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170103.842: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-170103.843: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-170103.843: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-170103.845: ACCController::updateWithState: 1
                            20140903-170103.846: ACCController::updateLocalFolder:
                            20140903-170103.846: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-170103.846: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-170103.847: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-170103.848: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-170103.849: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-170103.849: There is no cloud folder at [], so now initalize it.
                            20140903-170103.849: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-170103.849: ACCController::enableSync switch sync OFF
                            20140903-170103.851: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170103.851: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170103.852: ACCController::updateWithState: 11
                            20140903-170103.853: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170103.853: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170103.853: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-170103.854: 2014-09-03 17:01:03: File Monitoring was asked to stop on: : Sync turned off
                            20140903-170103.855: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170103.855: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-170103.859: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-170103.859: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170103.859: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-170103.860: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-170103.866: ACCController::updateWithState: 11
                            20140903-170103.867: Informational: [livetype] syncStatus: OFF
                            20140903-170103.869: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170103.873: ACCController::removeAllIcons
                            20140903-170103.876: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-170103.876: ACCController::enableSync completed switch sync OFF
                            20140903-170103.878: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170103.879: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170103.879: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-170103.880: 2014-09-03 17:01:03: File Monitoring was asked to stop on: : Update job
                            20140903-170103.880: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170103.884: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-170103.884: WorkerThreads: 8
                            20140903-170103.888: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-170103.889: ACCController::enableSync completed switch sync ON
                            20140903-170108.628: MControllerDelegate::enableSync invoked
                            20140903-170108.628: ACCController::enableSync switch sync ON
                            20140903-170108.630: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170108.631: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-170108.631: ACCController::updateWithState: 1
                            20140903-170108.632: ACCController::updateLocalFolder:
                            20140903-170108.632: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-170108.632: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-170108.637: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-170108.637: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-170108.638: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170108.640: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-170108.640: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-170108.641: There is no cloud folder at [], so now initalize it.
                            20140903-170108.641: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-170108.641: ACCController::enableSync switch sync OFF
                            20140903-170108.642: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170108.643: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-170108.643: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170108.646: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-170108.647: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170108.647: ACCController::updateWithState: 11
                            20140903-170108.648: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170108.649: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170108.649: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-170108.650: 2014-09-03 17:01:08: File Monitoring was asked to stop on: : Sync turned off
                            20140903-170108.651: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170108.652: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170108.652: ACCController::updateWithState: 11
                            20140903-170108.653: ACCController::removeAllIcons
                            20140903-170108.653: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-170108.654: ACCController::enableSync completed switch sync OFF
                            20140903-170108.656: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170108.656: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170108.657: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-170108.657: 2014-09-03 17:01:08: File Monitoring was asked to stop on: : Update job
                            20140903-170108.658: 2014-09-03 17:01:08: File Monitoring was asked to stop on: : Update job
                            20140903-170108.658: WorkerThreads: 8
                            20140903-170108.658: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-170108.659: ACCController::enableSync completed switch sync ON
                            20140903-170113.566: MControllerDelegate::enableSync invoked
                            20140903-170113.567: ACCController::enableSync switch sync ON
                            20140903-170113.568: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170113.569: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-170113.569: ACCController::updateWithState: 1
                            20140903-170113.570: ACCController::updateLocalFolder:
                            20140903-170113.570: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-170113.570: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-170113.575: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-170113.576: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-170113.576: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170113.578: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-170113.578: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-170113.579: There is no cloud folder at [], so now initalize it.
                            20140903-170113.579: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-170113.579: ACCController::enableSync switch sync OFF
                            20140903-170113.584: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170113.588: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-170113.588: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170113.588: ACCController::updateWithState: 11
                            20140903-170113.590: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170113.591: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170113.591: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-170113.591: 2014-09-03 17:01:13: File Monitoring was asked to stop on: : Sync turned off
                            20140903-170113.593: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170113.594: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170113.594: ACCController::updateWithState: 11
                            20140903-170113.595: ACCController::removeAllIcons
                            20140903-170113.595: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-170113.596: ACCController::enableSync completed switch sync OFF
                            20140903-170113.598: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170113.598: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170113.599: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-170113.599: 2014-09-03 17:01:13: File Monitoring was asked to stop on: : Update job
                            20140903-170113.600: 2014-09-03 17:01:13: File Monitoring was asked to stop on: : Update job
                            20140903-170113.600: WorkerThreads: 8
                            20140903-170113.600: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-170113.601: ACCController::enableSync completed switch sync ON
                            20140903-170217.870: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140903-170217.879: ACCController::Init
                            20140903-170217.887: ACCController::Init: init fileState cache
                            20140903-170217.890: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140903-170217.890: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-170217.942: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-170217.993: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140903-170217.993: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140903-170217.994: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140903-170218.047: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140903-170218.048: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-170218.049: WorkerThreads: 8
                            20140903-170218.049: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-170218.050: ACCController::Init: add notification observers
                            20140903-170218.053: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170218.054: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170218.055: ACCController::updateWithState: 11
                            20140903-170218.055: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140903-170218.056: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140903-170218.062: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140903-170218.062: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140903-170218.067: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140903-170218.068: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140903-170218.073: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140903-170218.073: Informational: AppHookControllerImpl::onStartup in
                            20140903-170218.078: Informational: [livetype] onStartup
                            20140903-170218.078: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140903-170218.082: Informational: [livetype] onStartup => success
                            20140903-170218.083: Informational: AppHookControllerImpl::onStartup out
                            20140903-170218.110: ACCController::injectFinderExt
                            20140903-170218.112: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-170218.113: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140903-170218.117: ACCController::finderInitSuccessfull: injectExt:YES
                            20140903-170219.151: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-170219.151: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-170219.152: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-170219.152: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-170219.153: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-170219.153: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-170219.154: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-170219.155: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-170219.155: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-170219.156: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-170219.156: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-170219.157: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-170219.157: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-170219.157: MControllerDelegate::enableCollaboration: YES
                            20140903-170219.160: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140903-170219.161: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 84eddec45d6ee98b899bf75f3b74dca6 userId 6E68593446662ED1992016B8@AdobeID
                            20140903-170219.163: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-170219.164: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-170219.164: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-170219.169: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-170219.169: 2014-09-03 17:02:19: File Monitoring was asked to stop on: : Update job
                            20140903-170219.169: MControllerDelegate::enableSync invoked
                            20140903-170219.172: Informational: [livetype] syncStatus: OFF
                            20140903-170219.176: 2014-09-03 17:02:19: File Monitoring was asked to stop on: : Update job
                            20140903-170219.177: WorkerThreads: 8
                            20140903-170219.177: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-170219.177: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-170219.180: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-170219.180: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-170219.181: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-170219.181: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170219.182: Informational: [livetype] syncStatus: OFF
                            20140903-170219.188: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170219.188: ACCController::updateWithState: 11
                            20140903-170219.189: Informational: AppHookControllerImpl::onSignIn in
                            20140903-170219.189: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170219.194: Informational: [livetype] onSignIn
                            20140903-170219.194: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140903-170219.194: Informational: AppHookControllerImpl::onSignIn out
                            20140903-170219.195: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140903-170219.195: ACCController::enableSync switch sync ON
                            20140903-170219.196: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170219.196: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-170219.197: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170219.197: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-170219.198: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-170219.198: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-170219.200: ACCController::updateWithState: 1
                            20140903-170219.201: ACCController::updateLocalFolder:
                            20140903-170219.201: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-170219.201: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-170219.202: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-170219.203: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-170219.204: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-170219.204: There is no cloud folder at [], so now initalize it.
                            20140903-170219.204: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-170219.205: ACCController::enableSync switch sync OFF
                            20140903-170219.206: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170219.206: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170219.207: ACCController::updateWithState: 11
                            20140903-170219.208: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170219.208: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170219.209: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-170219.209: 2014-09-03 17:02:19: File Monitoring was asked to stop on: : Sync turned off
                            20140903-170219.210: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170219.211: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170219.211: ACCController::updateWithState: 11
                            20140903-170219.211: ACCController::removeAllIcons
                            20140903-170219.212: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-170219.213: ACCController::enableSync completed switch sync OFF
                            20140903-170219.214: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-170219.215: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-170219.215: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-170219.216: 2014-09-03 17:02:19: File Monitoring was asked to stop on: : Update job
                            20140903-170219.216: WorkerThreads: 8
                            20140903-170219.216: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-170219.217: ACCController::enableSync completed switch sync ON
                            20140903-171112.553: ACCController::osSleepWake: NSConcreteNotification 0x7fe243301b60 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fe243409180>}
                            20140903-171112.553: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140903-171112.554: 2014-09-03 17:11:12: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140903-171112.555: 2014-09-03 17:11:12: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140903-171844.203: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-171844.708: ACCController::osSleepWake: NSConcreteNotification 0x7fe24346c880 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fe243409180>}
                            20140903-171856.830: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-171856.830: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140903-171856.831: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140903-173930.651: MControllerDelegate::enableSync invoked
                            20140903-173930.652: ACCController::enableSync switch sync ON
                            20140903-173930.654: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-173930.654: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-173930.655: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-173930.656: ACCController::updateWithState: 1
                            20140903-173930.657: ACCController::updateLocalFolder:
                            20140903-173930.657: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-173930.661: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-173930.661: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-173930.663: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-173930.665: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-173930.666: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-173930.666: There is no cloud folder at [], so now initalize it.
                            20140903-173930.666: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-173930.666: ACCController::enableSync switch sync OFF
                            20140903-173930.667: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-173930.669: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-173930.669: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-173930.669: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-173930.670: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-173930.670: ACCController::updateWithState: 11
                            20140903-173930.671: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-173930.672: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-173930.672: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-173930.672: 2014-09-03 17:39:30: File Monitoring was asked to stop on: : Sync turned off
                            20140903-173930.673: 2014-09-03 17:39:30: File Monitoring was asked to stop on: : Sync turned off
                            20140903-173930.674: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-173930.674: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-173930.674: ACCController::updateWithState: 11
                            20140903-173930.675: ACCController::removeAllIcons
                            20140903-173930.675: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-173930.676: ACCController::enableSync completed switch sync OFF
                            20140903-173930.678: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-173930.679: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-173930.679: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-173930.679: 2014-09-03 17:39:30: File Monitoring was asked to stop on: : Update job
                            20140903-173930.680: WorkerThreads: 8
                            20140903-173930.680: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-173930.680: ACCController::enableSync completed switch sync ON
                            20140903-174251.157: MControllerDelegate::enableSync invoked
                            20140903-174251.158: ACCController::enableSync switch sync ON
                            20140903-174251.160: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174251.161: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-174251.161: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174251.161: ACCController::updateWithState: 1
                            20140903-174251.164: ACCController::updateLocalFolder:
                            20140903-174251.164: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-174251.167: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-174251.167: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174251.169: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-174251.172: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-174251.173: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-174251.173: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174251.176: There is no cloud folder at [], so now initalize it.
                            20140903-174251.176: MControllerDelegate::syncStatus state 1 (CoreSyncStateSignedIn)
                            20140903-174251.179: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-174251.179: ACCController::enableSync switch sync OFF
                            20140903-174251.181: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174251.181: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174251.182: ACCController::updateWithState: 11
                            20140903-174251.183: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174251.183: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174251.183: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-174251.184: 2014-09-03 17:42:51: File Monitoring was asked to stop on: : Sync turned off
                            20140903-174251.185: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174251.186: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174251.186: ACCController::updateWithState: 11
                            20140903-174251.187: ACCController::removeAllIcons
                            20140903-174251.187: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174251.188: ACCController::enableSync completed switch sync OFF
                            20140903-174251.190: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174251.191: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174251.191: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-174251.191: 2014-09-03 17:42:51: File Monitoring was asked to stop on: : Update job
                            20140903-174251.192: WorkerThreads: 8
                            20140903-174251.192: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-174251.192: ACCController::enableSync completed switch sync ON
                            20140903-174353.451: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140903-174353.460: ACCController::Init
                            20140903-174353.468: ACCController::Init: init fileState cache
                            20140903-174353.472: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140903-174353.472: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-174353.524: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140903-174353.575: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140903-174353.576: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140903-174353.576: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140903-174353.629: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140903-174353.630: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-174353.631: WorkerThreads: 8
                            20140903-174353.631: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-174353.632: ACCController::Init: add notification observers
                            20140903-174353.635: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174353.636: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174353.637: ACCController::updateWithState: 11
                            20140903-174353.637: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140903-174353.638: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140903-174353.644: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140903-174353.644: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140903-174353.649: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140903-174353.649: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140903-174353.654: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140903-174353.654: Informational: AppHookControllerImpl::onStartup in
                            20140903-174353.657: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140903-174353.657: Informational: [livetype] onStartup
                            20140903-174353.662: Informational: [livetype] onStartup => success
                            20140903-174353.662: Informational: AppHookControllerImpl::onStartup out
                            20140903-174353.684: ACCController::injectFinderExt
                            20140903-174353.685: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-174353.685: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140903-174353.688: ACCController::finderInitSuccessfull: injectExt:YES
                            20140903-174354.731: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140903-174354.731: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140903-174354.732: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140903-174354.732: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140903-174354.732: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140903-174354.733: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140903-174354.734: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140903-174354.734: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140903-174354.735: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140903-174354.735: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140903-174354.736: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140903-174354.736: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140903-174354.736: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140903-174354.736: MControllerDelegate::enableCollaboration: YES
                            20140903-174354.738: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140903-174354.738: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 84eddec45d6ee98b899bf75f3b74dca6 userId 6E68593446662ED1992016B8@AdobeID
                            20140903-174354.740: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-174354.740: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-174354.745: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-174354.745: MControllerDelegate::enableSync invoked
                            20140903-174354.745: 2014-09-03 17:43:54: File Monitoring was asked to stop on: : Update job
                            20140903-174354.749: Informational: [livetype] syncStatus: OFF
                            20140903-174354.752: 2014-09-03 17:43:54: File Monitoring was asked to stop on: : Update job
                            20140903-174354.752: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-174354.757: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140903-174354.757: WorkerThreads: 8
                            20140903-174354.760: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-174354.760: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140903-174354.761: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174354.767: Informational: [livetype] syncStatus: OFF
                            20140903-174354.768: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174354.768: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174354.770: ACCController::updateWithState: 11
                            20140903-174354.771: Informational: AppHookControllerImpl::onSignIn in
                            20140903-174354.772: Informational: [livetype] onSignIn
                            20140903-174354.773: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140903-174354.773: Informational: AppHookControllerImpl::onSignIn out
                            20140903-174354.774: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140903-174354.774: ACCController::enableSync switch sync ON
                            20140903-174354.778: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174354.782: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-174354.783: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-174354.783: ACCController::updateWithState: 1
                            20140903-174354.783: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-174354.784: ACCController::updateLocalFolder:
                            20140903-174354.786: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140903-174354.787: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-174354.791: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-174354.791: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-174354.793: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-174354.794: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-174354.794: There is no cloud folder at [], so now initalize it.
                            20140903-174354.795: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-174354.795: ACCController::enableSync switch sync OFF
                            20140903-174354.797: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174354.798: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174354.798: ACCController::updateWithState: 11
                            20140903-174354.799: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174354.800: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174354.800: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-174354.801: 2014-09-03 17:43:54: File Monitoring was asked to stop on: : Sync turned off
                            20140903-174354.802: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174354.803: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174354.803: ACCController::updateWithState: 11
                            20140903-174354.804: ACCController::removeAllIcons
                            20140903-174354.804: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174354.805: ACCController::enableSync completed switch sync OFF
                            20140903-174354.807: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174354.808: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174354.808: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-174354.809: 2014-09-03 17:43:54: File Monitoring was asked to stop on: : Update job
                            20140903-174354.809: WorkerThreads: 8
                            20140903-174354.810: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-174354.810: ACCController::enableSync completed switch sync ON
                            20140903-174805.132: MControllerDelegate::enableSync invoked
                            20140903-174805.133: ACCController::enableSync switch sync ON
                            20140903-174805.135: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174805.135: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-174805.136: ACCController::updateWithState: 1
                            20140903-174805.136: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174805.140: ACCController::updateLocalFolder:
                            20140903-174805.140: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-174805.143: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-174805.143: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174805.144: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-174805.147: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-174805.147: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-174805.148: There is no cloud folder at [], so now initalize it.
                            20140903-174805.148: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-174805.148: ACCController::enableSync switch sync OFF
                            20140903-174805.149: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174805.149: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-174805.154: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-174805.154: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174805.155: ACCController::updateWithState: 11
                            20140903-174805.157: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174805.159: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174805.159: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-174805.159: 2014-09-03 17:48:05: File Monitoring was asked to stop on: : Sync turned off
                            20140903-174805.160: 2014-09-03 17:48:05: File Monitoring was asked to stop on: : Sync turned off
                            20140903-174805.161: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174805.161: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174805.161: ACCController::updateWithState: 11
                            20140903-174805.162: ACCController::removeAllIcons
                            20140903-174805.162: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174805.164: ACCController::enableSync completed switch sync OFF
                            20140903-174805.166: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174805.167: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174805.167: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-174805.168: 2014-09-03 17:48:05: File Monitoring was asked to stop on: : Update job
                            20140903-174805.168: WorkerThreads: 8
                            20140903-174805.169: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-174805.169: ACCController::enableSync completed switch sync ON
                            20140903-174823.615: MControllerDelegate::enableSync invoked
                            20140903-174823.615: ACCController::enableSync switch sync ON
                            20140903-174823.617: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174823.618: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-174823.619: ACCController::updateWithState: 1
                            20140903-174823.619: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174823.623: ACCController::updateLocalFolder:
                            20140903-174823.624: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-174823.624: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-174823.625: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-174823.625: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174823.628: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-174823.628: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-174823.628: There is no cloud folder at [], so now initalize it.
                            20140903-174823.629: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-174823.629: ACCController::enableSync switch sync OFF
                            20140903-174823.629: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174823.632: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-174823.632: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-174823.633: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174823.633: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174823.633: ACCController::updateWithState: 11
                            20140903-174823.635: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174823.637: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174823.637: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-174823.638: 2014-09-03 17:48:23: File Monitoring was asked to stop on: : Sync turned off
                            20140903-174823.640: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174823.641: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174823.641: ACCController::updateWithState: 11
                            20140903-174823.641: ACCController::removeAllIcons
                            20140903-174823.642: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174823.643: ACCController::enableSync completed switch sync OFF
                            20140903-174823.644: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174823.644: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174823.645: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-174823.645: 2014-09-03 17:48:23: File Monitoring was asked to stop on: : Update job
                            20140903-174823.645: WorkerThreads: 8
                            20140903-174823.646: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-174823.646: ACCController::enableSync completed switch sync ON
                            20140903-174826.231: MControllerDelegate::enableSync invoked
                            20140903-174826.232: ACCController::enableSync switch sync ON
                            20140903-174826.234: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.235: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-174826.236: ACCController::updateWithState: 1
                            20140903-174826.236: ACCController::updateLocalFolder:
                            20140903-174826.236: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174826.240: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-174826.240: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-174826.241: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-174826.241: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.243: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-174826.244: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-174826.244: There is no cloud folder at [], so now initalize it.
                            20140903-174826.244: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-174826.245: ACCController::enableSync switch sync OFF
                            20140903-174826.246: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.246: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-174826.249: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-174826.249: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174826.250: ACCController::updateWithState: 11
                            20140903-174826.251: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.252: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174826.253: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-174826.253: 2014-09-03 17:48:26: File Monitoring was asked to stop on: : Sync turned off
                            20140903-174826.254: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.255: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174826.255: ACCController::updateWithState: 11
                            20140903-174826.256: ACCController::removeAllIcons
                            20140903-174826.256: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174826.257: ACCController::enableSync completed switch sync OFF
                            20140903-174826.258: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.259: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174826.259: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-174826.259: 2014-09-03 17:48:26: File Monitoring was asked to stop on: : Update job
                            20140903-174826.260: 2014-09-03 17:48:26: File Monitoring was asked to stop on: : Update job
                            20140903-174826.260: WorkerThreads: 8
                            20140903-174826.260: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-174826.261: ACCController::enableSync completed switch sync ON
                            20140903-174826.805: MControllerDelegate::enableSync invoked
                            20140903-174826.806: ACCController::enableSync switch sync ON
                            20140903-174826.807: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.808: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-174826.809: ACCController::updateWithState: 1
                            20140903-174826.809: ACCController::updateLocalFolder:
                            20140903-174826.809: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-174826.810: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174826.811: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-174826.811: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-174826.813: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.814: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-174826.814: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-174826.814: There is no cloud folder at [], so now initalize it.
                            20140903-174826.815: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-174826.815: ACCController::enableSync switch sync OFF
                            20140903-174826.820: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.824: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140903-174826.825: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174826.825: ACCController::updateWithState: 11
                            20140903-174826.826: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.827: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174826.827: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-174826.827: 2014-09-03 17:48:26: File Monitoring was asked to stop on: : Sync turned off
                            20140903-174826.828: 2014-09-03 17:48:26: File Monitoring was asked to stop on: : Sync turned off
                            20140903-174826.829: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.829: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174826.829: ACCController::updateWithState: 11
                            20140903-174826.830: ACCController::removeAllIcons
                            20140903-174826.830: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174826.831: ACCController::enableSync completed switch sync OFF
                            20140903-174826.832: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174826.833: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174826.834: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-174826.835: 2014-09-03 17:48:26: File Monitoring was asked to stop on: : Update job
                            20140903-174826.836: WorkerThreads: 8
                            20140903-174826.837: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-174826.838: ACCController::enableSync completed switch sync ON
                            20140903-174827.095: MControllerDelegate::enableSync invoked
                            20140903-174827.096: ACCController::enableSync switch sync ON
                            20140903-174827.098: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174827.099: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-174827.099: ACCController::updateWithState: 1
                            20140903-174827.100: ACCController::updateLocalFolder:
                            20140903-174827.101: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174827.101: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-174827.106: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-174827.106: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-174827.107: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174827.109: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-174827.109: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-174827.110: There is no cloud folder at [], so now initalize it.
                            20140903-174827.110: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-174827.110: ACCController::enableSync switch sync OFF
                            20140903-174827.111: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174827.111: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-174827.111: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-174827.112: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174827.113: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174827.113: ACCController::updateWithState: 11
                            20140903-174827.115: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174827.115: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174827.116: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-174827.116: 2014-09-03 17:48:27: File Monitoring was asked to stop on: : Sync turned off
                            20140903-174827.118: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174827.119: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174827.119: ACCController::updateWithState: 11
                            20140903-174827.120: ACCController::removeAllIcons
                            20140903-174827.121: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-174827.122: ACCController::enableSync completed switch sync OFF
                            20140903-174827.123: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-174827.124: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-174827.124: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-174827.125: 2014-09-03 17:48:27: File Monitoring was asked to stop on: : Update job
                            20140903-174827.125: WorkerThreads: 8
                            20140903-174827.125: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-174827.126: ACCController::enableSync completed switch sync ON
                            20140903-174924.829: ACCController::osSleepWake: NSConcreteNotification 0x7fa212c331c0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fa210c56280>}
                            20140903-174924.830: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140903-174924.830: 2014-09-03 17:49:24: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140903-174924.831: 2014-09-03 17:49:24: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140903-175243.192: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-175243.712: ACCController::osSleepWake: NSConcreteNotification 0x7fa210e4ab40 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fa210c56280>}
                            20140903-175314.165: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-175446.098: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140903-175446.099: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140903-175527.160: ACCController::osSleepWake: NSConcreteNotification 0x7fa212c3e400 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fa210c56280>}
                            20140903-175527.161: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140903-175527.162: 2014-09-03 17:55:27: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140903-175940.162: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-191012.059: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140903-191012.060: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140903-191012.653: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-200303.225: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140903-200305.709: ACCController::osSleepWake: NSConcreteNotification 0x7fa212800b70 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fa210c56280>}
                            20140903-200351.910: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-200351.910: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140903-200351.910: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140903-200425.352: ACCController::doInjectFinderExt: injectExt = 1
                            20140903-200425.352: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140903-200425.353: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140903-201013.121: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140903-201013.123: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140903-201013.123: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140903-201327.013: MControllerDelegate::enableSync invoked
                            20140903-201327.014: ACCController::enableSync switch sync ON
                            20140903-201327.017: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-201327.029: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201327.033: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-201327.033: ACCController::updateWithState: 1
                            20140903-201327.034: ACCController::updateLocalFolder:
                            20140903-201327.034: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-201327.035: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-201327.035: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-201327.036: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201327.036: MControllerDelegate::syncStatus state 1 (CoreSyncStateSignedIn)
                            20140903-201327.038: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-201327.038: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-201327.038: There is no cloud folder at [], so now initalize it.
                            20140903-201327.038: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-201327.039: ACCController::enableSync switch sync OFF
                            20140903-201327.040: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201327.040: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-201327.041: ACCController::updateWithState: 11
                            20140903-201327.042: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201327.042: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-201327.042: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-201327.043: 2014-09-03 20:13:27: File Monitoring was asked to stop on: : Sync turned off
                            20140903-201327.044: 2014-09-03 20:13:27: File Monitoring was asked to stop on: : Sync turned off
                            20140903-201327.045: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201327.045: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-201327.045: ACCController::updateWithState: 11
                            20140903-201327.046: ACCController::removeAllIcons
                            20140903-201327.046: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-201327.047: ACCController::enableSync completed switch sync OFF
                            20140903-201327.049: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201327.049: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-201327.050: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-201327.050: 2014-09-03 20:13:27: File Monitoring was asked to stop on: : Update job
                            20140903-201327.051: WorkerThreads: 8
                            20140903-201327.051: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-201327.052: ACCController::enableSync completed switch sync ON
                            20140903-201404.445: MControllerDelegate::enableSync invoked
                            20140903-201404.446: ACCController::enableSync switch sync ON
                            20140903-201404.447: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201404.448: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140903-201404.448: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-201404.449: ACCController::updateWithState: 1
                            20140903-201404.451: ACCController::updateLocalFolder:
                            20140903-201404.451: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140903-201404.454: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140903-201404.455: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201404.457: No folder owner for current cloud folder, so archive directly to [archived].
                            20140903-201404.459: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140903-201404.459: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140903-201404.459: There is no cloud folder at [], so now initalize it.
