1 Reply Latest reply on Sep 7, 2014 11:51 PM by Laubender
    Frame custom grid problem.
    Joe_Caldwell Level 1
      Hello, everyone.
      I have created a baseline grid for my document but now need to create a different baseline grid for a few threaded frames.
      After a lot of research I found only a few tutorials that are reasonably clear and describe how to create a custom grid using the text frame option panel. However, I can't get it to work right and as easily as the document baseline grid. One of the major problems I am experiencing is the fact that the text appears attached to every other line and not to every line on my text frame.
      What am I doing wrong ? Is there a tutorial that clear shows how this is done ?
      Thank you,
      Joe.
        • 1. Re: Frame custom grid problem.
          @Joe – can you provide some numbers?
          What is the leading of the paragraphs (or paragraph styles) you want to force to the grid?
          What is the distance of one grid line to the next one in your custom baseline grid of the threaded text frames?
          Your problem indicates, that the leading is greater than the distance from one grid line to the other.
          Uwe
