1. Re: Flash CC Publish Setting Window is very small for iOS and normal for Android?
Mohanaraj Sep 8, 2014 2:31 AM (in response to Kirubakaran Srinivasan)Hi,
Can you try increase you Screen Resolution and see if that helps?
Also Flash CC 2014 has been released couple of months back. If you have a valid CC subscription then you are entitled to install the latest version. Recommend you to upgrade to the latest.
You can learn more about the latest release here at http://www.adobe.com/products/flash.html
Thanks!
Mohan
2. Re: Flash CC Publish Setting Window is very small for iOS and normal for Android?
Kirubakaran Srinivasan Sep 8, 2014 2:57 AM (in response to Mohanaraj)Hi Mohanraj,
I didn't work for me. I already tried to change screen resolution (my computer max resolution is 1360x768 and lower than this resolution, it is doing nothing) and i am the lasted and updated Flash CC. Nothing happened...
..Kiru..
3. Re: Flash CC Publish Setting Window is very small for iOS and normal for Android?
Mohanaraj Sep 8, 2014 3:22 AM (in response to Kirubakaran Srinivasan)Hi,
The recommended screen resolution for Flash CC is 1024 x 800. Since your resolution is lower than the recommended one you are facing this issue.
If your Flash CC build number is 13.1.0.226 in Help>About Flash then you are in Flash CC(2013) release. Flash CC 2014 is the latest version and can co-exist with Flash CC(2013) version.
Thanks!
Mohan