                            20140903-201404.460: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140903-201404.460: ACCController::enableSync switch sync OFF
                            20140903-201404.461: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201404.461: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140903-201404.461: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140903-201404.462: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201404.463: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-201404.463: ACCController::updateWithState: 11
                            20140903-201404.465: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201404.465: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-201404.465: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140903-201404.466: 2014-09-03 20:14:04: File Monitoring was asked to stop on: : Sync turned off
                            20140903-201404.467: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201404.468: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-201404.468: ACCController::updateWithState: 11
                            20140903-201404.468: ACCController::removeAllIcons
                            20140903-201404.469: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140903-201404.470: ACCController::enableSync completed switch sync OFF
                            20140903-201404.471: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140903-201404.472: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140903-201404.472: ACCSync::stopJob: forced: 1, reason: Update job
                            20140903-201404.472: 2014-09-03 20:14:04: File Monitoring was asked to stop on: : Update job
                            20140903-201404.473: 2014-09-03 20:14:04: File Monitoring was asked to stop on: : Update job
                            20140903-201404.473: WorkerThreads: 8
                            20140903-201404.473: Notice: setTargetDataRates: 0 upload, 0 download
                            20140903-201404.474: ACCController::enableSync completed switch sync ON
                            20140903-201413.130: MControllerDelegate::shutdownRequest
                            20140903-201413.130: ACCController::shutdown
                            20140903-201413.131: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140903-201413.131: 2014-09-03 20:14:13: File Monitoring was asked to stop on: : shutdown
                            20140903-201413.131: Informational: AppHookControllerImpl::onShutdown in
                            20140903-201442.272: Informational: [livetype] onShutdown
                            20140903-201442.272: Informational: [livetype]  disableFontSync
                            20140903-201442.273: Informational: [livetype] deactivated all fonts
                            20140903-201442.275: Informational: AppHookControllerImpl::onShutdown out
                            20140903-201442.276: ACCController::removeAllIcons
                            20140903-201442.278: ACCController::shutdown completed
                            20140904-091916.153: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140904-091916.163: ACCController::Init
                            20140904-091916.170: ACCController::Init: init fileState cache
                            20140904-091916.195: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140904-091916.196: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140904-091916.248: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140904-091916.249: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140904-091916.249: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140904-091916.299: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140904-091916.300: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-091916.301: WorkerThreads: 8
                            20140904-091916.302: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-091916.310: ACCController::Init: add notification observers
                            20140904-091916.313: CJournalDB::Init: schema differs: incorrect number of tables
                            20140904-091916.314: CJournalDB::_create: successfully created 5 tables
                            20140904-091916.382: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-091916.383: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-091916.383: ACCController::updateWithState: 11
                            20140904-091916.384: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140904-091916.384: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140904-091916.391: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140904-091916.391: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140904-091916.397: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140904-091916.397: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140904-091916.402: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140904-091916.402: Informational: AppHookControllerImpl::onStartup in
                            20140904-091916.415: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140904-091916.415: Informational: [livetype] onStartup
                            20140904-091916.419: Informational: [livetype] onStartup => success
                            20140904-091916.420: Informational: AppHookControllerImpl::onStartup out
                            20140904-091916.446: ACCController::injectFinderExt
                            20140904-091916.447: ACCController::doInjectFinderExt: injectExt = 1
                            20140904-091916.448: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140904-091916.496: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140904-091916.550: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140904-091916.564: ACCController::finderInitSuccessfull: injectExt:YES
                            20140904-091916.566: ACCController::finderInitSuccessfull: injectExt:YES
                            20140904-091916.567: ACCFinderExtensionController::init: intialization succsessfull
                            20140904-091917.482: MControllerDelegate::invalidateAccessToken
                            20140904-091917.483: ACCController::invalidateAccessToken
                            20140904-091917.483: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140904-091917.484: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140904-091917.484: Informational: [livetype] onInvalidateAccessToken
                            20140904-091917.485: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140904-091917.485: ACCController::invalidateAccessToken completed
                            20140904-091917.851: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-091917.851: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-091917.852: Informational: [livetype] syncStatus: OFF
                            20140904-092018.931: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140904-092018.931: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140904-092018.932: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140904-092018.932: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140904-092018.932: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140904-092018.933: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140904-092018.933: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140904-092018.933: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140904-092018.933: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140904-092018.934: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140904-092018.934: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140904-092018.934: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140904-092018.935: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140904-092018.935: MControllerDelegate::enableCollaboration: YES
                            20140904-092019.778: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140904-092019.778: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140904-092019.778: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140904-092019.779: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140904-092019.779: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140904-092019.780: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140904-092019.780: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140904-092019.780: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140904-092019.780: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140904-092019.781: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140904-092019.781: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140904-092019.781: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140904-092019.781: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140904-092019.782: MControllerDelegate::enableCollaboration: YES
                            20140904-092019.783: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140904-092019.784: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken e7e9e3ecb16a18675781978c7656af7b userId 6E68593446662ED1992016B8@AdobeID
                            20140904-092019.784: MControllerDelegate::disableSync invoked
                            20140904-092019.786: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-092019.786: PrefernceManager::updatePrefernces
                            20140904-092019.788: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-092019.789: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-092019.790: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-092019.791: 2014-09-04 09:20:19: File Monitoring was asked to stop on: : Update job
                            20140904-092019.791: Informational: [livetype] syncStatus: OFF
                            20140904-092019.793: 2014-09-04 09:20:19: File Monitoring was asked to stop on: : Update job
                            20140904-092019.794: WorkerThreads: 8
                            20140904-092019.794: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-092019.795: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-092019.795: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-092019.796: ACCController::updateWithState: 11
                            20140904-092019.797: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-092019.798: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140904-092019.798: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-092019.799: Informational: AppHookControllerImpl::onSignIn in
                            20140904-092019.800: Informational: [livetype] onSignIn
                            20140904-092019.800: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140904-092019.801: Informational: AppHookControllerImpl::onSignIn out
                            20140904-092019.801: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140904-092019.801: ACCController::disableSync sync is already disabled
                            20140904-092019.803: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140904-092101.004: ACCController::doInjectFinderExt: injectExt = 1
                            20140904-092101.004: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140904-092101.005: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140904-092335.467: ACCController::osSleepWake: NSConcreteNotification 0x7fc823c3bf90 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fc823b0c740>}
                            20140904-092335.468: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140904-092335.468: 2014-09-04 09:23:35: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140904-092335.469: 2014-09-04 09:23:35: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140904-100316.674: Warning: [GUDE]: Request Failed. ErrorCode: 100049 message: Platform Status. (NSPOSIXErrorDomain 49) Can't assign requested address. Can't assign requested address.
                            20140904-100316.702: ACCController::osSleepWake: NSConcreteNotification 0x7fc82382ed50 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fc823b0c740>}
                            20140904-100347.126: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140904-100510.487: MControllerDelegate::enableSync invoked
                            20140904-100510.488: ACCController::enableSync switch sync ON
                            20140904-100510.490: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100510.491: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140904-100510.491: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-100510.494: ACCController::updateWithState: 1
                            20140904-100510.494: ACCController::updateLocalFolder:
                            20140904-100510.494: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140904-100510.498: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140904-100510.498: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100510.500: No folder owner for current cloud folder, so archive directly to [archived].
                            20140904-100510.502: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140904-100510.503: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140904-100510.503: There is no cloud folder at [], so now initalize it.
                            20140904-100510.504: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140904-100510.504: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100510.506: ACCController::enableSync switch sync OFF
                            20140904-100510.506: MControllerDelegate::syncStatus state 1 (CoreSyncStateSignedIn)
                            20140904-100510.511: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100510.511: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-100510.512: ACCController::updateWithState: 11
                            20140904-100510.513: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100510.513: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-100510.513: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140904-100510.514: 2014-09-04 10:05:10: File Monitoring was asked to stop on: : Sync turned off
                            20140904-100510.515: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100510.516: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-100510.516: ACCController::updateWithState: 11
                            20140904-100510.517: ACCController::removeAllIcons
                            20140904-100510.517: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-100510.518: ACCController::enableSync completed switch sync OFF
                            20140904-100510.519: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100510.520: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-100510.520: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-100510.521: 2014-09-04 10:05:10: File Monitoring was asked to stop on: : Update job
                            20140904-100510.521: WorkerThreads: 8
                            20140904-100510.522: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-100510.522: ACCController::enableSync completed switch sync ON
                            20140904-100616.928: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140904-100616.937: ACCController::Init
                            20140904-100616.944: ACCController::Init: init fileState cache
                            20140904-100616.947: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140904-100616.948: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140904-100616.998: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140904-100616.999: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140904-100616.999: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140904-100617.052: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140904-100617.052: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-100617.053: WorkerThreads: 8
                            20140904-100617.053: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-100617.054: ACCController::Init: add notification observers
                            20140904-100617.057: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100617.057: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-100617.058: ACCController::updateWithState: 11
                            20140904-100617.058: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140904-100617.058: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140904-100617.063: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140904-100617.063: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140904-100617.067: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140904-100617.068: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140904-100617.072: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140904-100617.072: Informational: AppHookControllerImpl::onStartup in
                            20140904-100617.075: Informational: [livetype] onStartup
                            20140904-100617.075: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140904-100617.079: Informational: [livetype] onStartup => success
                            20140904-100617.079: Informational: AppHookControllerImpl::onStartup out
                            20140904-100617.100: ACCController::injectFinderExt
                            20140904-100617.101: ACCController::doInjectFinderExt: injectExt = 1
                            20140904-100617.102: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140904-100617.104: ACCController::finderInitSuccessfull: injectExt:YES
                            20140904-100618.144: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140904-100618.145: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140904-100618.145: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140904-100618.146: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140904-100618.147: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140904-100618.147: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140904-100618.148: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140904-100618.148: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140904-100618.149: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140904-100618.149: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140904-100618.149: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140904-100618.150: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140904-100618.150: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140904-100618.150: MControllerDelegate::enableCollaboration: YES
                            20140904-100618.152: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140904-100618.152: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken e7e9e3ecb16a18675781978c7656af7b userId 6E68593446662ED1992016B8@AdobeID
                            20140904-100618.154: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-100618.155: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-100618.157: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-100618.158: 2014-09-04 10:06:18: File Monitoring was asked to stop on: : Update job
                            20140904-100618.158: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-100618.158: MControllerDelegate::enableSync invoked
                            20140904-100618.160: 2014-09-04 10:06:18: File Monitoring was asked to stop on: : Update job
                            20140904-100618.165: WorkerThreads: 8
                            20140904-100618.166: Informational: [livetype] syncStatus: OFF
                            20140904-100618.166: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-100618.166: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-100618.174: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-100618.174: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-100618.174: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-100618.175: Informational: [livetype] syncStatus: OFF
                            20140904-100618.175: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100618.176: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100618.182: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-100618.182: ACCController::updateWithState: 11
                            20140904-100618.183: Informational: AppHookControllerImpl::onSignIn in
                            20140904-100618.184: Informational: [livetype] onSignIn
                            20140904-100618.185: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140904-100618.186: Informational: AppHookControllerImpl::onSignIn out
                            20140904-100618.186: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140904-100618.187: ACCController::enableSync switch sync ON
                            20140904-100618.187: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100618.188: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140904-100618.189: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100618.190: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140904-100618.190: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140904-100618.190: ACCController::updateWithState: 1
                            20140904-100618.192: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140904-100618.193: ACCController::updateLocalFolder:
                            20140904-100618.195: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140904-100618.196: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140904-100618.196: No folder owner for current cloud folder, so archive directly to [archived].
                            20140904-100618.198: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140904-100618.199: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140904-100618.199: There is no cloud folder at [], so now initalize it.
                            20140904-100618.200: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140904-100618.200: ACCController::enableSync switch sync OFF
                            20140904-100618.202: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100618.203: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-100618.204: ACCController::updateWithState: 11
                            20140904-100618.206: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100618.207: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-100618.207: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140904-100618.208: 2014-09-04 10:06:18: File Monitoring was asked to stop on: : Sync turned off
                            20140904-100618.210: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100618.210: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-100618.211: ACCController::updateWithState: 11
                            20140904-100618.212: ACCController::removeAllIcons
                            20140904-100618.213: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-100618.214: ACCController::enableSync completed switch sync OFF
                            20140904-100618.216: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-100618.217: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-100618.218: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-100618.218: 2014-09-04 10:06:18: File Monitoring was asked to stop on: : Update job
                            20140904-100618.219: 2014-09-04 10:06:18: File Monitoring was asked to stop on: : Update job
                            20140904-100618.219: WorkerThreads: 8
                            20140904-100618.219: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-100618.220: ACCController::enableSync completed switch sync ON
                            20140904-101455.194: MControllerDelegate::shutdownRequest
                            20140904-101455.195: ACCController::shutdown
                            20140904-101455.195: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140904-101455.195: 2014-09-04 10:14:55: File Monitoring was asked to stop on: : shutdown
                            20140904-101455.196: Informational: AppHookControllerImpl::onShutdown in
                            20140904-101455.297: Informational: [livetype] onShutdown
                            20140904-101455.297: Informational: [livetype]  disableFontSync
                            20140904-101455.297: Informational: [livetype] deactivated all fonts
                            20140904-101455.298: Informational: AppHookControllerImpl::onShutdown out
                            20140904-101455.298: ACCController::removeAllIcons
                            20140904-101455.301: ACCController::shutdown completed
                            20140904-151053.452: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140904-151053.473: ACCController::Init
                            20140904-151053.484: ACCController::Init: init fileState cache
                            20140904-151053.493: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140904-151054.497: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140904-151054.549: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140904-151054.600: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140904-151054.601: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140904-151054.653: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140904-151054.654: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-151054.655: WorkerThreads: 8
                            20140904-151054.656: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-151054.658: ACCController::Init: add notification observers
                            20140904-151054.671: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151054.677: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151054.678: ACCController::updateWithState: 11
                            20140904-151054.678: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140904-151054.678: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140904-151054.703: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140904-151054.703: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140904-151054.719: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140904-151054.719: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140904-151054.729: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140904-151054.730: Informational: AppHookControllerImpl::onStartup in
                            20140904-151054.734: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140904-151054.734: Informational: [livetype] onStartup
                            20140904-151054.738: Informational: [livetype] onStartup => success
                            20140904-151054.738: Informational: AppHookControllerImpl::onStartup out
                            20140904-151054.786: ACCController::injectFinderExt
                            20140904-151054.787: ACCController::doInjectFinderExt: injectExt = 1
                            20140904-151054.788: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140904-151054.791: ACCController::finderInitSuccessfull: injectExt:YES
                            20140904-151345.524: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140904-151347.811: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140904-151347.811: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140904-151347.812: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140904-151347.812: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140904-151347.812: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140904-151347.813: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140904-151347.813: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140904-151347.813: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140904-151347.814: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140904-151347.814: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140904-151347.814: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140904-151347.814: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140904-151347.815: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140904-151347.815: MControllerDelegate::enableCollaboration: YES
                            20140904-151400.846: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140904-151400.846: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140904-151400.846: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140904-151400.847: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140904-151400.847: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140904-151400.848: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140904-151400.848: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140904-151400.849: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140904-151400.850: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140904-151400.850: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140904-151400.851: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140904-151400.851: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140904-151400.852: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140904-151400.852: MControllerDelegate::enableCollaboration: YES
                            20140904-151400.853: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140904-151400.854: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken c6dfbb1dd7350cb87263bedeeb860c76 userId 6E68593446662ED1992016B8@AdobeID
                            20140904-151400.857: PrefernceManager::updatePrefernces
                            20140904-151400.857: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-151400.857: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-151400.860: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-151400.860: 2014-09-04 15:14:00: File Monitoring was asked to stop on: : Update job
                            20140904-151400.861: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-151400.861: WorkerThreads: 8
                            20140904-151400.861: MControllerDelegate::disableSync invoked
                            20140904-151400.867: Informational: [livetype] syncStatus: OFF
                            20140904-151400.869: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-151400.869: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-151400.875: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-151400.876: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-151400.876: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151400.877: Informational: [livetype] syncStatus: OFF
                            20140904-151400.880: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151400.881: ACCController::updateWithState: 11
                            20140904-151400.883: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151400.883: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140904-151400.884: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151400.884: Informational: AppHookControllerImpl::onSignIn in
                            20140904-151400.885: Informational: [livetype] onSignIn
                            20140904-151400.886: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140904-151400.886: Informational: AppHookControllerImpl::onSignIn out
                            20140904-151400.887: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140904-151400.887: ACCController::disableSync sync is already disabled
                            20140904-151400.888: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140904-151400.889: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140904-151415.779: MControllerDelegate::enableSync invoked
                            20140904-151415.780: ACCController::enableSync switch sync ON
                            20140904-151415.781: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151415.782: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140904-151415.782: ACCController::updateWithState: 1
                            20140904-151415.783: ACCController::updateLocalFolder:
                            20140904-151415.784: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-151415.784: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140904-151415.788: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140904-151415.788: No folder owner for current cloud folder, so archive directly to [archived].
                            20140904-151415.789: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151415.791: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140904-151415.791: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140904-151415.791: There is no cloud folder at [], so now initalize it.
                            20140904-151415.792: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140904-151415.792: ACCController::enableSync switch sync OFF
                            20140904-151415.793: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151415.793: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140904-151415.793: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140904-151415.794: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151415.794: ACCController::updateWithState: 11
                            20140904-151415.795: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151415.796: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151415.796: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140904-151415.796: 2014-09-04 15:14:15: File Monitoring was asked to stop on: : Sync turned off
                            20140904-151415.797: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151415.798: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151415.798: ACCController::updateWithState: 11
                            20140904-151415.799: ACCController::removeAllIcons
                            20140904-151415.799: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-151415.800: ACCController::enableSync completed switch sync OFF
                            20140904-151415.801: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151415.802: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151415.802: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-151415.803: 2014-09-04 15:14:15: File Monitoring was asked to stop on: : Update job
                            20140904-151415.804: WorkerThreads: 8
                            20140904-151415.804: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-151415.805: ACCController::enableSync completed switch sync ON
                            20140904-151424.833: MControllerDelegate::enableSync invoked
                            20140904-151424.834: ACCController::enableSync switch sync ON
                            20140904-151424.835: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151424.836: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140904-151424.837: ACCController::updateWithState: 1
                            20140904-151424.837: ACCController::updateLocalFolder:
                            20140904-151424.838: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-151424.839: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140904-151424.842: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140904-151424.843: No folder owner for current cloud folder, so archive directly to [archived].
                            20140904-151424.843: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151424.845: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140904-151424.846: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140904-151424.846: There is no cloud folder at [], so now initalize it.
                            20140904-151424.846: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140904-151424.846: ACCController::enableSync switch sync OFF
                            20140904-151424.847: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151424.847: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140904-151424.848: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151424.848: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140904-151424.850: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151424.851: ACCController::updateWithState: 11
                            20140904-151424.852: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151424.852: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151424.853: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140904-151424.853: 2014-09-04 15:14:24: File Monitoring was asked to stop on: : Sync turned off
                            20140904-151424.855: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151424.855: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151424.856: ACCController::updateWithState: 11
                            20140904-151424.856: ACCController::removeAllIcons
                            20140904-151424.857: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-151424.857: ACCController::enableSync completed switch sync OFF
                            20140904-151424.859: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151424.860: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151424.860: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-151424.860: 2014-09-04 15:14:24: File Monitoring was asked to stop on: : Update job
                            20140904-151424.861: WorkerThreads: 8
                            20140904-151424.861: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-151424.861: ACCController::enableSync completed switch sync ON
                            20140904-151531.287: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140904-151531.296: ACCController::Init
                            20140904-151531.303: ACCController::Init: init fileState cache
                            20140904-151531.306: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140904-151531.307: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140904-151531.359: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140904-151531.410: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140904-151531.411: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140904-151531.411: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140904-151531.464: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140904-151531.465: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-151531.466: WorkerThreads: 8
                            20140904-151531.467: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-151531.467: ACCController::Init: add notification observers
                            20140904-151531.471: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151531.472: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151531.472: ACCController::updateWithState: 11
                            20140904-151531.473: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140904-151531.473: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140904-151531.479: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140904-151531.479: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140904-151531.484: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140904-151531.484: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140904-151531.488: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140904-151531.489: Informational: AppHookControllerImpl::onStartup in
                            20140904-151531.492: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140904-151531.492: Informational: [livetype] onStartup
                            20140904-151531.495: Informational: [livetype] onStartup => success
                            20140904-151531.495: Informational: AppHookControllerImpl::onStartup out
                            20140904-151531.518: ACCController::injectFinderExt
                            20140904-151531.519: ACCController::doInjectFinderExt: injectExt = 1
                            20140904-151531.519: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140904-151531.522: ACCController::finderInitSuccessfull: injectExt:YES
                            20140904-151532.552: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140904-151532.553: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140904-151532.553: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140904-151532.554: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140904-151532.554: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140904-151532.555: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140904-151532.555: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140904-151532.556: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140904-151532.556: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140904-151532.556: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140904-151532.556: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140904-151532.557: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140904-151532.557: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140904-151532.557: MControllerDelegate::enableCollaboration: YES
                            20140904-151532.558: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140904-151532.559: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken c6dfbb1dd7350cb87263bedeeb860c76 userId 6E68593446662ED1992016B8@AdobeID
                            20140904-151532.560: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-151532.561: 2014-09-04 15:15:32: File Monitoring was asked to stop on: : Update job
                            20140904-151532.561: WorkerThreads: 8
                            20140904-151532.562: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-151532.563: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-151532.563: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151532.563: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-151532.564: MControllerDelegate::enableSync invoked
                            20140904-151532.570: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151532.570: Informational: [livetype] syncStatus: OFF
                            20140904-151532.571: ACCController::updateWithState: 11
                            20140904-151532.573: Informational: AppHookControllerImpl::onSignIn in
                            20140904-151532.574: Informational: [livetype] onSignIn
                            20140904-151532.574: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140904-151532.575: Informational: AppHookControllerImpl::onSignIn out
                            20140904-151532.575: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140904-151532.576: ACCController::enableSync switch sync ON
                            20140904-151532.578: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151532.578: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140904-151532.579: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140904-151532.581: ACCController::updateWithState: 1
                            20140904-151532.581: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-151532.581: ACCController::updateLocalFolder:
                            20140904-151532.585: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140904-151532.585: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140904-151532.586: No folder owner for current cloud folder, so archive directly to [archived].
                            20140904-151532.586: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151532.587: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-151532.587: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-151532.588: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140904-151532.589: Informational: [livetype] syncStatus: OFF
                            20140904-151532.589: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140904-151532.590: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151532.594: There is no cloud folder at [], so now initalize it.
                            20140904-151532.594: MControllerDelegate::syncStatus state 1 (CoreSyncStateSignedIn)
                            20140904-151532.597: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140904-151532.598: ACCController::enableSync switch sync OFF
                            20140904-151532.599: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151532.600: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151532.600: ACCController::updateWithState: 11
                            20140904-151532.601: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151532.602: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151532.602: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140904-151532.603: 2014-09-04 15:15:32: File Monitoring was asked to stop on: : Sync turned off
                            20140904-151532.604: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151532.605: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151532.605: ACCController::updateWithState: 11
                            20140904-151532.606: ACCController::removeAllIcons
                            20140904-151532.606: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-151532.607: ACCController::enableSync completed switch sync OFF
                            20140904-151532.608: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151532.609: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151532.609: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-151532.610: 2014-09-04 15:15:32: File Monitoring was asked to stop on: : Update job
                            20140904-151532.610: WorkerThreads: 8
                            20140904-151532.611: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-151532.612: ACCController::enableSync completed switch sync ON
                            20140904-151536.266: MControllerDelegate::enableSync invoked
                            20140904-151536.266: ACCController::enableSync switch sync ON
                            20140904-151536.267: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151536.268: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140904-151536.268: ACCController::updateWithState: 1
                            20140904-151536.269: ACCController::updateLocalFolder:
                            20140904-151536.269: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140904-151536.269: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140904-151536.270: No folder owner for current cloud folder, so archive directly to [archived].
                            20140904-151536.272: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140904-151536.272: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140904-151536.272: There is no cloud folder at [], so now initalize it.
