2 Replies Latest reply on Sep 6, 2014 3:32 AM by Peter Spier
    Deactivation and uninstalling InDesign CS3
      I need to uninstall InDesign CS3, but I can't start the application to deactivate it. Some font is misusing. Can I just drag it to the trash? Where do I find the uninstaller for CS3? Thanks in advance, Marie
        • 1. Re: Deactivation and uninstalling InDesign CS3
          No, don't put it into the trash.
          On the Mac, the uninstaller are in the Utilities Folder.
          You can also run the CS3 installer above the installed and corrupted version, to get a repair.
          • 2. Re: Deactivation and uninstalling InDesign CS3
            Did you see Willi's reply? It isn't showing up on the web page.
            Are you trying to move the application to a new computer? You don't really need to uninstall to do that, and uninstalling won't deactivate in any case, but that's not too likely to cause a problem, either. You are allowed two concurrent activations, and the activation counter resets after a period of time, so it's likely you can activate the new install without issue. If you get an activation error you should be able to call the phone, explain the problem, and get a reset at that time.
