This content has been marked as final.
Show 2 replies
1. Re: I have a system that can only print PCL format to a networked printer. Can LiveCycle PDF Generator act as a solution for this?
TundraSteve Sep 15, 2014 7:55 AM (in response to JerAmKlein)Yes a PDF converted with PDF/G can send the result to various email accounts. It sounds like you want to take a file, convert it to PDF and then send that result to a PCL printer is that correct, if so I don't believe LC can provide it? Or are you wanting to merge data with a template and produce PCL, LiveCycle can do this?
2. Re: I have a system that can only print PCL format to a networked printer. Can LiveCycle PDF Generator act as a solution for this?
JerAmKlein Oct 27, 2014 3:55 PM (in response to TundraSteve)I have a main system that I can generate reports in and designate a printer to print to once the report is finished. I want that printer to be a virtual printer that creates a PDF. I then the ability to have that PDF auto e-mailed to some address of my choosing. Can PDF/G do this?
Thank you