                            20140904-151536.273: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140904-151536.273: ACCController::enableSync switch sync OFF
                            20140904-151536.274: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151536.275: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151536.275: ACCController::updateWithState: 11
                            20140904-151536.276: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151536.276: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151536.277: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140904-151536.277: 2014-09-04 15:15:36: File Monitoring was asked to stop on: : Sync turned off
                            20140904-151536.278: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151536.279: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151536.279: ACCController::updateWithState: 11
                            20140904-151536.279: ACCController::removeAllIcons
                            20140904-151536.280: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-151536.281: ACCController::enableSync completed switch sync OFF
                            20140904-151536.282: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-151536.283: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-151536.283: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-151536.284: 2014-09-04 15:15:36: File Monitoring was asked to stop on: : Update job
                            20140904-151536.285: WorkerThreads: 8
                            20140904-151536.285: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-151536.285: ACCController::enableSync completed switch sync ON
                            20140904-151550.630: MControllerDelegate::shutdownRequest
                            20140904-151550.631: ACCController::shutdown
                            20140904-151550.631: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140904-151550.632: 2014-09-04 15:15:50: File Monitoring was asked to stop on: : shutdown
                            20140904-151550.632: Informational: AppHookControllerImpl::onShutdown in
                            20140904-151550.649: Informational: [livetype] onShutdown
                            20140904-151550.650: Informational: [livetype]  disableFontSync
                            20140904-151550.650: Informational: [livetype] deactivated all fonts
                            20140904-151550.651: Informational: AppHookControllerImpl::onShutdown out
                            20140904-151550.652: ACCController::removeAllIcons
                            20140904-151550.654: ACCController::shutdown completed
                            20140904-152121.654: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140904-152121.663: ACCController::Init
                            20140904-152121.671: ACCController::Init: init fileState cache
                            20140904-152121.674: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140904-152122.677: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140904-152122.729: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140904-152122.780: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140904-152122.781: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140904-152122.833: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140904-152122.834: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-152122.835: WorkerThreads: 8
                            20140904-152122.836: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-152122.836: ACCController::Init: add notification observers
                            20140904-152122.840: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-152122.841: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-152122.841: ACCController::updateWithState: 11
                            20140904-152122.841: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140904-152122.842: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140904-152122.848: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140904-152122.848: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140904-152122.852: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140904-152122.853: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140904-152122.857: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140904-152122.857: Informational: AppHookControllerImpl::onStartup in
                            20140904-152122.860: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140904-152122.860: Informational: [livetype] onStartup
                            20140904-152122.864: Informational: [livetype] onStartup => success
                            20140904-152122.864: Informational: AppHookControllerImpl::onStartup out
                            20140904-152122.886: ACCController::injectFinderExt
                            20140904-152122.887: ACCController::doInjectFinderExt: injectExt = 1
                            20140904-152122.887: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140904-152122.890: ACCController::finderInitSuccessfull: injectExt:YES
                            20140904-152352.627: ACCController::osSleepWake: NSConcreteNotification 0x608000252c00 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x600000001cf0>}
                            20140904-152352.628: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140904-152352.629: 2014-09-04 15:23:52: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140904-152352.630: 2014-09-04 15:23:52: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140904-152944.294: ACCController::osSleepWake: NSConcreteNotification 0x60000005c380 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x600000001cf0>}
                            20140904-153003.442: ACCController::doInjectFinderExt: injectExt = 1
                            20140904-153003.442: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140904-153003.442: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140904-153022.255: ACCController::osSleepWake: NSConcreteNotification 0x60000005c5f0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x600000001cf0>}
                            20140904-153022.255: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140904-153022.256: 2014-09-04 15:30:22: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140904-153022.257: 2014-09-04 15:30:22: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140904-172326.675: ACCController::osSleepWake: NSConcreteNotification 0x608000253680 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x600000001cf0>}
                            20140904-172546.481: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140904-172548.122: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140904-172548.122: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140904-172548.123: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140904-172548.123: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140904-172548.123: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140904-172548.124: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140904-172548.124: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140904-172548.124: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140904-172548.125: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140904-172548.125: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140904-172548.125: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140904-172548.126: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140904-172548.126: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140904-172548.126: MControllerDelegate::enableCollaboration: YES
                            20140904-172601.680: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140904-172601.681: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140904-172601.681: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140904-172601.681: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140904-172601.682: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140904-172601.682: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140904-172601.683: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140904-172601.683: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140904-172601.683: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140904-172601.684: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140904-172601.684: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140904-172601.685: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140904-172601.685: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140904-172601.685: MControllerDelegate::enableCollaboration: YES
                            20140904-172601.687: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140904-172601.688: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken fc403bea754d30c777ce2340d1469baf userId 6E68593446662ED1992016B8@AdobeID
                            20140904-172601.690: PrefernceManager::updatePrefernces
                            20140904-172601.691: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-172601.691: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-172601.695: 2014-09-04 17:26:01: File Monitoring was asked to stop on: : Update job
                            20140904-172601.695: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-172601.699: 2014-09-04 17:26:01: File Monitoring was asked to stop on: : Update job
                            20140904-172601.699: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-172601.699: MControllerDelegate::disableSync invoked
                            20140904-172601.701: WorkerThreads: 8
                            20140904-172601.706: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-172601.706: Informational: [livetype] syncStatus: OFF
                            20140904-172601.707: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-172601.713: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172601.715: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-172601.717: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-172601.718: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172601.719: ACCController::updateWithState: 11
                            20140904-172601.719: Informational: [livetype] syncStatus: OFF
                            20140904-172601.724: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172601.725: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140904-172601.725: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172601.726: Informational: AppHookControllerImpl::onSignIn in
                            20140904-172601.727: Informational: [livetype] onSignIn
                            20140904-172601.728: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140904-172601.728: Informational: AppHookControllerImpl::onSignIn out
                            20140904-172601.729: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140904-172601.729: ACCController::disableSync sync is already disabled
                            20140904-172601.731: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140904-172703.100: MControllerDelegate::enableSync invoked
                            20140904-172703.101: ACCController::enableSync switch sync ON
                            20140904-172703.102: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172703.103: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140904-172703.104: ACCController::updateWithState: 1
                            20140904-172703.104: ACCController::updateLocalFolder:
                            20140904-172703.104: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-172703.105: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140904-172703.108: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140904-172703.108: No folder owner for current cloud folder, so archive directly to [archived].
                            20140904-172703.109: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172703.110: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140904-172703.110: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140904-172703.111: There is no cloud folder at [], so now initalize it.
                            20140904-172703.111: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140904-172703.112: ACCController::enableSync switch sync OFF
                            20140904-172703.112: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172703.115: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140904-172703.116: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140904-172703.116: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172703.117: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172703.117: ACCController::updateWithState: 11
                            20140904-172703.118: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172703.119: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172703.119: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140904-172703.119: 2014-09-04 17:27:03: File Monitoring was asked to stop on: : Sync turned off
                            20140904-172703.120: 2014-09-04 17:27:03: File Monitoring was asked to stop on: : Sync turned off
                            20140904-172703.121: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172703.121: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172703.122: ACCController::updateWithState: 11
                            20140904-172703.122: ACCController::removeAllIcons
                            20140904-172703.123: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-172703.124: ACCController::enableSync completed switch sync OFF
                            20140904-172703.125: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172703.126: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172703.126: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-172703.126: 2014-09-04 17:27:03: File Monitoring was asked to stop on: : Update job
                            20140904-172703.127: 2014-09-04 17:27:03: File Monitoring was asked to stop on: : Update job
                            20140904-172703.127: WorkerThreads: 8
                            20140904-172703.127: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-172703.128: ACCController::enableSync completed switch sync ON
                            20140904-172815.946: MControllerDelegate::enableSync invoked
                            20140904-172815.946: ACCController::enableSync switch sync ON
                            20140904-172815.948: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172815.948: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140904-172815.949: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-172815.949: ACCController::updateWithState: 1
                            20140904-172815.953: ACCController::updateLocalFolder:
                            20140904-172815.953: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140904-172815.955: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140904-172815.956: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172815.957: No folder owner for current cloud folder, so archive directly to [archived].
                            20140904-172815.959: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140904-172815.959: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140904-172815.959: There is no cloud folder at [], so now initalize it.
                            20140904-172815.960: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140904-172815.960: ACCController::enableSync switch sync OFF
                            20140904-172815.961: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172815.961: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140904-172815.961: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140904-172815.963: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172815.963: ACCController::updateWithState: 11
                            20140904-172815.964: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172815.964: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172815.965: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140904-172815.965: 2014-09-04 17:28:15: File Monitoring was asked to stop on: : Sync turned off
                            20140904-172815.966: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172815.967: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172815.967: ACCController::updateWithState: 11
                            20140904-172815.967: ACCController::removeAllIcons
                            20140904-172815.968: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-172815.968: ACCController::enableSync completed switch sync OFF
                            20140904-172815.970: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172815.971: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172815.971: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-172815.971: 2014-09-04 17:28:15: File Monitoring was asked to stop on: : Update job
                            20140904-172815.972: 2014-09-04 17:28:15: File Monitoring was asked to stop on: : Update job
                            20140904-172815.972: WorkerThreads: 8
                            20140904-172815.972: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-172815.973: ACCController::enableSync completed switch sync ON
                            20140904-172917.610: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140904-172917.618: ACCController::Init
                            20140904-172917.627: ACCController::Init: init fileState cache
                            20140904-172917.631: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140904-172917.632: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140904-172917.683: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140904-172917.734: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140904-172917.735: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140904-172917.735: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140904-172917.789: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140904-172917.789: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-172917.790: WorkerThreads: 8
                            20140904-172917.791: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-172917.791: ACCController::Init: add notification observers
                            20140904-172917.794: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172917.795: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172917.796: ACCController::updateWithState: 11
                            20140904-172917.796: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140904-172917.797: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140904-172917.803: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140904-172917.803: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140904-172917.808: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140904-172917.808: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140904-172917.813: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140904-172917.813: Informational: AppHookControllerImpl::onStartup in
                            20140904-172917.816: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140904-172917.816: Informational: [livetype] onStartup
                            20140904-172917.819: Informational: [livetype] onStartup => success
                            20140904-172917.820: Informational: AppHookControllerImpl::onStartup out
                            20140904-172917.842: ACCController::injectFinderExt
                            20140904-172917.843: ACCController::doInjectFinderExt: injectExt = 1
                            20140904-172917.843: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140904-172917.846: ACCController::finderInitSuccessfull: injectExt:YES
                            20140904-172918.885: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140904-172918.886: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140904-172918.886: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140904-172918.886: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140904-172918.886: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140904-172918.887: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140904-172918.887: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140904-172918.887: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140904-172918.888: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140904-172918.888: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140904-172918.889: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140904-172918.889: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140904-172918.889: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140904-172918.889: MControllerDelegate::enableCollaboration: YES
                            20140904-172918.891: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140904-172918.891: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken fc403bea754d30c777ce2340d1469baf userId 6E68593446662ED1992016B8@AdobeID
                            20140904-172918.892: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-172918.893: 2014-09-04 17:29:18: File Monitoring was asked to stop on: : Update job
                            20140904-172918.893: WorkerThreads: 8
                            20140904-172918.894: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-172918.895: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172918.895: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172918.896: ACCController::updateWithState: 11
                            20140904-172918.896: Informational: AppHookControllerImpl::onSignIn in
                            20140904-172918.897: Informational: [livetype] onSignIn
                            20140904-172918.897: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140904-172918.898: Informational: AppHookControllerImpl::onSignIn out
                            20140904-172918.898: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140904-172918.899: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-172918.900: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-172918.900: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-172918.901: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140904-172918.901: Informational: [livetype] syncStatus: OFF
                            20140904-172918.905: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140904-172918.905: MControllerDelegate::enableSync invoked
                            20140904-172918.905: ACCController::enableSync switch sync ON
                            20140904-172918.907: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172918.907: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140904-172918.907: ACCController::updateWithState: 1
                            20140904-172918.908: ACCController::updateLocalFolder:
                            20140904-172918.908: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140904-172918.908: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140904-172918.909: No folder owner for current cloud folder, so archive directly to [archived].
                            20140904-172918.910: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140904-172918.911: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140904-172918.911: There is no cloud folder at [], so now initalize it.
                            20140904-172918.911: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140904-172918.912: ACCController::enableSync switch sync OFF
                            20140904-172918.913: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172918.914: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172918.914: ACCController::updateWithState: 11
                            20140904-172918.915: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172918.915: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172918.916: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140904-172918.916: 2014-09-04 17:29:18: File Monitoring was asked to stop on: : Sync turned off
                            20140904-172918.917: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-172918.918: 2014-09-04 17:29:18: File Monitoring was asked to stop on: : Sync turned off
                            20140904-172918.919: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-172918.921: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-172918.922: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-172918.922: Informational: [livetype] syncStatus: OFF
                            20140904-172918.922: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172918.923: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172918.928: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172918.928: ACCController::updateWithState: 11
                            20140904-172918.929: ACCController::removeAllIcons
                            20140904-172918.929: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-172918.930: ACCController::enableSync completed switch sync OFF
                            20140904-172918.933: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-172918.934: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140904-172918.934: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-172918.936: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-172918.937: 2014-09-04 17:29:18: File Monitoring was asked to stop on: : Update job
                            20140904-172918.937: WorkerThreads: 8
                            20140904-172918.938: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-172918.939: ACCController::enableSync completed switch sync ON
                            20140904-173000.653: MControllerDelegate::enableSync invoked
                            20140904-173000.654: ACCController::enableSync switch sync ON
                            20140904-173000.656: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-173000.657: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140904-173000.657: ACCController::updateWithState: 1
                            20140904-173000.658: ACCController::updateLocalFolder:
                            20140904-173000.658: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-173000.658: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140904-173000.663: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140904-173000.663: No folder owner for current cloud folder, so archive directly to [archived].
                            20140904-173000.664: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-173000.665: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140904-173000.665: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140904-173000.665: There is no cloud folder at [], so now initalize it.
                            20140904-173000.666: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140904-173000.666: ACCController::enableSync switch sync OFF
                            20140904-173000.668: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-173000.670: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140904-173000.671: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140904-173000.671: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-173000.672: ACCController::updateWithState: 11
                            20140904-173000.673: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-173000.674: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-173000.674: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140904-173000.675: 2014-09-04 17:30:00: File Monitoring was asked to stop on: : Sync turned off
                            20140904-173000.676: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-173000.677: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-173000.678: ACCController::updateWithState: 11
                            20140904-173000.678: ACCController::removeAllIcons
                            20140904-173000.679: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140904-173000.679: ACCController::enableSync completed switch sync OFF
                            20140904-173000.681: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-173000.682: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-173000.682: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-173000.682: 2014-09-04 17:30:00: File Monitoring was asked to stop on: : Update job
                            20140904-173000.683: 2014-09-04 17:30:00: File Monitoring was asked to stop on: : Update job
                            20140904-173000.683: WorkerThreads: 8
                            20140904-173000.683: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-173000.684: ACCController::enableSync completed switch sync ON
                            20140904-173015.064: ACCController::osSleepWake: NSConcreteNotification 0x7f872bb01030 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7f8729642bb0>}
                            20140904-173015.065: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140904-173015.066: 2014-09-04 17:30:15: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140904-175802.549: Warning: [GUDE]: Request Failed. ErrorCode: 100051 message: Platform Status. (NSPOSIXErrorDomain 51) Network is unreachable. Network is unreachable.
                            20140904-175802.698: ACCController::osSleepWake: NSConcreteNotification 0x7f872bb01030 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f8729642bb0>}
                            20140904-181151.980: ACCController::shutdown
                            20140904-181151.980: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140904-181151.981: 2014-09-04 18:11:51: File Monitoring was asked to stop on: : shutdown
                            20140904-181151.981: Informational: AppHookControllerImpl::onShutdown in
                            20140904-181152.012: MControllerDelegate::shutdownRequest
                            20140904-181152.073: Informational: [livetype] onShutdown
                            20140904-181152.074: Informational: [livetype]  disableFontSync
                            20140904-181152.074: Informational: [livetype] deactivated all fonts
                            20140904-181152.075: Informational: AppHookControllerImpl::onShutdown out
                            20140904-181152.076: ACCController::removeAllIcons
                            20140904-181152.076: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140904-181251.420: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140904-181251.440: ACCController::Init
                            20140904-181251.448: ACCController::Init: init fileState cache
                            20140904-181251.456: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140904-181251.460: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140904-181251.512: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140904-181251.512: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140904-181251.512: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140904-181251.565: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140904-181251.566: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-181251.567: WorkerThreads: 8
                            20140904-181251.567: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-181251.568: ACCController::Init: add notification observers
                            20140904-181251.575: CJournalDB::Init: schema differs: incorrect number of tables
                            20140904-181251.577: CJournalDB::_create: successfully created 5 tables
                            20140904-181251.579: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-181251.580: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-181251.581: ACCController::updateWithState: 11
                            20140904-181251.581: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140904-181251.582: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140904-181251.603: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140904-181251.604: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140904-181251.620: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140904-181251.620: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140904-181251.632: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140904-181251.633: Informational: AppHookControllerImpl::onStartup in
                            20140904-181251.637: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140904-181251.638: Informational: [livetype] onStartup
                            20140904-181251.641: Informational: [livetype] onStartup => success
                            20140904-181251.641: Informational: AppHookControllerImpl::onStartup out
                            20140904-181251.683: ACCController::injectFinderExt
                            20140904-181251.684: ACCController::doInjectFinderExt: injectExt = 1
                            20140904-181251.685: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140904-181251.698: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140904-181251.756: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140904-181251.778: ACCController::finderInitSuccessfull: injectExt:YES
                            20140904-181251.780: ACCController::finderInitSuccessfull: injectExt:YES
                            20140904-181251.780: ACCFinderExtensionController::init: intialization succsessfull
                            20140904-181252.701: MControllerDelegate::invalidateAccessToken
                            20140904-181252.701: ACCController::invalidateAccessToken
                            20140904-181252.701: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140904-181252.702: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140904-181252.702: Informational: [livetype] onInvalidateAccessToken
                            20140904-181252.703: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140904-181252.703: ACCController::invalidateAccessToken completed
                            20140904-181252.709: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-181252.711: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-181252.711: Informational: [livetype] syncStatus: OFF
                            20140904-181302.333: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140904-181302.334: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140904-181302.334: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140904-181302.334: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140904-181302.334: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140904-181302.335: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140904-181302.335: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140904-181302.335: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140904-181302.335: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140904-181302.335: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140904-181302.336: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140904-181302.336: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140904-181302.336: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140904-181302.336: MControllerDelegate::enableCollaboration: YES
                            20140904-181303.324: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140904-181303.325: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140904-181303.325: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140904-181303.325: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140904-181303.325: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140904-181303.326: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140904-181303.326: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140904-181303.326: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140904-181303.327: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140904-181303.327: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140904-181303.327: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140904-181303.327: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140904-181303.327: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140904-181303.328: MControllerDelegate::enableCollaboration: YES
                            20140904-181303.329: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140904-181303.329: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken fb37f09ac59d83498a31e2ae14285ef6 userId 6E68593446662ED1992016B8@AdobeID
                            20140904-181303.330: MControllerDelegate::disableSync invoked
                            20140904-181303.332: ACCSync::stopJob: forced: 1, reason: Update job
                            20140904-181303.332: 2014-09-04 18:13:03: File Monitoring was asked to stop on: : Update job
                            20140904-181303.333: WorkerThreads: 8
                            20140904-181303.333: Notice: setTargetDataRates: 0 upload, 0 download
                            20140904-181303.334: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140904-181303.334: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140904-181303.335: ACCController::updateWithState: 11
                            20140904-181303.335: Informational: AppHookControllerImpl::onSignIn in
                            20140904-181303.336: Informational: [livetype] onSignIn
                            20140904-181303.336: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140904-181303.337: Informational: AppHookControllerImpl::onSignIn out
                            20140904-181303.337: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140904-181303.337: ACCController::disableSync sync is already disabled
                            20140904-181303.338: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140904-181303.339: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140904-181303.339: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140904-181303.339: Informational: [livetype] syncStatus: OFF
                            20140904-181303.341: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140904-181712.557: ACCController::osSleepWake: NSConcreteNotification 0x7f9004300360 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7f9001e16910>}
                            20140904-181712.558: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140904-181712.558: 2014-09-04 18:17:12: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140904-181712.559: 2014-09-04 18:17:12: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140904-181807.701: ACCController::osSleepWake: NSConcreteNotification 0x7f9004003080 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f9001e16910>}
                            20140904-181807.705: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140904-181823.422: ACCController::shutdown
                            20140904-181823.423: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140904-181823.423: 2014-09-04 18:18:23: File Monitoring was asked to stop on: : shutdown
                            20140904-181823.424: Informational: AppHookControllerImpl::onShutdown in
                            20140904-181823.477: MControllerDelegate::shutdownRequest
                            20140904-181823.511: Informational: [livetype] onShutdown
                            20140904-181823.512: Informational: [livetype]  disableFontSync
                            20140904-181823.512: Informational: [livetype] deactivated all fonts
                            20140904-181823.513: Informational: AppHookControllerImpl::onShutdown out
                            20140904-181823.513: ACCController::removeAllIcons
                            20140904-181823.514: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140906-230552.319: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140906-230552.339: ACCController::Init
                            20140906-230552.347: ACCController::Init: init fileState cache
                            20140906-230552.383: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140906-230552.387: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140906-230552.438: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140906-230552.439: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140906-230552.439: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140906-230552.492: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140906-230552.493: Notice: setTargetDataRates: 0 upload, 0 download
                            20140906-230552.495: WorkerThreads: 8
                            20140906-230552.495: Notice: setTargetDataRates: 0 upload, 0 download
                            20140906-230552.498: ACCController::Init: add notification observers
                            20140906-230552.506: CJournalDB::Init: schema differs: incorrect number of tables
                            20140906-230552.508: CJournalDB::_create: successfully created 5 tables
                            20140906-230552.511: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140906-230552.513: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140906-230552.513: ACCController::updateWithState: 11
                            20140906-230552.513: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140906-230552.514: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140906-230552.540: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140906-230552.541: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140906-230552.561: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140906-230552.561: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140906-230552.576: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140906-230552.576: Informational: AppHookControllerImpl::onStartup in
                            20140906-230552.580: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140906-230552.581: Informational: [livetype] onStartup
                            20140906-230552.583: Informational: [livetype] onStartup => success
                            20140906-230552.583: Informational: AppHookControllerImpl::onStartup out
                            20140906-230552.628: ACCController::injectFinderExt
                            20140906-230552.630: ACCController::doInjectFinderExt: injectExt = 1
                            20140906-230552.630: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140906-230552.671: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140906-230552.762: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140906-230552.788: ACCController::finderInitSuccessfull: injectExt:YES
                            20140906-230552.789: ACCController::finderInitSuccessfull: injectExt:YES
                            20140906-230552.790: ACCFinderExtensionController::init: intialization succsessfull
                            20140906-230553.653: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140906-230553.654: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140906-230553.655: Informational: [livetype] syncStatus: OFF
                            20140906-230606.401: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140906-230606.402: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140906-230606.402: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140906-230606.402: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140906-230606.403: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140906-230606.403: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140906-230606.403: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140906-230606.404: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140906-230606.404: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140906-230606.404: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140906-230606.405: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140906-230606.405: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140906-230606.406: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140906-230606.406: MControllerDelegate::enableCollaboration: YES
                            20140906-230609.501: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140906-230609.502: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140906-230609.502: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140906-230609.502: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140906-230609.502: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140906-230609.503: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140906-230609.503: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140906-230609.504: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140906-230609.504: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140906-230609.504: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140906-230609.505: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140906-230609.505: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140906-230609.505: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140906-230609.505: MControllerDelegate::enableCollaboration: YES
                            20140906-230609.507: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140906-230609.507: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 2b0ee7cd4e89df7f8f64ea625fadf05d userId 6E68593446662ED1992016B8@AdobeID
                            20140906-230609.508: MControllerDelegate::disableSync invoked
                            20140906-230609.509: ACCSync::stopJob: forced: 1, reason: Update job
                            20140906-230609.510: 2014-09-06 23:06:09: File Monitoring was asked to stop on: : Update job
                            20140906-230609.511: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140906-230609.513: WorkerThreads: 8
                            20140906-230609.513: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140906-230609.517: Notice: setTargetDataRates: 0 upload, 0 download
                            20140906-230609.517: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140906-230609.519: Informational: [livetype] syncStatus: OFF
                            20140906-230609.520: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140906-230609.520: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140906-230609.521: ACCController::updateWithState: 11
                            20140906-230609.521: Informational: AppHookControllerImpl::onSignIn in
                            20140906-230609.522: Informational: [livetype] onSignIn
                            20140906-230609.522: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140906-230609.523: Informational: AppHookControllerImpl::onSignIn out
                            20140906-230609.524: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140906-230609.524: ACCController::disableSync sync is already disabled
                            20140906-230609.526: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140906-230638.635: ACCController::doInjectFinderExt: injectExt = 1
                            20140906-230638.636: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140906-230638.636: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140906-230813.836: ACCController::osSleepWake: NSConcreteNotification 0x7f966d2027f0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140906-230813.837: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140906-230813.837: 2014-09-06 23:08:13: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140906-230813.838: 2014-09-06 23:08:13: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140906-230839.466: ACCController::osSleepWake: NSConcreteNotification 0x7f966d201bd0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140906-230851.032: ACCController::doInjectFinderExt: injectExt = 1
                            20140906-230851.032: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140906-230851.033: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140906-231650.200: ACCController::osSleepWake: NSConcreteNotification 0x7f966be35d70 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140906-231650.201: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140906-231650.202: 2014-09-06 23:16:50: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140906-234705.726: Warning: [GUDE]: Request Failed. ErrorCode: 100051 message: Platform Status. (NSPOSIXErrorDomain 51) Network is unreachable. Network is unreachable.
                            20140907-000400.194: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-010400.135: Warning: [GUDE]: Request Failed. ErrorCode: 100050 message: Platform Status. (NSPOSIXErrorDomain 50) Network is down. Network is down.
                            20140907-010431.179: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-010502.171: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-010533.138: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-010604.109: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-010635.111: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-020400.120: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-020431.190: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-030400.133: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-030431.117: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-040400.192: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-040431.169: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-040502.190: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-040533.193: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-040604.202: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-050400.141: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-050431.117: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-050502.142: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-050533.158: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-050604.181: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-060400.122: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-060431.113: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-060502.143: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-060533.180: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-060604.185: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-070400.140: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-070431.123: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-070533.152: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-070604.183: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-080400.171: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-080431.138: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-080502.150: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-080533.156: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-080604.173: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-081132.151: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-081200.622: ACCController::osSleepWake: NSConcreteNotification 0x7f966be189b0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140907-081203.131: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-081234.160: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-081305.192: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-081820.433: ACCController::osSleepWake: NSConcreteNotification 0x7f966d12de90 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140907-081820.434: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140907-081820.434: 2014-09-07 08:18:20: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140907-081820.435: 2014-09-07 08:18:20: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140907-092842.622: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-092913.282: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-095659.489: ACCController::osSleepWake: NSConcreteNotification 0x7f966d113630 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140907-095727.207: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-095920.077: ACCController::doInjectFinderExt: injectExt = 1
                            20140907-095920.077: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140907-095920.077: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140907-100022.411: ACCController::osSleepWake: NSConcreteNotification 0x7f966d061ea0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140907-100022.412: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140907-100022.441: 2014-09-07 10:00:22: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140907-111048.696: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-202742.147: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-202745.173: ACCController::osSleepWake: NSConcreteNotification 0x7f966bdb4060 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140907-202813.151: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-203027.880: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-203123.967: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-204213.764: ACCController::osSleepWake: NSConcreteNotification 0x7f966bf06610 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140907-204213.765: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140907-204213.799: 2014-09-07 20:42:13: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140907-211228.682: Warning: [GUDE]: Request Failed. ErrorCode: 100051 message: Platform Status. (NSPOSIXErrorDomain 51) Network is unreachable. Network is unreachable.
                            20140907-211415.202: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-212744.147: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-212931.155: Warning: [GUDE]: Request Failed. ErrorCode: 100049 message: Platform Status. (NSPOSIXErrorDomain 49) Can't assign requested address. Can't assign requested address.
