4 Replies Latest reply on Apr 12, 2007 9:29 AM by dimival
    Custom object properties
      I want to add a property to my <mx:TextInput on my given project, that property being "errortext"
      this
      <mx:TextInput errorText="You must fill in this field"/> etc.
      How do i go about this?
      I figure i have to extend mx.controls.textInput...how do i do this?
        • 1. Re: Custom object properties
          mikeSibbald
          Like this
          package{
          import mx.controls.TextInput;
          public class ExtTextInput extends TextInput{
          private var _errorText:String;
          [Bindable]
          public function set errorText(value:String):void{
          this._errorText = value;
          public function get errorText():String{
          return this._errorText;
          • 2. Custom object properties
            ok so i've given your idea a shot but i've had no success :< sorry.
            Have i missed anything? It says the code is right but i get errors when i try to put it into my <mx:httpService tag or in <mx:script> httpService.
            This package has been put in a subdirectory of the mxml file and named extHttpService.as under the extClasses directory.
            my mx:script contains import extClasses.*;
            package extClasses
            import mx.rpc.http.mxml.HTTPService;
            public class ExtHttpService extends HTTPService{
            private var _errorString:String;
            [Bindable]
            public function set errorString(value:String):void{
            this._errorString = value;
            public function get errorString():String{
            return this._errorString;
            • 3. Re: Custom object properties
              edit; ok it seems to work fine when i extend mx.controls.label yet it fails when i extend mx.rpc.http.mxml.httpservice
              Have i imported the wrong package for extending?
              • 4. Re: Custom object properties
                dimival Level 1
                I see you are declaring the Bindable metadata on the setter method, i always put the bindable on the getter method. I am not sure if it will make any difference but you can try it out.
                The package you are importing is correct, is the one for the HTTPService mxml tag so i don't think the error is there
