WorkBench New Process Created in ES4 invoke will throws below exception
manojkumar Sep 5, 2014 12:49 AMError Occured while invoke new process created from work bench server ES4. If we import process from ES2 to ES4 same process will working fine
can any one help on the
LOGGING INFORMATION
ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error.
at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:152)
at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassi vationInterceptor.java:53)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTran sactionBMTAdapterBean.java:197)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionBMTAdapter_ 3af08fdf.doBMT(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:95)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:158)
at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:131)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:93)
at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:22 5)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:69)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:893)
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker. java:350)
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:158)
Caused by: com.adobe.livecycle.output.exception.OutputException: com.adobe.printSubmitter.PrintException: ALC-FRM-001-013: XMLFormFactory, PAexecute failure: "(com.adobe.document.xmlform.ReturnStatus@369d91fb) XMLForm, render : 12309, XFA template Model is empty." in com.adobe.livecycle.formsservice.exception.RenderFormException, cause: ALC-FRM-001-013: XMLFormFactory, PAexecute failure: "(com.adobe.document.xmlform.ReturnStatus@369d91fb) XMLForm, render : 12309, XFA template Model is empty." in com.adobe.livecycle.formsservice.exception.FormServerException
at com.adobe.printSubmitter.PrintServer.execute(PrintServer.java:678)
at com.adobe.printSubmitter.PrintServer.submit(PrintServer.java:233)
at com.adobe.printSubmitter.service.OutputServiceImpl.generateOutputInTxn(OutputServiceImpl. java:279)
at com.adobe.printSubmitter.service.OutputServiceImpl.generatePDFOutputInTxn(OutputServiceIm pl.java:438)
at com.adobe.printSubmitter.service.OutputServiceImpl.access$100(OutputServiceImpl.java:85)
at com.adobe.printSubmitter.service.OutputServiceImpl$2.doInTransaction(OutputServiceImpl.ja va:387)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew (EjbTransactionBMTAdapterBean.java:218)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionBMTAdapter_ 3af08fdf.doRequiresNew(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:133)
at com.adobe.idp.dsc.transaction.impl.DefaultTransactionTemplate.execute(DefaultTransactionT emplate.java:79)
at com.adobe.printSubmitter.service.OutputServiceImpl.invokeGeneratePDFOutputWithSMT(OutputS erviceImpl.java:382)
at com.adobe.printSubmitter.service.OutputServiceImpl.generatePDFOutput2(OutputServiceImpl.j ava:361)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
... 98 more
Caused by: com.adobe.printSubmitter.PrintException: ALC-FRM-001-013: XMLFormFactory, PAexecute failure: "(com.adobe.document.xmlform.ReturnStatus@369d91fb) XMLForm, render : 12309, XFA template Model is empty." in com.adobe.livecycle.formsservice.exception.RenderFormException, cause: ALC-FRM-001-013: XMLFormFactory, PAexecute failure: "(com.adobe.document.xmlform.ReturnStatus@369d91fb) XMLForm, render : 12309, XFA template Model is empty." in com.adobe.livecycle.formsservice.exception.FormServerException
Caused by: com.adobe.livecycle.formsservice.exception.RenderFormException: ALC-FRM-001-013: XMLFormFactory, PAexecute failure: "(com.adobe.document.xmlform.ReturnStatus@369d91fb) XMLForm, render : 12309, XFA template Model is empty."
Caused by: com.adobe.livecycle.formsservice.exception.FormServerException: ALC-FRM-001-013: XMLFormFactory, PAexecute failure: "(com.adobe.document.xmlform.ReturnStatus@369d91fb) XMLForm, render : 12309, XFA template Model is empty."