                            20140907-223016.170: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-232816.195: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140907-232816.690: MControllerDelegate::invalidateAccessToken
                            20140907-232816.691: ACCController::invalidateAccessToken
                            20140907-232816.691: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140907-232816.694: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140907-232816.695: Informational: [livetype] onInvalidateAccessToken
                            20140907-232816.695: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140907-232816.696: ACCController::invalidateAccessToken completed
                            20140907-232822.085: MControllerDelegate::updateAccessToken
                            20140907-232822.086: ACCController::updateAccessToken accessToken 32a7ef1dab8aed71ba85528f5385553b
                            20140907-232822.086: Informational: AppHookControllerImpl::onUpdateAccessToken in
                            20140907-232822.087: Informational: [livetype] onUpdateAccessToken
                            20140907-232822.087: Informational: AppHookControllerImpl::onUpdateAccessToken out
                            20140907-232822.087: ACCController::updateAccessToken completed
                            20140907-232826.746: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140907-232826.746: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140907-232826.746: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140907-232826.747: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140907-232826.747: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140907-232826.747: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140907-232826.747: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140907-232826.748: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140907-232826.748: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140907-232826.748: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140907-232826.748: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140907-232826.749: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140907-232826.749: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140907-232826.750: MControllerDelegate::enableCollaboration: YES
                            20140907-233004.180: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-002800.686: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-012800.168: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-022800.120: Warning: [GUDE]: Request Failed. ErrorCode: 100050 message: Platform Status. (NSPOSIXErrorDomain 50) Network is down. Network is down.
                            20140908-032801.194: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-042800.119: Warning: [GUDE]: Request Failed. ErrorCode: 100050 message: Platform Status. (NSPOSIXErrorDomain 50) Network is down. Network is down.
                            20140908-052800.183: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-062800.121: Warning: [GUDE]: Request Failed. ErrorCode: 100050 message: Platform Status. (NSPOSIXErrorDomain 50) Network is down. Network is down.
                            20140908-072800.157: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-082800.144: Warning: [GUDE]: Request Failed. ErrorCode: 100050 message: Platform Status. (NSPOSIXErrorDomain 50) Network is down. Network is down.
                            20140908-082830.525: ACCController::osSleepWake: NSConcreteNotification 0x7f966d202480 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140908-083159.653: ACCController::osSleepWake: NSConcreteNotification 0x7f966be1a750 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140908-083159.653: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140908-083159.654: 2014-09-08 08:31:59: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140908-091027.152: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-091027.694: ACCController::osSleepWake: NSConcreteNotification 0x7f966bc71de0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140908-091042.109: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-091042.110: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140908-091042.110: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140908-091155.139: ACCController::shutdown
                            20140908-091155.140: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140908-091155.140: 2014-09-08 09:11:55: File Monitoring was asked to stop on: : shutdown
                            20140908-091155.141: 2014-09-08 09:11:55: File Monitoring was asked to stop on: : shutdown
                            20140908-091155.141: Informational: AppHookControllerImpl::onShutdown in
                            20140908-091155.546: MControllerDelegate::shutdownRequest
                            20140908-091155.611: Informational: [livetype] onShutdown
                            20140908-091155.611: Informational: [livetype]  disableFontSync
                            20140908-091155.612: Informational: [livetype] deactivated all fonts
                            20140908-091155.617: Informational: AppHookControllerImpl::onShutdown out
                            20140908-091155.620: ACCController::removeAllIcons
                            20140908-091155.621: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140908-163730.615: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140908-163730.694: ACCController::Init
                            20140908-163730.705: ACCController::Init: init fileState cache
                            20140908-163730.789: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140908-163730.792: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140908-163730.794: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140908-163730.794: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140908-163730.797: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-163730.798: WorkerThreads: 8
                            20140908-163730.798: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-163730.824: ACCController::Init: add notification observers
                            20140908-163730.827: CJournalDB::Init: schema differs: incorrect number of tables
                            20140908-163730.828: CJournalDB::_create: successfully created 5 tables
                            20140908-163730.877: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-163730.878: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-163730.879: ACCController::updateWithState: 11
                            20140908-163730.879: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140908-163730.880: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140908-163730.889: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140908-163730.890: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140908-163730.897: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140908-163730.898: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140908-163730.905: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140908-163730.906: Informational: AppHookControllerImpl::onStartup in
                            20140908-163730.938: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140908-163730.938: Informational: [livetype] onStartup
                            20140908-163730.941: Informational: [livetype] onStartup => success
                            20140908-163730.941: Informational: AppHookControllerImpl::onStartup out
                            20140908-163730.977: ACCController::injectFinderExt
                            20140908-163730.980: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-163730.980: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140908-163731.041: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140908-163731.128: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140908-163731.152: ACCController::finderInitSuccessfull: injectExt:YES
                            20140908-163731.156: ACCController::finderInitSuccessfull: injectExt:YES
                            20140908-163731.157: ACCFinderExtensionController::init: intialization succsessfull
                            20140908-163731.992: MControllerDelegate::invalidateAccessToken
                            20140908-163731.993: ACCController::invalidateAccessToken
                            20140908-163731.993: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140908-163731.994: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140908-163731.994: Informational: [livetype] onInvalidateAccessToken
                            20140908-163731.995: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140908-163731.995: ACCController::invalidateAccessToken completed
                            20140908-163738.289: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-163738.290: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-163738.290: Informational: [livetype] syncStatus: OFF
                            20140908-163835.236: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140908-163835.236: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140908-163835.237: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140908-163835.237: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140908-163835.237: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140908-163835.238: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140908-163835.238: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140908-163835.238: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140908-163835.238: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140908-163835.239: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.market.designLibrary state=false
                            20140908-163835.239: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140908-163835.239: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140908-163835.240: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140908-163835.240: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140908-163835.240: MControllerDelegate::enableCollaboration: YES
                            20140908-163836.495: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140908-163836.495: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140908-163836.495: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140908-163836.496: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140908-163836.496: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140908-163836.496: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140908-163836.496: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140908-163836.497: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140908-163836.497: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140908-163836.497: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.market.designLibrary state=false
                            20140908-163836.497: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140908-163836.497: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140908-163836.498: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140908-163836.498: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140908-163836.498: MControllerDelegate::enableCollaboration: YES
                            20140908-163836.499: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140908-163836.500: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 5d0f995385a8c74f6e57082578cbaa06 userId 6E68593446662ED1992016B8@AdobeID
                            20140908-163836.501: MControllerDelegate::disableSync invoked
                            20140908-163836.503: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-163836.503: 2014-09-08 16:38:36: File Monitoring was asked to stop on: : Update job
                            20140908-163836.504: 2014-09-08 16:38:36: File Monitoring was asked to stop on: : Update job
                            20140908-163836.504: WorkerThreads: 8
                            20140908-163836.504: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-163836.505: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-163836.506: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-163836.506: ACCController::updateWithState: 11
                            20140908-163836.507: Informational: AppHookControllerImpl::onSignIn in
                            20140908-163836.507: Informational: [livetype] onSignIn
                            20140908-163836.508: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140908-163836.509: Informational: AppHookControllerImpl::onSignIn out
                            20140908-163836.509: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-163836.510: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140908-163836.512: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-163836.513: ACCController::disableSync sync is already disabled
                            20140908-163836.514: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-163836.514: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-163836.518: Informational: [livetype] syncStatus: OFF
                            20140908-163836.518: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-163925.972: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-163925.973: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140908-163925.973: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140908-164132.702: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-164132.703: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140908-164132.703: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140908-193904.293: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-193904.294: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140908-193904.294: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140908-194852.531: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-194852.532: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140908-194852.532: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140908-195419.232: MControllerDelegate::enableSync invoked
                            20140908-195419.233: ACCController::enableSync switch sync ON
                            20140908-195419.235: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.235: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195419.236: ACCController::updateWithState: 1
                            20140908-195419.237: ACCController::updateLocalFolder:
                            20140908-195419.237: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195419.241: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140908-195419.241: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195419.242: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195419.242: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.244: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195419.244: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195419.245: There is no cloud folder at [], so now initalize it.
                            20140908-195419.246: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195419.246: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.246: ACCController::enableSync switch sync OFF
                            20140908-195419.250: MControllerDelegate::syncStatus state 1 (CoreSyncStateSignedIn)
                            20140908-195419.251: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.252: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195419.252: ACCController::updateWithState: 11
                            20140908-195419.254: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.254: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195419.255: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195419.255: 2014-09-08 19:54:19: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195419.256: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.257: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195419.257: ACCController::updateWithState: 11
                            20140908-195419.257: ACCController::removeAllIcons
                            20140908-195419.258: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195419.259: ACCController::enableSync completed switch sync OFF
                            20140908-195419.260: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.261: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195419.261: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195419.261: 2014-09-08 19:54:19: File Monitoring was asked to stop on: : Update job
                            20140908-195419.262: 2014-09-08 19:54:19: File Monitoring was asked to stop on: : Update job
                            20140908-195419.262: WorkerThreads: 8
                            20140908-195419.262: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195419.263: ACCController::enableSync completed switch sync ON
                            20140908-195513.521: MControllerDelegate::enableSync invoked
                            20140908-195513.521: ACCController::enableSync switch sync ON
                            20140908-195513.523: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.524: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195513.525: ACCController::updateWithState: 1
                            20140908-195513.525: ACCController::updateLocalFolder:
                            20140908-195513.525: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195513.525: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140908-195513.531: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195513.531: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195513.532: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.534: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195513.534: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195513.535: There is no cloud folder at [], so now initalize it.
                            20140908-195513.535: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195513.535: ACCController::enableSync switch sync OFF
                            20140908-195513.536: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.537: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-195513.539: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-195513.540: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195513.540: ACCController::updateWithState: 11
                            20140908-195513.541: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.542: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195513.542: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195513.542: 2014-09-08 19:55:13: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195513.543: 2014-09-08 19:55:13: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195513.544: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.545: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195513.545: ACCController::updateWithState: 11
                            20140908-195513.545: ACCController::removeAllIcons
                            20140908-195513.546: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195513.547: ACCController::enableSync completed switch sync OFF
                            20140908-195513.548: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.548: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195513.549: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195513.549: 2014-09-08 19:55:13: File Monitoring was asked to stop on: : Update job
                            20140908-195513.550: WorkerThreads: 8
                            20140908-195513.550: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195513.550: ACCController::enableSync completed switch sync ON
                            20140908-195529.543: MControllerDelegate::updateFilePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop', uploadSetting:0, downloadSetting:0}
                            20140908-195529.545: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195529.546: MControllerDelegate::shutdownRequest
                            20140908-195529.547: ACCController::shutdown
                            20140908-195529.547: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140908-195529.547: 2014-09-08 19:55:29: File Monitoring was asked to stop on: : shutdown
                            20140908-195529.548: 2014-09-08 19:55:29: File Monitoring was asked to stop on: : shutdown
                            20140908-195529.548: Informational: AppHookControllerImpl::onShutdown in
                            20140908-195529.607: Informational: [livetype] onShutdown
                            20140908-195529.607: Informational: [livetype]  disableFontSync
                            20140908-195529.608: Informational: [livetype] deactivated all fonts
                            20140908-195529.608: Informational: AppHookControllerImpl::onShutdown out
                            20140908-195529.609: ACCController::removeAllIcons
                            20140908-195529.612: ACCController::shutdown completed
                            20140908-195547.684: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140908-195547.694: ACCController::Init
                            20140908-195547.701: ACCController::Init: init fileState cache
                            20140908-195547.703: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140908-195547.704: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-195547.756: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-195547.808: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140908-195547.809: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140908-195547.809: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140908-195547.862: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140908-195547.863: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195547.864: WorkerThreads: 8
                            20140908-195547.864: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195547.865: ACCController::Init: add notification observers
                            20140908-195547.868: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195547.869: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195547.870: ACCController::updateWithState: 11
                            20140908-195547.870: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140908-195547.870: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140908-195547.876: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140908-195547.876: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140908-195547.880: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140908-195547.880: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140908-195547.885: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140908-195547.885: Informational: AppHookControllerImpl::onStartup in
                            20140908-195547.888: Informational: [livetype] onStartup
                            20140908-195547.888: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140908-195547.892: Informational: [livetype] onStartup => success
                            20140908-195547.893: Informational: AppHookControllerImpl::onStartup out
                            20140908-195547.913: ACCController::injectFinderExt
                            20140908-195547.915: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-195547.915: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140908-195547.918: ACCController::finderInitSuccessfull: injectExt:YES
                            20140908-195548.978: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140908-195548.978: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140908-195548.978: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140908-195548.979: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140908-195548.979: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140908-195548.980: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140908-195548.980: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140908-195548.981: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140908-195548.982: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140908-195548.982: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.market.designLibrary state=false
                            20140908-195548.983: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140908-195548.983: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140908-195548.984: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140908-195548.984: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140908-195548.985: MControllerDelegate::enableCollaboration: YES
                            20140908-195548.987: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140908-195548.988: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 5d0f995385a8c74f6e57082578cbaa06 userId 6E68593446662ED1992016B8@AdobeID
                            20140908-195548.989: PrefernceManager::updatePrefernces
                            20140908-195548.990: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195548.990: 2014-09-08 19:55:48: File Monitoring was asked to stop on: : Update job
                            20140908-195548.991: 2014-09-08 19:55:48: File Monitoring was asked to stop on: : Update job
                            20140908-195548.991: WorkerThreads: 8
                            20140908-195548.991: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195548.992: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195548.993: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195548.993: ACCController::updateWithState: 11
                            20140908-195548.995: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195548.995: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-195548.996: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195548.996: Informational: AppHookControllerImpl::onSignIn in
                            20140908-195548.997: Informational: [livetype] onSignIn
                            20140908-195548.998: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140908-195548.998: Informational: AppHookControllerImpl::onSignIn out
                            20140908-195548.998: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140908-195549.000: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-195549.001: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-195549.387: MControllerDelegate::disableSync invoked
                            20140908-195549.387: ACCController::disableSync sync is already disabled
                            20140908-195549.427: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-195549.428: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-195549.428: Informational: [livetype] syncStatus: OFF
                            20140908-195549.430: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-195549.431: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-195549.431: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-195549.432: Informational: [livetype] syncStatus: OFF
                            20140908-195600.609: MControllerDelegate::enableSync invoked
                            20140908-195600.610: ACCController::enableSync switch sync ON
                            20140908-195600.612: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.613: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195600.613: ACCController::updateWithState: 1
                            20140908-195600.613: ACCController::updateLocalFolder:
                            20140908-195600.614: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-195600.614: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195600.615: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195600.615: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195600.620: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.620: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195600.622: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195600.622: There is no cloud folder at [], so now initalize it.
                            20140908-195600.623: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195600.623: ACCController::enableSync switch sync OFF
                            20140908-195600.625: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.626: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195600.626: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-195600.630: ACCController::updateWithState: 11
                            20140908-195600.631: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.632: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195600.632: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195600.633: 2014-09-08 19:56:00: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195600.634: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.635: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195600.635: ACCController::updateWithState: 11
                            20140908-195600.635: ACCController::removeAllIcons
                            20140908-195600.636: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195600.637: ACCController::enableSync completed switch sync OFF
                            20140908-195600.638: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.639: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195600.639: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195600.640: 2014-09-08 19:56:00: File Monitoring was asked to stop on: : Update job
                            20140908-195600.640: WorkerThreads: 8
                            20140908-195600.641: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195600.641: ACCController::enableSync completed switch sync ON
                            20140908-195625.994: MControllerDelegate::enableSync invoked
                            20140908-195625.994: ACCController::enableSync switch sync ON
                            20140908-195625.997: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195625.998: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195625.998: ACCController::updateWithState: 1
                            20140908-195625.999: ACCController::updateLocalFolder:
                            20140908-195625.999: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-195625.999: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195626.003: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195626.004: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195626.004: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195626.006: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195626.006: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195626.007: There is no cloud folder at [], so now initalize it.
                            20140908-195626.007: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195626.007: ACCController::enableSync switch sync OFF
                            20140908-195626.012: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195626.015: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-195626.016: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195626.016: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-195626.019: ACCController::updateWithState: 11
                            20140908-195626.020: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195626.021: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195626.021: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195626.021: 2014-09-08 19:56:26: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195626.022: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195626.023: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195626.023: ACCController::updateWithState: 11
                            20140908-195626.024: ACCController::removeAllIcons
                            20140908-195626.024: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195626.025: ACCController::enableSync completed switch sync OFF
                            20140908-195626.026: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195626.027: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195626.028: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195626.028: 2014-09-08 19:56:26: File Monitoring was asked to stop on: : Update job
                            20140908-195626.028: WorkerThreads: 8
                            20140908-195626.028: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195626.029: ACCController::enableSync completed switch sync ON
                            20140908-195637.511: MControllerDelegate::enableSync invoked
                            20140908-195637.512: ACCController::enableSync switch sync ON
                            20140908-195637.514: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.514: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195637.515: ACCController::updateWithState: 1
                            20140908-195637.515: ACCController::updateLocalFolder:
                            20140908-195637.516: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-195637.516: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195637.517: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195637.517: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195637.519: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.519: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195637.520: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195637.520: There is no cloud folder at [], so now initalize it.
                            20140908-195637.521: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195637.521: ACCController::enableSync switch sync OFF
                            20140908-195637.522: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.523: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.523: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195637.524: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-195637.526: ACCController::updateWithState: 11
                            20140908-195637.528: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.528: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195637.529: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195637.529: 2014-09-08 19:56:37: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195637.531: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.531: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195637.532: ACCController::updateWithState: 11
                            20140908-195637.532: ACCController::removeAllIcons
                            20140908-195637.532: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195637.533: ACCController::enableSync completed switch sync OFF
                            20140908-195637.535: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.536: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195637.536: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195637.536: 2014-09-08 19:56:37: File Monitoring was asked to stop on: : Update job
                            20140908-195637.537: 2014-09-08 19:56:37: File Monitoring was asked to stop on: : Update job
                            20140908-195637.537: WorkerThreads: 8
                            20140908-195637.537: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195637.538: ACCController::enableSync completed switch sync ON
                            20140908-195721.634: MControllerDelegate::enableSync invoked
                            20140908-195721.634: ACCController::enableSync switch sync ON
                            20140908-195721.636: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195721.636: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195721.637: ACCController::updateWithState: 1
                            20140908-195721.637: ACCController::updateLocalFolder:
                            20140908-195721.637: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-195721.638: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195721.638: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195721.640: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195721.640: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195721.640: There is no cloud folder at [], so now initalize it.
                            20140908-195721.641: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195721.641: ACCController::enableSync switch sync OFF
                            20140908-195721.642: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195721.643: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195721.643: ACCController::updateWithState: 11
                            20140908-195721.644: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195721.645: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195721.645: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195721.645: 2014-09-08 19:57:21: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195721.646: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195721.647: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195721.647: ACCController::updateWithState: 11
                            20140908-195721.648: ACCController::removeAllIcons
                            20140908-195721.648: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195721.649: ACCController::enableSync completed switch sync OFF
                            20140908-195721.650: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195721.651: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195721.651: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195721.651: 2014-09-08 19:57:21: File Monitoring was asked to stop on: : Update job
                            20140908-195721.652: 2014-09-08 19:57:21: File Monitoring was asked to stop on: : Update job
                            20140908-195721.652: WorkerThreads: 8
                            20140908-195721.652: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195721.653: ACCController::enableSync completed switch sync ON
                            20140908-195735.978: MControllerDelegate::enableSync invoked
                            20140908-195735.978: ACCController::enableSync switch sync ON
                            20140908-195735.980: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195735.980: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195735.981: ACCController::updateWithState: 1
                            20140908-195735.981: ACCController::updateLocalFolder:
                            20140908-195735.981: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-195735.982: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195735.983: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195735.985: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195735.985: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195735.985: There is no cloud folder at [], so now initalize it.
                            20140908-195735.986: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195735.986: ACCController::enableSync switch sync OFF
                            20140908-195735.987: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195735.988: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195735.988: ACCController::updateWithState: 11
                            20140908-195735.990: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195735.990: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195735.991: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195735.991: 2014-09-08 19:57:35: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195735.992: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195735.993: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195735.993: ACCController::updateWithState: 11
                            20140908-195735.994: ACCController::removeAllIcons
                            20140908-195735.994: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195735.995: ACCController::enableSync completed switch sync OFF
                            20140908-195735.996: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195735.997: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195735.997: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195735.997: 2014-09-08 19:57:35: File Monitoring was asked to stop on: : Update job
                            20140908-195735.997: WorkerThreads: 8
                            20140908-195735.998: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195735.998: ACCController::enableSync completed switch sync ON
                            20140908-195737.069: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195737.072: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195737.076: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195737.077: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-195755.759: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-195755.760: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140908-195755.760: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140908-200200.688: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-200200.689: ACCController::doInjectFinderExt: appIdentifier: com.apple.systempreferences
                            20140908-200200.689: ACCController::doInjectFinderExt: app identifier: com.apple.systempreferences not equal to com.apple.finder
                            20140908-200313.457: MControllerDelegate::enableSync invoked
                            20140908-200313.457: ACCController::enableSync switch sync ON
                            20140908-200313.460: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.461: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200313.461: ACCController::updateWithState: 1
                            20140908-200313.462: ACCController::updateLocalFolder:
                            20140908-200313.463: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200313.463: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200313.466: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200313.467: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200313.468: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.469: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200313.470: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200313.470: There is no cloud folder at [], so now initalize it.
                            20140908-200313.471: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200313.471: ACCController::enableSync switch sync OFF
                            20140908-200313.475: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.479: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-200313.480: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-200313.480: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200313.481: ACCController::updateWithState: 11
                            20140908-200313.482: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.483: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200313.483: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200313.483: 2014-09-08 20:03:13: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200313.484: 2014-09-08 20:03:13: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200313.485: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.485: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200313.486: ACCController::updateWithState: 11
                            20140908-200313.486: ACCController::removeAllIcons
                            20140908-200313.486: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200313.487: ACCController::enableSync completed switch sync OFF
                            20140908-200313.488: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.489: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200313.489: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200313.489: 2014-09-08 20:03:13: File Monitoring was asked to stop on: : Update job
                            20140908-200313.490: 2014-09-08 20:03:13: File Monitoring was asked to stop on: : Update job
                            20140908-200313.490: WorkerThreads: 8
                            20140908-200313.490: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200313.490: ACCController::enableSync completed switch sync ON
                            20140908-200327.365: MControllerDelegate::enableSync invoked
                            20140908-200327.366: ACCController::enableSync switch sync ON
                            20140908-200327.368: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.369: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200327.369: ACCController::updateWithState: 1
                            20140908-200327.370: ACCController::updateLocalFolder:
                            20140908-200327.370: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200327.370: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200327.374: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200327.374: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200327.375: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.376: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200327.377: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200327.377: There is no cloud folder at [], so now initalize it.
                            20140908-200327.377: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200327.377: ACCController::enableSync switch sync OFF
                            20140908-200327.379: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.379: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-200327.382: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-200327.383: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200327.383: ACCController::updateWithState: 11
                            20140908-200327.384: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.385: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200327.385: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200327.386: 2014-09-08 20:03:27: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200327.387: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.388: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200327.388: ACCController::updateWithState: 11
                            20140908-200327.388: ACCController::removeAllIcons
                            20140908-200327.389: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200327.389: ACCController::enableSync completed switch sync OFF
                            20140908-200327.391: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.391: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200327.392: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200327.392: 2014-09-08 20:03:27: File Monitoring was asked to stop on: : Update job
                            20140908-200327.393: WorkerThreads: 8
                            20140908-200327.393: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200327.394: ACCController::enableSync completed switch sync ON
                            20140908-200339.354: MControllerDelegate::enableSync invoked
                            20140908-200339.354: ACCController::enableSync switch sync ON
                            20140908-200339.356: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.357: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200339.357: ACCController::updateWithState: 1
                            20140908-200339.358: ACCController::updateLocalFolder:
                            20140908-200339.358: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200339.359: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200339.361: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200339.361: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200339.362: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.363: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200339.364: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200339.364: There is no cloud folder at [], so now initalize it.
                            20140908-200339.364: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200339.365: ACCController::enableSync switch sync OFF
                            20140908-200339.369: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.373: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-200339.373: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-200339.373: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200339.376: ACCController::updateWithState: 11
                            20140908-200339.377: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.378: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200339.378: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200339.379: 2014-09-08 20:03:39: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200339.380: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.381: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200339.381: ACCController::updateWithState: 11
                            20140908-200339.382: ACCController::removeAllIcons
                            20140908-200339.382: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200339.383: ACCController::enableSync completed switch sync OFF
                            20140908-200339.385: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.385: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200339.386: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200339.386: 2014-09-08 20:03:39: File Monitoring was asked to stop on: : Update job
                            20140908-200339.386: WorkerThreads: 8
                            20140908-200339.387: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200339.387: ACCController::enableSync completed switch sync ON
                            20140908-200408.886: MControllerDelegate::enableSync invoked
                            20140908-200408.886: ACCController::enableSync switch sync ON
                            20140908-200408.888: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.889: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200408.889: ACCController::updateWithState: 1
                            20140908-200408.890: ACCController::updateLocalFolder:
                            20140908-200408.890: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200408.890: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200408.893: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200408.894: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200408.894: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.895: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200408.896: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200408.896: There is no cloud folder at [], so now initalize it.
                            20140908-200408.896: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200408.896: ACCController::enableSync switch sync OFF
                            20140908-200408.901: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.905: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-200408.905: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200408.906: ACCController::updateWithState: 11
                            20140908-200408.907: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.907: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200408.908: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200408.908: 2014-09-08 20:04:08: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200408.909: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.910: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200408.910: ACCController::updateWithState: 11
                            20140908-200408.910: ACCController::removeAllIcons
                            20140908-200408.911: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200408.912: ACCController::enableSync completed switch sync OFF
                            20140908-200408.913: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.914: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200408.914: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200408.914: 2014-09-08 20:04:08: File Monitoring was asked to stop on: : Update job
                            20140908-200408.915: WorkerThreads: 8
                            20140908-200408.915: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200408.915: ACCController::enableSync completed switch sync ON
                            20140908-200437.116: MControllerDelegate::enableSync invoked
                            20140908-200437.117: ACCController::enableSync switch sync ON
                            20140908-200437.119: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.119: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200437.120: ACCController::updateWithState: 1
                            20140908-200437.120: ACCController::updateLocalFolder:
                            20140908-200437.121: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200437.121: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200437.124: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200437.125: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200437.125: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.127: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200437.127: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200437.128: There is no cloud folder at [], so now initalize it.
                            20140908-200437.128: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200437.128: ACCController::enableSync switch sync OFF
                            20140908-200437.132: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.135: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-200437.136: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-200437.136: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200437.138: ACCController::updateWithState: 11
                            20140908-200437.139: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.139: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200437.140: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200437.140: 2014-09-08 20:04:37: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200437.141: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.142: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200437.142: ACCController::updateWithState: 11
                            20140908-200437.143: ACCController::removeAllIcons
                            20140908-200437.143: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200437.144: ACCController::enableSync completed switch sync OFF
                            20140908-200437.146: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.147: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200437.147: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200437.147: 2014-09-08 20:04:37: File Monitoring was asked to stop on: : Update job
                            20140908-200437.148: WorkerThreads: 8
                            20140908-200437.148: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200437.149: ACCController::enableSync completed switch sync ON
                            20140908-200550.626: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140908-200550.634: ACCController::Init
                            20140908-200550.643: ACCController::Init: init fileState cache
                            20140908-200550.647: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140908-200550.648: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-200550.699: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-200550.750: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140908-200550.751: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140908-200550.751: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140908-200550.804: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140908-200550.805: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200550.806: WorkerThreads: 8
                            20140908-200550.806: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200550.807: ACCController::Init: add notification observers
                            20140908-200550.811: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200550.812: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200550.812: ACCController::updateWithState: 11
                            20140908-200550.812: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140908-200550.813: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140908-200550.818: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140908-200550.819: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140908-200550.823: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140908-200550.824: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140908-200550.828: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140908-200550.828: Informational: AppHookControllerImpl::onStartup in
                            20140908-200550.831: Informational: [livetype] onStartup
                            20140908-200550.831: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140908-200550.835: Informational: [livetype] onStartup => success
                            20140908-200550.835: Informational: AppHookControllerImpl::onStartup out
                            20140908-200550.858: ACCController::injectFinderExt
                            20140908-200550.859: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-200550.860: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140908-200550.863: ACCController::finderInitSuccessfull: injectExt:YES
                            20140908-200551.898: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140908-200551.899: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140908-200551.899: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140908-200551.900: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140908-200551.900: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140908-200551.901: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140908-200551.901: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140908-200551.902: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140908-200551.903: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140908-200551.903: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.market.designLibrary state=false
                            20140908-200551.904: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140908-200551.904: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140908-200551.905: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140908-200551.905: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140908-200551.905: MControllerDelegate::enableCollaboration: YES
                            20140908-200551.907: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140908-200551.907: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 5d0f995385a8c74f6e57082578cbaa06 userId 6E68593446662ED1992016B8@AdobeID
                            20140908-200551.909: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200551.909: 2014-09-08 20:05:51: File Monitoring was asked to stop on: : Update job
                            20140908-200551.910: WorkerThreads: 8
                            20140908-200551.910: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200551.911: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.912: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200551.912: ACCController::updateWithState: 11
                            20140908-200551.913: Informational: AppHookControllerImpl::onSignIn in
                            20140908-200551.914: Informational: [livetype] onSignIn
                            20140908-200551.914: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140908-200551.915: Informational: AppHookControllerImpl::onSignIn out
                            20140908-200551.915: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140908-200551.917: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-200551.917: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-200551.917: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-200551.921: Informational: [livetype] syncStatus: OFF
                            20140908-200551.921: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-200551.921: MControllerDelegate::enableSync invoked
                            20140908-200551.922: ACCController::enableSync switch sync ON
                            20140908-200551.923: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.923: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200551.924: ACCController::updateWithState: 1
                            20140908-200551.924: ACCController::updateLocalFolder:
                            20140908-200551.925: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200551.925: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200551.925: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200551.927: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200551.927: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200551.928: There is no cloud folder at [], so now initalize it.
                            20140908-200551.928: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200551.928: ACCController::enableSync switch sync OFF
                            20140908-200551.929: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.930: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200551.931: ACCController::updateWithState: 11
                            20140908-200551.932: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200551.932: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.933: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200551.934: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200551.934: 2014-09-08 20:05:51: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200551.935: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.935: 2014-09-08 20:05:51: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200551.939: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-200551.939: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.939: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-200551.942: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.942: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200551.942: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-200551.942: Informational: [livetype] syncStatus: OFF
                            20140908-200551.950: ACCController::updateWithState: 11
                            20140908-200551.951: ACCController::removeAllIcons
                            20140908-200551.952: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200551.952: ACCController::enableSync completed switch sync OFF
                            20140908-200551.954: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.954: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200551.954: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200551.955: 2014-09-08 20:05:51: File Monitoring was asked to stop on: : Update job
                            20140908-200551.955: WorkerThreads: 8
                            20140908-200551.955: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200551.956: ACCController::enableSync completed switch sync ON
                            20140908-200604.170: MControllerDelegate::enableSync invoked
                            20140908-200604.171: ACCController::enableSync switch sync ON
                            20140908-200604.173: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.174: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200604.175: ACCController::updateWithState: 1
                            20140908-200604.175: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200604.179: ACCController::updateLocalFolder:
                            20140908-200604.179: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200604.180: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200604.181: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200604.181: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.183: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200604.183: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200604.183: There is no cloud folder at [], so now initalize it.
                            20140908-200604.184: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200604.184: ACCController::enableSync switch sync OFF
                            20140908-200604.188: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.192: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-200604.193: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-200604.193: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200604.195: ACCController::updateWithState: 11
                            20140908-200604.196: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.197: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200604.197: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200604.198: 2014-09-08 20:06:04: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200604.199: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.200: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200604.200: ACCController::updateWithState: 11
                            20140908-200604.200: ACCController::removeAllIcons
                            20140908-200604.201: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200604.202: ACCController::enableSync completed switch sync OFF
                            20140908-200604.203: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.204: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200604.204: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200604.205: 2014-09-08 20:06:04: File Monitoring was asked to stop on: : Update job
                            20140908-200604.205: WorkerThreads: 8
                            20140908-200604.205: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200604.206: ACCController::enableSync completed switch sync ON
                            20140908-200608.112: MControllerDelegate::updateFilePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop', uploadSetting:0, downloadSetting:0}
                            20140908-200608.113: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200827.171: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-200827.171: ACCController::doInjectFinderExt: appIdentifier: com.apple.systempreferences
                            20140908-200827.171: ACCController::doInjectFinderExt: app identifier: com.apple.systempreferences not equal to com.apple.finder
                            20140908-200953.086: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-200953.087: ACCController::doInjectFinderExt: appIdentifier: com.apple.systempreferences
                            20140908-200953.087: ACCController::doInjectFinderExt: app identifier: com.apple.systempreferences not equal to com.apple.finder
                            20140908-201026.571: MControllerDelegate::enableSync invoked
                            20140908-201026.572: ACCController::enableSync switch sync ON
                            20140908-201026.574: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.575: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-201026.575: ACCController::updateWithState: 1
                            20140908-201026.576: ACCController::updateLocalFolder:
                            20140908-201026.576: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-201026.577: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201026.577: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-201026.578: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-201026.579: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.581: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-201026.581: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-201026.582: There is no cloud folder at [], so now initalize it.
                            20140908-201026.582: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-201026.582: ACCController::enableSync switch sync OFF
                            20140908-201026.586: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.590: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-201026.591: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-201026.591: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201026.591: ACCController::updateWithState: 11
                            20140908-201026.593: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.594: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201026.594: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-201026.594: 2014-09-08 20:10:26: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201026.595: 2014-09-08 20:10:26: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201026.596: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.596: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201026.597: ACCController::updateWithState: 11
                            20140908-201026.597: ACCController::removeAllIcons
                            20140908-201026.598: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201026.598: ACCController::enableSync completed switch sync OFF
                            20140908-201026.600: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.600: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201026.601: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-201026.601: 2014-09-08 20:10:26: File Monitoring was asked to stop on: : Update job
                            20140908-201026.602: 2014-09-08 20:10:26: File Monitoring was asked to stop on: : Update job
                            20140908-201026.602: WorkerThreads: 8
                            20140908-201026.602: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-201026.603: ACCController::enableSync completed switch sync ON
                            20140908-201027.259: MControllerDelegate::enableSync invoked
                            20140908-201027.259: ACCController::enableSync switch sync ON
                            20140908-201027.262: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.263: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-201027.263: ACCController::updateWithState: 1
                            20140908-201027.264: ACCController::updateLocalFolder:
                            20140908-201027.264: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201027.266: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-201027.268: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-201027.269: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-201027.269: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.273: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-201027.273: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-201027.273: There is no cloud folder at [], so now initalize it.
                            20140908-201027.274: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-201027.274: ACCController::enableSync switch sync OFF
                            20140908-201027.274: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.275: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-201027.275: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-201027.275: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.276: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.277: ACCController::updateWithState: 11
                            20140908-201027.278: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.278: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.279: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-201027.279: 2014-09-08 20:10:27: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201027.280: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.281: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.281: ACCController::updateWithState: 11
                            20140908-201027.282: ACCController::removeAllIcons
                            20140908-201027.282: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201027.283: ACCController::enableSync completed switch sync OFF
                            20140908-201027.284: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.285: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.286: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-201027.286: 2014-09-08 20:10:27: File Monitoring was asked to stop on: : Update job
                            20140908-201027.287: WorkerThreads: 8
                            20140908-201027.287: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-201027.288: ACCController::enableSync completed switch sync ON
                            20140908-201027.723: MControllerDelegate::enableSync invoked
                            20140908-201027.723: ACCController::enableSync switch sync ON
                            20140908-201027.725: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.726: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-201027.726: ACCController::updateWithState: 1
                            20140908-201027.727: ACCController::updateLocalFolder:
                            20140908-201027.727: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-201027.728: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201027.728: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-201027.728: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-201027.730: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.731: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-201027.732: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-201027.732: There is no cloud folder at [], so now initalize it.
                            20140908-201027.732: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-201027.732: ACCController::enableSync switch sync OFF
                            20140908-201027.736: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.739: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-201027.739: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.740: ACCController::updateWithState: 11
                            20140908-201027.742: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.742: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.742: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-201027.743: 2014-09-08 20:10:27: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201027.744: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.744: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.745: ACCController::updateWithState: 11
                            20140908-201027.745: ACCController::removeAllIcons
                            20140908-201027.746: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201027.746: ACCController::enableSync completed switch sync OFF
                            20140908-201027.748: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.749: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.749: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-201027.750: 2014-09-08 20:10:27: File Monitoring was asked to stop on: : Update job
                            20140908-201027.750: WorkerThreads: 8
                            20140908-201027.751: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-201027.751: ACCController::enableSync completed switch sync ON
                            20140908-201028.157: MControllerDelegate::enableSync invoked
                            20140908-201028.157: ACCController::enableSync switch sync ON
                            20140908-201028.159: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.160: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-201028.161: ACCController::updateWithState: 1
                            20140908-201028.162: ACCController::updateLocalFolder:
                            20140908-201028.162: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201028.164: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-201028.167: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-201028.167: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-201028.168: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.170: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-201028.170: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-201028.170: There is no cloud folder at [], so now initalize it.
                            20140908-201028.171: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-201028.171: ACCController::enableSync switch sync OFF
                            20140908-201028.171: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.172: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-201028.172: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-201028.172: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.175: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201028.175: ACCController::updateWithState: 11
                            20140908-201028.176: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.177: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201028.178: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-201028.178: 2014-09-08 20:10:28: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201028.180: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.181: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201028.181: ACCController::updateWithState: 11
                            20140908-201028.182: ACCController::removeAllIcons
                            20140908-201028.182: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201028.183: ACCController::enableSync completed switch sync OFF
                            20140908-201028.184: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.185: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201028.185: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-201028.186: 2014-09-08 20:10:28: File Monitoring was asked to stop on: : Update job
                            20140908-201028.186: WorkerThreads: 8
                            20140908-201028.186: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-201028.187: ACCController::enableSync completed switch sync ON
                            20140908-201040.225: MControllerDelegate::enableSync invoked
                            20140908-201040.225: ACCController::enableSync switch sync ON
                            20140908-201040.227: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.227: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-201040.228: ACCController::updateWithState: 1
                            20140908-201040.228: ACCController::updateLocalFolder:
                            20140908-201040.229: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-201040.229: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201040.233: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-201040.233: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-201040.234: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.235: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-201040.236: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-201040.236: There is no cloud folder at [], so now initalize it.
                            20140908-201040.236: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-201040.236: ACCController::enableSync switch sync OFF
                            20140908-201040.238: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.239: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201040.240: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-201040.241: ACCController::updateWithState: 11
                            20140908-201040.244: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.244: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201040.245: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-201040.245: 2014-09-08 20:10:40: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201040.246: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.247: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201040.247: ACCController::updateWithState: 11
                            20140908-201040.248: ACCController::removeAllIcons
                            20140908-201040.249: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201040.249: ACCController::enableSync completed switch sync OFF
                            20140908-201040.251: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.251: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201040.252: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-201040.252: 2014-09-08 20:10:40: File Monitoring was asked to stop on: : Update job
                            20140908-201040.252: WorkerThreads: 8
                            20140908-201040.253: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-201040.253: ACCController::enableSync completed switch sync ON
                            20140908-201052.130: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-201052.130: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140908-201052.131: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140908-201502.258: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-201502.259: ACCController::doInjectFinderExt: appIdentifier: com.apple.Safari
                            20140908-201502.259: ACCController::doInjectFinderExt: app identifier: com.apple.Safari not equal to com.apple.finder
                            20140908-201512.735: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-201512.736: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140908-201512.736: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140908-202345.931: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-202345.931: ACCController::doInjectFinderExt: appIdentifier: com.apple.systempreferences
                            20140908-202345.932: ACCController::doInjectFinderExt: app identifier: com.apple.systempreferences not equal to com.apple.finder
                            20140908-202352.883: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-202352.884: ACCController::doInjectFinderExt: appIdentifier: com.apple.DiskUtility
                            20140908-202352.884: ACCController::doInjectFinderExt: app identifier: com.apple.DiskUtility not equal to com.apple.finder
                            20140908-202756.414: MControllerDelegate::enableSync invoked
                            20140908-202756.414: ACCController::enableSync switch sync ON
                            20140908-202756.417: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.417: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-202756.418: ACCController::updateWithState: 1
                            20140908-202756.418: ACCController::updateLocalFolder:
                            20140908-202756.419: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-202756.419: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-202756.420: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-202756.421: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-202756.422: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.423: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-202756.424: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-202756.424: There is no cloud folder at [], so now initalize it.
                            20140908-202756.424: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-202756.425: ACCController::enableSync switch sync OFF
                            20140908-202756.430: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.433: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-202756.433: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202756.434: ACCController::updateWithState: 11
                            20140908-202756.435: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.435: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202756.435: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-202756.436: 2014-09-08 20:27:56: File Monitoring was asked to stop on: : Sync turned off
                            20140908-202756.437: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.437: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202756.438: ACCController::updateWithState: 11
                            20140908-202756.438: ACCController::removeAllIcons
                            20140908-202756.438: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-202756.439: ACCController::enableSync completed switch sync OFF
                            20140908-202756.441: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.441: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202756.442: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-202756.442: 2014-09-08 20:27:56: File Monitoring was asked to stop on: : Update job
                            20140908-202756.442: WorkerThreads: 8
                            20140908-202756.442: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202756.443: ACCController::enableSync completed switch sync ON
                            20140908-202808.365: MControllerDelegate::updateFilePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt', uploadSetting:0, downloadSetting:0}
                            20140908-202808.366: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202808.367: MControllerDelegate::shutdownRequest
                            20140908-202808.368: ACCController::shutdown
                            20140908-202808.368: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140908-202808.369: 2014-09-08 20:28:08: File Monitoring was asked to stop on: : shutdown
                            20140908-202808.370: Informational: AppHookControllerImpl::onShutdown in
                            20140908-202827.521: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140908-202827.528: ACCController::Init
                            20140908-202827.535: ACCController::Init: init fileState cache
                            20140908-202827.538: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140908-202827.538: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-202827.589: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-202827.641: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140908-202827.642: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140908-202827.642: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140908-202827.695: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140908-202827.696: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202827.697: WorkerThreads: 8
                            20140908-202827.698: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202827.698: ACCController::Init: add notification observers
                            20140908-202827.702: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202827.703: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202827.703: ACCController::updateWithState: 11
                            20140908-202827.703: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140908-202827.704: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140908-202827.710: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140908-202827.710: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140908-202827.714: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140908-202827.715: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140908-202827.720: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140908-202827.720: Informational: AppHookControllerImpl::onStartup in
                            20140908-202827.723: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140908-202827.723: Informational: [livetype] onStartup
                            20140908-202827.726: Informational: [livetype] onStartup => success
                            20140908-202827.726: Informational: AppHookControllerImpl::onStartup out
                            20140908-202827.748: ACCController::injectFinderExt
                            20140908-202827.750: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-202827.750: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140908-202827.753: ACCController::finderInitSuccessfull: injectExt:YES
                            20140908-202828.806: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140908-202828.807: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140908-202828.807: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140908-202828.808: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140908-202828.808: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140908-202828.808: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140908-202828.809: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140908-202828.809: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140908-202828.810: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140908-202828.811: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.market.designLibrary state=false
                            20140908-202828.811: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140908-202828.812: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140908-202828.812: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140908-202828.812: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140908-202828.813: MControllerDelegate::enableCollaboration: YES
                            20140908-202828.814: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140908-202828.815: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 5d0f995385a8c74f6e57082578cbaa06 userId 6E68593446662ED1992016B8@AdobeID
                            20140908-202828.816: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-202828.817: 2014-09-08 20:28:28: File Monitoring was asked to stop on: : Update job
                            20140908-202828.817: WorkerThreads: 8
                            20140908-202828.818: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202828.819: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202828.819: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202828.819: ACCController::updateWithState: 11
                            20140908-202828.820: Informational: AppHookControllerImpl::onSignIn in
                            20140908-202828.821: Informational: [livetype] onSignIn
                            20140908-202828.821: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140908-202828.822: Informational: AppHookControllerImpl::onSignIn out
                            20140908-202828.822: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140908-202828.824: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-202829.217: MControllerDelegate::disableSync invoked
                            20140908-202829.218: ACCController::disableSync sync is already disabled
                            20140908-202829.255: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-202829.256: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-202829.256: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-202829.256: Informational: [livetype] syncStatus: OFF
                            20140908-202829.258: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-202829.259: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-202829.259: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-202829.259: Informational: [livetype] syncStatus: OFF
                            20140908-202917.479: MControllerDelegate::enableSync invoked
                            20140908-202917.480: ACCController::enableSync switch sync ON
                            20140908-202917.482: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.483: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-202917.483: ACCController::updateWithState: 1
                            20140908-202917.484: ACCController::updateLocalFolder:
                            20140908-202917.484: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-202917.485: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140908-202917.488: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-202917.489: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-202917.490: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.492: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-202917.492: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-202917.493: There is no cloud folder at [], so now initalize it.
                            20140908-202917.493: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-202917.494: ACCController::enableSync switch sync OFF
                            20140908-202917.494: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.494: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-202917.495: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-202917.495: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.495: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202917.495: ACCController::updateWithState: 11
                            20140908-202917.497: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.497: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202917.498: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-202917.498: 2014-09-08 20:29:17: File Monitoring was asked to stop on: : Sync turned off
                            20140908-202917.499: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.500: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202917.500: ACCController::updateWithState: 11
                            20140908-202917.501: ACCController::removeAllIcons
                            20140908-202917.501: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-202917.502: ACCController::enableSync completed switch sync OFF
                            20140908-202917.503: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.504: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202917.504: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-202917.505: 2014-09-08 20:29:17: File Monitoring was asked to stop on: : Update job
                            20140908-202917.505: WorkerThreads: 8
                            20140908-202917.506: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202917.506: ACCController::enableSync completed switch sync ON
                            20140908-203227.771: ACCController::osSleepWake: NSConcreteNotification 0x7fa213901260 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fa2115e2c50>}
                            20140908-203227.772: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140908-203227.772: 2014-09-08 20:32:27: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140908-203227.773: 2014-09-08 20:32:27: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140908-210242.037: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140908-210242.730: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-210430.202: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-210617.193: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-220702.034: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140908-220702.035: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140908-220702.690: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-230500.155: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-002800.686: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-012800.168: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-022800.120: Warning: [GUDE]: Request Failed. ErrorCode: 100050 message: Platform Status. (NSPOSIXErrorDomain 50) Network is down. Network is down.
                            20140908-032801.194: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-042800.119: Warning: [GUDE]: Request Failed. ErrorCode: 100050 message: Platform Status. (NSPOSIXErrorDomain 50) Network is down. Network is down.
                            20140908-052800.183: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-062800.121: Warning: [GUDE]: Request Failed. ErrorCode: 100050 message: Platform Status. (NSPOSIXErrorDomain 50) Network is down. Network is down.
                            20140908-072800.157: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-082800.144: Warning: [GUDE]: Request Failed. ErrorCode: 100050 message: Platform Status. (NSPOSIXErrorDomain 50) Network is down. Network is down.
                            20140908-082830.525: ACCController::osSleepWake: NSConcreteNotification 0x7f966d202480 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140908-083159.653: ACCController::osSleepWake: NSConcreteNotification 0x7f966be1a750 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140908-083159.653: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140908-083159.654: 2014-09-08 08:31:59: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140908-091027.152: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-091027.694: ACCController::osSleepWake: NSConcreteNotification 0x7f966bc71de0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f966bec73e0>}
                            20140908-091042.109: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-091042.110: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140908-091042.110: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140908-091155.139: ACCController::shutdown
                            20140908-091155.140: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140908-091155.140: 2014-09-08 09:11:55: File Monitoring was asked to stop on: : shutdown
                            20140908-091155.141: 2014-09-08 09:11:55: File Monitoring was asked to stop on: : shutdown
                            20140908-091155.141: Informational: AppHookControllerImpl::onShutdown in
                            20140908-091155.546: MControllerDelegate::shutdownRequest
                            20140908-091155.611: Informational: [livetype] onShutdown
                            20140908-091155.611: Informational: [livetype]  disableFontSync
                            20140908-091155.612: Informational: [livetype] deactivated all fonts
                            20140908-091155.617: Informational: AppHookControllerImpl::onShutdown out
                            20140908-091155.620: ACCController::removeAllIcons
                            20140908-091155.621: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140908-163730.615: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140908-163730.694: ACCController::Init
                            20140908-163730.705: ACCController::Init: init fileState cache
                            20140908-163730.789: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140908-163730.792: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140908-163730.794: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140908-163730.794: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140908-163730.797: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-163730.798: WorkerThreads: 8
                            20140908-163730.798: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-163730.824: ACCController::Init: add notification observers
                            20140908-163730.827: CJournalDB::Init: schema differs: incorrect number of tables
                            20140908-163730.828: CJournalDB::_create: successfully created 5 tables
                            20140908-163730.877: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-163730.878: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-163730.879: ACCController::updateWithState: 11
                            20140908-163730.879: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140908-163730.880: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140908-163730.889: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140908-163730.890: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140908-163730.897: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140908-163730.898: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140908-163730.905: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140908-163730.906: Informational: AppHookControllerImpl::onStartup in
                            20140908-163730.938: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140908-163730.938: Informational: [livetype] onStartup
                            20140908-163730.941: Informational: [livetype] onStartup => success
                            20140908-163730.941: Informational: AppHookControllerImpl::onStartup out
                            20140908-163730.977: ACCController::injectFinderExt
                            20140908-163730.980: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-163730.980: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140908-163731.041: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140908-163731.128: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140908-163731.152: ACCController::finderInitSuccessfull: injectExt:YES
                            20140908-163731.156: ACCController::finderInitSuccessfull: injectExt:YES
                            20140908-163731.157: ACCFinderExtensionController::init: intialization succsessfull
                            20140908-163731.992: MControllerDelegate::invalidateAccessToken
                            20140908-163731.993: ACCController::invalidateAccessToken
                            20140908-163731.993: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140908-163731.994: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140908-163731.994: Informational: [livetype] onInvalidateAccessToken
                            20140908-163731.995: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140908-163731.995: ACCController::invalidateAccessToken completed
                            20140908-163738.289: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-163738.290: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-163738.290: Informational: [livetype] syncStatus: OFF
                            20140908-163835.236: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140908-163835.236: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140908-163835.237: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140908-163835.237: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140908-163835.237: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140908-163835.238: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140908-163835.238: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140908-163835.238: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140908-163835.238: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140908-163835.239: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.market.designLibrary state=false
                            20140908-163835.239: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140908-163835.239: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140908-163835.240: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140908-163835.240: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140908-163835.240: MControllerDelegate::enableCollaboration: YES
                            20140908-163836.495: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140908-163836.495: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140908-163836.495: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140908-163836.496: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140908-163836.496: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140908-163836.496: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140908-163836.496: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140908-163836.497: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140908-163836.497: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140908-163836.497: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.market.designLibrary state=false
                            20140908-163836.497: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140908-163836.497: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140908-163836.498: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140908-163836.498: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140908-163836.498: MControllerDelegate::enableCollaboration: YES
                            20140908-163836.499: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140908-163836.500: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 5d0f995385a8c74f6e57082578cbaa06 userId 6E68593446662ED1992016B8@AdobeID
                            20140908-163836.501: MControllerDelegate::disableSync invoked
                            20140908-163836.503: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-163836.503: 2014-09-08 16:38:36: File Monitoring was asked to stop on: : Update job
                            20140908-163836.504: 2014-09-08 16:38:36: File Monitoring was asked to stop on: : Update job
                            20140908-163836.504: WorkerThreads: 8
                            20140908-163836.504: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-163836.505: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-163836.506: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-163836.506: ACCController::updateWithState: 11
                            20140908-163836.507: Informational: AppHookControllerImpl::onSignIn in
                            20140908-163836.507: Informational: [livetype] onSignIn
                            20140908-163836.508: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140908-163836.509: Informational: AppHookControllerImpl::onSignIn out
                            20140908-163836.509: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-163836.510: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140908-163836.512: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-163836.513: ACCController::disableSync sync is already disabled
                            20140908-163836.514: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-163836.514: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-163836.518: Informational: [livetype] syncStatus: OFF
                            20140908-163836.518: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-163925.972: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-163925.973: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140908-163925.973: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140908-164132.702: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-164132.703: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140908-164132.703: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140908-193904.293: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-193904.294: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140908-193904.294: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140908-194852.531: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-194852.532: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140908-194852.532: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140908-195419.232: MControllerDelegate::enableSync invoked
                            20140908-195419.233: ACCController::enableSync switch sync ON
                            20140908-195419.235: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.235: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195419.236: ACCController::updateWithState: 1
                            20140908-195419.237: ACCController::updateLocalFolder:
                            20140908-195419.237: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195419.241: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140908-195419.241: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195419.242: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195419.242: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.244: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195419.244: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195419.245: There is no cloud folder at [], so now initalize it.
                            20140908-195419.246: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195419.246: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.246: ACCController::enableSync switch sync OFF
                            20140908-195419.250: MControllerDelegate::syncStatus state 1 (CoreSyncStateSignedIn)
                            20140908-195419.251: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.252: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195419.252: ACCController::updateWithState: 11
                            20140908-195419.254: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.254: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195419.255: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195419.255: 2014-09-08 19:54:19: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195419.256: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.257: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195419.257: ACCController::updateWithState: 11
                            20140908-195419.257: ACCController::removeAllIcons
                            20140908-195419.258: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195419.259: ACCController::enableSync completed switch sync OFF
                            20140908-195419.260: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195419.261: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195419.261: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195419.261: 2014-09-08 19:54:19: File Monitoring was asked to stop on: : Update job
                            20140908-195419.262: 2014-09-08 19:54:19: File Monitoring was asked to stop on: : Update job
                            20140908-195419.262: WorkerThreads: 8
                            20140908-195419.262: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195419.263: ACCController::enableSync completed switch sync ON
                            20140908-195513.521: MControllerDelegate::enableSync invoked
                            20140908-195513.521: ACCController::enableSync switch sync ON
                            20140908-195513.523: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.524: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195513.525: ACCController::updateWithState: 1
                            20140908-195513.525: ACCController::updateLocalFolder:
                            20140908-195513.525: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195513.525: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140908-195513.531: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195513.531: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195513.532: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.534: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195513.534: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195513.535: There is no cloud folder at [], so now initalize it.
                            20140908-195513.535: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195513.535: ACCController::enableSync switch sync OFF
                            20140908-195513.536: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.537: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-195513.539: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-195513.540: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195513.540: ACCController::updateWithState: 11
                            20140908-195513.541: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.542: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195513.542: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195513.542: 2014-09-08 19:55:13: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195513.543: 2014-09-08 19:55:13: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195513.544: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.545: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195513.545: ACCController::updateWithState: 11
                            20140908-195513.545: ACCController::removeAllIcons
                            20140908-195513.546: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195513.547: ACCController::enableSync completed switch sync OFF
                            20140908-195513.548: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195513.548: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195513.549: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195513.549: 2014-09-08 19:55:13: File Monitoring was asked to stop on: : Update job
                            20140908-195513.550: WorkerThreads: 8
                            20140908-195513.550: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195513.550: ACCController::enableSync completed switch sync ON
                            20140908-195529.543: MControllerDelegate::updateFilePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop', uploadSetting:0, downloadSetting:0}
                            20140908-195529.545: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195529.546: MControllerDelegate::shutdownRequest
                            20140908-195529.547: ACCController::shutdown
                            20140908-195529.547: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140908-195529.547: 2014-09-08 19:55:29: File Monitoring was asked to stop on: : shutdown
                            20140908-195529.548: 2014-09-08 19:55:29: File Monitoring was asked to stop on: : shutdown
                            20140908-195529.548: Informational: AppHookControllerImpl::onShutdown in
                            20140908-195529.607: Informational: [livetype] onShutdown
                            20140908-195529.607: Informational: [livetype]  disableFontSync
                            20140908-195529.608: Informational: [livetype] deactivated all fonts
                            20140908-195529.608: Informational: AppHookControllerImpl::onShutdown out
                            20140908-195529.609: ACCController::removeAllIcons
                            20140908-195529.612: ACCController::shutdown completed
                            20140908-195547.684: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140908-195547.694: ACCController::Init
                            20140908-195547.701: ACCController::Init: init fileState cache
                            20140908-195547.703: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140908-195547.704: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-195547.756: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-195547.808: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140908-195547.809: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140908-195547.809: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140908-195547.862: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140908-195547.863: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195547.864: WorkerThreads: 8
                            20140908-195547.864: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195547.865: ACCController::Init: add notification observers
                            20140908-195547.868: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195547.869: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195547.870: ACCController::updateWithState: 11
                            20140908-195547.870: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140908-195547.870: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140908-195547.876: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140908-195547.876: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140908-195547.880: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140908-195547.880: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140908-195547.885: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140908-195547.885: Informational: AppHookControllerImpl::onStartup in
                            20140908-195547.888: Informational: [livetype] onStartup
                            20140908-195547.888: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140908-195547.892: Informational: [livetype] onStartup => success
                            20140908-195547.893: Informational: AppHookControllerImpl::onStartup out
                            20140908-195547.913: ACCController::injectFinderExt
                            20140908-195547.915: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-195547.915: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140908-195547.918: ACCController::finderInitSuccessfull: injectExt:YES
                            20140908-195548.978: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140908-195548.978: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140908-195548.978: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140908-195548.979: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140908-195548.979: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140908-195548.980: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140908-195548.980: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140908-195548.981: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140908-195548.982: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140908-195548.982: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.market.designLibrary state=false
                            20140908-195548.983: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140908-195548.983: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140908-195548.984: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140908-195548.984: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140908-195548.985: MControllerDelegate::enableCollaboration: YES
                            20140908-195548.987: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140908-195548.988: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 5d0f995385a8c74f6e57082578cbaa06 userId 6E68593446662ED1992016B8@AdobeID
                            20140908-195548.989: PrefernceManager::updatePrefernces
                            20140908-195548.990: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195548.990: 2014-09-08 19:55:48: File Monitoring was asked to stop on: : Update job
                            20140908-195548.991: 2014-09-08 19:55:48: File Monitoring was asked to stop on: : Update job
                            20140908-195548.991: WorkerThreads: 8
                            20140908-195548.991: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195548.992: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195548.993: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195548.993: ACCController::updateWithState: 11
                            20140908-195548.995: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195548.995: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-195548.996: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195548.996: Informational: AppHookControllerImpl::onSignIn in
                            20140908-195548.997: Informational: [livetype] onSignIn
                            20140908-195548.998: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140908-195548.998: Informational: AppHookControllerImpl::onSignIn out
                            20140908-195548.998: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140908-195549.000: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-195549.001: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-195549.387: MControllerDelegate::disableSync invoked
                            20140908-195549.387: ACCController::disableSync sync is already disabled
                            20140908-195549.427: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-195549.428: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-195549.428: Informational: [livetype] syncStatus: OFF
                            20140908-195549.430: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-195549.431: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-195549.431: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-195549.432: Informational: [livetype] syncStatus: OFF
                            20140908-195600.609: MControllerDelegate::enableSync invoked
                            20140908-195600.610: ACCController::enableSync switch sync ON
                            20140908-195600.612: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.613: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195600.613: ACCController::updateWithState: 1
                            20140908-195600.613: ACCController::updateLocalFolder:
                            20140908-195600.614: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-195600.614: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195600.615: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195600.615: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195600.620: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.620: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195600.622: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195600.622: There is no cloud folder at [], so now initalize it.
                            20140908-195600.623: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195600.623: ACCController::enableSync switch sync OFF
                            20140908-195600.625: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.626: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195600.626: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-195600.630: ACCController::updateWithState: 11
                            20140908-195600.631: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.632: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195600.632: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195600.633: 2014-09-08 19:56:00: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195600.634: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.635: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195600.635: ACCController::updateWithState: 11
                            20140908-195600.635: ACCController::removeAllIcons
                            20140908-195600.636: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195600.637: ACCController::enableSync completed switch sync OFF
                            20140908-195600.638: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195600.639: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195600.639: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195600.640: 2014-09-08 19:56:00: File Monitoring was asked to stop on: : Update job
                            20140908-195600.640: WorkerThreads: 8
                            20140908-195600.641: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195600.641: ACCController::enableSync completed switch sync ON
                            20140908-195625.994: MControllerDelegate::enableSync invoked
                            20140908-195625.994: ACCController::enableSync switch sync ON
                            20140908-195625.997: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195625.998: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195625.998: ACCController::updateWithState: 1
                            20140908-195625.999: ACCController::updateLocalFolder:
                            20140908-195625.999: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-195625.999: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195626.003: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195626.004: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195626.004: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195626.006: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195626.006: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195626.007: There is no cloud folder at [], so now initalize it.
                            20140908-195626.007: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195626.007: ACCController::enableSync switch sync OFF
                            20140908-195626.012: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195626.015: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-195626.016: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195626.016: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-195626.019: ACCController::updateWithState: 11
                            20140908-195626.020: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195626.021: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195626.021: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195626.021: 2014-09-08 19:56:26: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195626.022: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195626.023: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195626.023: ACCController::updateWithState: 11
                            20140908-195626.024: ACCController::removeAllIcons
                            20140908-195626.024: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195626.025: ACCController::enableSync completed switch sync OFF
                            20140908-195626.026: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195626.027: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195626.028: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195626.028: 2014-09-08 19:56:26: File Monitoring was asked to stop on: : Update job
                            20140908-195626.028: WorkerThreads: 8
                            20140908-195626.028: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195626.029: ACCController::enableSync completed switch sync ON
                            20140908-195637.511: MControllerDelegate::enableSync invoked
                            20140908-195637.512: ACCController::enableSync switch sync ON
                            20140908-195637.514: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.514: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195637.515: ACCController::updateWithState: 1
                            20140908-195637.515: ACCController::updateLocalFolder:
                            20140908-195637.516: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-195637.516: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195637.517: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195637.517: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195637.519: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.519: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195637.520: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195637.520: There is no cloud folder at [], so now initalize it.
                            20140908-195637.521: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195637.521: ACCController::enableSync switch sync OFF
                            20140908-195637.522: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.523: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.523: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195637.524: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-195637.526: ACCController::updateWithState: 11
                            20140908-195637.528: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.528: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195637.529: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195637.529: 2014-09-08 19:56:37: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195637.531: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.531: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195637.532: ACCController::updateWithState: 11
                            20140908-195637.532: ACCController::removeAllIcons
                            20140908-195637.532: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195637.533: ACCController::enableSync completed switch sync OFF
                            20140908-195637.535: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195637.536: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195637.536: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195637.536: 2014-09-08 19:56:37: File Monitoring was asked to stop on: : Update job
                            20140908-195637.537: 2014-09-08 19:56:37: File Monitoring was asked to stop on: : Update job
                            20140908-195637.537: WorkerThreads: 8
                            20140908-195637.537: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195637.538: ACCController::enableSync completed switch sync ON
                            20140908-195721.634: MControllerDelegate::enableSync invoked
                            20140908-195721.634: ACCController::enableSync switch sync ON
                            20140908-195721.636: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195721.636: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195721.637: ACCController::updateWithState: 1
                            20140908-195721.637: ACCController::updateLocalFolder:
                            20140908-195721.637: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-195721.638: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195721.638: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195721.640: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195721.640: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195721.640: There is no cloud folder at [], so now initalize it.
                            20140908-195721.641: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195721.641: ACCController::enableSync switch sync OFF
                            20140908-195721.642: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195721.643: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195721.643: ACCController::updateWithState: 11
                            20140908-195721.644: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195721.645: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195721.645: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195721.645: 2014-09-08 19:57:21: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195721.646: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195721.647: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195721.647: ACCController::updateWithState: 11
                            20140908-195721.648: ACCController::removeAllIcons
                            20140908-195721.648: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195721.649: ACCController::enableSync completed switch sync OFF
                            20140908-195721.650: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195721.651: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195721.651: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195721.651: 2014-09-08 19:57:21: File Monitoring was asked to stop on: : Update job
                            20140908-195721.652: 2014-09-08 19:57:21: File Monitoring was asked to stop on: : Update job
                            20140908-195721.652: WorkerThreads: 8
                            20140908-195721.652: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195721.653: ACCController::enableSync completed switch sync ON
                            20140908-195735.978: MControllerDelegate::enableSync invoked
                            20140908-195735.978: ACCController::enableSync switch sync ON
                            20140908-195735.980: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195735.980: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-195735.981: ACCController::updateWithState: 1
                            20140908-195735.981: ACCController::updateLocalFolder:
                            20140908-195735.981: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-195735.982: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-195735.983: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-195735.985: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-195735.985: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-195735.985: There is no cloud folder at [], so now initalize it.
                            20140908-195735.986: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-195735.986: ACCController::enableSync switch sync OFF
                            20140908-195735.987: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195735.988: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195735.988: ACCController::updateWithState: 11
                            20140908-195735.990: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195735.990: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195735.991: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-195735.991: 2014-09-08 19:57:35: File Monitoring was asked to stop on: : Sync turned off
                            20140908-195735.992: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195735.993: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195735.993: ACCController::updateWithState: 11
                            20140908-195735.994: ACCController::removeAllIcons
                            20140908-195735.994: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195735.995: ACCController::enableSync completed switch sync OFF
                            20140908-195735.996: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195735.997: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-195735.997: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-195735.997: 2014-09-08 19:57:35: File Monitoring was asked to stop on: : Update job
                            20140908-195735.997: WorkerThreads: 8
                            20140908-195735.998: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-195735.998: ACCController::enableSync completed switch sync ON
                            20140908-195737.069: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-195737.072: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195737.076: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-195737.077: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-195755.759: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-195755.760: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140908-195755.760: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140908-200200.688: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-200200.689: ACCController::doInjectFinderExt: appIdentifier: com.apple.systempreferences
                            20140908-200200.689: ACCController::doInjectFinderExt: app identifier: com.apple.systempreferences not equal to com.apple.finder
                            20140908-200313.457: MControllerDelegate::enableSync invoked
                            20140908-200313.457: ACCController::enableSync switch sync ON
                            20140908-200313.460: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.461: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200313.461: ACCController::updateWithState: 1
                            20140908-200313.462: ACCController::updateLocalFolder:
                            20140908-200313.463: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200313.463: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200313.466: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200313.467: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200313.468: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.469: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200313.470: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200313.470: There is no cloud folder at [], so now initalize it.
                            20140908-200313.471: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200313.471: ACCController::enableSync switch sync OFF
                            20140908-200313.475: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.479: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-200313.480: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-200313.480: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200313.481: ACCController::updateWithState: 11
                            20140908-200313.482: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.483: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200313.483: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200313.483: 2014-09-08 20:03:13: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200313.484: 2014-09-08 20:03:13: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200313.485: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.485: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200313.486: ACCController::updateWithState: 11
                            20140908-200313.486: ACCController::removeAllIcons
                            20140908-200313.486: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200313.487: ACCController::enableSync completed switch sync OFF
                            20140908-200313.488: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200313.489: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200313.489: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200313.489: 2014-09-08 20:03:13: File Monitoring was asked to stop on: : Update job
                            20140908-200313.490: 2014-09-08 20:03:13: File Monitoring was asked to stop on: : Update job
                            20140908-200313.490: WorkerThreads: 8
                            20140908-200313.490: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200313.490: ACCController::enableSync completed switch sync ON
                            20140908-200327.365: MControllerDelegate::enableSync invoked
                            20140908-200327.366: ACCController::enableSync switch sync ON
                            20140908-200327.368: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.369: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200327.369: ACCController::updateWithState: 1
                            20140908-200327.370: ACCController::updateLocalFolder:
                            20140908-200327.370: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200327.370: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200327.374: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200327.374: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200327.375: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.376: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200327.377: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200327.377: There is no cloud folder at [], so now initalize it.
                            20140908-200327.377: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200327.377: ACCController::enableSync switch sync OFF
                            20140908-200327.379: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.379: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-200327.382: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-200327.383: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200327.383: ACCController::updateWithState: 11
                            20140908-200327.384: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.385: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200327.385: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200327.386: 2014-09-08 20:03:27: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200327.387: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.388: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200327.388: ACCController::updateWithState: 11
                            20140908-200327.388: ACCController::removeAllIcons
                            20140908-200327.389: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200327.389: ACCController::enableSync completed switch sync OFF
                            20140908-200327.391: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200327.391: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200327.392: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200327.392: 2014-09-08 20:03:27: File Monitoring was asked to stop on: : Update job
                            20140908-200327.393: WorkerThreads: 8
                            20140908-200327.393: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200327.394: ACCController::enableSync completed switch sync ON
                            20140908-200339.354: MControllerDelegate::enableSync invoked
                            20140908-200339.354: ACCController::enableSync switch sync ON
                            20140908-200339.356: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.357: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200339.357: ACCController::updateWithState: 1
                            20140908-200339.358: ACCController::updateLocalFolder:
                            20140908-200339.358: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200339.359: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200339.361: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200339.361: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200339.362: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.363: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200339.364: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200339.364: There is no cloud folder at [], so now initalize it.
                            20140908-200339.364: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200339.365: ACCController::enableSync switch sync OFF
                            20140908-200339.369: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.373: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-200339.373: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-200339.373: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200339.376: ACCController::updateWithState: 11
                            20140908-200339.377: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.378: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200339.378: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200339.379: 2014-09-08 20:03:39: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200339.380: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.381: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200339.381: ACCController::updateWithState: 11
                            20140908-200339.382: ACCController::removeAllIcons
                            20140908-200339.382: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200339.383: ACCController::enableSync completed switch sync OFF
                            20140908-200339.385: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200339.385: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200339.386: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200339.386: 2014-09-08 20:03:39: File Monitoring was asked to stop on: : Update job
                            20140908-200339.386: WorkerThreads: 8
                            20140908-200339.387: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200339.387: ACCController::enableSync completed switch sync ON
                            20140908-200408.886: MControllerDelegate::enableSync invoked
                            20140908-200408.886: ACCController::enableSync switch sync ON
                            20140908-200408.888: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.889: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200408.889: ACCController::updateWithState: 1
                            20140908-200408.890: ACCController::updateLocalFolder:
                            20140908-200408.890: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200408.890: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200408.893: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200408.894: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200408.894: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.895: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200408.896: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200408.896: There is no cloud folder at [], so now initalize it.
                            20140908-200408.896: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200408.896: ACCController::enableSync switch sync OFF
                            20140908-200408.901: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.905: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-200408.905: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200408.906: ACCController::updateWithState: 11
                            20140908-200408.907: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.907: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200408.908: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200408.908: 2014-09-08 20:04:08: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200408.909: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.910: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200408.910: ACCController::updateWithState: 11
                            20140908-200408.910: ACCController::removeAllIcons
                            20140908-200408.911: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200408.912: ACCController::enableSync completed switch sync OFF
                            20140908-200408.913: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200408.914: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200408.914: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200408.914: 2014-09-08 20:04:08: File Monitoring was asked to stop on: : Update job
                            20140908-200408.915: WorkerThreads: 8
                            20140908-200408.915: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200408.915: ACCController::enableSync completed switch sync ON
                            20140908-200437.116: MControllerDelegate::enableSync invoked
                            20140908-200437.117: ACCController::enableSync switch sync ON
                            20140908-200437.119: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.119: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200437.120: ACCController::updateWithState: 1
                            20140908-200437.120: ACCController::updateLocalFolder:
                            20140908-200437.121: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200437.121: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200437.124: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200437.125: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200437.125: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.127: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200437.127: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200437.128: There is no cloud folder at [], so now initalize it.
                            20140908-200437.128: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200437.128: ACCController::enableSync switch sync OFF
                            20140908-200437.132: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.135: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-200437.136: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-200437.136: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200437.138: ACCController::updateWithState: 11
                            20140908-200437.139: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.139: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200437.140: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200437.140: 2014-09-08 20:04:37: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200437.141: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.142: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200437.142: ACCController::updateWithState: 11
                            20140908-200437.143: ACCController::removeAllIcons
                            20140908-200437.143: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200437.144: ACCController::enableSync completed switch sync OFF
                            20140908-200437.146: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200437.147: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200437.147: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200437.147: 2014-09-08 20:04:37: File Monitoring was asked to stop on: : Update job
                            20140908-200437.148: WorkerThreads: 8
                            20140908-200437.148: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200437.149: ACCController::enableSync completed switch sync ON
                            20140908-200550.626: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140908-200550.634: ACCController::Init
                            20140908-200550.643: ACCController::Init: init fileState cache
                            20140908-200550.647: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140908-200550.648: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-200550.699: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-200550.750: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140908-200550.751: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140908-200550.751: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140908-200550.804: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140908-200550.805: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200550.806: WorkerThreads: 8
                            20140908-200550.806: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200550.807: ACCController::Init: add notification observers
                            20140908-200550.811: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200550.812: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200550.812: ACCController::updateWithState: 11
                            20140908-200550.812: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140908-200550.813: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140908-200550.818: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140908-200550.819: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140908-200550.823: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140908-200550.824: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140908-200550.828: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140908-200550.828: Informational: AppHookControllerImpl::onStartup in
                            20140908-200550.831: Informational: [livetype] onStartup
                            20140908-200550.831: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140908-200550.835: Informational: [livetype] onStartup => success
                            20140908-200550.835: Informational: AppHookControllerImpl::onStartup out
                            20140908-200550.858: ACCController::injectFinderExt
                            20140908-200550.859: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-200550.860: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140908-200550.863: ACCController::finderInitSuccessfull: injectExt:YES
                            20140908-200551.898: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140908-200551.899: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140908-200551.899: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140908-200551.900: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140908-200551.900: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140908-200551.901: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140908-200551.901: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140908-200551.902: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140908-200551.903: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140908-200551.903: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.market.designLibrary state=false
                            20140908-200551.904: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140908-200551.904: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140908-200551.905: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140908-200551.905: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140908-200551.905: MControllerDelegate::enableCollaboration: YES
                            20140908-200551.907: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140908-200551.907: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 5d0f995385a8c74f6e57082578cbaa06 userId 6E68593446662ED1992016B8@AdobeID
                            20140908-200551.909: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200551.909: 2014-09-08 20:05:51: File Monitoring was asked to stop on: : Update job
                            20140908-200551.910: WorkerThreads: 8
                            20140908-200551.910: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200551.911: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.912: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200551.912: ACCController::updateWithState: 11
                            20140908-200551.913: Informational: AppHookControllerImpl::onSignIn in
                            20140908-200551.914: Informational: [livetype] onSignIn
                            20140908-200551.914: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140908-200551.915: Informational: AppHookControllerImpl::onSignIn out
                            20140908-200551.915: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140908-200551.917: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-200551.917: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-200551.917: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-200551.921: Informational: [livetype] syncStatus: OFF
                            20140908-200551.921: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-200551.921: MControllerDelegate::enableSync invoked
                            20140908-200551.922: ACCController::enableSync switch sync ON
                            20140908-200551.923: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.923: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200551.924: ACCController::updateWithState: 1
                            20140908-200551.924: ACCController::updateLocalFolder:
                            20140908-200551.925: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200551.925: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200551.925: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200551.927: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200551.927: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200551.928: There is no cloud folder at [], so now initalize it.
                            20140908-200551.928: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200551.928: ACCController::enableSync switch sync OFF
                            20140908-200551.929: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.930: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200551.931: ACCController::updateWithState: 11
                            20140908-200551.932: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200551.932: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.933: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200551.934: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200551.934: 2014-09-08 20:05:51: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200551.935: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.935: 2014-09-08 20:05:51: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200551.939: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-200551.939: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.939: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-200551.942: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.942: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200551.942: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-200551.942: Informational: [livetype] syncStatus: OFF
                            20140908-200551.950: ACCController::updateWithState: 11
                            20140908-200551.951: ACCController::removeAllIcons
                            20140908-200551.952: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200551.952: ACCController::enableSync completed switch sync OFF
                            20140908-200551.954: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200551.954: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200551.954: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200551.955: 2014-09-08 20:05:51: File Monitoring was asked to stop on: : Update job
                            20140908-200551.955: WorkerThreads: 8
                            20140908-200551.955: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200551.956: ACCController::enableSync completed switch sync ON
                            20140908-200604.170: MControllerDelegate::enableSync invoked
                            20140908-200604.171: ACCController::enableSync switch sync ON
                            20140908-200604.173: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.174: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-200604.175: ACCController::updateWithState: 1
                            20140908-200604.175: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200604.179: ACCController::updateLocalFolder:
                            20140908-200604.179: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-200604.180: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-200604.181: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-200604.181: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.183: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-200604.183: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-200604.183: There is no cloud folder at [], so now initalize it.
                            20140908-200604.184: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-200604.184: ACCController::enableSync switch sync OFF
                            20140908-200604.188: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.192: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-200604.193: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-200604.193: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200604.195: ACCController::updateWithState: 11
                            20140908-200604.196: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.197: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200604.197: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-200604.198: 2014-09-08 20:06:04: File Monitoring was asked to stop on: : Sync turned off
                            20140908-200604.199: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.200: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200604.200: ACCController::updateWithState: 11
                            20140908-200604.200: ACCController::removeAllIcons
                            20140908-200604.201: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-200604.202: ACCController::enableSync completed switch sync OFF
                            20140908-200604.203: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-200604.204: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-200604.204: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-200604.205: 2014-09-08 20:06:04: File Monitoring was asked to stop on: : Update job
                            20140908-200604.205: WorkerThreads: 8
                            20140908-200604.205: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200604.206: ACCController::enableSync completed switch sync ON
                            20140908-200608.112: MControllerDelegate::updateFilePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop', uploadSetting:0, downloadSetting:0}
                            20140908-200608.113: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-200827.171: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-200827.171: ACCController::doInjectFinderExt: appIdentifier: com.apple.systempreferences
                            20140908-200827.171: ACCController::doInjectFinderExt: app identifier: com.apple.systempreferences not equal to com.apple.finder
                            20140908-200953.086: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-200953.087: ACCController::doInjectFinderExt: appIdentifier: com.apple.systempreferences
                            20140908-200953.087: ACCController::doInjectFinderExt: app identifier: com.apple.systempreferences not equal to com.apple.finder
                            20140908-201026.571: MControllerDelegate::enableSync invoked
                            20140908-201026.572: ACCController::enableSync switch sync ON
                            20140908-201026.574: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.575: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-201026.575: ACCController::updateWithState: 1
                            20140908-201026.576: ACCController::updateLocalFolder:
                            20140908-201026.576: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-201026.577: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201026.577: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-201026.578: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-201026.579: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.581: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-201026.581: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-201026.582: There is no cloud folder at [], so now initalize it.
                            20140908-201026.582: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-201026.582: ACCController::enableSync switch sync OFF
                            20140908-201026.586: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.590: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-201026.591: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-201026.591: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201026.591: ACCController::updateWithState: 11
                            20140908-201026.593: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.594: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201026.594: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-201026.594: 2014-09-08 20:10:26: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201026.595: 2014-09-08 20:10:26: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201026.596: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.596: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201026.597: ACCController::updateWithState: 11
                            20140908-201026.597: ACCController::removeAllIcons
                            20140908-201026.598: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201026.598: ACCController::enableSync completed switch sync OFF
                            20140908-201026.600: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201026.600: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201026.601: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-201026.601: 2014-09-08 20:10:26: File Monitoring was asked to stop on: : Update job
                            20140908-201026.602: 2014-09-08 20:10:26: File Monitoring was asked to stop on: : Update job
                            20140908-201026.602: WorkerThreads: 8
                            20140908-201026.602: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-201026.603: ACCController::enableSync completed switch sync ON
                            20140908-201027.259: MControllerDelegate::enableSync invoked
                            20140908-201027.259: ACCController::enableSync switch sync ON
                            20140908-201027.262: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.263: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-201027.263: ACCController::updateWithState: 1
                            20140908-201027.264: ACCController::updateLocalFolder:
                            20140908-201027.264: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201027.266: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-201027.268: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-201027.269: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-201027.269: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.273: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-201027.273: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-201027.273: There is no cloud folder at [], so now initalize it.
                            20140908-201027.274: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-201027.274: ACCController::enableSync switch sync OFF
                            20140908-201027.274: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.275: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-201027.275: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-201027.275: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.276: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.277: ACCController::updateWithState: 11
                            20140908-201027.278: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.278: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.279: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-201027.279: 2014-09-08 20:10:27: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201027.280: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.281: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.281: ACCController::updateWithState: 11
                            20140908-201027.282: ACCController::removeAllIcons
                            20140908-201027.282: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201027.283: ACCController::enableSync completed switch sync OFF
                            20140908-201027.284: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.285: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.286: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-201027.286: 2014-09-08 20:10:27: File Monitoring was asked to stop on: : Update job
                            20140908-201027.287: WorkerThreads: 8
                            20140908-201027.287: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-201027.288: ACCController::enableSync completed switch sync ON
                            20140908-201027.723: MControllerDelegate::enableSync invoked
                            20140908-201027.723: ACCController::enableSync switch sync ON
                            20140908-201027.725: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.726: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-201027.726: ACCController::updateWithState: 1
                            20140908-201027.727: ACCController::updateLocalFolder:
                            20140908-201027.727: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-201027.728: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201027.728: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-201027.728: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-201027.730: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.731: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-201027.732: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-201027.732: There is no cloud folder at [], so now initalize it.
                            20140908-201027.732: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-201027.732: ACCController::enableSync switch sync OFF
                            20140908-201027.736: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.739: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-201027.739: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.740: ACCController::updateWithState: 11
                            20140908-201027.742: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.742: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.742: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-201027.743: 2014-09-08 20:10:27: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201027.744: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.744: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.745: ACCController::updateWithState: 11
                            20140908-201027.745: ACCController::removeAllIcons
                            20140908-201027.746: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201027.746: ACCController::enableSync completed switch sync OFF
                            20140908-201027.748: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201027.749: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201027.749: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-201027.750: 2014-09-08 20:10:27: File Monitoring was asked to stop on: : Update job
                            20140908-201027.750: WorkerThreads: 8
                            20140908-201027.751: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-201027.751: ACCController::enableSync completed switch sync ON
                            20140908-201028.157: MControllerDelegate::enableSync invoked
                            20140908-201028.157: ACCController::enableSync switch sync ON
                            20140908-201028.159: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.160: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-201028.161: ACCController::updateWithState: 1
                            20140908-201028.162: ACCController::updateLocalFolder:
                            20140908-201028.162: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201028.164: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-201028.167: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-201028.167: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-201028.168: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.170: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-201028.170: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-201028.170: There is no cloud folder at [], so now initalize it.
                            20140908-201028.171: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-201028.171: ACCController::enableSync switch sync OFF
                            20140908-201028.171: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.172: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-201028.172: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-201028.172: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.175: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201028.175: ACCController::updateWithState: 11
                            20140908-201028.176: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.177: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201028.178: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-201028.178: 2014-09-08 20:10:28: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201028.180: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.181: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201028.181: ACCController::updateWithState: 11
                            20140908-201028.182: ACCController::removeAllIcons
                            20140908-201028.182: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201028.183: ACCController::enableSync completed switch sync OFF
                            20140908-201028.184: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201028.185: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201028.185: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-201028.186: 2014-09-08 20:10:28: File Monitoring was asked to stop on: : Update job
                            20140908-201028.186: WorkerThreads: 8
                            20140908-201028.186: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-201028.187: ACCController::enableSync completed switch sync ON
                            20140908-201040.225: MControllerDelegate::enableSync invoked
                            20140908-201040.225: ACCController::enableSync switch sync ON
                            20140908-201040.227: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.227: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-201040.228: ACCController::updateWithState: 1
                            20140908-201040.228: ACCController::updateLocalFolder:
                            20140908-201040.229: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-201040.229: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201040.233: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-201040.233: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-201040.234: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.235: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-201040.236: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-201040.236: There is no cloud folder at [], so now initalize it.
                            20140908-201040.236: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-201040.236: ACCController::enableSync switch sync OFF
                            20140908-201040.238: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.239: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201040.240: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-201040.241: ACCController::updateWithState: 11
                            20140908-201040.244: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.244: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201040.245: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-201040.245: 2014-09-08 20:10:40: File Monitoring was asked to stop on: : Sync turned off
                            20140908-201040.246: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.247: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201040.247: ACCController::updateWithState: 11
                            20140908-201040.248: ACCController::removeAllIcons
                            20140908-201040.249: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-201040.249: ACCController::enableSync completed switch sync OFF
                            20140908-201040.251: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-201040.251: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-201040.252: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-201040.252: 2014-09-08 20:10:40: File Monitoring was asked to stop on: : Update job
                            20140908-201040.252: WorkerThreads: 8
                            20140908-201040.253: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-201040.253: ACCController::enableSync completed switch sync ON
                            20140908-201052.130: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-201052.130: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140908-201052.131: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140908-201502.258: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-201502.259: ACCController::doInjectFinderExt: appIdentifier: com.apple.Safari
                            20140908-201502.259: ACCController::doInjectFinderExt: app identifier: com.apple.Safari not equal to com.apple.finder
                            20140908-201512.735: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-201512.736: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140908-201512.736: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140908-202345.931: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-202345.931: ACCController::doInjectFinderExt: appIdentifier: com.apple.systempreferences
                            20140908-202345.932: ACCController::doInjectFinderExt: app identifier: com.apple.systempreferences not equal to com.apple.finder
                            20140908-202352.883: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-202352.884: ACCController::doInjectFinderExt: appIdentifier: com.apple.DiskUtility
                            20140908-202352.884: ACCController::doInjectFinderExt: app identifier: com.apple.DiskUtility not equal to com.apple.finder
                            20140908-202756.414: MControllerDelegate::enableSync invoked
                            20140908-202756.414: ACCController::enableSync switch sync ON
                            20140908-202756.417: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.417: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-202756.418: ACCController::updateWithState: 1
                            20140908-202756.418: ACCController::updateLocalFolder:
                            20140908-202756.419: Old user '' has cloud path [/Users/sterlinghaidt/Desktop/Creative Cloud Files].
                            20140908-202756.419: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-202756.420: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-202756.421: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-202756.422: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.423: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-202756.424: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-202756.424: There is no cloud folder at [], so now initalize it.
                            20140908-202756.424: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-202756.425: ACCController::enableSync switch sync OFF
                            20140908-202756.430: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.433: MControllerDelegate::syncStatus state 11 (CoreSyncStateSyncDisabled)
                            20140908-202756.433: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202756.434: ACCController::updateWithState: 11
                            20140908-202756.435: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.435: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202756.435: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-202756.436: 2014-09-08 20:27:56: File Monitoring was asked to stop on: : Sync turned off
                            20140908-202756.437: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.437: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202756.438: ACCController::updateWithState: 11
                            20140908-202756.438: ACCController::removeAllIcons
                            20140908-202756.438: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Desktop/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-202756.439: ACCController::enableSync completed switch sync OFF
                            20140908-202756.441: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202756.441: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202756.442: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-202756.442: 2014-09-08 20:27:56: File Monitoring was asked to stop on: : Update job
                            20140908-202756.442: WorkerThreads: 8
                            20140908-202756.442: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202756.443: ACCController::enableSync completed switch sync ON
                            20140908-202808.365: MControllerDelegate::updateFilePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt', uploadSetting:0, downloadSetting:0}
                            20140908-202808.366: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202808.367: MControllerDelegate::shutdownRequest
                            20140908-202808.368: ACCController::shutdown
                            20140908-202808.368: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140908-202808.369: 2014-09-08 20:28:08: File Monitoring was asked to stop on: : shutdown
                            20140908-202808.370: Informational: AppHookControllerImpl::onShutdown in
                            20140908-202827.521: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140908-202827.528: ACCController::Init
                            20140908-202827.535: ACCController::Init: init fileState cache
                            20140908-202827.538: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140908-202827.538: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-202827.589: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140908-202827.641: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140908-202827.642: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140908-202827.642: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140908-202827.695: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140908-202827.696: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202827.697: WorkerThreads: 8
                            20140908-202827.698: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202827.698: ACCController::Init: add notification observers
                            20140908-202827.702: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202827.703: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202827.703: ACCController::updateWithState: 11
                            20140908-202827.703: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140908-202827.704: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140908-202827.710: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140908-202827.710: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140908-202827.714: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140908-202827.715: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140908-202827.720: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140908-202827.720: Informational: AppHookControllerImpl::onStartup in
                            20140908-202827.723: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140908-202827.723: Informational: [livetype] onStartup
                            20140908-202827.726: Informational: [livetype] onStartup => success
                            20140908-202827.726: Informational: AppHookControllerImpl::onStartup out
                            20140908-202827.748: ACCController::injectFinderExt
                            20140908-202827.750: ACCController::doInjectFinderExt: injectExt = 1
                            20140908-202827.750: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140908-202827.753: ACCController::finderInitSuccessfull: injectExt:YES
                            20140908-202828.806: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collaboration.whitelisted.urls state=ENABLED
                            20140908-202828.807: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.selfupdate state=ENABLED
                            20140908-202828.807: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.collab state=ENABLED
                            20140908-202828.808: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.defaultFileSync state=ON
                            20140908-202828.808: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.analytics state=ENABLED
                            20140908-202828.808: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.buyNow state=ENABLED
                            20140908-202828.809: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.uninstall state=ENABLED
                            20140908-202828.809: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.launchApp state=ENABLED
                            20140908-202828.810: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.startTrial state=ENABLED
                            20140908-202828.811: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.market.designLibrary state=false
                            20140908-202828.811: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files state=ENABLED
                            20140908-202828.812: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.files.client.type state=V2
                            20140908-202828.812: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts.paiduser state=true
                            20140908-202828.812: GetFeatureStates: found feature=com.adobe.oobe.acc.v1.fonts state=ENABLED
                            20140908-202828.813: MControllerDelegate::enableCollaboration: YES
                            20140908-202828.814: MControllerDelegate::signedIn user: SHAIDT@GMAIL.COM
                            20140908-202828.815: ACCController::signedIn user SHAIDT@GMAIL.COM accessToken 5d0f995385a8c74f6e57082578cbaa06 userId 6E68593446662ED1992016B8@AdobeID
                            20140908-202828.816: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-202828.817: 2014-09-08 20:28:28: File Monitoring was asked to stop on: : Update job
                            20140908-202828.817: WorkerThreads: 8
                            20140908-202828.818: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202828.819: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202828.819: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202828.819: ACCController::updateWithState: 11
                            20140908-202828.820: Informational: AppHookControllerImpl::onSignIn in
                            20140908-202828.821: Informational: [livetype] onSignIn
                            20140908-202828.821: Informational: [livetype]  sendText accc.app.GetConfigParamRequest (longpoll: Requesting longpoll host configuration.)
                            20140908-202828.822: Informational: AppHookControllerImpl::onSignIn out
                            20140908-202828.822: ACCController::signedIn completed user SHAIDT@GMAIL.COM
                            20140908-202828.824: Informational: [livetype] onTextReceived cosy.fonts.GetConfigParamResponse
                            20140908-202829.217: MControllerDelegate::disableSync invoked
                            20140908-202829.218: ACCController::disableSync sync is already disabled
                            20140908-202829.255: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-202829.256: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-202829.256: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-202829.256: Informational: [livetype] syncStatus: OFF
                            20140908-202829.258: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-202829.259: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140908-202829.259: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140908-202829.259: Informational: [livetype] syncStatus: OFF
                            20140908-202917.479: MControllerDelegate::enableSync invoked
                            20140908-202917.480: ACCController::enableSync switch sync ON
                            20140908-202917.482: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.483: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSignedIn (1)
                            20140908-202917.483: ACCController::updateWithState: 1
                            20140908-202917.484: ACCController::updateLocalFolder:
                            20140908-202917.484: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:1, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-202917.485: Old user '' has cloud path [/Users/sterlinghaidt/Creative Cloud Files].
                            20140908-202917.488: New user 'SHAIDT@GMAIL.COM' has cloud path [].
                            20140908-202917.489: No folder owner for current cloud folder, so archive directly to [archived].
                            20140908-202917.490: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.492: Restore cloud folder from [ (SHAIDT@GMAIL.COM)] to [].
                            20140908-202917.492: There is no old cloud folder [ (SHAIDT@GMAIL.COM)] to restore.
                            20140908-202917.493: There is no cloud folder at [], so now initalize it.
                            20140908-202917.493: ERROR: Unable to setup cloud folder at  : . Disable sync.
                            20140908-202917.494: ACCController::enableSync switch sync OFF
                            20140908-202917.494: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.494: BaseControllerDelegate::transformSyncStateForSending: Advising sending disabled state instead of CoreSyncStateSignedIn (1)
                            20140908-202917.495: MControllerDelegate::syncStatus state 11 (CoreSyncStateSignedIn)
                            20140908-202917.495: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.495: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202917.495: ACCController::updateWithState: 11
                            20140908-202917.497: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.497: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202917.498: ACCSync::stopJob: forced: 1, reason: Sync turned off
                            20140908-202917.498: 2014-09-08 20:29:17: File Monitoring was asked to stop on: : Sync turned off
                            20140908-202917.499: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.500: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202917.500: ACCController::updateWithState: 11
                            20140908-202917.501: ACCController::removeAllIcons
                            20140908-202917.501: MControllerDelegate::filePreferences FilePreferencesHolder {isSyncEnabled:0, cloudFolderLocation:'/Users/sterlinghaidt/Creative Cloud Files', uploadSetting:0, downloadSetting:0}
                            20140908-202917.502: ACCController::enableSync completed switch sync OFF
                            20140908-202917.503: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140908-202917.504: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140908-202917.504: ACCSync::stopJob: forced: 1, reason: Update job
                            20140908-202917.505: 2014-09-08 20:29:17: File Monitoring was asked to stop on: : Update job
                            20140908-202917.505: WorkerThreads: 8
                            20140908-202917.506: Notice: setTargetDataRates: 0 upload, 0 download
                            20140908-202917.506: ACCController::enableSync completed switch sync ON
                            20140908-203227.771: ACCController::osSleepWake: NSConcreteNotification 0x7fa213901260 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fa2115e2c50>}
                            20140908-203227.772: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140908-203227.772: 2014-09-08 20:32:27: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140908-203227.773: 2014-09-08 20:32:27: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140908-210242.037: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140908-210242.730: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-210430.202: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-210617.193: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-220702.034: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140908-220702.035: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140908-220702.690: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140908-230500.155: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140909-000500.078: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-000500.672: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-000500.673: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140909-000500.697: Warning: [GUDE]: Request Failed. ErrorCode: 100050 message: Platform Status. (NSPOSIXErrorDomain 50) Network is down. Network is down.
                            20140909-000647.193: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140909-010500.687: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140909-010501.039: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-010501.040: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-010501.040: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140909-020500.156: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140909-020502.079: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-020502.080: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-020502.080: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140909-030500.123: Warning: [GUDE]: Request Failed. ErrorCode: 100050 message: Platform Status. (NSPOSIXErrorDomain 50) Network is down. Network is down.
                            20140909-030503.035: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-030503.036: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-030503.036: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140909-040504.081: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-040504.082: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140909-050500.151: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140909-050505.103: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-050505.104: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140909-060500.178: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140909-060506.016: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-060506.017: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-060506.017: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140909-070500.157: Warning: [GUDE]: Request Failed. ErrorCode: 100051 message: Platform Status. (NSPOSIXErrorDomain 51) Network is unreachable. Network is unreachable.
                            20140909-070507.020: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-070507.021: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140909-080500.195: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140909-080508.093: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
                            20140909-080508.094: Informational: [livetype]  sendText accc.fonts.FontsInfoResponse (0 items)
                            20140909-081840.195: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140909-082201.267: Warning: [GUDE]: Request Failed. ErrorCode: 32 message: Network Error. (kCFErrorDomainCFNetwork 2) Host Unknown. nodename nor servname provided, or not known.
                            20140909-082201.271: ACCController::osSleepWake: NSConcreteNotification 0x7fa211402d30 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fa2115e2c50>}
                            20140909-082313.266: ACCController::shutdown
                            20140909-082313.267: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140909-082313.267: 2014-09-09 08:23:13: File Monitoring was asked to stop on: : shutdown
                            20140909-082313.268: 2014-09-09 08:23:13: File Monitoring was asked to stop on: : shutdown
                            20140909-082313.268: Informational: AppHookControllerImpl::onShutdown in
                            20140909-082313.310: MControllerDelegate::shutdownRequest
                            20140909-104701.091:  OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.1.4.19;
                            20140909-104701.105:  ACCController::Init
                            20140909-104701.121:  ACCController::Init: init fileState cache
                            20140909-104701.133:  VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140909-104701.136:  VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140909-104701.186:  VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140909-104701.187:  VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140909-104701.187:  VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140909-104701.238:  VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140909-104701.238:  CsHasBlackVelvetBeenUsed(): found a database: 35973b630c36e6bd78f72af2e465b554.db
                            20140909-104701.244:  CoreSyncSwitcher::sendSwitchMessage: sent message
                            20140909-104701.247:  MControllerDelegate::terminateApplication
                            20140909-104701.255:  Informational: AppHookControllerImpl::onShutdown in
                            20140909-104701.255:  Informational: AppHookControllerImpl::onShutdown out
                            20140909-104701.256:  ACCController::appTerminate
                            20140909-104701.256:  ACCController::removeAllIcons
                            20140909-104701.256:  ACCController::dealloc
                            20140909-104702.334: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140909-104702.343: ACCController::Init
                            20140909-104702.350: ACCController::Init: init fileState cache
                            20140909-104702.354: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140909-104702.355: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140909-104702.406: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140909-104702.406: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140909-104702.406: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140909-104702.458: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140909-104702.459: Notice: setTargetDataRates: 0 upload, 0 download
                            20140909-104702.460: WorkerThreads: 8
                            20140909-104702.460: Notice: setTargetDataRates: 0 upload, 0 download
                            20140909-104702.461: ACCController::Init: add notification observers
                            20140909-104702.464: CJournalDB::Init: schema differs: incorrect number of tables
                            20140909-104702.466: CJournalDB::_create: successfully created 5 tables
                            20140909-104702.468: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140909-104702.469: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140909-104702.469: ACCController::updateWithState: 11
                            20140909-104702.470: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140909-104702.470: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140909-104702.477: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140909-104702.477: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140909-104702.482: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140909-104702.482: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140909-104702.487: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140909-104702.488: Informational: AppHookControllerImpl::onStartup in
                            20140909-104702.491: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140909-104702.491: Informational: [livetype] onStartup
                            20140909-104702.496: Informational: [livetype] onStartup => success
                            20140909-104702.496: Informational: AppHookControllerImpl::onStartup out
                            20140909-104702.521: ACCController::injectFinderExt
                            20140909-104702.522: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-104702.523: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140909-104702.544: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140909-104702.621: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140909-104702.644: ACCController::finderInitSuccessfull: injectExt:YES
                            20140909-104702.646: ACCController::finderInitSuccessfull: injectExt:YES
                            20140909-104702.647: ACCFinderExtensionController::init: intialization succsessfull
                            20140909-104703.539: MControllerDelegate::invalidateAccessToken
                            20140909-104703.540: ACCController::invalidateAccessToken
                            20140909-104703.540: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140909-104703.541: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140909-104703.541: Informational: [livetype] onInvalidateAccessToken
                            20140909-104703.542: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140909-104703.542: ACCController::invalidateAccessToken completed
                            20140909-104703.584: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140909-104703.586: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140909-104703.586: Informational: [livetype] syncStatus: OFF
                            20140909-104718.588: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-104718.588: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140909-104718.589: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140909-104752.126: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-104752.126: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140909-104752.127: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140909-105118.820: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-105118.821: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140909-105118.821: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140909-105959.105: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-105959.105: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140909-105959.106: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140909-110459.080: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-110459.080: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140909-110459.081: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140909-110830.797: ACCController::osSleepWake: NSConcreteNotification 0x7faea1447bd0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7faea3402760>}
                            20140909-110830.798: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-110830.800: 2014-09-09 11:08:30: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-110830.801: 2014-09-09 11:08:30: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-111005.284: ACCController::osSleepWake: NSConcreteNotification 0x7faea1653e30 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7faea3402760>}
                            20140909-111904.507: ACCController::shutdown
                            20140909-111904.507: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140909-111904.508: 2014-09-09 11:19:04: File Monitoring was asked to stop on: : shutdown
                            20140909-111904.509: 2014-09-09 11:19:04: File Monitoring was asked to stop on: : shutdown
                            20140909-111904.509: Informational: AppHookControllerImpl::onShutdown in
                            20140909-111904.529: MControllerDelegate::shutdownRequest
                            20140909-111904.556: Informational: [livetype] onShutdown
                            20140909-111904.556: Informational: [livetype]  disableFontSync
                            20140909-111904.557: Informational: [livetype] deactivated all fonts
                            20140909-111904.557: Informational: AppHookControllerImpl::onShutdown out
                            20140909-111904.558: ACCController::removeAllIcons
                            20140909-111904.558: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140909-121205.134: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140909-121205.160: ACCController::Init
                            20140909-121205.169: ACCController::Init: init fileState cache
                            20140909-121205.178: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140909-121205.182: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140909-121205.233: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140909-121205.234: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140909-121205.234: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140909-121205.289: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140909-121205.292: Notice: setTargetDataRates: 0 upload, 0 download
                            20140909-121205.293: WorkerThreads: 8
                            20140909-121205.294: Notice: setTargetDataRates: 0 upload, 0 download
                            20140909-121205.295: ACCController::Init: add notification observers
                            20140909-121205.302: CJournalDB::Init: schema differs: incorrect number of tables
                            20140909-121205.303: CJournalDB::_create: successfully created 5 tables
                            20140909-121205.307: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140909-121205.308: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140909-121205.308: ACCController::updateWithState: 11
                            20140909-121205.308: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140909-121205.309: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140909-121205.335: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140909-121205.335: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140909-121205.356: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140909-121205.357: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140909-121205.370: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140909-121205.371: Informational: AppHookControllerImpl::onStartup in
                            20140909-121205.375: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140909-121205.376: Informational: [livetype] onStartup
                            20140909-121205.378: Informational: [livetype] onStartup => success
                            20140909-121205.378: Informational: AppHookControllerImpl::onStartup out
                            20140909-121205.426: ACCController::injectFinderExt
                            20140909-121205.427: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-121205.427: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140909-121205.441: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140909-121205.501: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140909-121205.526: ACCController::finderInitSuccessfull: injectExt:YES
                            20140909-121205.528: ACCController::finderInitSuccessfull: injectExt:YES
                            20140909-121205.529: ACCFinderExtensionController::init: intialization succsessfull
                            20140909-121208.917: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140909-121208.951: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140909-121208.951: Informational: [livetype] syncStatus: OFF
                            20140909-121311.293: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-121311.293: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140909-121311.294: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140909-122806.430: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-122806.430: ACCController::doInjectFinderExt: appIdentifier: com.apple.QuickTimePlayerX
                            20140909-122806.430: ACCController::doInjectFinderExt: app identifier: com.apple.QuickTimePlayerX not equal to com.apple.finder
                            20140909-123546.322: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-123546.322: ACCController::doInjectFinderExt: appIdentifier: com.adobe.PDApp
                            20140909-123546.322: ACCController::doInjectFinderExt: app identifier: com.adobe.PDApp not equal to com.apple.finder
                            20140909-123552.132: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-123552.132: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140909-123552.133: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140909-123603.357: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-123603.357: ACCController::doInjectFinderExt: appIdentifier: com.apple.Notes
                            20140909-123603.358: ACCController::doInjectFinderExt: app identifier: com.apple.Notes not equal to com.apple.finder
                            20140909-123737.539: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-123737.540: ACCController::doInjectFinderExt: appIdentifier: com.apple.Notes
                            20140909-123737.540: ACCController::doInjectFinderExt: app identifier: com.apple.Notes not equal to com.apple.finder
                            20140909-131234.993: ACCController::osSleepWake: NSConcreteNotification 0x7fdbeba02d90 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-131234.994: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-131234.997: 2014-09-09 13:12:34: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-131339.279: ACCController::osSleepWake: NSConcreteNotification 0x7fdbebc00000 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-131649.232: ACCController::osSleepWake: NSConcreteNotification 0x7fdbebc00ec0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-131649.233: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-131649.233: 2014-09-09 13:16:49: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-131649.234: 2014-09-09 13:16:49: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-132034.275: ACCController::osSleepWake: NSConcreteNotification 0x7fdbeb8a2f50 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-134523.883: ACCController::osSleepWake: NSConcreteNotification 0x7fdbe9e036c0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-134523.884: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-134523.885: 2014-09-09 13:45:23: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-134531.345: ACCController::osSleepWake: NSConcreteNotification 0x7fdbebb02fa0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-134534.995: ACCController::osSleepWake: NSConcreteNotification 0x7fdbeba03000 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-134534.995: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-134534.996: 2014-09-09 13:45:34: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-134534.997: 2014-09-09 13:45:34: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-134939.283: ACCController::osSleepWake: NSConcreteNotification 0x7fdbeba02d90 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-145004.361: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-145004.362: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140909-145004.362: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140909-145056.825: ACCController::osSleepWake: NSConcreteNotification 0x7fdbeba00090 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-145056.826: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-145056.827: 2014-09-09 14:50:56: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-145057.004: ACCController::osSleepWake: NSConcreteNotification 0x7fdbebc004d0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-145059.441: ACCController::osSleepWake: NSConcreteNotification 0x7fdbeb905fd0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-145059.442: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-145059.443: 2014-09-09 14:50:59: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-145201.830: ACCController::osSleepWake: NSConcreteNotification 0x7fdbebc00f90 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-145817.164: ACCController::osSleepWake: NSConcreteNotification 0x7fdbebb01910 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-145817.165: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-145817.166: 2014-09-09 14:58:17: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-145844.313: ACCController::osSleepWake: NSConcreteNotification 0x7fdbeb905fd0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-151707.606: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-151707.607: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140909-151707.607: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140909-155738.382: ACCController::osSleepWake: NSConcreteNotification 0x7fdbebc00f90 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-155738.383: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-155738.383: 2014-09-09 15:57:38: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-155738.384: 2014-09-09 15:57:38: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-155821.447: ACCController::osSleepWake: NSConcreteNotification 0x7fdbeb8a2f50 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-155823.525: ACCController::osSleepWake: NSConcreteNotification 0x7fdbebc00ec0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-155823.526: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-155823.526: 2014-09-09 15:58:23: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-155823.527: 2014-09-09 15:58:23: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-160615.338: ACCController::osSleepWake: NSConcreteNotification 0x7fdbebc00f20 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-163526.937: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-163526.938: ACCController::doInjectFinderExt: appIdentifier: com.apple.Notes
                            20140909-163526.938: ACCController::doInjectFinderExt: app identifier: com.apple.Notes not equal to com.apple.finder
                            20140909-165937.993: ACCController::osSleepWake: NSConcreteNotification 0x7fdbebc00f20 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-165937.994: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-165937.995: 2014-09-09 16:59:37: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-170019.799: ACCController::osSleepWake: NSConcreteNotification 0x7fdbe9f907c0 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-170650.871: ACCController::osSleepWake: NSConcreteNotification 0x7fdbeb8a3670 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-170650.872: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140909-170650.873: 2014-09-09 17:06:50: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140909-170743.314: ACCController::osSleepWake: NSConcreteNotification 0x7fdbeba00090 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7fdbeb87b0c0>}
                            20140909-171440.456: ACCController::shutdown
                            20140909-171440.457: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140909-171440.457: 2014-09-09 17:14:40: File Monitoring was asked to stop on: : shutdown
                            20140909-171440.458: Informational: AppHookControllerImpl::onShutdown in
                            20140909-171440.465: Informational: [livetype] onShutdown
                            20140909-171440.465: Informational: [livetype]  disableFontSync
                            20140909-171440.466: Informational: [livetype] deactivated all fonts
                            20140909-171440.467: Informational: AppHookControllerImpl::onShutdown out
                            20140909-171440.468: ACCController::removeAllIcons
                            20140909-174508.811: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140909-174508.825: ACCController::Init
                            20140909-174508.838: ACCController::Init: init fileState cache
                            20140909-174508.844: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140909-174508.847: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140909-174508.898: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140909-174508.899: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140909-174508.899: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140909-174508.952: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140909-174508.953: Notice: setTargetDataRates: 0 upload, 0 download
                            20140909-174508.954: WorkerThreads: 8
                            20140909-174508.955: Notice: setTargetDataRates: 0 upload, 0 download
                            20140909-174508.956: ACCController::Init: add notification observers
                            20140909-174508.960: CJournalDB::Init: schema differs: incorrect number of tables
                            20140909-174508.962: CJournalDB::_create: successfully created 5 tables
                            20140909-174508.966: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140909-174508.967: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140909-174508.968: ACCController::updateWithState: 11
                            20140909-174508.969: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140909-174508.969: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140909-174508.980: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140909-174508.981: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140909-174508.988: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140909-174508.989: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140909-174508.996: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140909-174508.997: Informational: AppHookControllerImpl::onStartup in
                            20140909-174509.002: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140909-174509.004: Informational: [livetype] onStartup
                            20140909-174509.006: Informational: [livetype] onStartup => success
                            20140909-174509.007: Informational: AppHookControllerImpl::onStartup out
                            20140909-174509.077: ACCController::injectFinderExt
                            20140909-174509.079: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-174509.080: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140909-174509.111: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140909-174509.202: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140909-174509.223: ACCController::finderInitSuccessfull: injectExt:YES
                            20140909-174509.227: ACCController::finderInitSuccessfull: injectExt:YES
                            20140909-174509.228: ACCFinderExtensionController::init: intialization succsessfull
                            20140909-174510.069: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140909-174510.070: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140909-174510.071: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140909-174510.072: Informational: [livetype] syncStatus: OFF
                            20140909-174541.758: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-174541.758: ACCController::doInjectFinderExt: appIdentifier: com.apple.appstore
                            20140909-174541.759: ACCController::doInjectFinderExt: app identifier: com.apple.appstore not equal to com.apple.finder
                            20140909-174904.137: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-174904.138: ACCController::doInjectFinderExt: appIdentifier: com.apple.iTunes
                            20140909-174904.138: ACCController::doInjectFinderExt: app identifier: com.apple.iTunes not equal to com.apple.finder
                            20140909-180050.563: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-180050.564: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140909-180050.564: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140909-181303.345: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-181303.346: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140909-181303.346: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140909-190012.885: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-190012.886: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140909-190012.886: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140909-202522.069: ACCController::doInjectFinderExt: injectExt = 1
                            20140909-202522.070: ACCController::doInjectFinderExt: appIdentifier: com.adobe.flashplayer.installmanager
                            20140909-202522.070: ACCController::doInjectFinderExt: app identifier: com.adobe.flashplayer.installmanager not equal to com.apple.finder
                            20140910-075947.320: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-075947.321: ACCController::doInjectFinderExt: appIdentifier: com.skype.skype
                            20140910-075947.321: ACCController::doInjectFinderExt: app identifier: com.skype.skype not equal to com.apple.finder
                            20140910-080701.076: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-080701.077: ACCController::doInjectFinderExt: appIdentifier: com.getdoxie.doxie
                            20140910-080701.077: ACCController::doInjectFinderExt: app identifier: com.getdoxie.doxie not equal to com.apple.finder
                            20140910-081130.477: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-081130.477: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140910-081130.478: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140910-084504.168: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-084504.169: ACCController::doInjectFinderExt: appIdentifier: com.apple.Preview
                            20140910-084504.169: ACCController::doInjectFinderExt: app identifier: com.apple.Preview not equal to com.apple.finder
                            20140910-084724.589: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-084724.590: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140910-084724.590: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140910-085450.248: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-085450.249: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140910-085450.249: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140910-090705.154: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-090705.155: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140910-090705.155: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140910-090732.896: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-090732.897: ACCController::doInjectFinderExt: appIdentifier: com.cocoatech.PathFinder
                            20140910-090732.897: ACCController::doInjectFinderExt: app identifier: com.cocoatech.PathFinder not equal to com.apple.finder
                            20140910-092655.361: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-092655.361: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140910-092655.362: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140910-093009.727: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-093009.727: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140910-093009.727: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140910-093307.776: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-093307.777: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140910-093307.777: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140910-093430.033: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-093430.033: ACCController::doInjectFinderExt: appIdentifier: com.dashlane.Dashlane
                            20140910-093430.034: ACCController::doInjectFinderExt: app identifier: com.dashlane.Dashlane not equal to com.apple.finder
                            20140910-093710.743: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-093710.744: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140910-093710.744: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140910-100853.304: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-100853.304: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140910-100853.305: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140910-101036.202: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-101036.202: ACCController::doInjectFinderExt: appIdentifier: com.dashlane.Dashlane
                            20140910-101036.202: ACCController::doInjectFinderExt: app identifier: com.dashlane.Dashlane not equal to com.apple.finder
                            20140910-101625.971: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-101625.971: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140910-101625.971: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140910-101728.605: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-101728.606: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140910-101728.606: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140910-101853.844: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-101853.845: ACCController::doInjectFinderExt: appIdentifier: com.intuit.Quicken.2015
                            20140910-101853.845: ACCController::doInjectFinderExt: app identifier: com.intuit.Quicken.2015 not equal to com.apple.finder
                            20140910-124302.557: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-124302.558: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Photoshop
                            20140910-124302.558: ACCController::doInjectFinderExt: app identifier: com.adobe.Photoshop not equal to com.apple.finder
                            20140910-124333.362: ACCController::shutdown
                            20140910-124333.363: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140910-124333.460: 2014-09-10 12:43:33: File Monitoring was asked to stop on: : shutdown
                            20140910-124333.461: 2014-09-10 12:43:33: File Monitoring was asked to stop on: : shutdown
                            20140910-124333.461: Informational: AppHookControllerImpl::onShutdown in
                            20140910-124333.503: MControllerDelegate::shutdownRequest
                            20140910-124333.543: Informational: [livetype] onShutdown
                            20140910-124333.544: Informational: [livetype]  disableFontSync
                            20140910-124333.544: Informational: [livetype] deactivated all fonts
                            20140910-124333.545: Informational: AppHookControllerImpl::onShutdown out
                            20140910-124333.546: ACCController::removeAllIcons
                            20140910-124333.547: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140910-165030.128: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140910-165030.143: ACCController::Init
                            20140910-165030.154: ACCController::Init: init fileState cache
                            20140910-165030.194: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140910-165030.200: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140910-165030.251: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140910-165030.252: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140910-165030.252: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140910-165030.306: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140910-165030.307: Notice: setTargetDataRates: 0 upload, 0 download
                            20140910-165030.308: WorkerThreads: 8
                            20140910-165030.309: Notice: setTargetDataRates: 0 upload, 0 download
                            20140910-165030.336: ACCController::Init: add notification observers
                            20140910-165030.342: CJournalDB::Init: schema differs: incorrect number of tables
                            20140910-165030.344: CJournalDB::_create: successfully created 5 tables
                            20140910-165030.543: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140910-165030.545: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140910-165030.545: ACCController::updateWithState: 11
                            20140910-165030.546: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140910-165030.546: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140910-165030.556: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140910-165030.556: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140910-165030.564: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140910-165030.564: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140910-165030.577: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140910-165030.578: Informational: AppHookControllerImpl::onStartup in
                            20140910-165030.583: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140910-165030.583: Informational: [livetype] onStartup
                            20140910-165030.585: Informational: [livetype] onStartup => success
                            20140910-165030.586: Informational: AppHookControllerImpl::onStartup out
                            20140910-165030.614: ACCController::injectFinderExt
                            20140910-165030.616: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-165030.617: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140910-165030.684: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140910-165030.758: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140910-165030.782: ACCController::finderInitSuccessfull: injectExt:YES
                            20140910-165030.785: ACCController::finderInitSuccessfull: injectExt:YES
                            20140910-165030.786: ACCFinderExtensionController::init: intialization succsessfull
                            20140910-165037.446: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140910-165037.447: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140910-165037.448: Informational: [livetype] syncStatus: OFF
                            20140910-165120.755: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-165120.755: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140910-165120.756: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140910-181115.847: ACCController::osSleepWake: NSConcreteNotification 0x7f8418e452e0 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7f8418f27410>}
                            20140910-181115.847: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140910-181115.907: 2014-09-10 18:11:15: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140910-182704.923: ACCController::osSleepWake: NSConcreteNotification 0x7f8418d07430 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f8418f27410>}
                            20140910-195016.861: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-195016.861: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140910-195016.862: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140910-195538.697: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-195538.698: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140910-195538.698: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140910-195736.432: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-195736.432: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140910-195736.433: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140910-200614.581: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-200614.582: ACCController::doInjectFinderExt: appIdentifier: com.apple.iPhoto
                            20140910-200614.582: ACCController::doInjectFinderExt: app identifier: com.apple.iPhoto not equal to com.apple.finder
                            20140910-212317.579: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-212317.580: ACCController::doInjectFinderExt: appIdentifier: com.dashlane.Dashlane
                            20140910-212317.580: ACCController::doInjectFinderExt: app identifier: com.dashlane.Dashlane not equal to com.apple.finder
                            20140910-212332.168: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-212332.168: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140910-212332.169: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140910-212614.008: ACCController::doInjectFinderExt: injectExt = 1
                            20140910-212614.008: ACCController::doInjectFinderExt: appIdentifier: com.intuit.Quicken.2015
                            20140910-212614.008: ACCController::doInjectFinderExt: app identifier: com.intuit.Quicken.2015 not equal to com.apple.finder
                            20140911-091743.804: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-091743.810: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140911-091743.811: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140911-091759.406: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-091759.407: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140911-091759.407: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140911-092533.311: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-092533.311: ACCController::doInjectFinderExt: appIdentifier: com.apple.Safari
                            20140911-092533.312: ACCController::doInjectFinderExt: app identifier: com.apple.Safari not equal to com.apple.finder
                            20140911-093003.057: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-093003.057: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140911-093003.058: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140911-094107.980: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-094107.980: ACCController::doInjectFinderExt: appIdentifier: com.dashlane.Dashlane
                            20140911-094107.981: ACCController::doInjectFinderExt: app identifier: com.dashlane.Dashlane not equal to com.apple.finder
                            20140911-094502.430: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-094502.430: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140911-094502.431: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140911-094648.440: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-094648.441: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140911-094648.441: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140911-094943.249: ACCController::osSleepWake: NSConcreteNotification 0x7f8418d05d10 {name = NSWorkspaceWillSleepNotification; object = <NSWorkspace: 0x7f8418f27410>}
                            20140911-094943.249: ACCSync::stopJob: forced: 1, reason: Mac goes to sleep
                            20140911-094943.250: 2014-09-11 09:49:43: File Monitoring was asked to stop on: : Mac goes to sleep
                            20140911-095305.034: ACCController::osSleepWake: NSConcreteNotification 0x7f8418d06170 {name = NSWorkspaceDidWakeNotification; object = <NSWorkspace: 0x7f8418f27410>}
                            20140911-105639.057: ACCController::shutdown
                            20140911-105639.058: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140911-105639.058: 2014-09-11 10:56:39: File Monitoring was asked to stop on: : shutdown
                            20140911-105639.059: 2014-09-11 10:56:39: File Monitoring was asked to stop on: : shutdown
                            20140911-105639.059: Informational: AppHookControllerImpl::onShutdown in
                            20140911-105639.165: MControllerDelegate::shutdownRequest
                            20140911-105639.186: Informational: [livetype] onShutdown
                            20140911-105639.186: Informational: [livetype]  disableFontSync
                            20140911-105639.187: Informational: [livetype] deactivated all fonts
                            20140911-105639.188: Informational: AppHookControllerImpl::onShutdown out
                            20140911-105639.189: ACCController::removeAllIcons
                            20140911-105639.195: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140911-110822.017: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140911-110822.047: ACCController::Init
                            20140911-110822.057: ACCController::Init: init fileState cache
                            20140911-110822.079: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140911-110822.081: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140911-110822.133: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140911-110822.134: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140911-110822.134: VulcanMessageAdapter::VulcanMessageAdapter : refresh pending, wait...
                            20140911-110822.187: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140911-110822.188: Notice: setTargetDataRates: 0 upload, 0 download
                            20140911-110822.190: WorkerThreads: 8
                            20140911-110822.190: Notice: setTargetDataRates: 0 upload, 0 download
                            20140911-110822.197: ACCController::Init: add notification observers
                            20140911-110822.201: CJournalDB::Init: schema differs: incorrect number of tables
                            20140911-110822.203: CJournalDB::_create: successfully created 5 tables
                            20140911-110822.228: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140911-110822.229: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140911-110822.230: ACCController::updateWithState: 11
                            20140911-110822.230: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140911-110822.231: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140911-110822.240: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140911-110822.240: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140911-110822.248: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140911-110822.249: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140911-110822.256: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140911-110822.257: Informational: AppHookControllerImpl::onStartup in
                            20140911-110822.261: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140911-110822.261: Informational: [livetype] onStartup
                            20140911-110822.264: Informational: [livetype] onStartup => success
                            20140911-110822.264: Informational: AppHookControllerImpl::onStartup out
                            20140911-110822.297: ACCController::injectFinderExt
                            20140911-110822.299: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-110822.299: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140911-110822.315: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140911-110822.380: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140911-110822.399: ACCController::finderInitSuccessfull: injectExt:YES
                            20140911-110822.402: ACCController::finderInitSuccessfull: injectExt:YES
                            20140911-110822.403: ACCFinderExtensionController::init: intialization succsessfull
                            20140911-110823.321: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140911-110823.330: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140911-110823.331: Informational: [livetype] syncStatus: OFF
                            20140911-110857.722: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-110857.723: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140911-110857.723: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140911-110958.211: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-110958.211: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140911-110958.212: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140911-111021.119: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-111021.119: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140911-111021.120: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            20140911-111208.720: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-111208.720: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140911-111208.721: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140911-114532.412: ACCController::shutdown
                            20140911-114532.412: ACCSync::stopJob: forced: 1, reason: shutdown
                            20140911-114532.414: 2014-09-11 11:45:32: File Monitoring was asked to stop on: : shutdown
                            20140911-114532.415: Informational: AppHookControllerImpl::onShutdown in
                            20140911-114532.432: MControllerDelegate::shutdownRequest
                            20140911-114532.459: Informational: [livetype] onShutdown
                            20140911-114532.459: Informational: [livetype]  disableFontSync
                            20140911-114532.460: Informational: [livetype] deactivated all fonts
                            20140911-114532.460: Informational: AppHookControllerImpl::onShutdown out
                            20140911-114532.461: ACCController::removeAllIcons
                            20140911-114532.461: ACCController::removeRemoteStateCache: Failed to notify finder extension
                            20140911-131224.204: OSVer: Version 10.9.4 (Build 13E28); Arch: i486; AppVer: 1.3.0.342;
                            20140911-131224.235: ACCController::Init
                            20140911-131224.247: ACCController::Init: init fileState cache
                            20140911-131224.266: VulcanMessageAdapter::VulcanMessageAdapter create IVulcanMessageDispatcher
                            20140911-131224.268: VulcanMessageAdapter::VulcanMessageAdapter : not ready, wait
                            20140911-131224.319: VulcanMessageAdapter::VulcanMessageAdapter : Refreshing Endpoints
                            20140911-131224.320: VulcanMessageAdapter::refreshEndPointsCallback : switching to point to point
                            20140911-131224.320: VulcanMessageAdapter::VulcanMessageAdapter : initialization done
                            20140911-131224.321: Notice: setTargetDataRates: 0 upload, 0 download
                            20140911-131224.323: WorkerThreads: 8
                            20140911-131224.323: Notice: setTargetDataRates: 0 upload, 0 download
                            20140911-131224.324: ACCController::Init: add notification observers
                            20140911-131224.329: CJournalDB::Init: schema differs: incorrect number of tables
                            20140911-131224.331: CJournalDB::_create: successfully created 5 tables
                            20140911-131224.378: MControllerDelegate::quota {storageFree:-1, storageTotal:-1}
                            20140911-131224.379: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncDisabled (11)
                            20140911-131224.380: ACCController::updateWithState: 11
                            20140911-131224.380: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins'
                            20140911-131224.381: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient'
                            20140911-131224.392: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ANSClient/ANSClient.framework'
                            20140911-131224.393: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin'
                            20140911-131224.401: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/ExchangePlugin/ExchangePlugin.framework'
                            20140911-131224.401: Informational: Loading plugins from folder: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType'
                            20140911-131224.409: Informational: Plugin loaded: '/Applications/Utilities/Adobe Creative Cloud/CoreSync/plugins/LiveType/LiveType.framework'
                            20140911-131224.410: Informational: AppHookControllerImpl::onStartup in
                            20140911-131224.414: Informational: [ExchangePlugin] (EPTaskManager.cpp, 389 ) --initMainloop: initMainloop begin, and begin check if core lib is loaded..., version is 1.2.0.33
                            20140911-131224.414: Informational: [livetype] onStartup
                            20140911-131224.417: Informational: [livetype] onStartup => success
                            20140911-131224.418: Informational: AppHookControllerImpl::onStartup out
                            20140911-131224.451: ACCController::injectFinderExt
                            20140911-131224.453: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-131224.453: ACCController::doInjectFinderExt: appIdentifier: com.apple.finder
                            20140911-131224.476: ACCController::doInjectFinderExt: launch helper tool at path:/Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/MacOS/ACCFinderBundleLo ader_64
                            20140911-131224.556: ACCFinderExtenson::loadBundle: path = /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/Resources/ACCFinderBundleLoader_64.app/Contents/Resources/ACCFinderInne rExtesion.bundle
                            20140911-131224.576: ACCController::finderInitSuccessfull: injectExt:YES
                            20140911-131224.578: ACCController::finderInitSuccessfull: injectExt:YES
                            20140911-131224.580: ACCFinderExtensionController::init: intialization succsessfull
                            20140911-131225.472: MControllerDelegate::invalidateAccessToken
                            20140911-131225.473: ACCController::invalidateAccessToken
                            20140911-131225.473: Informational: AppHookControllerImpl::onInvalidateAccessToken in
                            20140911-131225.474: Error: [ExchangePlugin] (ExchangeAppHook.cpp, 173 ) --onInvalidateAccessToken: Invaid access token!
                            20140911-131225.474: Informational: [livetype] onInvalidateAccessToken
                            20140911-131225.475: Informational: AppHookControllerImpl::onInvalidateAccessToken out
                            20140911-131225.475: ACCController::invalidateAccessToken completed
                            20140911-131231.497: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140911-131231.498: Informational: [livetype] onTextReceived cosy.fonts.UpdatePreferencesRequest
                            20140911-131231.498: Informational: [livetype]  sendText accc.fonts.UpdatePreferencesResponse (success)
                            20140911-131231.499: Informational: [livetype] syncStatus: OFF
                            20140911-131628.840: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-131628.841: ACCController::doInjectFinderExt: appIdentifier: com.apple.AddressBook
                            20140911-131628.841: ACCController::doInjectFinderExt: app identifier: com.apple.AddressBook not equal to com.apple.finder
                            20140911-131957.768: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-131957.769: ACCController::doInjectFinderExt: appIdentifier: com.apple.mail
                            20140911-131957.769: ACCController::doInjectFinderExt: app identifier: com.apple.mail not equal to com.apple.finder
                            20140911-132227.646: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-132227.647: ACCController::doInjectFinderExt: appIdentifier: org.mozilla.firefox
                            20140911-132227.647: ACCController::doInjectFinderExt: app identifier: org.mozilla.firefox not equal to com.apple.finder
                            20140911-132449.762: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-132449.763: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140911-132449.763: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140911-132500.343: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-132500.344: ACCController::doInjectFinderExt: appIdentifier: com.adobe.Acrobat.Pro
                            20140911-132500.344: ACCController::doInjectFinderExt: app identifier: com.adobe.Acrobat.Pro not equal to com.apple.finder
                            20140911-132604.283: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-132604.283: ACCController::doInjectFinderExt: appIdentifier: com.apple.automator.SaveasAdobePDF
                            20140911-132604.283: ACCController::doInjectFinderExt: app identifier: com.apple.automator.SaveasAdobePDF not equal to com.apple.finder
                            20140911-133001.020: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-133001.020: ACCController::doInjectFinderExt: appIdentifier: com.microsoft.Word
                            20140911-133001.021: ACCController::doInjectFinderExt: app identifier: com.microsoft.Word not equal to com.apple.finder
                            20140911-134234.091: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-134234.092: ACCController::doInjectFinderExt: appIdentifier: com.apple.print.PrinterProxy
                            20140911-134234.092: ACCController::doInjectFinderExt: app identifier: com.apple.print.PrinterProxy not equal to com.apple.finder
                            20140911-134704.231: ACCController::doInjectFinderExt: injectExt = 1
                            20140911-134704.231: ACCController::doInjectFinderExt: appIdentifier: com.apple.iCal
                            20140911-134704.231: ACCController::doInjectFinderExt: app identifier: com.apple.iCal not equal to com.apple.finder
                            I opened and copied all the logs.  Seems overwhelming.  Hope it helps.
                            • 11. Re: problems with synch being ON
                              N.Goodall Employee Hosts
                              Hi Zoharatist,
                              Looking at the logs there are many lines like this:
                              New user 'SHAIDT@GMAIL.COM' has cloud path [].
                              This is an indication that CoreSync has been unable to pick up the correct path for your CC Files. This indicates there is still a faulty options.tix file present on your machine.
                              Can you please make sure you have fully exited Creative Cloud Desktop and then delete the option.tix file - rm ~/Library/Application\ Support/Adobe/CoreSync/options.tix
                              Regards,
                              Nick
                              • 12. Re: problems with synch being ON
                                dude man
                                Me too, same problem. CC lets me click the file synch "on" button but after I exit the dialogue, it goes back to "off".
                                I want to access some royalty free resources on CC, but since the synching don't work, it aint happening
                                • 13. Re: problems with synch being ON
                                  Elba Sobrino Adobe Employee
                                  Please follow the complete instructions in this KB article:
                                  Creative Cloud desktop app | Unable to turn-on File sync
                                  Hopefully this will resolve your issue.
                                  Elba
                                  • 14. Re: problems with synch being ON
                                    lingismyname
                                    Hi Elba,
                                    Just wanted to post and say that I had problems with syncing on my mac and the instructions you linked to worked for me. Thank you!
                                    Ling
                                    • 15. Re: problems with synch being ON
                                      dude man Community Member
                                      Thanks for the respons.
                                      I’ll check it out.
                                      Med vänlig hälsning / Best regards,
                                      Torgny
                                      Torgny Näsman
                                      mobile: +46 (0)73 3893 288  |  office: +46 (0)8 5000 11 55  |  www.progrezzo.com
                                      16 sep 2014 kl. 18:11 skrev Elba Sobrino <forums_noreply@adobe.com>:
                                      created by Elba Sobrino in File Hosting, Syncing, and Collaboration - View the full discussion
                                      Elba
                                      Please note that the Adobe Forums do not accept email attachments. If you want to embed a screen image in your message please visit the thread in the forum to embed the image at https://forums.adobe.com/message/6734892#6734892
                                      Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:
                                      To unsubscribe from this thread, please visit the message page at . In the Actions box on the right, click the Stop Email Notifications link.
                                      Start a new discussion in File Hosting, Syncing, and Collaboration by email or at Adobe Community
                                      For more information about maintaining your forum email notifications please go to http://forums.adobe.com/thread/416458?tstart=0.
